[GRASS-SVN] r47385 - grass/trunk/gui/scripts
Wed Aug 3 12:40:49 EDT 2011
Author: martinl
Date: 2011-08-03 09:40:48 -0700 (Wed, 03 Aug 2011)
New Revision: 47385
Removed:
   grass/trunk/gui/scripts/p.cmd.py
   grass/trunk/gui/scripts/p.db.py
   grass/trunk/gui/scripts/p.mon.py
   grass/trunk/gui/scripts/p.rast.py
   grass/trunk/gui/scripts/p.vect.py
wxGUI: remove p.* scripts, replaced by d.mon
Deleted: grass/trunk/gui/scripts/p.cmd.py
--- grass/trunk/gui/scripts/p.cmd.py	2011-08-03 16:40:43 UTC (rev 47384)
+++ grass/trunk/gui/scripts/p.cmd.py	2011-08-03 16:40:48 UTC (rev 47385)
@@ -1,65 +0,0 @@
-#!/usr/bin/env python
-# MODULE:       p.cmd
-# AUTHOR(S):    Martin Landa, Hamish Bowman
-#               Converted to Python by Huidae Cho
-# PURPOSE:      Wrapper for display commands and pX monitors
-# COPYRIGHT:    (C) 2009 by The GRASS Development Team
-#  This program is free software; you can redistribute it and/or modify
-#  it under the terms of the GNU General Public License as published by
-#  the Free Software Foundation; either version 2 of the License, or
-#  (at your option) any later version.
-#  This program is distributed in the hope that it will be useful,
-#  but WITHOUT ANY WARRANTY; without even the implied warranty of
-#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-#  GNU General Public License for more details.
-#%Module
-#% description: Wrapper for display commands and pX monitors
-#% keywords: display
-#%End
-#%Option
-#% key: cmd
-#% type: string
-#% required: yes
-#% multiple: no
-#% label: Command to be performed
-#% description: Example: "d.rast map=elevation.dem at PERMANENT catlist=1300-1400 -i"
-#%End
-#%Option
-#% key: opacity
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: val
-#% description: Opacity level in percentage
-#% answer: 100
-#%End
-import os
-import grass.script as grass
-def main():
-    cmd_file = grass.gisenv()["GRASS_PYCMDFILE"]
-    if cmd_file == "" or os.path.exists(cmd_file) == False:
-        grass.message(_("GRASS_PYCMDFILE - File not found. Run p.mon."), "e")
-        return
-    cmd = options["cmd"]
-    opacity = options["opacity"]
-    fp = open(cmd_file, "a")
-    fp.write("%s opacity=%s\n" % (cmd, opacity))
-    fp.close()
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
Deleted: grass/trunk/gui/scripts/p.db.py
--- grass/trunk/gui/scripts/p.db.py	2011-08-03 16:40:43 UTC (rev 47384)
+++ grass/trunk/gui/scripts/p.db.py	2011-08-03 16:40:48 UTC (rev 47385)
@@ -1,44 +0,0 @@
-# MODULE:       p.db
-# AUTHOR(S):    Jachym Cepicky, Markus Neteler, Hamish Bowman
-# PURPOSE:      Start stand-alone attribute table manager
-#%Module
-#% description: Start stand-alone attribute table manager
-#% keywords: database
-#%End
-#%Option
-#% key: table
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Table name
-#%End
-import os
-def main():
-    table = options["table"]
-    os.spawnlp(os.P_NOWAIT, os.environ["GRASS_PYTHON"], os.environ["GRASS_PYTHON"], "%s/etc/wxpython/gui_modules/dbm.py" % os.environ["GISBASE"], table)
-    main()
Deleted: grass/trunk/gui/scripts/p.mon.py
--- grass/trunk/gui/scripts/p.mon.py	2011-08-03 16:40:43 UTC (rev 47384)
+++ grass/trunk/gui/scripts/p.mon.py	2011-08-03 16:40:48 UTC (rev 47385)
@@ -1,107 +0,0 @@
-# MODULE:       p.mon
-# AUTHOR(S):    Jachym Cepicky, Michael Barton, Martin Landa, Markus Neteler,
-#               Hamish Bowman
-# PURPOSE:      To establish and control use of a graphics display monitor.
-#%Module
-#% description: To establish and control use of a graphics display monitor.
-#%End
-##%Flag
-##% key: l
-##% description: List all monitors
-##%End
-##%Flag
-##% key: L
-##% description: List all monitors (with current status)
-##%End
-##%Flag
-##% key: p
-##% description: Print name of currently selected monitor
-##%End
-##%Flag
-##% key: r
-##% description: Release currently selected monitor
-##%End
-##%Flag
-##% key: s
-##% description: Do not automatically select when starting
-##%End
-#%Option
-#% key: start
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Name of graphics monitor to start (p0-p9)
-#%End
-##%Option
-##% key: stop
-##% type: string
-##% required: no
-##% multiple: no
-##% description: Name of graphics monitor to stop
-##%End
-##%Option
-##% key: select
-##% type: string
-##% required: no
-##% multiple: no
-##% description: Name of graphics monitor to select
-##%End
-##%Option
-##% key: unlock
-##% type: string
-##% required: no
-##% multiple: no
-##% description: Name of graphics monitor to unlock
-##%End
-import os
-def main():
-    start = options["start"]
-#    select = options["select"]
-#    stop = options["stop"]
-#    unlock = options["unlock"]
-    # create the command file
-    command_file = grass.tempfile()
-    os.system("g.gisenv set=GRASS_PYCMDFILE=%s" % command_file)
-    if start != "":
-        os.spawnlp(os.P_NOWAIT, os.environ["GRASS_PYTHON"], os.environ["GRASS_PYTHON"], "%s/etc/gui/wxpython/gui_modules/mapdisp.py" % os.environ["GISBASE"], start, command_file)
-        return
-#    if stop != "" or select != "" or unlock != "":
-#        grass.message(_("Not implemented yet"), "w")
-    main()
Deleted: grass/trunk/gui/scripts/p.rast.py
--- grass/trunk/gui/scripts/p.rast.py	2011-08-03 16:40:43 UTC (rev 47384)
+++ grass/trunk/gui/scripts/p.rast.py	2011-08-03 16:40:48 UTC (rev 47385)
@@ -1,110 +0,0 @@
-# MODULE:       p.rast
-# AUTHOR(S):    Jachym Cepicky, Martin Landa, Hamish Bowman
-# PURPOSE:      Displays raster map layer in the active map display window.
-#%module
-#% description: Displays raster map layer in the active map display window.
-#% keywords: display, raster
-#%end
-#%flag
-#% key: n
-#% description: Make null cells opaque
-#%end
-#%flag
-#% key: i
-#% description: Invert catlist
-#% guisection: Selection
-#%end
-#%option
-#% key: map
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Raster map to be displayed
-#% gisprompt: old,cell,raster
-#%end
-#%option
-#% key: catlist
-#% type: string
-#% required: no
-#% multiple: yes
-#% key_desc: cat[-cat]
-#% description: List of categories to be displayed (INT maps)
-#%end
-#%option
-#% key: vallist
-#% type: string
-#% required: no
-#% multiple: yes
-#% key_desc: val[-val]
-#% description: List of values to be displayed (FP maps)
-#%end
-#%option
-#% key: bg
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: color
-#% description: Background color (for null)
-#% gisprompt: old_color,color,color
-#%end
-#%option
-#% key: opacity
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: val
-#% answer: 100
-#% description: Set opacity between 0-100%
-#%end
-import sys
-import os
-def construct_command(cmd):
-    line = cmd
-    for key, val in options.iteritems():
-        if val != "":
-            line += " %s=%s" % (key, val)
-    for key, val in flags.iteritems():
-        if val == True:
-            line += " -%s" % key
-    return line
-def main():
-        return
-    cmd = construct_command("d"+os.path.basename(sys.argv[0])[1:-3])
-    fp.write("%s\n" % cmd)
-    fp.close()
-    main()
Deleted: grass/trunk/gui/scripts/p.vect.py
--- grass/trunk/gui/scripts/p.vect.py	2011-08-03 16:40:43 UTC (rev 47384)
+++ grass/trunk/gui/scripts/p.vect.py	2011-08-03 16:40:48 UTC (rev 47385)
@@ -1,367 +0,0 @@
-# MODULE:       p.vect
-# AUTHOR(S):    Jachym Cepicky, Hamish Bowman
-# PURPOSE:      Displays vector map layer in the active map display window.
-#%module
-#% description: Displays vector map layer in the active map display window.
-#% keywords: display, vector
-#%end
-#%flag
-#% key: a
-#% description: Get colors from map table column (of form RRR:GGG:BBB)
-#% guisection: Colors
-#%end
-#%flag
-#% key: c
-#% description: Random colors according to category number (or layer number if 'layer=-1' is given)
-#%end
-#%flag
-#% key: i
-#% description: Use values from 'cats' option as feature id
-#%end
-#%flag
-#% key: z
-#% description: Colorize polygons according to z height
-#%end
-#%option
-#% key: map
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name of input vector map
-#% gisprompt: old,vector,vector
-#%end
-#%option
-#% key: display
-#% type: string
-#% required: no
-#% multiple: yes
-#% options: shape,cat,topo,dir,attr,zcoor
-#% answer: shape
-#%end
-#%option
-#% key: type
-#% type: string
-#% required: no
-#% multiple: yes
-#% options: point,line,boundary,centroid,area,face
-#% description: Feature type
-#% answer: point,line,boundary,centroid,area,face
-#%end
-#%option
-#% key: layer
-#% type: string
-#% required: no
-#% multiple: no
-#% label: Layer number (if -1, all layers are displayed)
-#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
-#% answer: 1
-#% gisprompt: old_layer,layer,layer_all
-#%end
-#%option
-#% key: cats
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: range
-#% label: Category values
-#% description: Example: 1,3,7-9,13
-#%end
-#%option
-#% key: where
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: sql_query
-#% label: WHERE conditions of SQL statement without 'where' keyword
-#% description: Example: income < 1000 and inhab >= 10000
-#%end
-#%option
-#% key: color
-#% type: string
-#% required: no
-#% multiple: no
-#% label: Line color
-#% description: Either a standard GRASS color, R:G:B triplet, or "none"
-#% answer: black
-#% gisprompt: old_color,color,color_none
-#%end
-#%option
-#% key: fcolor
-#% type: string
-#% required: no
-#% multiple: no
-#% label: Area fill color
-#% answer: 200:200:200
-#%end
-#%option
-#% key: rgb_column
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: name
-#% description: Name of color definition column (for use with -a flag)
-#% answer: GRASSRGB
-#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
-#%end
-#%option
-#% key: zcolor
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: style
-#% description: Type of color table (for use with -z flag)
-#% answer: terrain
-#%end
-#%option
-#% key: width
-#% type: integer
-#% required: no
-#% multiple: no
-#% description: Line width
-#% answer: 0
-#% guisection: Lines
-#%end
-#%option
-#% key: wcolumn
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: name
-#% description: Name of column for line widths (these values will be scaled by wscale)
-#%end
-#%option
-#% key: wscale
-#% type: double
-#% required: no
-#% multiple: no
-#% description: Scale factor for wcolumn
-#% answer: 1
-#%end
-#%option
-#% key: icon
-#% type: string
-#% required: no
-#% multiple: no
-#% options: basic/marker,basic/circle,basic/arrow1,basic/star,basic/point,basic/triangle,basic/box,basic/arrow2,basic/octagon,basic/cross2,basic/pushpin,basic/diamond,basic/cross1,basic/x,demo/smrk,demo/muchomurka,extra/dive_flag,extra/half-box,extra/bridge,extra/fiducial,extra/ping,extra/offbox_ne,extra/adcp,extra/alpha_flag,extra/4pt_star,extra/half-circle,extra/offbox_nw,extra/fancy_compass,extra/airport,extra/compass,extra/offbox_se,extra/fish,extra/target,extra/offbox_sw,extra/n_arrow1,extra/pentagon,extra/n_arrow2,geology/strike_circle,geology/strike_box,geology/strike_line,geology/strike_triangle
-#% description: Point and centroid symbol
-#% answer: basic/x
-#% guisection: Symbols
-#%end
-#%option
-#% key: size
-#% type: integer
-#% required: no
-#% multiple: no
-#% description: Symbol size
-#% answer: 5
-#%end
-#%option
-#% key: size_column
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: name
-#% description: Name of numeric column containing symbol size
-#%end
-#%option
-#% key: rot_column
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: name
-#% label: Name of numeric column containing symbol rotation angle
-#% description: Measured in degrees CCW from east
-#%end
-#%option
-#% key: llayer
-#% type: string
-#% required: no
-#% multiple: no
-#% label: Layer number or name
-#% description: Layer number for labels (default: the given layer number)
-#% answer: 1
-#% guisection: Labels
-#%end
-#%option
-#% key: attrcol
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: name
-#% description: Name of column to be displayed
-#%end
-#%option
-#% key: lcolor
-#% type: string
-#% required: no
-#% multiple: no
-#% label: Label color
-#% description: Either a standard color name or R:G:B triplet
-#% answer: red
-#%end
-#%option
-#% key: bgcolor
-#% type: string
-#% required: no
-#% multiple: no
-#% label: Label background color
-#% answer: none
-#%end
-#%option
-#% key: bcolor
-#% type: string
-#% required: no
-#% multiple: no
-#% label: Label border color
-#% answer: none
-#%end
-#%option
-#% key: lsize
-#% type: integer
-#% required: no
-#% multiple: no
-#% description: Label size (pixels)
-#% answer: 8
-#%end
-#%option
-#% key: font
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Font name
-#%end
-#%option
-#% key: encoding
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Text encoding
-#%end
-#%option
-#% key: xref
-#% type: string
-#% required: no
-#% multiple: no
-#% options: left,center,right
-#% description: Label horizontal justification
-#% answer: left
-#%end
-#%option
-#% key: yref
-#% type: string
-#% required: no
-#% multiple: no
-#% options: top,center,bottom
-#% description: Label vertical justification
-#% answer: center
-#%end
-#%option
-#% key: minreg
-#% type: double
-#% required: no
-#% multiple: no
-#% description: Minimum region size (average from height and width) when map is displayed
-#%end
-#%option
-#% key: maxreg
-#% type: double
-#% required: no
-#% multiple: no
-#% description: Maximum region size (average from height and width) when map is displayed
-#%end
-#%option
-#% key: opacity
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: val
-#% answer: 100
-#%end
-import sys
-import os
-    line = cmd
-        if val != "":
-        if val == True:
-    return line
-def main():
-        return
-    fp.close()
-    main()
