[GRASS-SVN] r47461 - grass/trunk/db/drivers/ogr
svn_grass at osgeo.org
Fri Aug 5 09:08:51 EDT 2011
Author: martinl
Date: 2011-08-05 06:08:51 -0700 (Fri, 05 Aug 2011)
New Revision: 47461
grass/trunk/db/drivers/ogr/execute.c
DBMI-OGR: fix db__driver_execute() - call also OGR_DS_ExecuteSQL for RDBMS
Modified: grass/trunk/db/drivers/ogr/execute.c
--- grass/trunk/db/drivers/ogr/execute.c 2011-08-05 13:06:57 UTC (rev 47460)
+++ grass/trunk/db/drivers/ogr/execute.c 2011-08-05 13:08:51 UTC (rev 47461)
@@ -17,6 +17,7 @@
#include <grass/glocale.h>
#include <ogr_api.h>
+#include <cpl_error.h>
#include "globals.h"
#include "proto.h"
@@ -38,20 +39,23 @@
init_error();
+ G_debug(3, "\tSQL: '%s'", db_get_string(sql));
/* parse UPDATE statement */
- G_debug(3, "\tSQL: '%s'", db_get_string(sql));
res = parse_sql_update(db_get_string(sql), &table, &cols, &ncols, &where);
- G_debug(3, "\t table=%s, where=%s, ncols=%d", table, where ? where : "", ncols);
+ G_debug(3, "\tUPDATE: table=%s, where=%s, ncols=%d", table, where ? where : "", ncols);
if (res != 0) {
- append_error(_("Unable to parse '%s'\n"), db_get_string(sql));
- append_error(_("DBMI-OGR driver only supports UPDATE statements"));
- report_error();
- return DB_FAILED;
+ /* try RDBMS SQL */
+ hLayer = OGR_DS_ExecuteSQL(hDs, db_get_string(sql), NULL, NULL);
+ if (CPLGetLastErrorType() != CE_None)
+ return DB_FAILED;
+ return DB_OK;
/* get OGR layer */
hLayer = OGR_DS_GetLayerByName(hDs, table);
- if (hLayer) {
+ if (!hLayer) {
append_error(_("OGR layer <%s> not found"), table);
report_error();
return DB_FAILED;
@@ -74,7 +78,7 @@
hFieldDefn = OGR_FD_GetFieldDefn(hFeatureDefn, cols[i].index);
cols[i].type = OGR_Fld_GetType(hFieldDefn);
- G_debug(3, "\t\tcol=%s, val=%s idx=%d, type=%d, qidx=%d",
+ G_debug(3, "\t\tcol=%s, val=%s, idx=%d, type=%d, qidx=%d",
cols[i].name, cols[i].value, cols[i].index, cols[i].type,
cols[i].qindex);
@@ -126,10 +130,10 @@
char *prefix;
char *p, *w, *c, *t;
char **token, **itoken;
prefix = "UPDATE";
nprefix = strlen(prefix);
- if (strncasecmp(sql, prefix, nprefix) != 0)
+ if (G_strncasecmp(sql, prefix, nprefix) != 0)
return 1;
p = (char *) sql + nprefix; /* skip 'UPDATE' */
@@ -150,7 +154,7 @@
return 1;
p++;
- if (strncasecmp(p, "SET", 3) != 0)
+ if (G_strncasecmp(p, "SET", 3) != 0)
return 1;
p += 3; /* skip 'SET' */
@@ -159,7 +163,8 @@
return 1;
p++;
- w = strstr(p, "WHERE");
+ w = G_strcasestr(p, "WHERE");
if (!w) {
has_where = FALSE;
w = (char *)sql + strlen(sql);
@@ -173,7 +178,8 @@
c = G_malloc(n + 1);
strncpy(c, p, n);
c[n] = '\0';
+ G_debug(0, "%s", w);
token = G_tokenize(c, ",");
*ncols = G_number_of_tokens(token);
*cols = (column_info *)G_malloc(sizeof(column_info) * (*ncols));
@@ -191,7 +197,7 @@
G_free_tokens(token);
G_free(c);
if (!has_where) {
*where = NULL;
return 0;
@@ -202,9 +208,9 @@
if (*w != ' ')
return 1;
w++;
G_strip(w);
*where = G_store(w);
return 0;
