[GRASS-SVN] r47460 - in grass/trunk: include lib/gis
svn_grass at osgeo.org
Fri Aug 5 09:06:57 EDT 2011
Author: martinl
Date: 2011-08-05 06:06:57 -0700 (Fri, 05 Aug 2011)
New Revision: 47460
grass/trunk/include/gisdefs.h
grass/trunk/lib/gis/gislib.dox
grass/trunk/lib/gis/strings.c
gislib: add G_strcasestr()
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2011-08-05 12:53:34 UTC (rev 47459)
+++ grass/trunk/include/gisdefs.h 2011-08-05 13:06:57 UTC (rev 47460)
@@ -586,6 +586,7 @@
void G_str_to_lower(char *);
int G_str_to_sql(char *);
void G_squeeze(char *);
+char *G_strcasestr(const char *, const char *);
/* tempfile.c */
void G_init_tempfile(void);
Modified: grass/trunk/lib/gis/gislib.dox
--- grass/trunk/lib/gis/gislib.dox 2011-08-05 12:53:34 UTC (rev 47459)
+++ grass/trunk/lib/gis/gislib.dox 2011-08-05 13:06:57 UTC (rev 47460)
@@ -1978,7 +1978,7 @@
String compare ignoring case (upper or lower).
- - G_strstr()
+ - G_strcasestr()
Return a pointer to the first occurrence of subString in mainString,
or NULL if no occurrences are found.
Modified: grass/trunk/lib/gis/strings.c
--- grass/trunk/lib/gis/strings.c 2011-08-05 12:53:34 UTC (rev 47459)
+++ grass/trunk/lib/gis/strings.c 2011-08-05 13:06:57 UTC (rev 47460)
@@ -367,6 +367,41 @@
*(line + l) = '\0';
+ \brief Finds the first occurrence of the sub-string in the
+ null-terminated string ignoring case (upper or lower)
+ \param str string where to find sub-string
+ \param substr sub-string
+ \return a pointer to the first occurrence of sub-string
+ \return NULL if no occurrences are found
+char *G_strcasestr(const char *str, const char *substr)
+ const char *p;
+ const char *q;
+ int length;
+ p = substr;
+ q = str;
+ length = strlen(substr);
+ do {
+ /* match 1st substr char */
+ while (*q != '\0' && toupper(*q) != toupper(*p)) {
+ q++;
+ } while (*q != '\0' && G_strncasecmp(p, q, length) != 0 && q++);
+ if (*q == '\0') {
+ /* ran off end of str */
+ return NULL;
+ return (char *) q;
int _strncasecmp(const char *x, const char *y, int n)
int xx, yy, i;
