[GRASS-SVN] r47558 -
grass-addons/grass7/gui/wxpython/wx.stream/gui_modules
svn_grass at osgeo.org
Thu Aug 11 16:24:49 EDT 2011
Author: madi
Date: 2011-08-11 13:24:49 -0700 (Thu, 11 Aug 2011)
New Revision: 47558
grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py
grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
Added new map display
Modified: grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py
--- grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py 2011-08-11 20:21:18 UTC (rev 47557)
+++ grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py 2011-08-11 20:24:49 UTC (rev 47558)
@@ -67,7 +67,7 @@
class RStreamFrame(wx.Frame):
- def __init__(self, parent = None, id = wx.ID_ANY, style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
+ def __init__(self, parent, id = wx.ID_ANY, style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
title = _("GRASS GIS Hydrological Modelling Utility"), **kwargs):
"""!Main window of r.stream's GUI
@@ -109,7 +109,7 @@
self.SetSizer(self.sizer)
- self.mapdisp = self.parent.curr_page.maptree.mapdisplay
+ #self.mapdisp = self.parent.curr_page.maptree.mapdisplay
def OnClose(self, event):
self.Destroy()
Modified: grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
--- grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py 2011-08-11 20:21:18 UTC (rev 47557)
+++ grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py 2011-08-11 20:24:49 UTC (rev 47558)
@@ -9,7 +9,8 @@
See http://grass.osgeo.org/wiki/Wx.stream_GSoC_2011
Classes:
- - RStreamFrame
+ - SPD
+ - TabPanelOne
(C) 2011 by Margherita Di Leo, and the GRASS Development Team
This program is free software under the GNU General Public License
@@ -24,7 +25,6 @@
sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython', 'gui_modules'))
import wx
-#import wx.aui
import wx.lib.flatnotebook as FN
from debug import Debug as Debug
@@ -39,11 +39,65 @@
import menuform
import mapdisp_window
+from wxgui import GMFrame # for SPD class
+from render import MapLayer
-# First panel # Network extraction
+# SPD = Select Point Display
+class SPD(GMFrame, wx.Frame):
+ """!Secondary Map Display that allows user to select the point which is the centre of preview region
+ def __init__(self, parent, grwiz = None, id = wx.ID_ANY,
+ title = _("Select the centre of Preview region"),
+ size = (700, 300), Map = None, lmgr = None):
+ GMFrame.__init__(self, parent, id = wx.ID_ANY, title = "SPDMapWindow",
+ workspace = None,
+ size = globalvar.GM_WINDOW_SIZE, style = wx.DEFAULT_FRAME_STYLE)
+ # init variables
+ self.parent = parent # TabPanelOne
+class SPDCanvas(MapLayer):
+ def __init__(self, type, cmd, name = None,
+ active = True, hidden = False, opacity = 1.0):
+ """!Represents map layer in the map canvas
+ @param type layer type ('raster', 'vector', 'command', etc.)
+ @param cmd GRASS command to render layer,
+ given as list, e.g. ['d.rast', 'map=elevation at PERMANENT']
+ @param name layer name, e.g. 'elevation at PERMANENT' (for layer tree) or None
+ @param active layer is active, will be rendered only if True
+ @param hidden layer is hidden, won't be listed in Layer Manager if True
+ @param opacity layer opacity <0;1>
+ MapLayer.__init__(self, type, cmd, name,
+ active, hidden, opacity)
+ def GetMapset(self):
+ """!Get mapset of map layer
+ @return mapset name
+ @return '' on error (no name given)
+ if not self.name:
+ return ''
+ try:
+ return self.name.split('@')[1]
+ except IndexError:
+ return self.name
class TabPanelOne(wx.Panel):
+ """!First panel for Network extraction
def __init__(self, parent):
wx.Panel.__init__(self, parent, id = wx.ID_ANY)
@@ -55,17 +109,13 @@
self.r_stre = 'r_stre'
self.v_net = 'v_net'
self.r_drain = 'r_drain'
- #self.mapdisp =
- # define the panel for select maps
- self.panel = wx.Panel(self)
- # create the layout
+ self.panel = wx.Panel(self)
self._layout()
def _layout(self):
- # create the grid for gselect
self.select = wx.GridBagSizer(20, 5)
@@ -306,6 +356,8 @@
#-------------Preview funct-------------
def OnPreview(self, event):
+ """!Allows to watch a preview of the analysis on a small region
pass
info_region = grass.read_command('g.region', flags = 'p')
@@ -317,8 +369,11 @@
print "OK"
# get current Map Display
- self.mapdisp.Raise()
+ self.mapdisp = SPD(parent = self)
+ self.spddisp = SPDCanvas(type = 'command', cmd = ['d.rast', 'map = self.r_elev']) # FIXME
# Get position by panel on mouse click
@@ -333,6 +388,8 @@
#-------------Network extraction-------------
def OnRun(self, event):
+ """!Calculates flow accumulation if it is missing, and runs stream extraction
radioval1 = self.cb1.GetValue()
radioval2 = self.cb2.GetValue()
