[GRASS-SVN] r47557 - grass/trunk/lib/init
svn_grass at osgeo.org
Thu Aug 11 16:21:19 EDT 2011
Author: lucadelu
Date: 2011-08-11 13:21:18 -0700 (Thu, 11 Aug 2011)
New Revision: 47557
grass/trunk/lib/init/grass.py
add --config option in the startup script; it is usefull to return some paramaters of GRASS installation
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2011-08-11 20:14:07 UTC (rev 47556)
+++ grass/trunk/lib/init/grass.py 2011-08-11 20:21:18 UTC (rev 47557)
@@ -10,6 +10,7 @@
# Hamish Bowman <hamish_b yahoo,com>
# Converted to Python (based on init.sh) by Glynn Clements
# Martin Landa <landa.martin gmail.com>
+# Luca Delucchi <lucadeluge at gmail.com>
# PURPOSE: Sets up environment variables, parses any remaining
# command line options for setting the GISDBASE, LOCATION,
# and/or MAPSET. Finally it starts GRASS with the appropriate user
@@ -143,6 +144,8 @@
%s
-gui %s
%s
+ --config %s
+ %s
%s:
GISDBASE %s
@@ -167,6 +170,8 @@
_("and set as default"),
_("use $DEFAULT_GUI graphical user interface"),
+ _("print GRASS configuration parameters"),
+ _("options: arch,build,compiler,path"),
_("Parameters"),
_("initial database (path to GIS data)"),
_("initial location"),
@@ -849,6 +854,32 @@
nul = open(os.devnull, 'w')
call([gfile("etc", "clean_temp")], stdout = nul, stderr = nul)
nul.close()
+def grep(string,list):
+ expr = re.compile(string)
+ return [elem for elem in list if expr.match(elem)]
+def print_params():
+ plat = os.path.join(gisbase,'include','Make','Platform.make')
+ fileplat = open(plat)
+ linesplat = fileplat.readlines()
+ fileplat.close()
+ for i in sys.argv[2:]:
+ if i == 'path':
+ print gisbase
+ elif i == 'arch':
+ val = grep('ARCH',linesplat)
+ print val[0].split('=')[1].strip()
+ elif i == 'build':
+ build = os.path.join(gisbase,'include','grass','confparms.h')
+ filebuild = open(build)
+ val = filebuild.readline()
+ print val.strip().strip('"').strip()
+ elif i == 'compiler':
+ val = grep('CC',linesplat)
+ else:
+ print "Parameter not supported"
def get_username():
global user
@@ -895,6 +926,9 @@
# Check if the user wants to create a new mapset
elif i == "-c":
create_new = True
+ elif i == "--config":
+ print_params()
+ sys.exit()
else:
args.append(i)
