[GRASS-SVN] r47386 - in grass/trunk/gui/wxpython: . gui_modules
icons
svn_grass at osgeo.org
Wed Aug 3 12:50:21 EDT 2011
Author: martinl
Date: 2011-08-03 09:50:21 -0700 (Wed, 03 Aug 2011)
New Revision: 47386
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/ghelp.py
grass/trunk/gui/wxpython/gui_modules/globalvar.py
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/psmap.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
grass/trunk/gui/wxpython/icons/grass_icons.py
grass/trunk/gui/wxpython/icons/icon.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: clean up - gettext and __main__
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -35,10 +35,6 @@
import copy
import types
-### i18N
-import gettext
-gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
import globalvar
import wx
import wx.lib.mixins.listctrl as listmix
@@ -3049,30 +3045,28 @@
event.Skip()
-def main(argv=None):
+def main(argv = None):
+ import gettext
+ gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
if argv is None:
argv = sys.argv
if len(argv) != 2:
print >> sys.stderr, __doc__
sys.exit()
- # Command line arguments of the script to be run are preserved by the
- # hotswap.py wrapper but hotswap.py and its options are removed that
- # sys.argv looks as if no wrapper was present.
- #print "argv:", `argv`
#some applications might require image handlers
wx.InitAllImageHandlers()
app = wx.PySimpleApp()
f = AttributeManager(parent=None, id=wx.ID_ANY,
title="%s - <%s>" % (_("GRASS GIS Attribute Table Manager"),
argv[1]),
size=(900,600), vectorName=argv[1])
f.Show()
app.MainLoop()
if __name__ == '__main__':
main()
Modified: grass/trunk/gui/wxpython/gui_modules/ghelp.py
--- grass/trunk/gui/wxpython/gui_modules/ghelp.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/gui_modules/ghelp.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -23,6 +23,7 @@
import os
+import codecs
import wx
try:
@@ -667,7 +668,7 @@
"""Contributors info"""
contribfile = os.path.join(os.getenv("GISBASE"), "contributors.csv")
if os.path.exists(contribfile):
- contribFile = open(contribfile, 'r')
+ contribFile = codecs.open(contribfile, encoding = 'utf-8', mode = 'r')
contribs = dict()
errLines = list()
for line in contribFile.readlines():
Modified: grass/trunk/gui/wxpython/gui_modules/globalvar.py
--- grass/trunk/gui/wxpython/gui_modules/globalvar.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/gui_modules/globalvar.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -20,9 +20,6 @@
if not os.getenv("GISBASE"):
sys.exit("GRASS is not running. Exiting...")
-### i18N
-import gettext
# path to python scripts
ETCDIR = os.path.join(os.getenv("GISBASE"), "etc")
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -4546,6 +4546,9 @@
def main():
+ import gettext
+ gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
frame = ModelFrame(parent = None)
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -2668,11 +2668,3 @@
self.transnum = self.translist.GetSelection()
self.transnum = self.transnum - 1
return self.transnum
-if __name__ == "__main__":
- import gettext
- gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
- app = wx.PySimpleApp()
- gWizard = RegionDef(None)
- gWizzard.Show()
- app.MainLoop()
Modified: grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py
--- grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -578,8 +578,10 @@
menuform.GUI(parent = self).ParseCommand(cmd = [self.cmd, 'expression=' + expr])
+ import gettext
app = wx.App(0)
frame = MapCalcFrame(parent = None, cmd = 'r.mapcalc')
frame.Show()
app.MainLoop()
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -57,10 +57,6 @@
import Queue
import tempfile
-### i18N
-import gettext
-gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
import globalvar
import wx
import wx.html
@@ -2083,9 +2079,12 @@
return self.GetPageIndex(self.notebookPages[page])
+ import gettext
if len(sys.argv) == 1:
sys.exit(_("usage: %s <grass command>") % sys.argv[0])
if sys.argv[1] != 'test':
q = wx.LogNull()
cmd = utils.split(sys.argv[1])
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -37,10 +37,6 @@
except ImportError:
havePwd = False
-### i18N
-import gettext
import wx
import wx.lib.filebrowsebutton as filebrowse
import wx.lib.colourselect as csel
Modified: grass/trunk/gui/wxpython/gui_modules/psmap.py
--- grass/trunk/gui/wxpython/gui_modules/psmap.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/gui_modules/psmap.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -1647,6 +1647,9 @@
rect.GetSize()[0]*scale, rect.GetSize()[1]*scale)
def main():
+ import gettext
frame = PsMapFrame()
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -1328,30 +1328,22 @@
layer.Render()
- """!Test of Display class.
- Usage: display=Render()
import gettext
- print "Initializing..."
- grass.run_command("g.region", flags = "d")
+ Map = Map()
+ Map.GetRegion(update = True)
- map = Map()
- map.width = 640
- map.height = 480
- map.AddLayer(type = "raster",
- name = "elevation.dem",
- command = ["d.rast", "elevation.dem at PERMANENT", "catlist=1000-1500", "-i"],
+ Map.AddLayer(type = "raster",
+ name = "elevation",
+ command = ["d.rast", "map=elevation at PERMANENT"],
l_opacity = .7)
- map.AddLayer(type = "vector",
- name = "streams",
- command = ["d.vect", "streams at PERMANENT", "color=red", "width=3", "type=line"])
+ Map.AddLayer(type = "vector",
+ name = "roadsmajor",
+ command = ["d.vect", "map=roadsmajor at PERMANENT", "color=red", "width=3", "type=line"])
- image = map.Render(force = True)
+ image = Map.Render(force = True)
if image:
- os.system("display %s" % image)
+ grass.call(["display", image])
Modified: grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
--- grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -13,7 +13,7 @@
python sqlbuilder.py vector_map
@endcode
-(C) 2007-2009 by the GRASS Development Team
+(C) 2007-2009, 2011 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -28,10 +28,6 @@
import sys
import time
-### i18N
-import gettext
import globalvar
import wx
@@ -58,7 +54,7 @@
self.vectmap = vectmap # fullname
if not "@" in self.vectmap:
- self.vectmap = self.vectmap + "@" + grass.gisenv()['MAPSET']
+ self.vectmap = grass.find_file(self.vectmap, element = 'vector')['fullname']
self.mapname, self.mapset = self.vectmap.split("@")
# db info
@@ -446,6 +442,9 @@
print >>sys.stderr, __doc__
sys.exit()
+ import gettext
app = wx.App(0)
sqlb = SQLFrame(parent = None, title = _('SQL Builder'), vectmap = sys.argv[1])
sqlb.Show()
Modified: grass/trunk/gui/wxpython/icons/grass_icons.py
--- grass/trunk/gui/wxpython/icons/grass_icons.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/icons/grass_icons.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -7,7 +7,7 @@
import os
-from gui_modules import globalvar
+import globalvar
iconPath = os.path.join(globalvar.ETCDIR, "gui", "icons", "grass")
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/icons/icon.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -22,11 +22,11 @@
import os
import sys
-sys.path.append(os.path.join(os.getenv("GISBASE"), "etc", "wxpython", "gui_modules"))
+sys.path.append(os.path.join(os.getenv("GISBASE"), "etc", "gui", "wxpython", "gui_modules"))
import wx
-from gui_modules.preferences import globalSettings as UserSettings
+from preferences import globalSettings as UserSettings
# default icon set
import grass_icons
@@ -445,4 +445,5 @@
# testing ...
for k, v in Icons.iteritems():
- print v.GetImageName()
+ for kk, vv in v.iteritems():
+ print k, kk, vv.GetImageName()
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2011-08-03 16:40:48 UTC (rev 47385)
+++ grass/trunk/gui/wxpython/wxgui.py 2011-08-03 16:50:21 UTC (rev 47386)
@@ -28,17 +28,11 @@
import platform
import signal
import tempfile
-### XML
try:
import xml.etree.ElementTree as etree
except ImportError:
import elementtree.ElementTree as etree # Python <= 2.4
-### i18N
-import gettext
import wx
import wx.aui
@@ -1715,9 +1709,9 @@
return (workspaceFile,)
- # process command-line arguments
+ import gettext
if argv is None:
argv = sys.argv
try:
@@ -1726,19 +1720,18 @@
["help", "workspace"])
except getopt.error, msg:
raise Usage(msg)
except Usage, err:
print >> sys.stderr, err.msg
print >> sys.stderr, "for help use --help"
printHelp()
workspaceFile = process_opt(opts, args)[0]
- # run application
app = GMApp(workspaceFile)
# suppress wxPython logs
q = wx.LogNull()
app.MainLoop()
