[GRASS-SVN] r47337 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Mon Aug 1 11:23:49 EDT 2011
Author: martinl
Date: 2011-08-01 08:23:49 -0700 (Mon, 01 Aug 2011)
New Revision: 47337
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: launch ATM when creating new vector map (cont'ed)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2011-08-01 15:16:57 UTC (rev 47336)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2011-08-01 15:23:49 UTC (rev 47337)
@@ -2063,8 +2063,8 @@
if not dlg:
return
- if dlg.GetName() and dlg.IsChecked('add'):
- name = dlg.GetName() + '@' + grass.gisenv()['MAPSET']
+ name = dlg.GetName(full = True)
+ if name and dlg.IsChecked('add'):
# add layer to map layer tree
self.parent.curr_page.maptree.AddLayer(ltype = 'vector',
lname = name,
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2011-08-01 15:16:57 UTC (rev 47336)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2011-08-01 15:23:49 UTC (rev 47337)
@@ -275,10 +275,20 @@
self.panel.SetSizer(self.sizer)
self.sizer.Fit(self)
- def GetName(self):
- """!Get name of vector map to be created"""
- return self.GetElement().split('@', 1)[0]
+ def GetName(self, full = False):
+ """!Get name of vector map to be created
+ @param full True to get fully qualified name
+ name = self.GetElement()
+ if full:
+ if '@' in name:
+ return name
+ else:
+ return name + '@' + grass.gisenv()['MAPSET']
+ return name.split('@', 1)[0]
def IsChecked(self, key):
"""!Get dialog properties
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2011-08-01 15:16:57 UTC (rev 47336)
+++ grass/trunk/gui/wxpython/wxgui.py 2011-08-01 15:23:49 UTC (rev 47337)
@@ -647,18 +647,21 @@
def OnNewVector(self, event):
"""!Create new vector map layer"""
- name, add = gdialogs.CreateNewVector(self, log = self.goutput,
- cmd = (('v.edit',
- { 'tool' : 'create' },
- 'map')))
+ dlg = gdialogs.CreateNewVector(self, log = self.goutput,
+ cmd = (('v.edit',
+ { 'tool' : 'create' },
+ 'map')))
- if name and add:
+ if not dlg:
+ return
self.curr_page.maptree.AddLayer(ltype = 'vector',
lname = name,
- lchecked = True,
- lopacity = 1.0,
lcmd = ['d.vect', 'map=%s' % name])
+ dlg.Destroy()
def OnAboutGRASS(self, event):
"""!Display 'About GRASS' dialog"""
