[GRASS-SVN] r47593 - in grass/trunk: general/g.region include
lib/gpde lib/gpde/test lib/ogsf lib/raster3d
lib/raster3d/test raster/r.colors raster/r.colors.out
raster/r.mapcalc raster/r.to.rast3 raster/r.to.rast3elev
raster/r.univar raster3d/r3.cross.rast raster3d/r3.gwflow
raster3d/r3.in.ascii raster3d/r3.in.v5d raster3d/r3.info
raster3d/r3.mask raster3d/r3.mkdspf raster3d/r3.null
raster3d/r3.out.ascii raster3d/r3.out.v5d raster3d/r3.out.vtk
raster3d/r3.retile raster3d/r3.showdspf raster3d/r3.stats
raster3d/r3.to.rast vector/v.colors vector/v.to.rast3
vector/v.vol.rst
svn_grass at osgeo.org
Fri Aug 12 04:32:31 EDT 2011
Author: martinl
Date: 2011-08-12 01:32:30 -0700 (Fri, 12 Aug 2011)
New Revision: 47593
grass/trunk/general/g.region/main.c
grass/trunk/include/raster3ddefs.h
grass/trunk/lib/gpde/N_arrays.c
grass/trunk/lib/gpde/N_arrays_calc.c
grass/trunk/lib/gpde/N_arrays_io.c
grass/trunk/lib/gpde/N_geom.c
grass/trunk/lib/gpde/test/test_arrays.c
grass/trunk/lib/gpde/test/test_geom.c
grass/trunk/lib/ogsf/GVL2.c
grass/trunk/lib/ogsf/Gvl3.c
grass/trunk/lib/ogsf/gvl_file.c
grass/trunk/lib/raster3d/cache.c
grass/trunk/lib/raster3d/cache1.c
grass/trunk/lib/raster3d/cachehash.c
grass/trunk/lib/raster3d/cats.c
grass/trunk/lib/raster3d/changeprecision.c
grass/trunk/lib/raster3d/changetype.c
grass/trunk/lib/raster3d/close.c
grass/trunk/lib/raster3d/color.c
grass/trunk/lib/raster3d/defaults.c
grass/trunk/lib/raster3d/doubleio.c
grass/trunk/lib/raster3d/error.c
grass/trunk/lib/raster3d/filecompare.c
grass/trunk/lib/raster3d/fpcompress.c
grass/trunk/lib/raster3d/fpxdr.c
grass/trunk/lib/raster3d/getblock.c
grass/trunk/lib/raster3d/getvalue.c
grass/trunk/lib/raster3d/header.c
grass/trunk/lib/raster3d/headerinfo.c
grass/trunk/lib/raster3d/history.c
grass/trunk/lib/raster3d/index.c
grass/trunk/lib/raster3d/intio.c
grass/trunk/lib/raster3d/keys.c
grass/trunk/lib/raster3d/long.c
grass/trunk/lib/raster3d/mapset.c
grass/trunk/lib/raster3d/mask.c
grass/trunk/lib/raster3d/misc.c
grass/trunk/lib/raster3d/null.c
grass/trunk/lib/raster3d/open.c
grass/trunk/lib/raster3d/open2.c
grass/trunk/lib/raster3d/param.c
grass/trunk/lib/raster3d/putvalue.c
grass/trunk/lib/raster3d/range.c
grass/trunk/lib/raster3d/raster3d_intern.h
grass/trunk/lib/raster3d/region.c
grass/trunk/lib/raster3d/resample.c
grass/trunk/lib/raster3d/retile.c
grass/trunk/lib/raster3d/rle.c
grass/trunk/lib/raster3d/test/test_coordinate_transform.c
grass/trunk/lib/raster3d/test/test_main.c
grass/trunk/lib/raster3d/test/test_put_get_value.c
grass/trunk/lib/raster3d/tilealloc.c
grass/trunk/lib/raster3d/tileio.c
grass/trunk/lib/raster3d/tilemath.c
grass/trunk/lib/raster3d/tilenull.c
grass/trunk/lib/raster3d/tileread.c
grass/trunk/lib/raster3d/tilewrite.c
grass/trunk/lib/raster3d/volume.c
grass/trunk/lib/raster3d/window.c
grass/trunk/lib/raster3d/windowio.c
grass/trunk/lib/raster3d/writeascii.c
grass/trunk/raster/r.colors.out/raster3d_main.c
grass/trunk/raster/r.colors/edit_colors.c
grass/trunk/raster/r.colors/stats.c
grass/trunk/raster/r.mapcalc/map3.c
grass/trunk/raster/r.to.rast3/main.c
grass/trunk/raster/r.to.rast3elev/main.c
grass/trunk/raster/r.univar/r3.univar_main.c
grass/trunk/raster3d/r3.cross.rast/main.c
grass/trunk/raster3d/r3.gwflow/main.c
grass/trunk/raster3d/r3.in.ascii/main.c
grass/trunk/raster3d/r3.in.v5d/main.c
grass/trunk/raster3d/r3.info/r3.info.main.c
grass/trunk/raster3d/r3.mask/main.c
grass/trunk/raster3d/r3.mkdspf/main.c
grass/trunk/raster3d/r3.mkdspf/r3_data.c
grass/trunk/raster3d/r3.null/main.c
grass/trunk/raster3d/r3.out.ascii/main.c
grass/trunk/raster3d/r3.out.v5d/main.c
grass/trunk/raster3d/r3.out.vtk/errorHandling.c
grass/trunk/raster3d/r3.out.vtk/main.c
grass/trunk/raster3d/r3.out.vtk/writeVTKData.c
grass/trunk/raster3d/r3.retile/main.c
grass/trunk/raster3d/r3.showdspf/main_ogl.c
grass/trunk/raster3d/r3.showdspf/r3_data.c
grass/trunk/raster3d/r3.stats/main.c
grass/trunk/raster3d/r3.to.rast/main.c
grass/trunk/vector/v.colors/main.c
grass/trunk/vector/v.to.rast3/main.c
grass/trunk/vector/v.vol.rst/main.c
grass/trunk/vector/v.vol.rst/user1.c
raster3dlib: change camelCase to underscores in the function names
Modified: grass/trunk/general/g.region/main.c
--- grass/trunk/general/g.region/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/general/g.region/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -488,11 +488,11 @@
if ((mapset = G_find_grid3(name, "")) == NULL)
G_fatal_error(_("3D raster map <%s> not found"), name);
- if (Rast3d_readRegionMap(name, mapset, &win) < 0)
+ if (Rast3d_read_region_map(name, mapset, &win) < 0)
G_fatal_error(_("Unable to read header of 3D raster map <%s@%s>"),
name, mapset);
- Rast3d_regionToCellHead(&win, &window);
+ Rast3d_region_to_cell_head(&win, &window);
/* vect= */
Modified: grass/trunk/include/raster3ddefs.h
--- grass/trunk/include/raster3ddefs.h 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/include/raster3ddefs.h 2011-08-12 08:32:30 UTC (rev 47593)
@@ -5,8 +5,8 @@
void Rast3d_cache_reset(RASTER3D_cache *);
void Rast3d_cache_dispose(RASTER3D_cache *);
void *Rast3d_cache_new(int, int, int, write_fn *, void *, read_fn *, void *);
-void Rast3d_cache_set_removeFun(RASTER3D_cache *, write_fn *, void *);
-void Rast3d_cache_set_loadFun(RASTER3D_cache *, read_fn *, void *);
+void Rast3d_cache_set_remove_fun(RASTER3D_cache *, write_fn *, void *);
+void Rast3d_cache_set_load_fun(RASTER3D_cache *, read_fn *, void *);
void *Rast3d_cache_new_read(int, int, int, read_fn *, void *);
int Rast3d_cache_lock(RASTER3D_cache *, int);
void Rast3d_cache_lock_intern(RASTER3D_cache *, int);
@@ -15,7 +15,7 @@
int Rast3d_cache_lock_all(RASTER3D_cache *);
void Rast3d_cache_autolock_on(RASTER3D_cache *);
void Rast3d_cache_autolock_off(RASTER3D_cache *);
-void Rast3d_cache_set_minUnlock(RASTER3D_cache *, int);
+void Rast3d_cache_set_min_unlock(RASTER3D_cache *, int);
int Rast3d_cache_remove_elt(RASTER3D_cache *, int);
int Rast3d_cache_flush(RASTER3D_cache *, int);
int Rast3d_cache_remove_all(RASTER3D_cache *);
@@ -34,13 +34,13 @@
int Rast3d_cache_hash_name2index(Rast3d_cache_hash *, int);
/* changeprecision.c */
-void Rast3d_changePrecision(void *, int, const char *);
+void Rast3d_change_precision(void *, int, const char *);
/* changetype.c */
-void Rast3d_changeType(void *, const char *);
+void Rast3d_change_type(void *, const char *);
/* filecompare.c */
-void Rast3d_compareFiles(const char *, const char *, const char *, const char *);
+void Rast3d_compare_files(const char *, const char *, const char *, const char *);
/* filename.c */
void Rast3d_filename(char *, const char *, const char *, const char *);
@@ -49,14 +49,14 @@
char *G_find_grid3(const char *, const char *);
/* fpcompress.c */
-void G_fpcompress_printBinary(char *, int);
-void G_fpcompress_dissectXdrDouble(unsigned char *);
-int G_fpcompress_writeXdrNums(int, char *, int, int, char *, int, int, int);
-int G_fpcompress_writeXdrFloats(int, char *, int, int, char *, int, int);
-int G_fpcompress_writeXdrDouble(int, char *, int, int, char *, int, int);
-int G_fpcompress_readXdrNums(int, char *, int, int, int, char *, int);
-int G_fpcompress_readXdrFloats(int, char *, int, int, int, char *);
-int G_fpcompress_readXdrDoubles(int, char *, int, int, int, char *);
+void Rast3d_fpcompress_print_binary(char *, int);
+void Rast3d_fpcompress_dissect_xdr_double(unsigned char *);
+int Rast3d_fpcompress_write_xdr_nums(int, char *, int, int, char *, int, int, int);
+int Rast3d_fpcompress_write_xdr_floats(int, char *, int, int, char *, int, int);
+int Rast3d_fpcompress_write_xdr_double(int, char *, int, int, char *, int, int);
+int Rast3d_fpcompress_read_xdr_nums(int, char *, int, int, int, char *, int);
+int Rast3d_fpcompress_read_xdr_floats(int, char *, int, int, int, char *);
+int Rast3d_fpcompress_read_xdr_doubles(int, char *, int, int, int, char *);
/* g3dalloc.c */
void *Rast3d_malloc(int);
@@ -64,104 +64,104 @@
void Rast3d_free(void *);
/* g3dcache.c */
-int Rast3d_initCache(RASTER3D_Map *, int);
-int Rast3d_disposeCache(RASTER3D_Map *);
-int Rast3d_flushAllTiles(RASTER3D_Map *);
+int Rast3d_init_cache(RASTER3D_Map *, int);
+int Rast3d_dispose_cache(RASTER3D_Map *);
+int Rast3d_flush_all_tiles(RASTER3D_Map *);
/* g3dcats.c */
-int Rast3d_writeCats(const char *, struct Categories *);
-int Rast3d_readCats(const char *, const char *, struct Categories *);
+int Rast3d_write_cats(const char *, struct Categories *);
+int Rast3d_read_cats(const char *, const char *, struct Categories *);
/* g3dclose.c */
-int Rast3d_closeCell(RASTER3D_Map *);
+int Rast3d_close_cell(RASTER3D_Map *);
/* g3dcolor.c */
-int Rast3d_removeColor(const char *);
-int Rast3d_readColors(const char *, const char *, struct Colors *);
-int Rast3d_writeColors(const char *, const char *, struct Colors *);
+int Rast3d_remove_color(const char *);
+int Rast3d_read_colors(const char *, const char *, struct Colors *);
+int Rast3d_write_colors(const char *, const char *, struct Colors *);
/* g3ddefaults.c */
-void Rast3d_setCompressionMode(int, int, int, int);
-void Rast3d_getCompressionMode(int *, int *, int *, int *);
-void Rast3d_setCacheSize(int);
-int Rast3d_getCacheSize(void);
-void Rast3d_setCacheLimit(int);
-int Rast3d_getCacheLimit(void);
-void Rast3d_setFileType(int);
-int Rast3d_getFileType(void);
-void Rast3d_setTileDimension(int, int, int);
-void Rast3d_getTileDimension(int *, int *, int *);
-void Rast3d_setErrorFun(void (*)(const char *));
-void Rast3d_setUnit(const char *);
-void Rast3d_initDefaults(void);
+void Rast3d_set_compression_mode(int, int, int, int);
+void Rast3d_get_compression_mode(int *, int *, int *, int *);
+void Rast3d_set_cache_size(int);
+int Rast3d_get_cache_size(void);
+void Rast3d_set_cache_limit(int);
+int Rast3d_get_cache_limit(void);
+void Rast3d_set_file_type(int);
+int Rast3d_get_file_type(void);
+void Rast3d_set_tile_dimension(int, int, int);
+void Rast3d_get_tile_dimension(int *, int *, int *);
+void Rast3d_set_error_fun(void (*)(const char *));
+void Rast3d_set_unit(const char *);
+void Rast3d_init_defaults(void);
/* g3ddoubleio.c */
-int Rast3d_writeDoubles(int, int, const double *, int);
-int Rast3d_readDoubles(int, int, double *, int);
+int Rast3d_write_doubles(int, int, const double *, int);
+int Rast3d_read_doubles(int, int, double *, int);
/* g3derror.c */
-void Rast3d_skipError(const char *);
-void Rast3d_printError(const char *);
-void Rast3d_fatalError(const char *, ...) __attribute__ ((format(printf, 1, 2)))
+void Rast3d_skip_error(const char *);
+void Rast3d_print_error(const char *);
+void Rast3d_fatal_error(const char *, ...) __attribute__ ((format(printf, 1, 2)))
__attribute__ ((noreturn));
-void Rast3d_fatalError_noargs(const char *) __attribute__ ((noreturn));
+void Rast3d_fatal_error_noargs(const char *) __attribute__ ((noreturn));
void Rast3d_error(const char *, ...) __attribute__ ((format(printf, 1, 2)));
/* g3dfpxdr.c */
-int Rast3d_isXdrNullNum(const void *, int);
-int Rast3d_isXdrNullFloat(const float *);
-int Rast3d_isXdrNullDouble(const double *);
-void Rast3d_setXdrNullNum(void *, int);
-void Rast3d_setXdrNullDouble(double *);
-void Rast3d_setXdrNullFloat(float *);
-int Rast3d_initFpXdr(RASTER3D_Map *, int);
-int Rast3d_initCopyToXdr(RASTER3D_Map *, int);
-int Rast3d_copyToXdr(const void *, int);
-int Rast3d_initCopyFromXdr(RASTER3D_Map *, int);
-int Rast3d_copyFromXdr(int, void *);
+int Rast3d_is_xdr_null_num(const void *, int);
+int Rast3d_is_xdr_null_float(const float *);
+int Rast3d_is_xdr_null_double(const double *);
+void Rast3d_set_xdr_null_num(void *, int);
+void Rast3d_set_xdr_null_double(double *);
+void Rast3d_set_xdr_null_float(float *);
+int Rast3d_init_fp_xdr(RASTER3D_Map *, int);
+int Rast3d_init_copy_to_xdr(RASTER3D_Map *, int);
+int Rast3d_copy_to_xdr(const void *, int);
+int Rast3d_init_copy_from_xdr(RASTER3D_Map *, int);
+int Rast3d_copy_from_xdr(int, void *);
/* g3dhistory.c */
-int Rast3d_writeHistory(const char *, struct History *);
-int Rast3d_readHistory(const char *, const char *, struct History *);
+int Rast3d_write_history(const char *, struct History *);
+int Rast3d_read_history(const char *, const char *, struct History *);
/* g3dintio.c */
-int Rast3d_writeInts(int, int, const int *, int);
-int Rast3d_readInts(int, int, int *, int);
+int Rast3d_write_ints(int, int, const int *, int);
+int Rast3d_read_ints(int, int, int *, int);
/* g3dkeys.c */
-int Rast3d_keyGetInt(struct Key_Value *, const char *, int *);
-int Rast3d_keyGetDouble(struct Key_Value *, const char *, double *);
-int Rast3d_keyGetString(struct Key_Value *, const char *, char **);
-int Rast3d_keyGetValue(struct Key_Value *, const char *, char *, char *, int,
+int Rast3d_key_get_int(struct Key_Value *, const char *, int *);
+int Rast3d_key_get_double(struct Key_Value *, const char *, double *);
+int Rast3d_key_get_string(struct Key_Value *, const char *, char **);
+int Rast3d_key_get_value(struct Key_Value *, const char *, char *, char *, int,
int, int *);
-int Rast3d_keySetInt(struct Key_Value *, const char *, const int *);
-int Rast3d_keySetDouble(struct Key_Value *, const char *, const double *);
-int Rast3d_keySetString(struct Key_Value *, const char *, char *const *);
-int Rast3d_keySetValue(struct Key_Value *, const char *, const char *,
+int Rast3d_key_set_int(struct Key_Value *, const char *, const int *);
+int Rast3d_key_set_double(struct Key_Value *, const char *, const double *);
+int Rast3d_key_set_string(struct Key_Value *, const char *, char *const *);
+int Rast3d_key_set_value(struct Key_Value *, const char *, const char *,
const char *, int, int, const int *);
/* g3dlong.c */
-int Rast3d_longEncode(long *, unsigned char *, int);
-void Rast3d_longDecode(unsigned char *, long *, int, int);
+int Rast3d_long_encode(long *, unsigned char *, int);
+void Rast3d_long_decode(unsigned char *, long *, int, int);
/* g3dmapset.c */
-void Rast3d_makeMapsetMapDirectory(const char *);
+void Rast3d_make_mapset_map_directory(const char *);
/* g3dmask.c */
-int Rast3d_maskClose(void);
-int Rast3d_maskFileExists(void);
-int Rast3d_maskOpenOld(void);
-int Rast3d_maskReopen(int);
-int Rast3d_isMasked(RASTER3D_Map *, int, int, int);
-void Rast3d_maskNum(RASTER3D_Map *, int, int, int, void *, int);
-void Rast3d_maskFloat(RASTER3D_Map *, int, int, int, float *);
-void Rast3d_maskDouble(RASTER3D_Map *, int, int, int, double *);
-void Rast3d_maskTile(RASTER3D_Map *, int, void *, int);
-void Rast3d_maskOn(RASTER3D_Map *);
-void Rast3d_maskOff(RASTER3D_Map *);
-int Rast3d_maskIsOn(RASTER3D_Map *);
-int Rast3d_maskIsOff(RASTER3D_Map *);
-const char *Rast3d_maskFile(void);
-int Rast3d_maskMapExists(void);
+int Rast3d_mask_close(void);
+int Rast3d_mask_file_exists(void);
+int Rast3d_mask_open_old(void);
+int Rast3d_mask_reopen(int);
+int Rast3d_is_masked(RASTER3D_Map *, int, int, int);
+void Rast3d_mask_num(RASTER3D_Map *, int, int, int, void *, int);
+void Rast3d_mask_float(RASTER3D_Map *, int, int, int, float *);
+void Rast3d_mask_double(RASTER3D_Map *, int, int, int, double *);
+void Rast3d_mask_tile(RASTER3D_Map *, int, void *, int);
+void Rast3d_mask_on(RASTER3D_Map *);
+void Rast3d_mask_off(RASTER3D_Map *);
+int Rast3d_mask_is_on(RASTER3D_Map *);
+int Rast3d_mask_is_off(RASTER3D_Map *);
+const char *Rast3d_mask_file(void);
+int Rast3d_mask_map_exists(void);
/* maskfn.c */
int Rast3d_mask_d_select(DCELL *, d_Mask *);
@@ -169,192 +169,192 @@
void Rast3d_parse_vallist(char **, d_Mask **);
/* g3dmisc.c */
-int Rast3d_g3dType2cellType(int);
-void Rast3d_copyFloat2Double(const float *, int, double *, int, int);
-void Rast3d_copyDouble2Float(const double *, int, float *, int, int);
-void Rast3d_copyValues(const void *, int, int, void *, int, int, int);
+int Rast3d_g3d_type2cell_type(int);
+void Rast3d_copy_float2Double(const float *, int, double *, int, int);
+void Rast3d_copy_double2Float(const double *, int, float *, int, int);
+void Rast3d_copy_values(const void *, int, int, void *, int, int, int);
int Rast3d_length(int);
-int Rast3d_externLength(int);
+int Rast3d_extern_length(int);
/* g3dnull.c */
-int Rast3d_isNullValueNum(const void *, int);
-void Rast3d_setNullValue(void *, int, int);
+int Rast3d_is_null_value_num(const void *, int);
+void Rast3d_set_null_value(void *, int, int);
/* g3dopen2.c */
-void *Rast3d_openNewParam(const char *, int , int, RASTER3D_Region *, int, int, int, int, int, int, int);
+void *Rast3d_open_new_param(const char *, int , int, RASTER3D_Region *, int, int, int, int, int, int, int);
/* g3dopen.c */
-void *Rast3d_openCellOldNoHeader(const char *, const char *);
-void *Rast3d_openCellOld(const char *, const char *, RASTER3D_Region *, int, int);
-void *Rast3d_openCellNew(const char *, int, int, RASTER3D_Region *);
-void *Rast3d_openNewOptTileSize(const char *, int , RASTER3D_Region * , int , int );
+void *Rast3d_open_cell_old_no_header(const char *, const char *);
+void *Rast3d_open_cell_old(const char *, const char *, RASTER3D_Region *, int, int);
+void *Rast3d_open_cell_new(const char *, int, int, RASTER3D_Region *);
+void *Rast3d_open_new_opt_tile_size(const char *, int , RASTER3D_Region * , int , int );
/* g3dparam.c */
-void Rast3d_setStandard3dInputParams(void);
-int Rast3d_getStandard3dParams(int *, int *, int *, int *, int *, int *, int *,
+void Rast3d_set_standard3d_input_params(void);
+int Rast3d_get_standard3d_params(int *, int *, int *, int *, int *, int *, int *,
int *, int *, int *, int *, int *);
-void Rast3d_setWindowParams(void);
-char *Rast3d_getWindowParams(void);
+void Rast3d_set_window_params(void);
+char *Rast3d_get_window_params(void);
/* g3drange.c */
-void Rast3d_range_updateFromTile(RASTER3D_Map *, const void *, int, int, int, int,
+void Rast3d_range_update_from_tile(RASTER3D_Map *, const void *, int, int, int, int,
-int Rast3d_readRange(const char *, const char *, struct FPRange *);
+int Rast3d_read_range(const char *, const char *, struct FPRange *);
int Rast3d_range_load(RASTER3D_Map *);
void Rast3d_range_min_max(RASTER3D_Map *, double *, double *);
int Rast3d_range_write(RASTER3D_Map *);
int Rast3d_range_init(RASTER3D_Map *);
/* g3dregion.c */
-void Rast3d_getRegionValue(RASTER3D_Map *, double, double, double, void *, int);
-void Rast3d_adjustRegion(RASTER3D_Region *);
-void Rast3d_regionCopy(RASTER3D_Region *, RASTER3D_Region *);
-void Rast3d_incorporate2dRegion(struct Cell_head *, RASTER3D_Region *);
-void Rast3d_regionFromToCellHead(struct Cell_head *, RASTER3D_Region *);
-void Rast3d_adjustRegionRes(RASTER3D_Region *);
-void Rast3d_extract2dRegion(RASTER3D_Region *, struct Cell_head *);
-void Rast3d_regionToCellHead(RASTER3D_Region *, struct Cell_head *);
-int Rast3d_readRegionMap(const char *, const char *, RASTER3D_Region *);
-int Rast3d_isValidLocation(RASTER3D_Region *, double, double, double);
+void Rast3d_get_region_value(RASTER3D_Map *, double, double, double, void *, int);
+void Rast3d_adjust_region(RASTER3D_Region *);
+void Rast3d_region_copy(RASTER3D_Region *, RASTER3D_Region *);
+void Rast3d_incorporate2d_region(struct Cell_head *, RASTER3D_Region *);
+void Rast3d_region_from_to_cell_head(struct Cell_head *, RASTER3D_Region *);
+void Rast3d_adjust_region_res(RASTER3D_Region *);
+void Rast3d_extract2d_region(RASTER3D_Region *, struct Cell_head *);
+void Rast3d_region_to_cell_head(RASTER3D_Region *, struct Cell_head *);
+int Rast3d_read_region_map(const char *, const char *, RASTER3D_Region *);
+int Rast3d_is_valid_location(RASTER3D_Region *, double, double, double);
void Rast3d_location2coord(RASTER3D_Region *, double, double, double, int *, int *, int *);
void Rast3d_location2coord2(RASTER3D_Region *, double, double, double, int *, int *, int *);
void Rast3d_coord2location(RASTER3D_Region *, double, double, double, double *, double *, double *);
/* g3dresample.c */
-void Rast3d_nearestNeighbor(RASTER3D_Map *, int, int, int, void *, int);
-void Rast3d_setResamplingFun(RASTER3D_Map *, void (*)());
-void Rast3d_getResamplingFun(RASTER3D_Map *, void (**)());
-void Rast3d_getNearestNeighborFunPtr(void (**)());
+void Rast3d_nearest_neighbor(RASTER3D_Map *, int, int, int, void *, int);
+void Rast3d_set_resampling_fun(RASTER3D_Map *, void (*)());
+void Rast3d_get_resampling_fun(RASTER3D_Map *, void (**)());
+void Rast3d_get_nearest_neighbor_fun_ptr(void (**)());
/* g3dvolume.c */
-void Rast3d_getVolumeA(void *, double[2][2][2][3], int, int, int, void *, int);
-void Rast3d_getVolume(void *, double, double, double, double, double, double,
+void Rast3d_get_volume_a(void *, double[2][2][2][3], int, int, int, void *, int);
+void Rast3d_get_volume(void *, double, double, double, double, double, double,
double, double, double, double, double, double, int, int,
int, void *, int);
-void Rast3d_getAlignedVolume(void *, double, double, double, double, double,
+void Rast3d_get_aligned_volume(void *, double, double, double, double, double,
double, int, int, int, void *, int);
-void Rast3d_makeAlignedVolumeFile(void *, const char *, double, double, double,
+void Rast3d_make_aligned_volume_file(void *, const char *, double, double, double,
double, double, double, int, int, int);
/* g3dwindow.c */
-void Rast3d_getValue(RASTER3D_Map *, int, int, int, void *, int);
-float Rast3d_getFloat(RASTER3D_Map *, int, int, int);
-double Rast3d_getDouble(RASTER3D_Map *, int, int, int);
-void Rast3d_getWindowValue(RASTER3D_Map *, double, double, double, void *, int);
+void Rast3d_get_value(RASTER3D_Map *, int, int, int, void *, int);
+float Rast3d_get_float(RASTER3D_Map *, int, int, int);
+double Rast3d_get_double(RASTER3D_Map *, int, int, int);
+void Rast3d_get_window_value(RASTER3D_Map *, double, double, double, void *, int);
-RASTER3D_Region *Rast3d_windowPtr(void);
-void Rast3d_setWindow(RASTER3D_Region *);
-void Rast3d_setWindowMap(RASTER3D_Map *, RASTER3D_Region *);
-void Rast3d_getWindow(RASTER3D_Region *);
+RASTER3D_Region *Rast3d_window_ptr(void);
+void Rast3d_set_window(RASTER3D_Region *);
+void Rast3d_set_window_map(RASTER3D_Map *, RASTER3D_Region *);
+void Rast3d_get_window(RASTER3D_Region *);
/* g3dwindowio.c */
-void Rast3d_useWindowParams(void);
-int Rast3d_readWindow(RASTER3D_Region *, const char *);
+void Rast3d_use_window_params(void);
+int Rast3d_read_window(RASTER3D_Region *, const char *);
/* int Rast3d_writeWindow (RASTER3D_Region *, char *); */
/* getblock.c */
-void Rast3d_getBlockNocache(RASTER3D_Map *, int, int, int, int, int, int, void *,
+void Rast3d_get_block_nocache(RASTER3D_Map *, int, int, int, int, int, int, void *,
int);
-void Rast3d_getBlock(RASTER3D_Map *, int, int, int, int, int, int, void *, int);
+void Rast3d_get_block(RASTER3D_Map *, int, int, int, int, int, int, void *, int);
/* header.c */
-int Rast3d_readHeader(RASTER3D_Map *, int *, int *, double *, double *, double *,
+int Rast3d_read_header(RASTER3D_Map *, int *, int *, double *, double *, double *,
double *, double *, double *, int *, int *, int *,
double *, double *, double *, int *, int *, int *, int *,
int *, int *, int *, int *, int *, int *, int *, char **);
-int Rast3d_writeHeader(RASTER3D_Map *, int, int, double, double, double, double,
+int Rast3d_write_header(RASTER3D_Map *, int, int, double, double, double, double,
double, double, int, int, int, double, double, double,
int, int, int, int, int, int, int, int, int, int, int,
char *);
-int Rast3d_cacheSizeEncode(int, int);
-int Rast3d__computeCacheSize(RASTER3D_Map *, int);
-int Rast3d_fillHeader(RASTER3D_Map *, int, int, int, int, int, int, int, int, int,
+int Rast3d_cache_size_encode(int, int);
+int Rast3d__compute_cache_size(RASTER3D_Map *, int);
+int Rast3d_fill_header(RASTER3D_Map *, int, int, int, int, int, int, int, int, int,
int, int, int, int, int, int, int, double, double, double,
double, double, double, int, int, int, double, double,
double, char *);
/* headerinfo.c */
-void Rast3d_getCoordsMap(RASTER3D_Map *, int *, int *, int *);
-void Rast3d_getCoordsMapWindow(RASTER3D_Map *, int *, int *, int *);
-void Rast3d_getNofTilesMap(RASTER3D_Map *, int *, int *, int *);
-void Rast3d_getRegionMap(RASTER3D_Map *, double *, double *, double *, double *,
+void Rast3d_get_coords_map(RASTER3D_Map *, int *, int *, int *);
+void Rast3d_get_coords_map_window(RASTER3D_Map *, int *, int *, int *);
+void Rast3d_get_nof_tiles_map(RASTER3D_Map *, int *, int *, int *);
+void Rast3d_get_region_map(RASTER3D_Map *, double *, double *, double *, double *,
-void Rast3d_getWindowMap(RASTER3D_Map *, double *, double *, double *, double *,
+void Rast3d_get_window_map(RASTER3D_Map *, double *, double *, double *, double *,
-void Rast3d_getTileDimensionsMap(RASTER3D_Map *, int *, int *, int *);
-int Rast3d_tileTypeMap(RASTER3D_Map *);
-int Rast3d_fileTypeMap(RASTER3D_Map *);
-int Rast3d_tilePrecisionMap(RASTER3D_Map *);
-int Rast3d_tileUseCacheMap(RASTER3D_Map *);
-void Rast3d_printHeader(RASTER3D_Map *);
-void Rast3d_getRegionStructMap(RASTER3D_Map *, RASTER3D_Region *);
+void Rast3d_get_tile_dimensions_map(RASTER3D_Map *, int *, int *, int *);
+int Rast3d_tile_type_map(RASTER3D_Map *);
+int Rast3d_file_type_map(RASTER3D_Map *);
+int Rast3d_tile_precision_map(RASTER3D_Map *);
+int Rast3d_tile_use_cache_map(RASTER3D_Map *);
+void Rast3d_print_header(RASTER3D_Map *);
+void Rast3d_get_region_struct_map(RASTER3D_Map *, RASTER3D_Region *);
/* index.c */
-int Rast3d_flushIndex(RASTER3D_Map *);
-int Rast3d_initIndex(RASTER3D_Map *, int);
+int Rast3d_flush_index(RASTER3D_Map *);
+int Rast3d_init_index(RASTER3D_Map *, int);
/* retile.c */
void Rast3d_retile(void *, const char *, int, int, int);
/* rle.c */
-int G_rle_count_only(char *, int, int);
-void G_rle_encode(char *, char *, int, int);
-void G_rle_decode(char *, char *, int, int, int *, int *);
+int Rast3d_rle_count_only(char *, int, int);
+void Rast3d_rle_encode(char *, char *, int, int);
+void Rast3d_rle_decode(char *, char *, int, int, int *, int *);
/* tilealloc.c */
-void *Rast3d_allocTilesType(RASTER3D_Map *, int, int);
-void *Rast3d_allocTiles(RASTER3D_Map *, int);
-void Rast3d_freeTiles(void *);
+void *Rast3d_alloc_tiles_type(RASTER3D_Map *, int, int);
+void *Rast3d_alloc_tiles(RASTER3D_Map *, int);
+void Rast3d_free_tiles(void *);
/* tileio.c */
-void *Rast3d_getTilePtr(RASTER3D_Map *, int);
-int Rast3d_tileLoad(RASTER3D_Map *, int);
-int Rast3d__removeTile(RASTER3D_Map *, int);
-float Rast3d_getFloatRegion(RASTER3D_Map *, int, int, int);
-double Rast3d_getDoubleRegion(RASTER3D_Map *, int, int, int);
-void Rast3d_getValueRegion(RASTER3D_Map *, int, int, int, void *, int);
+void *Rast3d_get_tile_ptr(RASTER3D_Map *, int);
+int Rast3d_tile_load(RASTER3D_Map *, int);
+int Rast3d__remove_tile(RASTER3D_Map *, int);
+float Rast3d_get_float_region(RASTER3D_Map *, int, int, int);
+double Rast3d_get_double_region(RASTER3D_Map *, int, int, int);
+void Rast3d_get_value_region(RASTER3D_Map *, int, int, int, void *, int);
/* tilemath.c */
-void Rast3d_computeOptimalTileDimension(RASTER3D_Region *, int, int *, int *, int *, int);
-void Rast3d_tileIndex2tile(RASTER3D_Map *, int, int *, int *, int *);
-int Rast3d_tile2tileIndex(RASTER3D_Map *, int, int, int);
-void Rast3d_tileCoordOrigin(RASTER3D_Map *, int, int, int, int *, int *, int *);
-void Rast3d_tileIndexOrigin(RASTER3D_Map *, int, int *, int *, int *);
-void Rast3d_coord2tileCoord(RASTER3D_Map *, int, int, int, int *, int *, int *, int *,
+void Rast3d_compute_optimal_tile_dimension(RASTER3D_Region *, int, int *, int *, int *, int);
+void Rast3d_tile_index2tile(RASTER3D_Map *, int, int *, int *, int *);
+int Rast3d_tile2tile_index(RASTER3D_Map *, int, int, int);
+void Rast3d_tile_coord_origin(RASTER3D_Map *, int, int, int, int *, int *, int *);
+void Rast3d_tile_index_origin(RASTER3D_Map *, int, int *, int *, int *);
+void Rast3d_coord2tile_coord(RASTER3D_Map *, int, int, int, int *, int *, int *, int *,
int *, int *);
-void Rast3d_coord2tileIndex(RASTER3D_Map *, int, int, int, int *, int *);
-int Rast3d_coordInRange(RASTER3D_Map *, int, int, int);
-int Rast3d_tileIndexInRange(RASTER3D_Map *, int);
-int Rast3d_tileInRange(RASTER3D_Map *, int, int, int);
-int Rast3d_computeClippedTileDimensions(RASTER3D_Map *, int, int *, int *, int *,
+void Rast3d_coord2tile_index(RASTER3D_Map *, int, int, int, int *, int *);
+int Rast3d_coord_in_range(RASTER3D_Map *, int, int, int);
+int Rast3d_tile_index_in_range(RASTER3D_Map *, int);
+int Rast3d_tile_in_range(RASTER3D_Map *, int, int, int);
+int Rast3d_compute_clipped_tile_dimensions(RASTER3D_Map *, int, int *, int *, int *,
/* tilenull.c */
-void Rast3d_setNullTileType(RASTER3D_Map *, void *, int);
-void Rast3d_setNullTile(RASTER3D_Map *, void *);
+void Rast3d_set_null_tile_type(RASTER3D_Map *, void *, int);
+void Rast3d_set_null_tile(RASTER3D_Map *, void *);
/* tileread.c */
-int Rast3d_readTile(RASTER3D_Map *, int, void *, int);
-int Rast3d_readTileFloat(RASTER3D_Map *, int, void *);
-int Rast3d_readTileDouble(RASTER3D_Map *, int, void *);
-int Rast3d_lockTile(RASTER3D_Map *, int);
-int Rast3d_unlockTile(RASTER3D_Map *, int);
-int Rast3d_unlockAll(RASTER3D_Map *);
-void Rast3d_autolockOn(RASTER3D_Map *);
-void Rast3d_autolockOff(RASTER3D_Map *);
-void Rast3d_minUnlocked(RASTER3D_Map *, int);
-int Rast3d_beginCycle(RASTER3D_Map *);
-int Rast3d_endCycle(RASTER3D_Map *);
+int Rast3d_read_tile(RASTER3D_Map *, int, void *, int);
+int Rast3d_read_tile_float(RASTER3D_Map *, int, void *);
+int Rast3d_read_tile_double(RASTER3D_Map *, int, void *);
+int Rast3d_lock_tile(RASTER3D_Map *, int);
+int Rast3d_unlock_tile(RASTER3D_Map *, int);
+int Rast3d_unlock_all(RASTER3D_Map *);
+void Rast3d_autolock_on(RASTER3D_Map *);
+void Rast3d_autolock_off(RASTER3D_Map *);
+void Rast3d_min_unlocked(RASTER3D_Map *, int);
+int Rast3d_begin_cycle(RASTER3D_Map *);
+int Rast3d_end_cycle(RASTER3D_Map *);
/* tilewrite.c */
-int Rast3d_writeTile(RASTER3D_Map *, int, const void *, int);
-int Rast3d_writeTileFloat(RASTER3D_Map *, int, const void *);
-int Rast3d_writeTileDouble(RASTER3D_Map *, int, const void *);
-int Rast3d_flushTile(RASTER3D_Map *, int);
-int Rast3d_flushTileCube(RASTER3D_Map *, int, int, int, int, int, int);
-int Rast3d_flushTilesInCube(RASTER3D_Map *, int, int, int, int, int, int);
-int Rast3d_putFloat(RASTER3D_Map *, int, int, int, float);
-int Rast3d_putDouble(RASTER3D_Map *, int, int, int, double);
-int Rast3d_putValue(RASTER3D_Map *, int, int, int, const void *, int);
+int Rast3d_write_tile(RASTER3D_Map *, int, const void *, int);
+int Rast3d_write_tile_float(RASTER3D_Map *, int, const void *);
+int Rast3d_write_tile_double(RASTER3D_Map *, int, const void *);
+int Rast3d_flush_tile(RASTER3D_Map *, int);
+int Rast3d_flush_tile_cube(RASTER3D_Map *, int, int, int, int, int, int);
+int Rast3d_flush_tiles_in_cube(RASTER3D_Map *, int, int, int, int, int, int);
+int Rast3d_put_float(RASTER3D_Map *, int, int, int, float);
+int Rast3d_put_double(RASTER3D_Map *, int, int, int, double);
+int Rast3d_put_value(RASTER3D_Map *, int, int, int, const void *, int);
/* writeascii.c */
-void Rast3d_writeAscii(void *, const char *);
+void Rast3d_write_ascii(void *, const char *);
#endif /* RASTER3DDEFS */
Modified: grass/trunk/lib/gpde/N_arrays.c
--- grass/trunk/lib/gpde/N_arrays.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/gpde/N_arrays.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -886,7 +886,7 @@
G_debug(6,
"N_is_array_3d_value_null: null value is of type DCELL_TYPE at pos [%i][%i][%i]",
depth, row, col);
- return Rast3d_isNullValueNum((void *)
+ return Rast3d_is_null_value_num((void *)
&(data->
fcell_array[depth *
(data->rows_intern *
@@ -898,7 +898,7 @@
G_debug(6,
depth, row, col);
&(data->
dcell_array[depth *
@@ -912,7 +912,7 @@
G_debug(6,
depth, row, col);
&(data->
fcell_array[(depth +
data->offset) *
@@ -928,7 +928,7 @@
G_debug(6,
depth, row, col);
&(data->
dcell_array[(depth +
data->offset) *
@@ -1082,7 +1082,7 @@
if (data->offset == 0) {
if (data->type == FCELL_TYPE && data->fcell_array != NULL) {
- Rast3d_setNullValue((void *)
+ Rast3d_set_null_value((void *)
&(data->
fcell_array[depth *
@@ -1091,7 +1091,7 @@
FCELL_TYPE);
else if (data->type == DCELL_TYPE && data->dcell_array != NULL) {
&(data->
dcell_array[depth *
@@ -1102,7 +1102,7 @@
else {
&(data->
data->offset) *
@@ -1116,7 +1116,7 @@
FCELL_TYPE);
&(data->
data->offset) *
Modified: grass/trunk/lib/gpde/N_arrays_calc.c
--- grass/trunk/lib/gpde/N_arrays_calc.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/gpde/N_arrays_calc.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -522,7 +522,7 @@
i++) {
null = 0;
if (source->type == FCELL_TYPE) {
- if (Rast3d_isNullValueNum
+ if (Rast3d_is_null_value_num
((void *)&(source->fcell_array[i]), FCELL_TYPE))
null = 1;
@@ -531,7 +531,7 @@
if (target->type == DCELL_TYPE) {
if (null)
- Rast3d_setNullValue((void *)&(target->dcell_array[i]), 1,
+ Rast3d_set_null_value((void *)&(target->dcell_array[i]), 1,
DCELL_TYPE);
else
target->dcell_array[i] = (double)source->fcell_array[i];
@@ -539,13 +539,13 @@
if (source->type == DCELL_TYPE) {
((void *)&(source->dcell_array[i]), DCELL_TYPE))
null = 1;
if (target->type == FCELL_TYPE) {
if (null)
- Rast3d_setNullValue((void *)&(target->fcell_array[i]), 1,
+ Rast3d_set_null_value((void *)&(target->fcell_array[i]), 1,
FCELL_TYPE);
else
target->fcell_array[i] = (float)source->dcell_array[i];
@@ -596,19 +596,19 @@
v2 = 0.0;
if (a->type == FCELL_TYPE) {
- if (!Rast3d_isNullValueNum((void *)&(a->fcell_array[i]), FCELL_TYPE))
+ if (!Rast3d_is_null_value_num((void *)&(a->fcell_array[i]), FCELL_TYPE))
v1 = (double)a->fcell_array[i];
if (a->type == DCELL_TYPE) {
- if (!Rast3d_isNullValueNum((void *)&(a->dcell_array[i]), DCELL_TYPE))
+ if (!Rast3d_is_null_value_num((void *)&(a->dcell_array[i]), DCELL_TYPE))
v1 = (double)a->dcell_array[i];
if (b->type == FCELL_TYPE) {
- if (!Rast3d_isNullValueNum((void *)&(b->fcell_array[i]), FCELL_TYPE))
+ if (!Rast3d_is_null_value_num((void *)&(b->fcell_array[i]), FCELL_TYPE))
v2 = (double)b->fcell_array[i];
if (b->type == DCELL_TYPE) {
- if (!Rast3d_isNullValueNum((void *)&(b->dcell_array[i]), DCELL_TYPE))
+ if (!Rast3d_is_null_value_num((void *)&(b->dcell_array[i]), DCELL_TYPE))
v2 = (double)b->dcell_array[i];
@@ -859,7 +859,7 @@
for (i = 0; i < a->cols_intern * a->rows_intern * a->depths_intern;
i++) {
- if (Rast3d_isNullValueNum((void *)&(a->fcell_array[i]), FCELL_TYPE)) {
+ if (Rast3d_is_null_value_num((void *)&(a->fcell_array[i]), FCELL_TYPE)) {
a->fcell_array[i] = 0.0;
count++;
@@ -868,7 +868,7 @@
i++) {
- if (Rast3d_isNullValueNum((void *)&(a->dcell_array[i]), DCELL_TYPE)) {
+ if (Rast3d_is_null_value_num((void *)&(a->dcell_array[i]), DCELL_TYPE)) {
a->dcell_array[i] = 0.0;
count++;
Modified: grass/trunk/lib/gpde/N_arrays_io.c
--- grass/trunk/lib/gpde/N_arrays_io.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/gpde/N_arrays_io.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -242,7 +242,7 @@
* <br><br>
* The new created or the provided array is returned.
- * If the reading of the volume map fails, Rast3d_fatalError() will
+ * If the reading of the volume map fails, Rast3d_fatal_error() will
* be invoked.
* \param name * char - the name of an existing volume map
@@ -262,7 +262,7 @@
/*get the current region */
- Rast3d_getWindow(®ion);
+ Rast3d_get_window(®ion);
cols = region.cols;
rows = region.rows;
@@ -270,17 +270,17 @@
if (NULL == G_find_grid3(name, ""))
- Rast3d_fatalError(_("Requested g3d map <%s> not found"), name);
+ Rast3d_fatal_error(_("Requested g3d map <%s> not found"), name);
/*Open all maps with default region */
map =
- Rast3d_openCellOld(name, G_find_grid3(name, ""), RASTER3D_DEFAULT_WINDOW,
+ Rast3d_open_cell_old(name, G_find_grid3(name, ""), RASTER3D_DEFAULT_WINDOW,
RASTER3D_TILE_SAME_AS_FILE, RASTER3D_USE_CACHE_DEFAULT);
if (map == NULL)
- Rast3d_fatalError(_("Error opening g3d map <%s>"), name);
+ Rast3d_fatal_error(_("Error opening g3d map <%s>"), name);
- type = Rast3d_tileTypeMap(map);
+ type = Rast3d_tile_type_map(map);
/*if the array is NULL create a new one with the data type of the volume map */
/*the offset is 0 by default */
@@ -310,10 +310,10 @@
/*if requested set the Mask on */
if (mask) {
- if (Rast3d_maskFileExists()) {
+ if (Rast3d_mask_file_exists()) {
changemask = 0;
- if (Rast3d_maskIsOff(map)) {
- Rast3d_maskOn(map);
+ if (Rast3d_mask_is_off(map)) {
+ Rast3d_mask_on(map);
changemask = 1;
@@ -324,7 +324,7 @@
for (y = 0; y < rows; y++) {
for (x = 0; x < cols; x++) {
if (type == FCELL_TYPE) {
- Rast3d_getValue(map, x, y, z, &f1, type);
+ Rast3d_get_value(map, x, y, z, &f1, type);
if (Rast_is_f_null_value((void *)&f1)) {
N_put_array_3d_value_null(data, x, y, z);
@@ -336,7 +336,7 @@
else {
- Rast3d_getValue(map, x, y, z, &d1, type);
+ Rast3d_get_value(map, x, y, z, &d1, type);
if (Rast_is_d_null_value((void *)&d1)) {
@@ -354,14 +354,14 @@
/*We set the Mask off, if it was off before */
if (mask) {
- if (Rast3d_maskIsOn(map) && changemask)
- Rast3d_maskOff(map);
+ if (Rast3d_mask_is_on(map) && changemask)
+ Rast3d_mask_off(map);
/* Close files and exit */
- if (!Rast3d_closeCell(map))
- Rast3d_fatalError(map, NULL, 0, _("Error closing g3d file"));
+ if (!Rast3d_close_cell(map))
+ Rast3d_fatal_error(map, NULL, 0, _("Error closing g3d file"));
return data;
@@ -372,7 +372,7 @@
* A new volume map is created with the same type as the N_array_3d.
* The current region is used to open the volume map.
* The N_array_3d must have the same size as the current region.
- * If the writing of the volume map fails, Rast3d_fatalError() will
+ * If the writing of the volume map fails, Rast3d_fatal_error() will
* be invoked.
@@ -392,7 +392,7 @@
RASTER3D_Region region;
cols = region.cols;
rows = region.rows;
@@ -412,21 +412,21 @@
/*Open the new map */
if (type == DCELL_TYPE)
- map = Rast3d_openNewOptTileSize(name, RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, 32);
+ map = Rast3d_open_new_opt_tile_size(name, RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, 32);
else if (type == FCELL_TYPE)
- map = Rast3d_openNewOptTileSize(name, RASTER3D_USE_CACHE_XY, ®ion, FCELL_TYPE, 32);
+ map = Rast3d_open_new_opt_tile_size(name, RASTER3D_USE_CACHE_XY, ®ion, FCELL_TYPE, 32);
if (map == NULL)
G_message(_("Write 3d array to g3d map <%s>"), name);
if (mask) {
changemask = 0;
changemask = 1;
@@ -439,11 +439,11 @@
f1 = N_get_array_3d_f_value(data, x, y, z);
- Rast3d_putFloat(map, x, y, z, f1);
+ Rast3d_put_float(map, x, y, z, f1);
else if (type == DCELL_TYPE) {
d1 = N_get_array_3d_d_value(data, x, y, z);
- Rast3d_putDouble(map, x, y, z, d1);
+ Rast3d_put_double(map, x, y, z, d1);
@@ -451,17 +451,17 @@
if (mask) {
/* Flush all tile */
- if (!Rast3d_flushAllTiles(map))
- Rast3d_fatalError("Error flushing tiles with Rast3d_flushAllTiles");
+ if (!Rast3d_flush_all_tiles(map))
+ Rast3d_fatal_error("Error flushing tiles with Rast3d_flush_all_tiles");
return;
Modified: grass/trunk/lib/gpde/N_geom.c
--- grass/trunk/lib/gpde/N_geom.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/gpde/N_geom.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -90,7 +90,7 @@
/*convert the 3d into a 2d region and begin the area calculation */
G_get_set_window(®ion2d); /*this function is not thread safe */
- Rast3d_regionToCellHead(region3d, ®ion2d);
+ Rast3d_region_to_cell_head(region3d, ®ion2d);
return N_init_geom_data_2d(®ion2d, geom);
Modified: grass/trunk/lib/gpde/test/test_arrays.c
--- grass/trunk/lib/gpde/test/test_arrays.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/gpde/test/test_arrays.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -834,8 +834,8 @@
N_free_array_3d(data2);
/*Set the defaults */
- Rast3d_initDefaults();
+ Rast3d_init_defaults();
data1 =
N_alloc_array_3d(region.cols, region.rows, region.depths, 0,
Modified: grass/trunk/lib/gpde/test/test_geom.c
--- grass/trunk/lib/gpde/test/test_geom.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/gpde/test/test_geom.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -60,10 +60,10 @@
- Rast3d_getWindow(®ion3d);
+ Rast3d_get_window(®ion3d);
geom = N_alloc_geom_data();
if (!geom) {
Modified: grass/trunk/lib/ogsf/GVL2.c
--- grass/trunk/lib/ogsf/GVL2.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/ogsf/GVL2.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -36,8 +36,8 @@
void GVL_libinit(void)
- Rast3d_getWindow(&wind3);
+ Rast3d_get_window(&wind3);
Region[0] = wind3.north;
Region[1] = wind3.south;
Modified: grass/trunk/lib/ogsf/Gvl3.c
--- grass/trunk/lib/ogsf/Gvl3.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/ogsf/Gvl3.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -44,7 +44,7 @@
if (NULL == (colors = (struct Colors *)G_malloc(sizeof(struct Colors))))
return (-1);
- if (0 > Rast3d_readColors(name, mapset, colors)) {
+ if (0 > Rast3d_read_colors(name, mapset, colors)) {
G_free(colors);
return (-1);
Modified: grass/trunk/lib/ogsf/gvl_file.c
--- grass/trunk/lib/ogsf/gvl_file.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/ogsf/gvl_file.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -431,7 +431,7 @@
/* open g3d file */
map =
- Rast3d_openCellOld(filename, mapset, RASTER3D_DEFAULT_WINDOW,
+ Rast3d_open_cell_old(filename, mapset, RASTER3D_DEFAULT_WINDOW,
if (!map) {
G_warning(_("Unable to open 3D raster map <%s>"), filename);
@@ -447,7 +447,7 @@
Rast3d_range_min_max(map, min, max);
/* get file data type */
- itype = Rast3d_fileTypeMap(map);
+ itype = Rast3d_file_type_map(map);
if (itype == FCELL_TYPE)
*type = VOL_DTYPE_FLOAT;
if (itype == DCELL_TYPE)
@@ -467,7 +467,7 @@
int close_g3d_file(void *map)
/* close opened g3d file */
- if (Rast3d_closeCell((RASTER3D_Map *) map) != 1) {
+ if (Rast3d_close_cell((RASTER3D_Map *) map) != 1) {
G_warning(_("Unable to close 3D raster map <%s>"),
((RASTER3D_Map *) map)->fileName);
return (-1);
@@ -492,12 +492,12 @@
switch (type) {
/* float data type */
case (VOL_DTYPE_FLOAT):
- *((float *)value) = Rast3d_getFloat(map, x, y, z);
+ *((float *)value) = Rast3d_get_float(map, x, y, z);
break;
/* double data type */
case (VOL_DTYPE_DOUBLE):
- *((double *)value) = Rast3d_getDouble(map, x, y, z);
+ *((double *)value) = Rast3d_get_double(map, x, y, z);
break;
/* unsupported data type */
@@ -529,7 +529,7 @@
for (x = 0; x < Cols; x++) {
for (y = 0; y < Rows; y++) {
((float *)data)[x + y * Cols] =
- Rast3d_getFloat(map, x, y, level);
+ Rast3d_get_float(map, x, y, level);
@@ -540,7 +540,7 @@
((double *)data)[x + y * Cols] =
- Rast3d_getDouble(map, x, y, level);
+ Rast3d_get_double(map, x, y, level);
@@ -575,7 +575,7 @@
for (z = 0; z < Depths; z++) {
((float *)data)[x + y * Cols + z * Rows * Cols] =
- Rast3d_getFloat(map, x, y, z);
+ Rast3d_get_float(map, x, y, z);
@@ -588,7 +588,7 @@
((double *)data)[x + y * Cols + z * Rows * Cols] =
- Rast3d_getDouble(map, x, y, z);
+ Rast3d_get_double(map, x, y, z);
@@ -618,12 +618,12 @@
switch (type) {
- return Rast3d_isNullValueNum(value, FCELL_TYPE);
+ return Rast3d_is_null_value_num(value, FCELL_TYPE);
break;
- return Rast3d_isNullValueNum(value, DCELL_TYPE);
+ return Rast3d_is_null_value_num(value, DCELL_TYPE);
break;
Modified: grass/trunk/lib/raster3d/cache.c
--- grass/trunk/lib/raster3d/cache.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/cache.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -11,8 +11,8 @@
RASTER3D_Map *map = closure;
- if (!Rast3d_readTile(map, tileIndex, tileBuf, map->typeIntern)) {
- Rast3d_error("cacheRead_readFun: error in Rast3d_readTile");
+ if (!Rast3d_read_tile(map, tileIndex, tileBuf, map->typeIntern)) {
+ Rast3d_error("cacheRead_readFun: error in Rast3d_read_tile");
return 0;
return 1;
@@ -62,8 +62,8 @@
pos = map->index[tileIndex];
/* tile has already been flushed onto output file or does not exist yet */
- if (pos >= -1) { /* note, Rast3d_readTile takes care of the case pos == -1 */
- Rast3d_readTile(map, tileIndex, tileBuf, map->typeIntern);
+ if (pos >= -1) { /* note, Rast3d_read_tile takes care of the case pos == -1 */
+ Rast3d_read_tile(map, tileIndex, tileBuf, map->typeIntern);
return 1;
@@ -212,18 +212,18 @@
-int Rast3d_initCache(RASTER3D_Map * map, int nCached)
+int Rast3d_init_cache(RASTER3D_Map * map, int nCached)
if (map->operation == RASTER3D_READ_DATA) {
if (!initCacheRead(map, nCached)) {
- Rast3d_error("Rast3d_initCache: error in initCacheRead");
+ Rast3d_error("Rast3d_init_cache: error in initCacheRead");
return 0;
return 1;
if (!initCacheWrite(map, nCached)) {
- Rast3d_error("Rast3d_initCache: error in initCacheWrite");
+ Rast3d_error("Rast3d_init_cache: error in initCacheWrite");
return 0;
@@ -240,18 +240,18 @@
-int Rast3d_disposeCache(RASTER3D_Map * map)
+int Rast3d_dispose_cache(RASTER3D_Map * map)
if (!disposeCacheRead(map)) {
- Rast3d_error("Rast3d_disposeCache: error in disposeCacheRead");
+ Rast3d_error("Rast3d_dispose_cache: error in disposeCacheRead");
return 0;
return 1;
if (!disposeCacheWrite(map)) {
- Rast3d_error("Rast3d_disposeCache: error in disposeCacheWrite");
+ Rast3d_error("Rast3d_dispose_cache: error in disposeCacheWrite");
return 0;
@@ -265,8 +265,8 @@
- if (!Rast3d_writeTile(map, tileIndex, tileBuf, map->typeIntern)) {
- Rast3d_error("cacheFlushFun: error in Rast3d_writeTile");
+ if (!Rast3d_write_tile(map, tileIndex, tileBuf, map->typeIntern)) {
+ Rast3d_error("cacheFlushFun: error in Rast3d_write_tile");
return 0;
@@ -275,21 +275,21 @@
-int Rast3d_flushAllTiles(RASTER3D_Map * map)
+int Rast3d_flush_all_tiles(RASTER3D_Map * map)
int tileIndex, nBytes;
long offs;
if (!Rast3d_cache_remove_all(map->cache)) {
- Rast3d_error("Rast3d_flushAllTiles: error in Rast3d_cache_remove_all");
+ Rast3d_error("Rast3d_flush_all_tiles: error in Rast3d_cache_remove_all");
return 0;
return 1;
/* make cache write into output file instead of cache file */
- Rast3d_cache_set_removeFun(map->cache, cacheFlushFun, map);
+ Rast3d_cache_set_remove_fun(map->cache, cacheFlushFun, map);
/* first flush all the tiles which are in the file cache */
@@ -299,32 +299,32 @@
offs = map->cachePosLast * (nBytes + sizeof(int)) + nBytes;
if (lseek(map->cacheFD, offs, SEEK_SET) == -1) {
- Rast3d_error("Rast3d_flushAllTiles: can't position file");
+ Rast3d_error("Rast3d_flush_all_tiles: can't position file");
return 0;
if (read(map->cacheFD, &tileIndex, sizeof(int)) != sizeof(int)) {
- Rast3d_error("Rast3d_flushAllTiles: can't read file");
+ Rast3d_error("Rast3d_flush_all_tiles: can't read file");
return 0;
if (!Rast3d_cache_load(map->cache, tileIndex)) {
- Rast3d_error("Rast3d_flushAllTiles: error in Rast3d_cache_load");
+ Rast3d_error("Rast3d_flush_all_tiles: error in Rast3d_cache_load");
return 0;
if (!Rast3d_cache_flush(map->cache, tileIndex)) {
- Rast3d_error("Rast3d_flushAllTiles: error in Rast3d_cache_flush");
+ Rast3d_error("Rast3d_flush_all_tiles: error in Rast3d_cache_flush");
return 0;
/* then flush all the tiles which remain in the non-file cache */
if (!Rast3d_cache_flush_all(map->cache)) {
- Rast3d_error("Rast3d_flushAllTiles: error in Rast3d_cache_flush_all");
+ Rast3d_error("Rast3d_flush_all_tiles: error in Rast3d_cache_flush_all");
return 0;
/* now the cache should write into the cache file again */
- Rast3d_cache_set_removeFun(map->cache, cacheWrite_writeFun, map);
+ Rast3d_cache_set_remove_fun(map->cache, cacheWrite_writeFun, map);
return 1;
Modified: grass/trunk/lib/raster3d/cache1.c
--- grass/trunk/lib/raster3d/cache1.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/cache1.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -135,7 +135,7 @@
void
-Rast3d_cache_set_removeFun(RASTER3D_cache * c, int (*eltRemoveFun) (),
+Rast3d_cache_set_remove_fun(RASTER3D_cache * c, int (*eltRemoveFun) (),
void *eltRemoveFunData)
c->eltRemoveFun = eltRemoveFun;
@@ -145,7 +145,7 @@
void
-Rast3d_cache_set_loadFun(RASTER3D_cache * c, int (*eltLoadFun) (),
+Rast3d_cache_set_load_fun(RASTER3D_cache * c, int (*eltLoadFun) (),
void *eltLoadFunData)
c->eltLoadFun = eltLoadFun;
@@ -166,7 +166,7 @@
static void cache_queue_dequeue(RASTER3D_cache * c, int index)
if (IS_NOT_IN_QUEUE_ELT(index))
- Rast3d_fatalError("cache_queue_dequeue: index not in queue");
+ Rast3d_fatal_error("cache_queue_dequeue: index not in queue");
if (index == c->first)
c->first = c->next[index];
@@ -186,18 +186,18 @@
static void cache_queue_enqueue(RASTER3D_cache * c, int left, int index)
if (IS_IN_QUEUE_ELT(index))
- Rast3d_fatalError("cache_queue_enqueue: index already in queue");
+ Rast3d_fatal_error("cache_queue_enqueue: index already in queue");
if (c->first == -1) {
if (left != c->last)
- Rast3d_fatalError("cache_queue_enqueue: position out of range");
+ Rast3d_fatal_error("cache_queue_enqueue: position out of range");
c->first = c->last = index;
return;
if (IS_NOT_IN_QUEUE_ELT(left))
- Rast3d_fatalError("cache_queue_enqueue: position not in queue");
+ Rast3d_fatal_error("cache_queue_enqueue: position not in queue");
if (left == -1) {
@@ -359,7 +359,7 @@
-void Rast3d_cache_set_minUnlock(RASTER3D_cache * c, int nofMinUnLocked)
+void Rast3d_cache_set_min_unlock(RASTER3D_cache * c, int nofMinUnLocked)
c->minUnlocked = nofMinUnLocked;
Modified: grass/trunk/lib/raster3d/cachehash.c
--- grass/trunk/lib/raster3d/cachehash.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/cachehash.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -77,10 +77,10 @@
void Rast3d_cache_hash_remove_name(Rast3d_cache_hash * h, int name)
if (name >= h->nofNames)
- Rast3d_fatalError("Rast3d_cache_hash_remove_name: name out of range");
+ Rast3d_fatal_error("Rast3d_cache_hash_remove_name: name out of range");
if (h->active[name] == 0)
- Rast3d_fatalError("Rast3d_cache_hash_remove_name: name not in hashtable");
+ Rast3d_fatal_error("Rast3d_cache_hash_remove_name: name not in hashtable");
h->active[name] = 0;
if (name == h->lastName)
@@ -92,10 +92,10 @@
void Rast3d_cache_hash_load_name(Rast3d_cache_hash * h, int name, int index)
- Rast3d_fatalError("Rast3d_cache_hash_load_name: name out of range");
+ Rast3d_fatal_error("Rast3d_cache_hash_load_name: name out of range");
if (h->active[name] != 0)
- Rast3d_fatalError("Rast3d_cache_hash_load_name: name already in hashtable");
+ Rast3d_fatal_error("Rast3d_cache_hash_load_name: name already in hashtable");
h->index[name] = index;
h->active[name] = 1;
Modified: grass/trunk/lib/raster3d/cats.c
--- grass/trunk/lib/raster3d/cats.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/cats.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -26,7 +26,7 @@
* \return int
-int Rast3d_writeCats(const char *name, struct Categories *cats)
+int Rast3d_write_cats(const char *name, struct Categories *cats)
/* adapted from Rast_write_cats */
FILE *fd;
@@ -176,7 +176,7 @@
int
-Rast3d_readCats(const char *name, const char *mapset, struct Categories *pcats)
+Rast3d_read_cats(const char *name, const char *mapset, struct Categories *pcats)
/* adapted from Rast_read_cats */
const char *type;
Modified: grass/trunk/lib/raster3d/changeprecision.c
--- grass/trunk/lib/raster3d/changeprecision.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/changeprecision.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -20,7 +20,7 @@
* \return void
-void Rast3d_changePrecision(void *map, int precision, const char *nameOut)
+void Rast3d_change_precision(void *map, int precision, const char *nameOut)
void *map2;
int x, y, z, savePrecision, saveCompression, saveLzw, saveRle;
@@ -30,47 +30,47 @@
int nx, ny, nz;
int tileXsave, tileYsave, tileZsave, tileX, tileY, tileZ, saveType;
- saveType = Rast3d_getFileType();
- /* Rast3d_setFileType (Rast3d_fileTypeMap (map)); */
- Rast3d_getCompressionMode(&saveCompression, &saveLzw, &saveRle,
+ saveType = Rast3d_get_file_type();
+ /* Rast3d_set_file_type (Rast3d_file_type_map (map)); */
+ Rast3d_get_compression_mode(&saveCompression, &saveLzw, &saveRle,
&savePrecision);
- Rast3d_setCompressionMode(RASTER3D_COMPRESSION, saveLzw, saveRle, precision);
- Rast3d_getTileDimension(&tileXsave, &tileYsave, &tileZsave);
- Rast3d_getTileDimensionsMap(map, &tileX, &tileY, &tileZ);
- Rast3d_setTileDimension(tileX, tileY, tileZ);
+ Rast3d_set_compression_mode(RASTER3D_COMPRESSION, saveLzw, saveRle, precision);
+ Rast3d_get_tile_dimension(&tileXsave, &tileYsave, &tileZsave);
+ Rast3d_get_tile_dimensions_map(map, &tileX, &tileY, &tileZ);
+ Rast3d_set_tile_dimension(tileX, tileY, tileZ);
- typeIntern = Rast3d_tileTypeMap(map);
- Rast3d_getRegionStructMap(map, ®ion);
+ typeIntern = Rast3d_tile_type_map(map);
+ Rast3d_get_region_struct_map(map, ®ion);
map2 =
- Rast3d_openCellNew(nameOut, typeIntern, RASTER3D_USE_CACHE_DEFAULT, ®ion);
+ Rast3d_open_cell_new(nameOut, typeIntern, RASTER3D_USE_CACHE_DEFAULT, ®ion);
if (map2 == NULL)
- Rast3d_fatalError("Rast3d_changePrecision: error in Rast3d_openCellNew");
+ Rast3d_fatal_error("Rast3d_change_precision: error in Rast3d_open_cell_new");
- Rast3d_setFileType(saveType);
- Rast3d_setCompressionMode(saveCompression, saveLzw, saveRle, savePrecision);
- Rast3d_setTileDimension(tileXsave, tileYsave, tileZsave);
+ Rast3d_set_file_type(saveType);
+ Rast3d_set_compression_mode(saveCompression, saveLzw, saveRle, savePrecision);
+ Rast3d_set_tile_dimension(tileXsave, tileYsave, tileZsave);
- data = Rast3d_allocTiles(map, 1);
+ data = Rast3d_alloc_tiles(map, 1);
if (data == NULL)
- Rast3d_fatalError("Rast3d_changePrecision: error in Rast3d_allocTiles");
- Rast3d_getNofTilesMap(map2, &nx, &ny, &nz);
+ Rast3d_fatal_error("Rast3d_change_precision: error in Rast3d_alloc_tiles");
+ Rast3d_get_nof_tiles_map(map2, &nx, &ny, &nz);
for (z = 0; z < nz; z++)
for (y = 0; y < ny; y++)
for (x = 0; x < nx; x++) {
- if (!Rast3d_readTile(map, Rast3d_tile2tileIndex(map, x, y, z), data,
+ if (!Rast3d_read_tile(map, Rast3d_tile2tile_index(map, x, y, z), data,
typeIntern))
- Rast3d_fatalError
- ("Rast3d_changePrecision: error in Rast3d_readTile");
- (map2, Rast3d_tile2tileIndex(map2, x, y, z), data,
+ ("Rast3d_change_precision: error in Rast3d_read_tile");
+ (map2, Rast3d_tile2tile_index(map2, x, y, z), data,
typeIntern))
- Rast3d_fatalError
- ("Rast3d_changePrecision: error in Rast3d_writeTile");
+ ("Rast3d_change_precision: error in Rast3d_write_tile");
- Rast3d_freeTiles(data);
- if (!Rast3d_closeCell(map2))
- Rast3d_fatalError("Rast3d_changePrecision: error in Rast3d_closeCell");
+ Rast3d_free_tiles(data);
+ if (!Rast3d_close_cell(map2))
+ Rast3d_fatal_error("Rast3d_change_precision: error in Rast3d_close_cell");
Modified: grass/trunk/lib/raster3d/changetype.c
--- grass/trunk/lib/raster3d/changetype.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/changetype.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -21,7 +21,7 @@
* \return void
-void Rast3d_changeType(void *map, const char *nameOut)
+void Rast3d_change_type(void *map, const char *nameOut)
void *map2;
int x, y, z, saveType;
@@ -31,51 +31,51 @@
int tileX, tileY, tileZ, typeIntern, typeIntern2;
int tileXsave, tileYsave, tileZsave, nx, ny, nz;
- Rast3d_setFileType(Rast3d_fileTypeMap(map) == FCELL_TYPE ?
+ Rast3d_set_file_type(Rast3d_file_type_map(map) == FCELL_TYPE ?
DCELL_TYPE : FCELL_TYPE);
map2 =
- Rast3d_openCellNew(nameOut, FCELL_TYPE, RASTER3D_USE_CACHE_DEFAULT, ®ion);
+ Rast3d_open_cell_new(nameOut, FCELL_TYPE, RASTER3D_USE_CACHE_DEFAULT, ®ion);
if (map2 == NULL)
- Rast3d_fatalError("Rast3d_changeType: error in Rast3d_openCellNew");
+ Rast3d_fatal_error("Rast3d_change_type: error in Rast3d_open_cell_new");
if (data == NULL)
- Rast3d_fatalError("Rast3d_changeType: error in Rast3d_allocTiles");
- data2 = Rast3d_allocTiles(map2, 1);
+ Rast3d_fatal_error("Rast3d_change_type: error in Rast3d_alloc_tiles");
+ data2 = Rast3d_alloc_tiles(map2, 1);
if (data2 == NULL)
- typeIntern2 = Rast3d_tileTypeMap(map2);
+ typeIntern2 = Rast3d_tile_type_map(map2);
tileSize = tileX * tileY * tileZ;
typeIntern))
- Rast3d_fatalError("Rast3d_changeType: error in Rast3d_readTile");
- Rast3d_copyValues(data, 0, typeIntern, data2, 0, typeIntern2,
+ Rast3d_fatal_error("Rast3d_change_type: error in Rast3d_read_tile");
+ Rast3d_copy_values(data, 0, typeIntern, data2, 0, typeIntern2,
tileSize);
- (map2, Rast3d_tile2tileIndex(map2, x, y, z), data2,
+ (map2, Rast3d_tile2tile_index(map2, x, y, z), data2,
typeIntern2))
- Rast3d_fatalError("Rast3d_changeType: error in Rast3d_writeTile");
+ Rast3d_fatal_error("Rast3d_change_type: error in Rast3d_write_tile");
- Rast3d_freeTiles(data2);
- Rast3d_fatalError("Rast3d_changeType: error in Rast3d_closeCell");
+ Rast3d_free_tiles(data2);
+ Rast3d_fatal_error("Rast3d_change_type: error in Rast3d_close_cell");
Modified: grass/trunk/lib/raster3d/close.c
--- grass/trunk/lib/raster3d/close.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/close.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -18,11 +18,11 @@
struct Categories cats;
struct History hist;
- Rast3d_removeColor(map->fileName);
+ Rast3d_remove_color(map->fileName);
/* create empty cats file */
Rast_init_cats(NULL, &cats);
- Rast3d_writeCats(map->fileName, &cats);
+ Rast3d_write_cats(map->fileName, &cats);
Rast_free_cats(&cats);
/*genrate the history file, use the normal G_ functions */
@@ -30,7 +30,7 @@
Rast_command_history(&hist);
/*Use the G3d function to write the history file,
* otherwise the path is wrong */
- if (!Rast3d_writeHistory(map->fileName, &hist)) {
+ if (!Rast3d_write_history(map->fileName, &hist)) {
Rast3d_error("Rast3d_closeNew: can't write raster3d history");
@@ -66,13 +66,13 @@
long ltmp;
if (map->useCache)
- if (!Rast3d_flushAllTiles(map)) {
- Rast3d_error("Rast3d_closeCellNew: error in Rast3d_flushAllTiles");
+ if (!Rast3d_flush_all_tiles(map)) {
+ Rast3d_error("Rast3d_closeCellNew: error in Rast3d_flush_all_tiles");
return 0;
- if (!Rast3d_flushIndex(map)) {
- Rast3d_error("Rast3d_closeCellNew: error in Rast3d_flushIndex");
+ if (!Rast3d_flush_index(map)) {
+ Rast3d_error("Rast3d_closeCellNew: error in Rast3d_flush_index");
return 0;
@@ -86,12 +86,12 @@
return 0;
- if (!Rast3d_writeInts(map->data_fd, map->useXdr, &(map->indexNbytesUsed), 1)) {
+ if (!Rast3d_write_ints(map->data_fd, map->useXdr, &(map->indexNbytesUsed), 1)) {
Rast3d_error("Rast3d_closeCellNew: can't write header");
return 0;
- Rast3d_longEncode(&(map->indexOffset), (unsigned char *)<mp, 1);
+ Rast3d_long_encode(&(map->indexOffset), (unsigned char *)<mp, 1);
if (write(map->data_fd, <mp, sizeof(long)) != sizeof(long)) {
return 0;
@@ -144,17 +144,17 @@
* 0 ... otherwise.
-int Rast3d_closeCell(RASTER3D_Map * map)
+int Rast3d_close_cell(RASTER3D_Map * map)
if (map->operation == RASTER3D_WRITE_DATA) {
if (!Rast3d_closeCellNew(map)) {
- Rast3d_error("Rast3d_closeCell: error in Rast3d_closeCellNew");
+ Rast3d_error("Rast3d_close_cell: error in Rast3d_closeCellNew");
return 0;
else {
if (!Rast3d_closeCellOld(map) != 0) {
- Rast3d_error("Rast3d_closeCell: error in Rast3d_closeCellOld");
+ Rast3d_error("Rast3d_close_cell: error in Rast3d_closeCellOld");
return 0;
@@ -163,8 +163,8 @@
Rast3d_free(map->tileLength);
if (map->useCache) {
- if (!Rast3d_disposeCache(map)) {
- Rast3d_error("Rast3d_closeCell: error in Rast3d_disposeCache");
+ if (!Rast3d_dispose_cache(map)) {
+ Rast3d_error("Rast3d_close_cell: error in Rast3d_dispose_cache");
return 0;
@@ -172,7 +172,7 @@
Rast3d_free(map->data);
- if (!Rast3d_writeHeader(map,
+ if (!Rast3d_write_header(map,
map->region.proj, map->region.zone,
map->region.north, map->region.south,
map->region.east, map->region.west,
@@ -186,7 +186,7 @@
map->compression, map->useRle, map->useLzw,
map->precision, map->offset, map->useXdr,
map->hasIndex, map->unit)) {
- Rast3d_error("Rast3d_closeCell: error in Rast3d_writeHeader");
+ Rast3d_error("Rast3d_close_cell: error in Rast3d_write_header");
return 0;
Modified: grass/trunk/lib/raster3d/color.c
--- grass/trunk/lib/raster3d/color.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/color.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -19,7 +19,7 @@
-int Rast3d_removeColor(const char *name)
+int Rast3d_remove_color(const char *name)
/* adapted from G_remove_colr */
return G_remove_misc(RASTER3D_DIRECTORY, RASTER3D_COLOR_ELEMENT, name);
@@ -28,7 +28,7 @@
int
-Rast3d_readColors(const char *name, const char *mapset, struct Colors *colors)
+Rast3d_read_colors(const char *name, const char *mapset, struct Colors *colors)
/* adapted from Rast_read_colors */
const char *err;
@@ -41,7 +41,7 @@
switch (read_colors(name, mapset, colors)) {
case -2:
- if (Rast3d_readRange(name, mapset, &drange) >= 0) {
+ if (Rast3d_read_range(name, mapset, &drange) >= 0) {
Rast_get_fp_range_min_max(&drange, &dmin, &dmax);
if (!Rast_is_d_null_value(&dmin) && !Rast_is_d_null_value(&dmax))
Rast_make_rainbow_fp_colors(colors, dmin, dmax);
@@ -324,7 +324,7 @@
int
-Rast3d_writeColors(const char *name, const char *mapset, struct Colors *colors)
+Rast3d_write_colors(const char *name, const char *mapset, struct Colors *colors)
/* adapted from Rast_write_colors */
FILE *fd;
Modified: grass/trunk/lib/raster3d/defaults.c
--- grass/trunk/lib/raster3d/defaults.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/defaults.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -17,7 +17,7 @@
#define RASTER3D_TILE_X_DEFAULT 16
#define RASTER3D_TILE_Y_DEFAULT 16
#define RASTER3D_TILE_Z_DEFAULT 8
-#define RASTER3D_ERROR_FUN_DEFAULT Rast3d_skipError
+#define RASTER3D_ERROR_FUN_DEFAULT Rast3d_skip_error
#define RASTER3D_UNIT_DEFAULT "none"
@@ -82,10 +82,10 @@
void
-Rast3d_setCompressionMode(int doCompress, int doLzw, int doRle, int precision)
+Rast3d_set_compression_mode(int doCompress, int doLzw, int doRle, int precision)
if ((doCompress != RASTER3D_NO_COMPRESSION) && (doCompress != RASTER3D_COMPRESSION))
- Rast3d_fatalError("Rast3d_setCompressionMode: wrong value for doCompress.");
+ Rast3d_fatal_error("Rast3d_set_compression_mode: wrong value for doCompress.");
g3d_do_compression = doCompress;
@@ -93,13 +93,13 @@
return;
if ((doLzw != RASTER3D_NO_LZW) && (doLzw != RASTER3D_USE_LZW))
- Rast3d_fatalError("Rast3d_setCompressionMode: wrong value for doLzw.");
+ Rast3d_fatal_error("Rast3d_set_compression_mode: wrong value for doLzw.");
if ((doRle != RASTER3D_NO_RLE) && (doRle != RASTER3D_USE_RLE))
- Rast3d_fatalError("Rast3d_setCompressionMode: wrong value for doRle.");
+ Rast3d_fatal_error("Rast3d_set_compression_mode: wrong value for doRle.");
if (precision < -1)
- Rast3d_fatalError("Rast3d_setCompressionMode: wrong value for precision.");
+ Rast3d_fatal_error("Rast3d_set_compression_mode: wrong value for precision.");
g3d_do_lzw_compression = doLzw;
g3d_do_rle_compression = doRle;
@@ -122,7 +122,7 @@
void
-Rast3d_getCompressionMode(int *doCompress, int *doLzw, int *doRle,
+Rast3d_get_compression_mode(int *doCompress, int *doLzw, int *doRle,
int *precision)
if (doCompress != NULL)
@@ -147,10 +147,10 @@
* \return void
-void Rast3d_setCacheSize(int nTiles)
+void Rast3d_set_cache_size(int nTiles)
if (nTiles < 0)
- Rast3d_fatalError("Rast3d_setCacheSize: size out of range.");
+ Rast3d_fatal_error("Rast3d_set_cache_size: size out of range.");
g3d_cache_default = nTiles;
@@ -166,7 +166,7 @@
* \return int
-int Rast3d_getCacheSize()
+int Rast3d_get_cache_size()
return g3d_cache_default;
@@ -183,10 +183,10 @@
* \return void
-void Rast3d_setCacheLimit(int nBytes)
+void Rast3d_set_cache_limit(int nBytes)
if (nBytes <= 0)
- Rast3d_fatalError("Rast3d_setCacheLimit: size out of range.");
+ Rast3d_fatal_error("Rast3d_set_cache_limit: size out of range.");
g3d_cache_max = nBytes;
@@ -203,7 +203,7 @@
* \return int
-int Rast3d_getCacheLimit()
+int Rast3d_get_cache_limit()
return g3d_cache_max;
@@ -220,10 +220,10 @@
* \return void
-void Rast3d_setFileType(int type)
+void Rast3d_set_file_type(int type)
if ((type != FCELL_TYPE) && (type != DCELL_TYPE))
- Rast3d_fatalError("Rast3d_setFileTypeDefault: invalid type");
+ Rast3d_fatal_error("Rast3d_setFileTypeDefault: invalid type");
g3d_file_type = type;
@@ -240,7 +240,7 @@
* \return int
-int Rast3d_getFileType()
+int Rast3d_get_file_type()
return g3d_file_type;
@@ -259,19 +259,19 @@
* \return void
-void Rast3d_setTileDimension(int tileX, int tileY, int tileZ)
+void Rast3d_set_tile_dimension(int tileX, int tileY, int tileZ)
if ((g3d_tile_dimension[0] = tileX) <= 0)
- Rast3d_fatalError
- ("Rast3d_setTileDimension: value for tile x environment variable out of range");
+ ("Rast3d_set_tile_dimension: value for tile x environment variable out of range");
if ((g3d_tile_dimension[1] = tileY) <= 0)
- Rast3d_fatalError
- ("Rast3d_setTileDimension: value for tile y environment variable out of range");
+ ("Rast3d_set_tile_dimension: value for tile y environment variable out of range");
if ((g3d_tile_dimension[2] = tileZ) <= 0)
- Rast3d_fatalError
- ("Rast3d_setTileDimension: value for tile z environment variable out of range");
+ ("Rast3d_set_tile_dimension: value for tile z environment variable out of range");
@@ -288,7 +288,7 @@
* \return void
-void Rast3d_getTileDimension(int *tileX, int *tileY, int *tileZ)
+void Rast3d_get_tile_dimension(int *tileX, int *tileY, int *tileZ)
*tileX = g3d_tile_dimension[0];
*tileY = g3d_tile_dimension[1];
@@ -307,7 +307,7 @@
* \return void
-void Rast3d_setErrorFun(void (*fun) (const char *))
+void Rast3d_set_error_fun(void (*fun) (const char *))
g3d_error_fun = fun;
@@ -324,7 +324,7 @@
* \return void
-void Rast3d_setUnit(const char *unit)
+void Rast3d_set_unit(const char *unit)
Rast3d_free(g3d_unit_default);
g3d_unit_default = G_store(unit);
@@ -344,7 +344,7 @@
* \return void
static int firstTime = 1;
const char *value, *windowName;
@@ -407,13 +407,13 @@
else {
if (sscanf(value, "%d", &g3d_precision) != 1) {
- Rast3d_fatalError
- ("Rast3d_initDefaults: precision environment variable has invalid value");
+ ("Rast3d_init_defaults: precision environment variable has invalid value");
else {
if (g3d_precision < -1) {
- Rast3d_fatalError
- ("Rast3d_initDefaults: value for cache environment variable out of range");
+ ("Rast3d_init_defaults: value for cache environment variable out of range");
@@ -442,12 +442,12 @@
else {
if (sscanf(value, "%d", &g3d_cache_default) != 1) {
- Rast3d_fatalError
- ("Rast3d_initDefaults: cache environment variable has invalid value");
+ ("Rast3d_init_defaults: cache environment variable has invalid value");
if (g3d_cache_default < 0) {
- Rast3d_fatalError
@@ -460,12 +460,12 @@
else {
if (sscanf(value, "%d", &g3d_cache_max) != 1) {
- Rast3d_fatalError
if (g3d_cache_max < 0) {
- Rast3d_fatalError
@@ -478,12 +478,12 @@
else {
if (sscanf(value, "%d", g3d_tile_dimension) != 1) {
- Rast3d_fatalError
- ("Rast3d_initDefaults: tile dimension x environment variable has invalid value");
+ ("Rast3d_init_defaults: tile dimension x environment variable has invalid value");
if (g3d_tile_dimension[0] <= 0) {
- Rast3d_fatalError
- ("Rast3d_initDefaults: value for tile x environment variable out of range");
+ ("Rast3d_init_defaults: value for tile x environment variable out of range");
@@ -494,12 +494,12 @@
else {
if (sscanf(value, "%d", g3d_tile_dimension + 1) != 1) {
- Rast3d_fatalError
- ("Rast3d_initDefaults: tile dimension y environment variable has invalid value");
+ ("Rast3d_init_defaults: tile dimension y environment variable has invalid value");
if (g3d_tile_dimension[1] <= 0) {
- Rast3d_fatalError
- ("Rast3d_initDefaults: value for tile y environment variable out of range");
+ ("Rast3d_init_defaults: value for tile y environment variable out of range");
@@ -510,12 +510,12 @@
else {
if (sscanf(value, "%d", g3d_tile_dimension + 2) != 1) {
- Rast3d_fatalError
- ("Rast3d_initDefaults: tile dimension z environment variable has invalid value");
+ ("Rast3d_init_defaults: tile dimension z environment variable has invalid value");
if (g3d_tile_dimension[2] <= 0) {
- Rast3d_fatalError
- ("Rast3d_initDefaults: value for tile z environment variable out of range");
+ ("Rast3d_init_defaults: value for tile z environment variable out of range");
@@ -524,13 +524,13 @@
value = getenv(RASTER3D_FATAL_ERROR_ENV_VAR);
if (value != NULL) {
- g3d_error_fun = Rast3d_fatalError_noargs;
+ g3d_error_fun = Rast3d_fatal_error_noargs;
else {
value = getenv(RASTER3D_PRINT_ERROR_ENV_VAR);
- g3d_error_fun = Rast3d_printError;
+ g3d_error_fun = Rast3d_print_error;
else {
g3d_error_fun = RASTER3D_ERROR_FUN_DEFAULT;
@@ -541,7 +541,7 @@
if (g3d_unit_default == NULL)
g3d_unit_default = G_store(RASTER3D_UNIT_DEFAULT);
- windowName = Rast3d_getWindowParams();
+ windowName = Rast3d_get_window_params();
if (windowName == NULL) {
value = getenv(RASTER3D_DEFAULT_WINDOW3D);
if (value != NULL)
@@ -549,8 +549,8 @@
windowName = value;
- if (!Rast3d_readWindow(&window, windowName))
- Rast3d_fatalError("Rast3d_initDefaults: Error reading window");
- Rast3d_setWindow(&window);
+ if (!Rast3d_read_window(&window, windowName))
+ Rast3d_fatal_error("Rast3d_init_defaults: Error reading window");
+ Rast3d_set_window(&window);
Modified: grass/trunk/lib/raster3d/doubleio.c
--- grass/trunk/lib/raster3d/doubleio.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/doubleio.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -8,7 +8,7 @@
-int Rast3d_writeDoubles(int fd, int useXdr, const double *i, int nofNum)
+int Rast3d_write_doubles(int fd, int useXdr, const double *i, int nofNum)
int firstTime = 1;
XDR xdrEncodeStream;
@@ -16,11 +16,11 @@
u_int n;
if (nofNum <= 0)
- Rast3d_fatalError("Rast3d_writeDoubles: nofNum out of range");
+ Rast3d_fatal_error("Rast3d_write_doubles: nofNum out of range");
if (useXdr == RASTER3D_NO_XDR) {
if (write(fd, i, sizeof(double) * nofNum) != sizeof(double) * nofNum) {
- Rast3d_error("Rast3d_writeDoubles: writing to file failed");
+ Rast3d_error("Rast3d_write_doubles: writing to file failed");
return 0;
else {
@@ -41,19 +41,19 @@
n = 1024;
if (!xdr_setpos(&xdrEncodeStream, 0)) {
- Rast3d_error("Rast3d_writeDoubles: positioning xdr failed");
+ Rast3d_error("Rast3d_write_doubles: positioning xdr failed");
return 0;
if (!xdr_vector(&xdrEncodeStream, (char *)i, n, sizeof(double),
(xdrproc_t) xdr_double)) {
- Rast3d_error("Rast3d_writeDoubles: writing xdr failed");
+ Rast3d_error("Rast3d_write_doubles: writing xdr failed");
return 0;
if (write(fd, xdrDoubleBuf, RASTER3D_XDR_DOUBLE_LENGTH * n) !=
RASTER3D_XDR_DOUBLE_LENGTH * n) {
- Rast3d_error("Rast3d_writeDoubles: writing xdr to file failed");
+ Rast3d_error("Rast3d_write_doubles: writing xdr to file failed");
return 0;
@@ -66,7 +66,7 @@
-int Rast3d_readDoubles(int fd, int useXdr, double *i, int nofNum)
+int Rast3d_read_doubles(int fd, int useXdr, double *i, int nofNum)
int firstTime = 1;
XDR xdrDecodeStream;
@@ -74,11 +74,11 @@
u_int n;
if (nofNum <= 0)
- Rast3d_fatalError("Rast3d_readDoubles: nofNum out of range");
+ Rast3d_fatal_error("Rast3d_read_doubles: nofNum out of range");
if (read(fd, i, sizeof(double) * nofNum) != sizeof(double) * nofNum) {
- Rast3d_error("Rast3d_readDoubles: reading from file failed");
+ Rast3d_error("Rast3d_read_doubles: reading from file failed");
return 0;
else {
@@ -99,18 +99,18 @@
if (read(fd, xdrDoubleBuf, RASTER3D_XDR_DOUBLE_LENGTH * n) !=
- Rast3d_error("Rast3d_readDoubles: reading xdr from file failed");
+ Rast3d_error("Rast3d_read_doubles: reading xdr from file failed");
return 0;
if (!xdr_setpos(&xdrDecodeStream, 0)) {
- Rast3d_error("Rast3d_readDoubles: positioning xdr failed");
+ Rast3d_error("Rast3d_read_doubles: positioning xdr failed");
return 0;
if (!xdr_vector(&xdrDecodeStream, (char *)i, n, sizeof(double),
- Rast3d_error("Rast3d_readDoubles: reading xdr failed");
+ Rast3d_error("Rast3d_read_doubles: reading xdr failed");
return 0;
Modified: grass/trunk/lib/raster3d/error.c
--- grass/trunk/lib/raster3d/error.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/error.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -22,7 +22,7 @@
* \return void
-void Rast3d_skipError(const char *msg)
+void Rast3d_skip_error(const char *msg)
@@ -37,7 +37,7 @@
* \return void
-void Rast3d_printError(const char *msg)
+void Rast3d_print_error(const char *msg)
fprintf(stderr, "ERROR: ");
fprintf(stderr, msg);
@@ -55,7 +55,7 @@
* \return void
-void Rast3d_fatalError(const char *msg, ...)
+void Rast3d_fatal_error(const char *msg, ...)
char buffer[2000]; /* No novels to the error logs, OK? */
va_list ap;
@@ -67,7 +67,7 @@
G_fatal_error("%s", buffer);
-void Rast3d_fatalError_noargs(const char *msg)
+void Rast3d_fatal_error_noargs(const char *msg)
G_fatal_error("%s", msg);
Modified: grass/trunk/lib/raster3d/filecompare.c
--- grass/trunk/lib/raster3d/filecompare.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/filecompare.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -20,10 +20,10 @@
xdrmem_create(&xdrEncodeStream, (caddr_t) xdrf, 4, XDR_ENCODE);
- Rast3d_fatalError("Rast3d_float2xdrFloat: positioning xdr failed");
+ Rast3d_fatal_error("Rast3d_float2xdrFloat: positioning xdr failed");
if (!xdr_float(&xdrEncodeStream, f))
- Rast3d_fatalError("Rast3d_float2xdrFloat: writing xdr failed");
+ Rast3d_fatal_error("Rast3d_float2xdrFloat: writing xdr failed");
xdr_destroy(&xdrEncodeStream);
@@ -37,10 +37,10 @@
xdrmem_create(&xdrEncodeStream, (caddr_t) xdrd, 8, XDR_ENCODE);
- Rast3d_fatalError("Rast3d_double2xdrDouble: positioning xdr failed");
+ Rast3d_fatal_error("Rast3d_double2xdrDouble: positioning xdr failed");
if (!xdr_double(&xdrEncodeStream, d))
- Rast3d_fatalError("Rast3d_double2xdrDouble: writing xdr failed");
+ Rast3d_fatal_error("Rast3d_double2xdrDouble: writing xdr failed");
@@ -196,8 +196,8 @@
unsigned char *c1, *c2;
float xdrf1, xdrf2;
- if (Rast3d_isNullValueNum(f1, FCELL_TYPE))
- return Rast3d_isNullValueNum(f2, FCELL_TYPE);
+ if (Rast3d_is_null_value_num(f1, FCELL_TYPE))
+ return Rast3d_is_null_value_num(f2, FCELL_TYPE);
Rast3d_float2xdrFloat(f1, &xdrf1);
Rast3d_float2xdrFloat(f2, &xdrf2);
@@ -227,8 +227,8 @@
double xdrd1, xdrd2;
- if (Rast3d_isNullValueNum(d1, DCELL_TYPE))
- return Rast3d_isNullValueNum(d2, DCELL_TYPE);
+ if (Rast3d_is_null_value_num(d1, DCELL_TYPE))
+ return Rast3d_is_null_value_num(d2, DCELL_TYPE);
Rast3d_double2xdrDouble(d1, &xdrd1);
Rast3d_double2xdrDouble(d2, &xdrd2);
@@ -261,8 +261,8 @@
float xdrf, fTmp;
double xdrd, xdrd2, dTmp;
- if (Rast3d_isNullValueNum(f, FCELL_TYPE))
- return Rast3d_isNullValueNum(d, DCELL_TYPE);
+ if (Rast3d_is_null_value_num(f, FCELL_TYPE))
+ return Rast3d_is_null_value_num(d, DCELL_TYPE);
/* need this since assigning a double to a float actually may change the */
/* bit pattern. an example (in xdr format) is the double */
@@ -309,13 +309,13 @@
int nx, ny, nz;
- p1 = Rast3d_tilePrecisionMap(map);
- p2 = Rast3d_tilePrecisionMap(map2);
+ p1 = Rast3d_tile_precision_map(map);
+ p2 = Rast3d_tile_precision_map(map2);
n1p = &n1;
f1p = (float *)&n1;
@@ -328,8 +328,8 @@
for (y = 0; y < ny * tileY; y++) {
for (x = 0; x < nx * tileX; x++) {
- Rast3d_getBlock(map, x, y, z, 1, 1, 1, n1p, typeIntern);
- Rast3d_getBlock(map2, x, y, z, 1, 1, 1, n2p, typeIntern2);
+ Rast3d_get_block(map, x, y, z, 1, 1, 1, n1p, typeIntern);
+ Rast3d_get_block(map2, x, y, z, 1, 1, 1, n2p, typeIntern2);
if (typeIntern == FCELL_TYPE) {
if (typeIntern2 == FCELL_TYPE)
@@ -347,12 +347,12 @@
if (!correct) {
int xTile, yTile, zTile, xOffs, yOffs, zOffs;
- Rast3d_coord2tileCoord(map2, x, y, z, &xTile, &yTile, &zTile,
+ Rast3d_coord2tile_coord(map2, x, y, z, &xTile, &yTile, &zTile,
&xOffs, &yOffs, &zOffs);
printf("(%d %d %d) (%d %d %d) (%d %d %d) %.20f %.20f\n",
x, y, z, xTile, yTile, zTile, xOffs, yOffs, zOffs,
*n1p, *n2p);
- Rast3d_fatalError
("compareFilesNocache: files don't match\n");
@@ -383,7 +383,7 @@
void
-Rast3d_compareFiles(const char *f1, const char *mapset1, const char *f2,
+Rast3d_compare_files(const char *f1, const char *mapset1, const char *f2,
const char *mapset2)
void *map, *map2;
@@ -398,35 +398,35 @@
printf("\nComparing %s and %s\n", f1, f2);
- map = Rast3d_openCellOld(f1, mapset1, RASTER3D_DEFAULT_WINDOW,
+ map = Rast3d_open_cell_old(f1, mapset1, RASTER3D_DEFAULT_WINDOW,
if (map == NULL)
- Rast3d_fatalError("Rast3d_compareFiles: error in Rast3d_openCellOld");
+ Rast3d_fatal_error("Rast3d_compare_files: error in Rast3d_open_cell_old");
- Rast3d_printHeader(map);
+ Rast3d_print_header(map);
- map2 = Rast3d_openCellOld(f2, mapset2, RASTER3D_DEFAULT_WINDOW,
+ map2 = Rast3d_open_cell_old(f2, mapset2, RASTER3D_DEFAULT_WINDOW,
if (map2 == NULL)
- Rast3d_printHeader(map2);
+ Rast3d_print_header(map2);
- Rast3d_getTileDimensionsMap(map2, &tileX2, &tileY2, &tileZ2);
- Rast3d_getCoordsMap(map, &rows, &cols, &depths);
+ Rast3d_get_tile_dimensions_map(map2, &tileX2, &tileY2, &tileZ2);
+ Rast3d_get_coords_map(map, &rows, &cols, &depths);
- if ((!Rast3d_tileUseCacheMap(map)) || (!Rast3d_tileUseCacheMap(map2))) {
+ if ((!Rast3d_tile_use_cache_map(map)) || (!Rast3d_tile_use_cache_map(map2))) {
compareFilesNocache(map, map2);
- Rast3d_closeCell(map);
- Rast3d_closeCell(map2);
+ Rast3d_close_cell(map);
+ Rast3d_close_cell(map2);
return;
@@ -435,33 +435,33 @@
n2p = &n2;
f2p = (float *)&n2;
- Rast3d_autolockOn(map);
- Rast3d_autolockOn(map2);
- Rast3d_minUnlocked(map, cols / tileX + 1);
+ Rast3d_autolock_on(map);
+ Rast3d_autolock_on(map2);
+ Rast3d_min_unlocked(map, cols / tileX + 1);
- Rast3d_getCoordsMap(map2, &rows, &cols, &depths);
- Rast3d_minUnlocked(map2, cols / tileX + 1);
+ Rast3d_get_coords_map(map2, &rows, &cols, &depths);
+ Rast3d_min_unlocked(map2, cols / tileX + 1);
for (z = 0; z < depths; z++) {
printf("comparing: z = %d\n", z);
if ((z % tileZ) == 0) {
- if (!Rast3d_unlockAll(map))
- Rast3d_fatalError("Rast3d_compareFiles: error in Rast3d_unlockAll");
+ if (!Rast3d_unlock_all(map))
+ Rast3d_fatal_error("Rast3d_compare_files: error in Rast3d_unlock_all");
if ((z % tileZ2) == 0) {
- if (!Rast3d_unlockAll(map2))
+ if (!Rast3d_unlock_all(map2))
- Rast3d_getValueRegion(map, x, y, z, n1p, typeIntern);
- Rast3d_getValueRegion(map2, x, y, z, n2p, typeIntern2);
+ Rast3d_get_value_region(map, x, y, z, n1p, typeIntern);
+ Rast3d_get_value_region(map2, x, y, z, n2p, typeIntern2);
- Rast3d_isNullValueNum(n1p, typeIntern);
- Rast3d_isNullValueNum(n2p, typeIntern2);
+ Rast3d_is_null_value_num(n1p, typeIntern);
+ Rast3d_is_null_value_num(n2p, typeIntern2);
@@ -479,15 +479,15 @@
if (!correct) {
- Rast3d_fatalError("Rast3d_compareFiles: files don't match\n");
+ Rast3d_fatal_error("Rast3d_compare_files: files don't match\n");
printf("Files are identical up to precision.\n");
Modified: grass/trunk/lib/raster3d/fpcompress.c
--- grass/trunk/lib/raster3d/fpcompress.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/fpcompress.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -19,7 +19,7 @@
-void G_fpcompress_printBinary(char *c, int numBits)
+void Rast3d_fpcompress_print_binary(char *c, int numBits)
unsigned char bit;
int i;
@@ -34,7 +34,7 @@
-void G_fpcompress_dissectXdrDouble(unsigned char *numPointer)
+void Rast3d_fpcompress_dissect_xdr_double(unsigned char *numPointer)
char sign, exponent;
@@ -42,13 +42,13 @@
exponent = (*numPointer << 1) | (*(numPointer + 1) >> 7);
printf("%f: sign = ", *((float *)numPointer));
- G_fpcompress_printBinary(&sign, 1);
+ Rast3d_fpcompress_print_binary(&sign, 1);
printf(" exp = ");
- G_fpcompress_printBinary(&exponent, 8);
+ Rast3d_fpcompress_print_binary(&exponent, 8);
printf(" mantissa = ");
- G_fpcompress_printBinary((char *)(numPointer + 1), 7);
- G_fpcompress_printBinary((char *)(numPointer + 2), 8);
- G_fpcompress_printBinary((char *)(numPointer + 3), 8);
+ Rast3d_fpcompress_print_binary((char *)(numPointer + 1), 7);
+ Rast3d_fpcompress_print_binary((char *)(numPointer + 2), 8);
+ Rast3d_fpcompress_print_binary((char *)(numPointer + 3), 8);
printf("\n");
@@ -100,7 +100,7 @@
f = (float *)src;
nofNull = 0;
while (srcStop != (unsigned char *)f)
- nofNull += Rast3d_isXdrNullFloat(f++);
+ nofNull += Rast3d_is_xdr_null_float(f++);
if (nofNull == size) {
*dst = (unsigned char)ALL_NULL_CODE;
@@ -135,7 +135,7 @@
while (srcStop != src) {
if (nofNull) {
- isNull = Rast3d_isXdrNullFloat((float *)src);
+ isNull = Rast3d_is_xdr_null_float((float *)src);
if (nNullBits) {
*nullBits |= ((unsigned char)isNull << nNullBits++);
@@ -258,7 +258,7 @@
d = (double *)src;
nofNull = 0;
while (srcStop != (unsigned char *)d)
- nofNull += Rast3d_isXdrNullDouble(d++);
+ nofNull += Rast3d_is_xdr_null_double(d++);
@@ -300,7 +300,7 @@
if (nofNull) {
- isNull = Rast3d_isXdrNullDouble((double *)src);
+ isNull = Rast3d_is_xdr_null_double((double *)src);
if (nNullBits) {
@@ -435,7 +435,7 @@
if (*src == (unsigned char)ALL_NULL_CODE) {
f = (float *)dst;
while (dstStop != (unsigned char *)f)
- Rast3d_setXdrNullFloat(f++);
+ Rast3d_set_xdr_null_float(f++);
return;
@@ -485,7 +485,7 @@
if (isNull) {
- Rast3d_setXdrNullFloat((float *)dst);
+ Rast3d_set_xdr_null_float((float *)dst);
dst += XDR_FLOAT_LENGTH;
continue;
@@ -577,7 +577,7 @@
/*printf ("all null\n"); */
d = (double *)dst;
while (dstStop != (unsigned char *)d)
- Rast3d_setXdrNullDouble(d++);
+ Rast3d_set_xdr_null_double(d++);
return;
@@ -637,7 +637,7 @@
if (isNull) {
- Rast3d_setXdrNullDouble((double *)dst);
+ Rast3d_set_xdr_null_double((double *)dst);
dst += XDR_DOUBLE_LENGTH;
continue;
@@ -695,7 +695,7 @@
/* IMPORTANT!!! this function changes the "src". */
int
-G_fpcompress_writeXdrNums(int fd, char *src, int nofNum, int precision,
+Rast3d_fpcompress_write_xdr_nums(int fd, char *src, int nofNum, int precision,
char *compressBuf, int isFloat, int useRle,
int useLzw)
@@ -721,11 +721,11 @@
#endif
if (useRle == RASTER3D_USE_RLE)
- rleLength = G_rle_count_only(compressBuf + 1, offsetMantissa, 1);
+ rleLength = Rast3d_rle_count_only(compressBuf + 1, offsetMantissa, 1);
if ((useRle == RASTER3D_USE_RLE) && (rleLength < offsetMantissa)) {
- G_rle_encode(compressBuf + 1, src, offsetMantissa, 1);
+ Rast3d_rle_encode(compressBuf + 1, src, offsetMantissa, 1);
srcStop = src + rleLength;
dst = compressBuf + 1 + offsetMantissa - rleLength;
while (src != srcStop)
@@ -782,7 +782,7 @@
if (status < 0) {
- Rast3d_error("G_fpcompress_writeXdrNums: write error");
+ Rast3d_error("Rast3d_fpcompress_write_xdr_nums: write error");
return 0;
@@ -792,13 +792,13 @@
int
-G_fpcompress_writeXdrFloats(int fd, char *src, int nofNum, int precision,
+Rast3d_fpcompress_write_xdr_floats(int fd, char *src, int nofNum, int precision,
char *compressBuf, int useRle, int useLzw)
- if (!G_fpcompress_writeXdrNums(fd, src, nofNum, precision, compressBuf, 1,
+ if (!Rast3d_fpcompress_write_xdr_nums(fd, src, nofNum, precision, compressBuf, 1,
useRle, useLzw)) {
Rast3d_error
- ("G_fpcompress_writeXdrFloats: error in G_fpcompress_writeXdrNums");
+ ("Rast3d_fpcompress_write_xdr_floats: error in Rast3d_fpcompress_write_xdr_nums");
return 0;
@@ -808,13 +808,13 @@
int
-G_fpcompress_writeXdrDouble(int fd, char *src, int nofNum, int precision,
+Rast3d_fpcompress_write_xdr_double(int fd, char *src, int nofNum, int precision,
- if (!G_fpcompress_writeXdrNums(fd, src, nofNum, precision, compressBuf, 0,
+ if (!Rast3d_fpcompress_write_xdr_nums(fd, src, nofNum, precision, compressBuf, 0,
useRle, useLzw)) {
Rast3d_error
- ("G_fpcompress_writeXdrDouble: error in G_fpcompress_writeXdrNums");
+ ("Rast3d_fpcompress_write_xdr_double: error in Rast3d_fpcompress_write_xdr_nums");
return 0;
@@ -824,7 +824,7 @@
int
-G_fpcompress_readXdrNums(int fd, char *dst, int nofNum, int fileBytes,
+Rast3d_fpcompress_read_xdr_nums(int fd, char *dst, int nofNum, int fileBytes,
int precision, char *compressBuf, int isFloat)
int status, lengthEncode, lengthDecode;
@@ -840,16 +840,16 @@
nofNum * nBytes + 1);
#endif
if (status < 0) {
- Rast3d_error("G_fpcompress_readXdrNums: read error");
+ Rast3d_error("Rast3d_fpcompress_read_xdr_nums: read error");
return 0;
if (*compressBuf++ == 1) {
status--;
- G_rle_decode(compressBuf, dst, nofNum * nBytes, 1,
+ Rast3d_rle_decode(compressBuf, dst, nofNum * nBytes, 1,
&lengthEncode, &lengthDecode);
if (*dst == ALL_NULL_CODE)
- Rast3d_fatalError("G_fpcompress_readXdrNums: wrong code");
+ Rast3d_fatal_error("Rast3d_fpcompress_read_xdr_nums: wrong code");
if (status == nofNum * nBytes)
status -= lengthDecode - lengthEncode;
@@ -880,13 +880,13 @@
int
-G_fpcompress_readXdrFloats(int fd, char *dst, int nofNum, int fileBytes,
+Rast3d_fpcompress_read_xdr_floats(int fd, char *dst, int nofNum, int fileBytes,
int precision, char *compressBuf)
- if (!G_fpcompress_readXdrNums(fd, dst, nofNum, fileBytes, precision,
+ if (!Rast3d_fpcompress_read_xdr_nums(fd, dst, nofNum, fileBytes, precision,
compressBuf, 1)) {
Rast3d_error
- ("G_fpcompress_readXdrFloats: error in G_fpcompress_readXdrNums");
+ ("Rast3d_fpcompress_read_xdr_floats: error in Rast3d_fpcompress_read_xdr_nums");
return 0;
@@ -896,13 +896,13 @@
int
-G_fpcompress_readXdrDoubles(int fd, char *dst, int nofNum, int fileBytes,
+Rast3d_fpcompress_read_xdr_doubles(int fd, char *dst, int nofNum, int fileBytes,
compressBuf, 0)) {
Rast3d_error
- ("G_fpcompress_readXdrDouble: error in G_fpcompress_readXdrNums");
+ ("G_fpcompress_readXdrDouble: error in Rast3d_fpcompress_read_xdr_nums");
return 0;
Modified: grass/trunk/lib/raster3d/fpxdr.c
--- grass/trunk/lib/raster3d/fpxdr.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/fpxdr.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -12,7 +12,7 @@
-int Rast3d_isXdrNullNum(const void *num, int isFloat)
+int Rast3d_is_xdr_null_num(const void *num, int isFloat)
static const char null_bytes[8] = {
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
@@ -23,21 +23,21 @@
-int Rast3d_isXdrNullFloat(const float *f)
+int Rast3d_is_xdr_null_float(const float *f)
- return Rast3d_isXdrNullNum(f, 1);
+ return Rast3d_is_xdr_null_num(f, 1);
-int Rast3d_isXdrNullDouble(const double *d)
+int Rast3d_is_xdr_null_double(const double *d)
- return Rast3d_isXdrNullNum(d, 0);
+ return Rast3d_is_xdr_null_num(d, 0);
-void Rast3d_setXdrNullNum(void *num, int isFloat)
+void Rast3d_set_xdr_null_num(void *num, int isFloat)
@@ -48,23 +48,23 @@
-void Rast3d_setXdrNullDouble(double *d)
+void Rast3d_set_xdr_null_double(double *d)
- Rast3d_setXdrNullNum(d, 0);
+ Rast3d_set_xdr_null_num(d, 0);
-void Rast3d_setXdrNullFloat(float *f)
+void Rast3d_set_xdr_null_float(float *f)
- Rast3d_setXdrNullNum(f, 1);
+ Rast3d_set_xdr_null_num(f, 1);
XDR xdrEncodeStream, xdrDecodeStream; /* xdr support structures */
-int Rast3d_initFpXdr(RASTER3D_Map * map, int misuseBytes)
+int Rast3d_init_fp_xdr(RASTER3D_Map * map, int misuseBytes)
@@ -81,7 +81,7 @@
misuseBytes;
xdr = Rast3d_malloc(xdrLength);
if (xdr == NULL) {
- Rast3d_error("Rast3d_initFpXdr: error in Rast3d_malloc");
+ Rast3d_error("Rast3d_init_fp_xdr: error in Rast3d_malloc");
return 0;
@@ -95,7 +95,7 @@
misuseBytes;
xdr = Rast3d_realloc(xdr, xdrLength);
if (xdr == NULL) {
- Rast3d_error("Rast3d_initFpXdr: error in Rast3d_realloc");
+ Rast3d_error("Rast3d_init_fp_xdr: error in Rast3d_realloc");
return 0;
@@ -118,7 +118,7 @@
static XDR *xdrs;
static double tmpValue, *tmp;
-int Rast3d_initCopyToXdr(RASTER3D_Map * map, int sType)
+int Rast3d_init_copy_to_xdr(RASTER3D_Map * map, int sType)
xdrTmp = xdr;
useXdr = map->useXdr;
@@ -134,7 +134,7 @@
type = map->type;
isFloat = (type == FCELL_TYPE);
- externLength = Rast3d_externLength(type);
+ externLength = Rast3d_extern_length(type);
eltLength = Rast3d_length(srcType);
if (isFloat)
xdrFun = xdr_float;
@@ -147,29 +147,29 @@
-int Rast3d_copyToXdr(const void *src, int nofNum)
+int Rast3d_copy_to_xdr(const void *src, int nofNum)
int i;
- Rast3d_copyValues(src, 0, srcType, xdrTmp, 0, type, nofNum);
- xdrTmp = G_incr_void_ptr(xdrTmp, nofNum * Rast3d_externLength(type));
+ Rast3d_copy_values(src, 0, srcType, xdrTmp, 0, type, nofNum);
+ xdrTmp = G_incr_void_ptr(xdrTmp, nofNum * Rast3d_extern_length(type));
return 1;
for (i = 0; i < nofNum; i++, src = G_incr_void_ptr(src, eltLength)) {
- if (Rast3d_isNullValueNum(src, srcType)) {
- Rast3d_setXdrNullNum(xdrTmp, isFloat);
+ if (Rast3d_is_null_value_num(src, srcType)) {
+ Rast3d_set_xdr_null_num(xdrTmp, isFloat);
if (!xdr_setpos(xdrs, xdr_getpos(xdrs) + externLength)) {
- Rast3d_error("Rast3d_copyToXdr: positioning xdr failed");
+ Rast3d_error("Rast3d_copy_to_xdr: positioning xdr failed");
return 0;
else {
if (type == srcType) {
if (xdrFun(xdrs, src) < 0) {
- Rast3d_error("Rast3d_copyToXdr: writing xdr failed");
+ Rast3d_error("Rast3d_copy_to_xdr: writing xdr failed");
return 0;
@@ -179,7 +179,7 @@
else
*((double *)tmp) = (double)*((float *)src);
if (xdrFun(xdrs, tmp) < 0) {
return 0;
@@ -193,7 +193,7 @@
-int Rast3d_initCopyFromXdr(RASTER3D_Map * map, int dType)
+int Rast3d_init_copy_from_xdr(RASTER3D_Map * map, int dType)
xdrTmp = xdr;
@@ -201,7 +201,7 @@
if (useXdr == RASTER3D_USE_XDR) {
if (!xdr_setpos(&(xdrDecodeStream), 0)) {
- Rast3d_error("Rast3d_initCopyFromXdr: positioning xdr failed");
+ Rast3d_error("Rast3d_init_copy_from_xdr: positioning xdr failed");
return 0;
xdrs = &(xdrDecodeStream);
@@ -209,7 +209,7 @@
type = map->type;
eltLength = Rast3d_length(dstType);
if (isFloat)
xdrFun = xdr_float;
@@ -222,35 +222,35 @@
-int Rast3d_copyFromXdr(int nofNum, void *dst)
+int Rast3d_copy_from_xdr(int nofNum, void *dst)
int i;
- Rast3d_copyValues(xdrTmp, 0, type, dst, 0, dstType, nofNum);
+ Rast3d_copy_values(xdrTmp, 0, type, dst, 0, dstType, nofNum);
return 1;
for (i = 0; i < nofNum; i++, dst = G_incr_void_ptr(dst, eltLength)) {
- if (Rast3d_isXdrNullNum(xdrTmp, isFloat)) {
- Rast3d_setNullValue(dst, 1, dstType);
+ if (Rast3d_is_xdr_null_num(xdrTmp, isFloat)) {
+ Rast3d_set_null_value(dst, 1, dstType);
- Rast3d_error("Rast3d_copyFromXdr: positioning xdr failed");
+ Rast3d_error("Rast3d_copy_from_xdr: positioning xdr failed");
return 0;
else {
if (type == dstType) {
if (xdrFun(xdrs, dst) < 0) {
- Rast3d_error("Rast3d_copyFromXdr: reading xdr failed");
+ Rast3d_error("Rast3d_copy_from_xdr: reading xdr failed");
return 0;
else {
return 0;
Modified: grass/trunk/lib/raster3d/getblock.c
--- grass/trunk/lib/raster3d/getblock.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/getblock.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -9,7 +9,7 @@
void
-Rast3d_getBlockNocache(RASTER3D_Map * map, int x0, int y0, int z0, int nx, int ny,
+Rast3d_get_block_nocache(RASTER3D_Map * map, int x0, int y0, int z0, int nx, int ny,
int nz, void *block, int type)
void *tile;
@@ -19,13 +19,13 @@
int tileIndex;
if (!map->useCache)
- tile = Rast3d_allocTilesType(map, 1, type);
+ tile = Rast3d_alloc_tiles_type(map, 1, type);
if (tile == NULL)
- Rast3d_fatalError("Rast3d_getBlockNocache: error in Rast3d_allocTiles");
+ Rast3d_fatal_error("Rast3d_get_block_nocache: error in Rast3d_alloc_tiles");
- Rast3d_coord2tileCoord(map, x0, y0, z0, &tileX0, &tileY0, &tileZ0,
+ Rast3d_coord2tile_coord(map, x0, y0, z0, &tileX0, &tileY0, &tileZ0,
&tileOffsX0, &tileOffsY0, &tileOffsZ0);
- Rast3d_coord2tileCoord(map, x0 + nx - 1, y0 + ny - 1, z0 + nz - 1,
+ Rast3d_coord2tile_coord(map, x0 + nx - 1, y0 + ny - 1, z0 + nz - 1,
&tileX1, &tileY1, &tileZ1,
&tileOffsX1, &tileOffsY1, &tileOffsZ1);
@@ -36,24 +36,24 @@
for (tx = tileX0; tx <= tileX1; tx++) {
dx = (tx - tileX0) * map->tileX - tileOffsX0;
- tileIndex = Rast3d_tile2tileIndex(map, tx, ty, tz);
+ tileIndex = Rast3d_tile2tile_index(map, tx, ty, tz);
- if (Rast3d_tileIndexInRange(map, tileIndex))
+ if (Rast3d_tile_index_in_range(map, tileIndex))
- tile = Rast3d_getTilePtr(map, tileIndex);
+ tile = Rast3d_get_tile_ptr(map, tileIndex);
if (tile == NULL)
- Rast3d_fatalError
- ("Rast3d_getBlockNocache: error in Rast3d_getTilePtr");
+ ("Rast3d_get_block_nocache: error in Rast3d_get_tile_ptr");
else {
(map, tileIndex, tile, map->typeIntern))
- Rast3d_fatalError
- ("Rast3d_getBlockNocache: error in Rast3d_readTile");
+ ("Rast3d_get_block_nocache: error in Rast3d_read_tile");
else
- Rast3d_setNullTile(map, tile);
+ Rast3d_set_null_tile(map, tile);
cols = (tx == tileX1 ? tileOffsX1 : map->tileX - 1);
rows = (ty == tileY1 ? tileOffsY1 : map->tileY - 1);
@@ -63,7 +63,7 @@
for (z = (tz == tileZ0 ? tileOffsZ0 : 0); z <= depths; z++)
for (y = (ty == tileY0 ? tileOffsY0 : 0); y <= rows; y++) {
- Rast3d_copyValues(tile,
+ Rast3d_copy_values(tile,
z * map->tileXY + y * map->tileX + x,
map->typeIntern,
block,
@@ -75,7 +75,7 @@
if (!map->useCache)
- Rast3d_freeTiles(tile);
+ Rast3d_free_tiles(tile);
@@ -102,13 +102,13 @@
void
-Rast3d_getBlock(RASTER3D_Map * map, int x0, int y0, int z0, int nx, int ny, int nz,
+Rast3d_get_block(RASTER3D_Map * map, int x0, int y0, int z0, int nx, int ny, int nz,
int x, y, z, nNull, x1, y1, z1, length;
if (!map->useCache) {
- Rast3d_getBlockNocache(map, x0, y0, z0, nx, ny, nz, block, type);
+ Rast3d_get_block_nocache(map, x0, y0, z0, nx, ny, nz, block, type);
return;
@@ -121,17 +121,17 @@
for (z = z0; z < z1; z++) {
for (y = y0; y < y1; y++) {
for (x = x0; x < x1; x++) {
- Rast3d_getValueRegion(map, x, y, z, block, type);
+ Rast3d_get_value_region(map, x, y, z, block, type);
block = G_incr_void_ptr(block, length);
nNull = x0 + nx - x;
- Rast3d_setNullValue(block, nNull, type);
+ Rast3d_set_null_value(block, nNull, type);
block = G_incr_void_ptr(block, length * nNull);
nNull = (y0 + ny - y) * nx;
nNull = (z0 + nz - z) * ny * nx;
Modified: grass/trunk/lib/raster3d/getvalue.c
--- grass/trunk/lib/raster3d/getvalue.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/getvalue.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -19,7 +19,7 @@
* \return void
-void Rast3d_getValue(RASTER3D_Map * map, int x, int y, int z, void *value, int type)
+void Rast3d_get_value(RASTER3D_Map * map, int x, int y, int z, void *value, int type)
/* get the resampled value */
map->resampleFun(map, x, y, z, value, type);
@@ -31,7 +31,7 @@
* \brief
* Is equivalent to
- * <tt>Rast3d_getValue (map, x, y, z, &value, FCELL_TYPE);</tt> return value.
+ * <tt>Rast3d_get_value (map, x, y, z, &value, FCELL_TYPE);</tt> return value.
* \param map
* \param x
@@ -40,11 +40,11 @@
* \return float
-float Rast3d_getFloat(RASTER3D_Map * map, int x, int y, int z)
+float Rast3d_get_float(RASTER3D_Map * map, int x, int y, int z)
float value;
- Rast3d_getValue(map, x, y, z, &value, FCELL_TYPE);
+ Rast3d_get_value(map, x, y, z, &value, FCELL_TYPE);
return value;
@@ -54,7 +54,7 @@
* \brief
* Is equivalent
- * to <tt>Rast3d_getValue (map, x, y, z, &value, DCELL_TYPE);</tt> return value.
+ * to <tt>Rast3d_get_value (map, x, y, z, &value, DCELL_TYPE);</tt> return value.
* \param map
* \param x
@@ -63,11 +63,11 @@
* \return double
-double Rast3d_getDouble(RASTER3D_Map * map, int x, int y, int z)
+double Rast3d_get_double(RASTER3D_Map * map, int x, int y, int z)
double value;
- Rast3d_getValue(map, x, y, z, &value, DCELL_TYPE);
+ Rast3d_get_value(map, x, y, z, &value, DCELL_TYPE);
return value;
@@ -91,7 +91,7 @@
void
-Rast3d_getWindowValue(RASTER3D_Map * map, double north, double east, double top,
+Rast3d_get_window_value(RASTER3D_Map * map, double north, double east, double top,
int col, row, depth;
@@ -102,7 +102,7 @@
if ((row < 0) || (row >= map->window.rows) ||
(col < 0) || (col >= map->window.cols) ||
(depth < 0) || (depth >= map->window.depths)) {
- Rast3d_setNullValue(value, 1, type);
+ Rast3d_set_null_value(value, 1, type);
return;
@@ -128,7 +128,7 @@
void
-Rast3d_getRegionValue(RASTER3D_Map * map, double north, double east, double top,
+Rast3d_get_region_value(RASTER3D_Map * map, double north, double east, double top,
int row, col, depth;
@@ -139,12 +139,12 @@
if ((row < 0) || (row >= map->region.rows) ||
(col < 0) || (col >= map->region.cols) ||
(depth < 0) || (depth >= map->region.depths)) {
return;
/* Get the value from the map in map-region resolution */
- Rast3d_getValueRegion(map, col, row, depth, value, type);
+ Rast3d_get_value_region(map, col, row, depth, value, type);
@@ -152,7 +152,7 @@
* \brief
- * Is equivalent to <tt>Rast3d_getValueRegion (map, x, y, z, &value, FCELL_TYPE);</tt>
+ * Is equivalent to <tt>Rast3d_get_value_region (map, x, y, z, &value, FCELL_TYPE);</tt>
* return value.
* \param map
@@ -162,19 +162,19 @@
* \return float
-float Rast3d_getFloatRegion(RASTER3D_Map * map, int x, int y, int z)
+float Rast3d_get_float_region(RASTER3D_Map * map, int x, int y, int z)
int tileIndex, offs;
float *tile;
if (map->typeIntern == DCELL_TYPE)
- return (float)Rast3d_getDoubleRegion(map, x, y, z);
+ return (float)Rast3d_get_double_region(map, x, y, z);
- Rast3d_coord2tileIndex(map, x, y, z, &tileIndex, &offs);
- tile = (float *)Rast3d_getTilePtr(map, tileIndex);
+ Rast3d_coord2tile_index(map, x, y, z, &tileIndex, &offs);
+ tile = (float *)Rast3d_get_tile_ptr(map, tileIndex);
if (tile == NULL)
- Rast3d_fatalError("Rast3d_getFloatRegion: error in Rast3d_getTilePtr");
+ Rast3d_fatal_error("Rast3d_get_float_region: error in Rast3d_get_tile_ptr");
return tile[offs];
@@ -185,7 +185,7 @@
* \brief
* DCELL_TYPE);</tt> return value.
* \param map
@@ -195,19 +195,19 @@
* \return double
-double Rast3d_getDoubleRegion(RASTER3D_Map * map, int x, int y, int z)
+double Rast3d_get_double_region(RASTER3D_Map * map, int x, int y, int z)
double *tile;
if (map->typeIntern == FCELL_TYPE)
- return (double)Rast3d_getFloatRegion(map, x, y, z);
+ return (double)Rast3d_get_float_region(map, x, y, z);
- tile = (double *)Rast3d_getTilePtr(map, tileIndex);
+ tile = (double *)Rast3d_get_tile_ptr(map, tileIndex);
if (tile == NULL)
- Rast3d_fatalError("Rast3d_getDoubleRegion: error in Rast3d_getTilePtr");
+ Rast3d_fatal_error("Rast3d_get_double_region: error in Rast3d_get_tile_ptr");
return tile[offs];
@@ -234,12 +234,12 @@
void
-Rast3d_getValueRegion(RASTER3D_Map * map, int x, int y, int z, void *value, int type)
+Rast3d_get_value_region(RASTER3D_Map * map, int x, int y, int z, void *value, int type)
if (type == FCELL_TYPE) {
- *((float *)value) = Rast3d_getFloatRegion(map, x, y, z);
+ *((float *)value) = Rast3d_get_float_region(map, x, y, z);
return;
- *((double *)value) = Rast3d_getDoubleRegion(map, x, y, z);
+ *((double *)value) = Rast3d_get_double_region(map, x, y, z);
Modified: grass/trunk/lib/raster3d/header.c
--- grass/trunk/lib/raster3d/header.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/header.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -46,16 +46,16 @@
int (*headerString) ();
if (doRead) {
- headerDouble = Rast3d_keyGetDouble;
- headerInt = Rast3d_keyGetInt;
- headerString = Rast3d_keyGetString;
- headerValue = Rast3d_keyGetValue;
+ headerDouble = Rast3d_key_get_double;
+ headerInt = Rast3d_key_get_int;
+ headerString = Rast3d_key_get_string;
+ headerValue = Rast3d_key_get_value;
else {
- headerDouble = Rast3d_keySetDouble;
- headerInt = Rast3d_keySetInt;
- headerString = Rast3d_keySetString;
- headerValue = Rast3d_keySetValue;
+ headerDouble = Rast3d_key_set_double;
+ headerInt = Rast3d_key_set_int;
+ headerString = Rast3d_key_set_string;
+ headerValue = Rast3d_key_set_value;
returnVal = 1;
@@ -109,7 +109,7 @@
int
-Rast3d_readHeader(RASTER3D_Map * map, int *proj, int *zone, double *north,
+Rast3d_read_header(RASTER3D_Map * map, int *proj, int *zone, double *north,
double *south, double *east, double *west, double *top,
double *bottom, int *rows, int *cols, int *depths,
double *ew_res, double *ns_res, double *tb_res, int *tileX,
@@ -122,7 +122,7 @@
Rast3d_filename(path, RASTER3D_HEADER_ELEMENT, map->fileName, map->mapset);
if (access(path, R_OK) != 0) {
- Rast3d_error("Rast3d_readHeader: unable to find [%s]", path);
+ Rast3d_error("Rast3d_read_header: unable to find [%s]", path);
return 0;
@@ -136,7 +136,7 @@
type, compression, useRle, useLzw, precision,
dataOffset, useXdr, hasIndex, unit)) {
- Rast3d_error("Rast3d_readHeader: error extracting header key(s) of file %s",
+ Rast3d_error("Rast3d_read_header: error extracting header key(s) of file %s",
path);
return 0;
@@ -148,7 +148,7 @@
int
-Rast3d_writeHeader(RASTER3D_Map * map, int proj, int zone, double north, double south,
+Rast3d_write_header(RASTER3D_Map * map, int proj, int zone, double north, double south,
double east, double west, double top, double bottom, int rows,
int cols, int depths, double ew_res, double ns_res,
double tb_res, int tileX, int tileY, int tileZ, int type,
@@ -169,13 +169,13 @@
&type, &compression, &useRle, &useLzw,
&precision, &dataOffset, &useXdr, &hasIndex,
&unit)) {
- Rast3d_error("Rast3d_writeHeader: error adding header key(s) for file %s",
+ Rast3d_error("Rast3d_write_header: error adding header key(s) for file %s",
path);
return 0;
- Rast3d_makeMapsetMapDirectory(map->fileName);
+ Rast3d_make_mapset_map_directory(map->fileName);
G_write_key_value_file(path, headerKeys);
G_free_key_value(headerKeys);
@@ -211,7 +211,7 @@
* \return int
-int Rast3d_cacheSizeEncode(int cacheCode, int n)
+int Rast3d_cache_size_encode(int cacheCode, int n)
if (cacheCode >= RASTER3D_NO_CACHE)
return cacheCode * n;
@@ -219,14 +219,14 @@
return cacheCode;
if (cacheCode < RASTER3D_USE_CACHE_XYZ)
- Rast3d_fatalError("Rast3d_cacheSizeEncode: invalid cache code");
+ Rast3d_fatal_error("Rast3d_cache_size_encode: invalid cache code");
return n * (-10) + cacheCode;
-int Rast3d__computeCacheSize(RASTER3D_Map * map, int cacheCode)
+int Rast3d__compute_cache_size(RASTER3D_Map * map, int cacheCode)
int n, size;
@@ -254,7 +254,7 @@
else if (cacheCode == RASTER3D_USE_CACHE_XYZ)
size = map->nTiles;
else
- Rast3d_fatalError("Rast3d__computeCacheSize: invalid cache code");
+ Rast3d_fatal_error("Rast3d__compute_cache_size: invalid cache code");
return RASTER3D_MIN(size, map->nTiles);
@@ -266,7 +266,7 @@
/* and initializes the index and cache. This function should be taken apart. */
int
-Rast3d_fillHeader(RASTER3D_Map * map, int operation, int compression, int useRle,
+Rast3d_fill_header(RASTER3D_Map * map, int operation, int compression, int useRle,
int useLzw, int type, int precision, int cache, int hasIndex,
int useXdr, int typeIntern, int nofHeaderBytes, int tileX,
int tileY, int tileZ, int proj, int zone, double north,
@@ -275,7 +275,7 @@
double ns_res, double tb_res, char *unit)
if (!RASTER3D_VALID_OPERATION(operation))
- Rast3d_fatalError("Rast3d_fillHeader: operation not valid\n");
+ Rast3d_fatal_error("Rast3d_fill_header: operation not valid\n");
map->operation = operation;
@@ -299,7 +299,7 @@
map->region.ns_res = ns_res;
map->region.tb_res = tb_res;
- Rast3d_adjustRegion(&(map->region));
+ Rast3d_adjust_region(&(map->region));
map->tileX = tileX;
map->tileY = tileY;
@@ -327,28 +327,28 @@
map->clipZ = -1;
- Rast3d_fatalError("Rast3d_fillHeader: invalid type");
+ Rast3d_fatal_error("Rast3d_fill_header: invalid type");
map->type = type;
if ((typeIntern != FCELL_TYPE) && (typeIntern != DCELL_TYPE))
map->typeIntern = typeIntern;
if (!RASTER3D_VALID_XDR_OPTION(useXdr))
- Rast3d_fatalError("Rast3d_fillHeader: invalid xdr option");
+ Rast3d_fatal_error("Rast3d_fill_header: invalid xdr option");
map->useXdr = useXdr;
map->offset = nofHeaderBytes;
if ((map->fileEndPtr = lseek(map->data_fd, (long)0, SEEK_END)) == -1) {
- Rast3d_error("Rast3d_fillHeader: can't position file");
+ Rast3d_error("Rast3d_fill_header: can't position file");
return 0;
map->useCache = (cache != RASTER3D_NO_CACHE);
map->numLengthIntern = Rast3d_length(map->typeIntern);
- map->numLengthExtern = Rast3d_externLength(map->type);
+ map->numLengthExtern = Rast3d_extern_length(map->type);
map->compression = compression;
map->useRle = useRle;
@@ -364,7 +364,7 @@
RLE_STATUS_BYTES;
tmpCompress = Rast3d_malloc(tmpCompressLength);
if (tmpCompress == NULL) {
- Rast3d_error("Rast3d_fillHeader: error in Rast3d_malloc");
+ Rast3d_error("Rast3d_fill_header: error in Rast3d_malloc");
return 0;
@@ -376,7 +376,7 @@
RLE_STATUS_BYTES;
tmpCompress = Rast3d_realloc(tmpCompress, tmpCompressLength);
- Rast3d_error("Rast3d_fillHeader: error in Rast3d_realloc");
+ Rast3d_error("Rast3d_fill_header: error in Rast3d_realloc");
return 0;
@@ -384,8 +384,8 @@
#define XDR_MISUSE_BYTES 10
- if (!Rast3d_initFpXdr(map, XDR_MISUSE_BYTES)) {
- Rast3d_error("Rast3d_fillHeader: error in Rast3d_initFpXdr");
+ if (!Rast3d_init_fp_xdr(map, XDR_MISUSE_BYTES)) {
+ Rast3d_error("Rast3d_fill_header: error in Rast3d_init_fp_xdr");
return 0;
@@ -396,25 +396,25 @@
/* allocate one tile buffer */
map->data = Rast3d_malloc(map->tileSize * map->numLengthIntern);
if (map->data == NULL) {
return 0;
map->currentIndex = -1;
else {
- if (!Rast3d_initCache(map,
+ if (!Rast3d_init_cache(map,
RASTER3D_MAX(1,
- RASTER3D_MIN(Rast3d__computeCacheSize(map, cache),
+ RASTER3D_MIN(Rast3d__compute_cache_size(map, cache),
g3d_cache_max /
map->tileSize /
map->numLengthIntern)))) {
- Rast3d_error("Rast3d_fillHeader: error in Rast3d_initCache");
+ Rast3d_error("Rast3d_fill_header: error in Rast3d_init_cache");
return 0;
- if (!Rast3d_initIndex(map, hasIndex)) {
- Rast3d_error("Rast3d_fillHeader: error in Rast3d_initIndex");
+ if (!Rast3d_init_index(map, hasIndex)) {
+ Rast3d_error("Rast3d_fill_header: error in Rast3d_init_index");
return 0;
Modified: grass/trunk/lib/raster3d/headerinfo.c
--- grass/trunk/lib/raster3d/headerinfo.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/headerinfo.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -16,7 +16,7 @@
* \return void
-void Rast3d_getCoordsMap(RASTER3D_Map * map, int *rows, int *cols, int *depths)
+void Rast3d_get_coords_map(RASTER3D_Map * map, int *rows, int *cols, int *depths)
*rows = map->region.rows;
*cols = map->region.cols;
@@ -25,7 +25,7 @@
-void Rast3d_getCoordsMapWindow(RASTER3D_Map * map, int *rows, int *cols, int *depths)
+void Rast3d_get_coords_map_window(RASTER3D_Map * map, int *rows, int *cols, int *depths)
*rows = map->window.rows;
*cols = map->window.cols;
@@ -48,7 +48,7 @@
* \return void
-void Rast3d_getNofTilesMap(RASTER3D_Map * map, int *nx, int *ny, int *nz)
+void Rast3d_get_nof_tiles_map(RASTER3D_Map * map, int *nx, int *ny, int *nz)
*nx = map->nx;
*ny = map->ny;
@@ -74,7 +74,7 @@
void
-Rast3d_getRegionMap(RASTER3D_Map * map, double *north, double *south, double *east,
+Rast3d_get_region_map(RASTER3D_Map * map, double *north, double *south, double *east,
double *west, double *top, double *bottom)
*north = map->region.north;
@@ -88,7 +88,7 @@
void
-Rast3d_getWindowMap(RASTER3D_Map * map, double *north, double *south, double *east,
+Rast3d_get_window_map(RASTER3D_Map * map, double *north, double *south, double *east,
*north = map->window.north;
@@ -112,16 +112,16 @@
* \return void
-void Rast3d_getRegionStructMap(RASTER3D_Map * map, RASTER3D_Region * region)
+void Rast3d_get_region_struct_map(RASTER3D_Map * map, RASTER3D_Region * region)
- Rast3d_regionCopy(region, &(map->region));
+ Rast3d_region_copy(region, &(map->region));
void Rast3d_getWindowStructMap(RASTER3D_Map * map, RASTER3D_Region * window)
- Rast3d_regionCopy(window, &(map->window));
+ Rast3d_region_copy(window, &(map->window));
@@ -139,7 +139,7 @@
* \return void
-void Rast3d_getTileDimensionsMap(RASTER3D_Map * map, int *x, int *y, int *z)
+void Rast3d_get_tile_dimensions_map(RASTER3D_Map * map, int *x, int *y, int *z)
*x = map->tileX;
*y = map->tileY;
@@ -158,7 +158,7 @@
* \return int
-int Rast3d_tileTypeMap(RASTER3D_Map * map)
+int Rast3d_tile_type_map(RASTER3D_Map * map)
return map->typeIntern;
@@ -175,7 +175,7 @@
* \return int
-int Rast3d_fileTypeMap(RASTER3D_Map * map)
+int Rast3d_file_type_map(RASTER3D_Map * map)
return map->type;
@@ -192,7 +192,7 @@
* \return int
-int Rast3d_tilePrecisionMap(RASTER3D_Map * map)
+int Rast3d_tile_precision_map(RASTER3D_Map * map)
return map->precision;
@@ -209,7 +209,7 @@
* \return int
-int Rast3d_tileUseCacheMap(RASTER3D_Map * map)
+int Rast3d_tile_use_cache_map(RASTER3D_Map * map)
return map->useCache;
@@ -225,7 +225,7 @@
* \return void
-void Rast3d_printHeader(RASTER3D_Map * map)
+void Rast3d_print_header(RASTER3D_Map * map)
double rangeMin, rangeMax;
@@ -265,11 +265,11 @@
map->region.depths);
printf(" Tile size (%d %d %d)\n", map->tileX, map->tileY, map->tileZ);
printf(" Range (");
- if (Rast3d_isNullValueNum(&rangeMin, DCELL_TYPE))
+ if (Rast3d_is_null_value_num(&rangeMin, DCELL_TYPE))
printf("NULL, ");
else
printf("%f, ", (double)rangeMin);
- if (Rast3d_isNullValueNum(&rangeMax, DCELL_TYPE))
+ if (Rast3d_is_null_value_num(&rangeMax, DCELL_TYPE))
printf("NULL)\n");
else
printf("%f)\n", (double)rangeMax);
Modified: grass/trunk/lib/raster3d/history.c
--- grass/trunk/lib/raster3d/history.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/history.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -1,7 +1,7 @@
- * Rast3d_readHistory (name, mapset, hist)
+ * Rast3d_read_history (name, mapset, hist)
* char *name name of map
* char *mapset mapset that map belongs to
* struct History *hist structure to hold history info
@@ -16,7 +16,7 @@
- * Rast3d_writeHistory (name, hist)
+ * Rast3d_write_history (name, hist)
* struct History *hist structure holding history info
@@ -61,7 +61,7 @@
* \return int
-int Rast3d_readHistory(const char *name, const char *mapset, struct History *hist)
+int Rast3d_read_history(const char *name, const char *mapset, struct History *hist)
FILE *fp;
@@ -94,7 +94,7 @@
* \return int
-int Rast3d_writeHistory(const char *name, struct History *hist)
+int Rast3d_write_history(const char *name, struct History *hist)
/* This function is adapted from Rast_write_history */
FILE *fp = G_fopen_new_misc(RASTER3D_DIRECTORY, RASTER3D_HISTORY_ELEMENT, name);
Modified: grass/trunk/lib/raster3d/index.c
--- grass/trunk/lib/raster3d/index.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/index.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -51,7 +51,7 @@
return 0;
- G_rle_decode(tmp2, tmp, map->indexLongNbytes * map->nTiles, 1,
+ Rast3d_rle_decode(tmp2, tmp, map->indexLongNbytes * map->nTiles, 1,
&dummy1, &dummy2);
if (indexLength > sizeof(long) * map->nTiles)
@@ -62,7 +62,7 @@
return 0;
- Rast3d_longDecode(tmp, map->index, map->nTiles, map->indexLongNbytes);
+ Rast3d_long_decode(tmp, map->index, map->nTiles, map->indexLongNbytes);
for (tileIndex = 0; tileIndex < map->nTiles; tileIndex++)
if (map->index[tileIndex] == 0)
@@ -75,7 +75,7 @@
-int Rast3d_flushIndex(RASTER3D_Map * map)
+int Rast3d_flush_index(RASTER3D_Map * map)
int sizeCompressed, indexLength, tileIndex;
unsigned char *tmp;
@@ -86,16 +86,16 @@
map->indexOffset = lseek(map->data_fd, (long)0, SEEK_END);
if (map->indexOffset == -1) {
- Rast3d_error("Rast3d_flushIndex: can't rewind file");
+ Rast3d_error("Rast3d_flush_index: can't rewind file");
return 0;
- map->indexNbytesUsed = Rast3d_longEncode(&(map->indexOffset),
+ map->indexNbytesUsed = Rast3d_long_encode(&(map->indexOffset),
(unsigned char *)&ldummy, 1);
tmp = Rast3d_malloc(sizeof(long) * map->nTiles);
if (tmp == NULL) {
- Rast3d_error("Rast3d_flushIndex: error in Rast3d_malloc");
+ Rast3d_error("Rast3d_flush_index: error in Rast3d_malloc");
return 0;
@@ -103,29 +103,29 @@
if (map->index[tileIndex] == -1)
map->index[tileIndex] = 0;
- (void)Rast3d_longEncode(map->index, tmp, map->nTiles);
+ (void)Rast3d_long_encode(map->index, tmp, map->nTiles);
- sizeCompressed = G_rle_count_only(tmp, sizeof(long) * map->nTiles, 1);
+ sizeCompressed = Rast3d_rle_count_only(tmp, sizeof(long) * map->nTiles, 1);
if (sizeCompressed >= map->nTiles * sizeof(long)) {
indexLength = map->nTiles * sizeof(long);
if (write(map->data_fd, tmp, indexLength) != indexLength) {
- Rast3d_error("Rast3d_flushIndex: can't write file");
+ Rast3d_error("Rast3d_flush_index: can't write file");
return 0;
else {
indexLength = sizeCompressed;
- G_rle_encode(tmp, (char *)map->index, sizeof(long) * map->nTiles, 1);
+ Rast3d_rle_encode(tmp, (char *)map->index, sizeof(long) * map->nTiles, 1);
if (write(map->data_fd, map->index, sizeCompressed) != sizeCompressed) {
return 0;
Rast3d_free(tmp);
if (!Rast3d_readIndex(map)) {
- Rast3d_error("Rast3d_flushIndex: error in Rast3d_readIndex");
+ Rast3d_error("Rast3d_flush_index: error in Rast3d_readIndex");
return 0;
@@ -152,7 +152,7 @@
-int Rast3d_initIndex(RASTER3D_Map * map, int hasIndex)
+int Rast3d_init_index(RASTER3D_Map * map, int hasIndex)
int tile;
int i0, i1, i2, i3, i4, i5, offset, nofElts;
@@ -163,7 +163,7 @@
map->tileLength = Rast3d_malloc(sizeof(int) * map->nTiles);
if ((map->index == NULL) || (map->tileLength == NULL)) {
- Rast3d_error("Rast3d_initIndex: error in Rast3d_malloc");
+ Rast3d_error("Rast3d_init_index: error in Rast3d_malloc");
return 0;
@@ -177,7 +177,7 @@
offset = 0;
for (tile = 0; tile < map->nTiles; tile++) {
map->index[tile] = offset * map->numLengthExtern + map->offset;
- nofElts = Rast3d_computeClippedTileDimensions
+ nofElts = Rast3d_compute_clipped_tile_dimensions
(map, tile, &i0, &i1, &i2, &i3, &i4, &i5);
map->tileLength[tile] = nofElts * map->numLengthExtern;
offset += nofElts;
@@ -186,13 +186,13 @@
- Rast3d_error("Rast3d_initIndex: error in Rast3d_readIndex");
+ Rast3d_error("Rast3d_init_index: error in Rast3d_readIndex");
return 0;
offsetP = Rast3d_malloc(sizeof(int) * map->nTiles);
if (offsetP == NULL) {
return 0;
Modified: grass/trunk/lib/raster3d/intio.c
--- grass/trunk/lib/raster3d/intio.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/intio.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -8,7 +8,7 @@
-int Rast3d_writeInts(int fd, int useXdr, const int *i, int nofNum)
+int Rast3d_write_ints(int fd, int useXdr, const int *i, int nofNum)
int firstTime = 1;
@@ -16,11 +16,11 @@
u_int n;
if (nofNum <= 0)
- Rast3d_fatalError("Rast3d_writeInts: nofNum out of range");
+ Rast3d_fatal_error("Rast3d_write_ints: nofNum out of range");
if (write(fd, i, sizeof(int) * nofNum) != sizeof(int) * nofNum) {
- Rast3d_error("Rast3d_writeInts: writing to file failed");
+ Rast3d_error("Rast3d_write_ints: writing to file failed");
return 0;
else {
@@ -40,19 +40,19 @@
n = 1024;
- Rast3d_error("Rast3d_writeInts: positioning xdr failed");
+ Rast3d_error("Rast3d_write_ints: positioning xdr failed");
return 0;
if (!xdr_vector(&xdrEncodeStream, (char *)i, n, sizeof(int),
(xdrproc_t) xdr_int)) {
- Rast3d_error("Rast3d_writeInts: writing xdr failed");
+ Rast3d_error("Rast3d_write_ints: writing xdr failed");
return 0;
if (write(fd, xdrIntBuf, RASTER3D_XDR_INT_LENGTH * n) !=
RASTER3D_XDR_INT_LENGTH * n) {
- Rast3d_error("Rast3d_writeInts: writing xdr to file failed");
+ Rast3d_error("Rast3d_write_ints: writing xdr to file failed");
return 0;
@@ -65,7 +65,7 @@
-int Rast3d_readInts(int fd, int useXdr, int *i, int nofNum)
+int Rast3d_read_ints(int fd, int useXdr, int *i, int nofNum)
int firstTime = 1;
@@ -73,11 +73,11 @@
u_int n;
if (nofNum <= 0)
- Rast3d_fatalError("Rast3d_readInts: nofNum out of range");
+ Rast3d_fatal_error("Rast3d_read_ints: nofNum out of range");
if (read(fd, i, sizeof(int) * nofNum) != sizeof(int) * nofNum) {
- Rast3d_error("Rast3d_readInts: reading from file failed");
+ Rast3d_error("Rast3d_read_ints: reading from file failed");
return 0;
else {
@@ -98,18 +98,18 @@
if (read(fd, xdrIntBuf, RASTER3D_XDR_INT_LENGTH * n) !=
- Rast3d_error("Rast3d_readInts: reading xdr from file failed");
+ Rast3d_error("Rast3d_read_ints: reading xdr from file failed");
return 0;
- Rast3d_error("Rast3d_readInts: positioning xdr failed");
+ Rast3d_error("Rast3d_read_ints: positioning xdr failed");
return 0;
if (!xdr_vector(&xdrDecodeStream, (char *)i, n, sizeof(int),
- Rast3d_error("Rast3d_readInts: reading xdr failed");
+ Rast3d_error("Rast3d_read_ints: reading xdr failed");
return 0;
Modified: grass/trunk/lib/raster3d/keys.c
--- grass/trunk/lib/raster3d/keys.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/keys.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -4,12 +4,12 @@
-int Rast3d_keyGetInt(struct Key_Value *keys, const char *key, int *i)
+int Rast3d_key_get_int(struct Key_Value *keys, const char *key, int *i)
const char *str;
if ((str = G_find_key_value(key, keys)) == NULL) {
- Rast3d_error("Rast3d_keyGetInt: cannot find field %s in key structure",
+ Rast3d_error("Rast3d_key_get_int: cannot find field %s in key structure",
key);
return 0;
@@ -17,18 +17,18 @@
if (sscanf(str, "%d", i) == 1)
return 1;
- Rast3d_error("Rast3d_keyGetInt: invalid value: field %s in key structure", key);
+ Rast3d_error("Rast3d_key_get_int: invalid value: field %s in key structure", key);
return 0;
-int Rast3d_keyGetDouble(struct Key_Value *keys, const char *key, double *d)
+int Rast3d_key_get_double(struct Key_Value *keys, const char *key, double *d)
const char *str;
- Rast3d_error("Rast3d_keyGetDouble: cannot find field %s in key structure",
+ Rast3d_error("Rast3d_key_get_double: cannot find field %s in key structure",
key);
return 0;
@@ -36,7 +36,7 @@
if (sscanf(str, "%lf", d) == 1)
return 1;
- Rast3d_error("Rast3d_keyGetDouble: invalid value: field %s in key structure",
+ Rast3d_error("Rast3d_key_get_double: invalid value: field %s in key structure",
key);
return 0;
@@ -44,12 +44,12 @@
int
-Rast3d_keyGetString(struct Key_Value *keys, const char *key, char **returnStr)
+Rast3d_key_get_string(struct Key_Value *keys, const char *key, char **returnStr)
const char *str;
- Rast3d_error("Rast3d_keyGetString: cannot find field %s in key structure",
+ Rast3d_error("Rast3d_key_get_string: cannot find field %s in key structure",
key);
return 0;
@@ -61,13 +61,13 @@
int
-Rast3d_keyGetValue(struct Key_Value *keys, const char *key, char *val1,
+Rast3d_key_get_value(struct Key_Value *keys, const char *key, char *val1,
char *val2, int result1, int result2, int *resultVar)
const char *str;
- Rast3d_error("Rast3d_keyGetValue: cannot find field %s in key structure",
+ Rast3d_error("Rast3d_key_get_value: cannot find field %s in key structure",
key);
return 0;
@@ -81,14 +81,14 @@
return 1;
- Rast3d_error("Rast3d_keyGetValue: invalid type: field %s in key structure",
+ Rast3d_error("Rast3d_key_get_value: invalid type: field %s in key structure",
key);
return 0;
-int Rast3d_keySetInt(struct Key_Value *keys, const char *key, const int *i)
+int Rast3d_key_set_int(struct Key_Value *keys, const char *key, const int *i)
char keyValStr[200];
@@ -99,7 +99,7 @@
-int Rast3d_keySetDouble(struct Key_Value *keys, const char *key, const double *d)
+int Rast3d_key_set_double(struct Key_Value *keys, const char *key, const double *d)
@@ -111,7 +111,7 @@
int
-Rast3d_keySetString(struct Key_Value *keys, const char *key,
+Rast3d_key_set_string(struct Key_Value *keys, const char *key,
char *const *keyValStr)
G_set_key_value(key, *keyValStr, keys);
@@ -121,7 +121,7 @@
int
-Rast3d_keySetValue(struct Key_Value *keys, const char *key, const char *val1,
+Rast3d_key_set_value(struct Key_Value *keys, const char *key, const char *val1,
const char *val2, int keyval1, int keyval2,
const int *keyvalVar)
@@ -135,6 +135,6 @@
return 1;
- Rast3d_error("Rast3d_keySetValue: wrong key value");
+ Rast3d_error("Rast3d_key_set_value: wrong key value");
return 0;
Modified: grass/trunk/lib/raster3d/long.c
--- grass/trunk/lib/raster3d/long.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/long.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -2,7 +2,7 @@
-int Rast3d_longEncode(long *source, unsigned char *dst, int nofNums)
+int Rast3d_long_encode(long *source, unsigned char *dst, int nofNums)
long *src, d;
int eltLength, nBytes;
@@ -33,7 +33,7 @@
void
-Rast3d_longDecode(unsigned char *source, long *dst, int nofNums, int longNbytes)
+Rast3d_long_decode(unsigned char *source, long *dst, int nofNums, int longNbytes)
long *dest;
int eltLength;
@@ -50,7 +50,7 @@
while (source != srcStop) {
*dest = *source--;
if ((eltLength >= RASTER3D_LONG_LENGTH) && (*dest != 0))
- Rast3d_fatalError("Rast3d_longDecode: decoded long too long");
+ Rast3d_fatal_error("Rast3d_long_decode: decoded long too long");
dest--;
@@ -62,7 +62,7 @@
*dest *= 256;
*dest += *source--;
dest--;
Modified: grass/trunk/lib/raster3d/mapset.c
--- grass/trunk/lib/raster3d/mapset.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/mapset.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -6,7 +6,7 @@
-void Rast3d_makeMapsetMapDirectory(const char *mapName)
+void Rast3d_make_mapset_map_directory(const char *mapName)
char buf[GNAME_MAX + sizeof(RASTER3D_DIRECTORY) + 2];
Modified: grass/trunk/lib/raster3d/mask.c
--- grass/trunk/lib/raster3d/mask.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/mask.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -24,16 +24,16 @@
static float RASTER3D_MASKNUMmaskValue;
-/* Call to dummy() to match void return type of Rast3d_setNullValue() */
+/* Call to dummy() to match void return type of Rast3d_set_null_value() */
#define RASTER3D_MASKNUM(map,Xmask,Ymask,Zmask,VALUEmask,TYPEmask) \
(RASTER3D_MASKNUMmaskValue = Rast3d_getMaskFloat (map, Xmask, Ymask, Zmask), \
- ((Rast3d_isNullValueNum (&RASTER3D_MASKNUMmaskValue, FCELL_TYPE)) ? \
- Rast3d_setNullValue (VALUEmask, 1, TYPEmask) : dummy()))
+ ((Rast3d_is_null_value_num (&RASTER3D_MASKNUMmaskValue, FCELL_TYPE)) ? \
+ Rast3d_set_null_value (VALUEmask, 1, TYPEmask) : dummy()))
-int Rast3d_maskClose()
+int Rast3d_mask_close()
/* No Idea if this is correct return value */
if (!Rast3d_maskMapExistsVar)
@@ -41,8 +41,8 @@
Rast3d_maskMapExistsVar = 0;
- if (!Rast3d_closeCell(Rast3d_maskMap)) {
- Rast3d_error("Rast3d_maskClose: error closing mask");
+ if (!Rast3d_close_cell(Rast3d_maskMap)) {
+ Rast3d_error("Rast3d_mask_close: error closing mask");
return 0;
@@ -61,7 +61,7 @@
* \return int
-int Rast3d_maskFileExists(void)
+int Rast3d_mask_file_exists(void)
return G_find_file_misc(RASTER3D_DIRECTORY, RASTER3D_CELL_ELEMENT, RASTER3D_MASK_MAP, G_mapset()) != NULL;
@@ -70,7 +70,7 @@
static int maskOpenOldCacheDefault = RASTER3D_USE_CACHE_DEFAULT;
-int Rast3d_maskOpenOld(void)
+int Rast3d_mask_open_old(void)
RASTER3D_Region region;
@@ -78,22 +78,22 @@
if (Rast3d_maskMapExistsVar)
return 1;
- Rast3d_maskMapExistsVar = Rast3d_maskFileExists();
+ Rast3d_maskMapExistsVar = Rast3d_mask_file_exists();
return 1;
- if ((Rast3d_maskMap = Rast3d_openCellOld(RASTER3D_MASK_MAP, G_mapset(),
+ if ((Rast3d_maskMap = Rast3d_open_cell_old(RASTER3D_MASK_MAP, G_mapset(),
RASTER3D_DEFAULT_WINDOW, FCELL_TYPE,
maskOpenOldCacheDefault))
== NULL) {
- Rast3d_error("Rast3d_maskOpenOld: cannot open mask");
+ Rast3d_error("Rast3d_mask_open_old: cannot open mask");
return 0;
- Rast3d_getRegionStructMap(Rast3d_maskMap, ®ion);
- Rast3d_setWindowMap(Rast3d_maskMap, ®ion);
+ Rast3d_get_region_struct_map(Rast3d_maskMap, ®ion);
+ Rast3d_set_window_map(Rast3d_maskMap, ®ion);
return 1;
@@ -112,7 +112,7 @@
top = ((double)z + 0.5) / (double)map->window.depths *
(map->window.top - map->window.bottom) + map->window.bottom;
- Rast3d_getRegionValue(Rast3d_maskMap, north, east, top, &value, FCELL_TYPE);
+ Rast3d_get_region_value(Rast3d_maskMap, north, east, top, &value, FCELL_TYPE);
return value;
@@ -131,13 +131,13 @@
* 0 ... otherwise.
-int Rast3d_maskReopen(int cache)
+int Rast3d_mask_reopen(int cache)
int tmp;
- if (!Rast3d_maskClose()) {
- Rast3d_error("Rast3d_maskReopen: error closing mask");
+ if (!Rast3d_mask_close()) {
+ Rast3d_error("Rast3d_mask_reopen: error closing mask");
return 0;
@@ -145,8 +145,8 @@
tmp = maskOpenOldCacheDefault;
maskOpenOldCacheDefault = cache;
- if (!Rast3d_maskOpenOld()) {
- Rast3d_error("Rast3d_maskReopen: error opening mask");
+ if (!Rast3d_mask_open_old()) {
+ Rast3d_error("Rast3d_mask_reopen: error opening mask");
return 0;
@@ -170,13 +170,13 @@
* \return int
-int Rast3d_isMasked(RASTER3D_Map * map, int x, int y, int z)
+int Rast3d_is_masked(RASTER3D_Map * map, int x, int y, int z)
return 0;
RASTER3D_MASKNUMmaskValue = Rast3d_getMaskFloat(map, x, y, z);
- return (Rast3d_isNullValueNum(&RASTER3D_MASKNUMmaskValue, FCELL_TYPE));
+ return (Rast3d_is_null_value_num(&RASTER3D_MASKNUMmaskValue, FCELL_TYPE));
@@ -186,7 +186,7 @@
* \brief
* Replaces the value stored in <em>value</em> with the NULL-value if
- * <em>Rast3d_isMasked (x, y, z)</em> returns 1. Does nothing otherwise.
+ * <em>Rast3d_is_masked (x, y, z)</em> returns 1. Does nothing otherwise.
* <em>value</em> is assumed to be of<em>type</em>.
* \param x
@@ -197,7 +197,7 @@
* \return void
-void Rast3d_maskNum(RASTER3D_Map * map, int x, int y, int z, void *value, int type)
+void Rast3d_mask_num(RASTER3D_Map * map, int x, int y, int z, void *value, int type)
return;
@@ -210,7 +210,7 @@
* \brief
- * Same as <em>Rast3d_maskNum (x, y, z, value, FCELL_TYPE)</em>.
+ * Same as <em>Rast3d_mask_num (x, y, z, value, FCELL_TYPE)</em>.
* \param x
* \param y
@@ -219,7 +219,7 @@
* \return void
-void Rast3d_maskFloat(RASTER3D_Map * map, int x, int y, int z, float *value)
+void Rast3d_mask_float(RASTER3D_Map * map, int x, int y, int z, float *value)
return;
@@ -232,7 +232,7 @@
* \brief
- * Same as <em>Rast3d_maskNum (x, y, z, value, DCELL_TYPE)</em>.
+ * Same as <em>Rast3d_mask_num (x, y, z, value, DCELL_TYPE)</em>.
* \param x
* \param y
@@ -241,7 +241,7 @@
* \return void
-void Rast3d_maskDouble(RASTER3D_Map * map, int x, int y, int z, double *value)
+void Rast3d_mask_double(RASTER3D_Map * map, int x, int y, int z, double *value)
return;
@@ -255,7 +255,7 @@
* \brief
* Replaces the values stored in <em>tile</em> (with <em>tileIndex</em>) for
- * which <em>Rast3d_isMasked</em> returns 1 with NULL-values. Does not change
+ * which <em>Rast3d_is_masked</em> returns 1 with NULL-values. Does not change
* the remaining values. The values are assumed to be of <em>type</em>.
* Whether replacement is performed or not only depends on location of the
* cells of the tile and not on the status of the mask for <em>map</em>
@@ -268,7 +268,7 @@
* \return void
-void Rast3d_maskTile(RASTER3D_Map * map, int tileIndex, void *tile, int type)
+void Rast3d_mask_tile(RASTER3D_Map * map, int tileIndex, void *tile, int type)
int nofNum, rows, cols, depths, xRedundant, yRedundant, zRedundant;
int x, y, z, xLength, yLength, dx, dy, dz, length;
@@ -276,21 +276,21 @@
return;
- nofNum = Rast3d_computeClippedTileDimensions(map, tileIndex,
+ nofNum = Rast3d_compute_clipped_tile_dimensions(map, tileIndex,
&rows, &cols, &depths,
&xRedundant, &yRedundant,
&zRedundant);
- Rast3d_tileIndexOrigin(map, tileIndex, &x, &y, &z);
+ Rast3d_tile_index_origin(map, tileIndex, &x, &y, &z);
if (nofNum == map->tileSize) {
/*AV*/
/* BEGIN OF ORIGINAL CODE */
- * Rast3d_getTileDimensionsMap (map, &rows, &cols, &depths);
+ * Rast3d_get_tile_dimensions_map (map, &rows, &cols, &depths);
/*AV*/
/* BEGIN OF MY CODE */
- Rast3d_getTileDimensionsMap(map, &cols, &rows, &depths);
+ Rast3d_get_tile_dimensions_map(map, &cols, &rows, &depths);
/* END OF MY CODE */
xRedundant = yRedundant = 0;
@@ -329,7 +329,7 @@
* \return void
-void Rast3d_maskOn(RASTER3D_Map * map)
+void Rast3d_mask_on(RASTER3D_Map * map)
map->useMask = 1;
@@ -346,7 +346,7 @@
* \return void
-void Rast3d_maskOff(RASTER3D_Map * map)
+void Rast3d_mask_off(RASTER3D_Map * map)
map->useMask = 0;
@@ -362,7 +362,7 @@
* \return int
-int Rast3d_maskIsOn(RASTER3D_Map * map)
+int Rast3d_mask_is_on(RASTER3D_Map * map)
return map->useMask;
@@ -377,7 +377,7 @@
* \return int
-int Rast3d_maskIsOff(RASTER3D_Map * map)
+int Rast3d_mask_is_off(RASTER3D_Map * map)
return !map->useMask;
@@ -391,7 +391,7 @@
* \return char *
-const char *Rast3d_maskFile(void)
+const char *Rast3d_mask_file(void)
return RASTER3D_MASK_MAP;
@@ -405,7 +405,7 @@
* \return int
-int Rast3d_maskMapExists(void)
+int Rast3d_mask_map_exists(void)
return Rast3d_maskMapExistsVar;
Modified: grass/trunk/lib/raster3d/misc.c
--- grass/trunk/lib/raster3d/misc.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/misc.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -12,7 +12,7 @@
-int Rast3d_g3dType2cellType(int g3dType)
+int Rast3d_g3d_type2cell_type(int g3dType)
if (g3dType == FCELL_TYPE)
return FCELL_TYPE;
@@ -22,7 +22,7 @@
void
-Rast3d_copyFloat2Double(const float *src, int offsSrc, double *dst, int offsDst,
+Rast3d_copy_float2Double(const float *src, int offsSrc, double *dst, int offsDst,
int nElts)
int i;
@@ -37,7 +37,7 @@
void
-Rast3d_copyDouble2Float(const double *src, int offsSrc, float *dst, int offsDst,
+Rast3d_copy_double2Float(const double *src, int offsSrc, float *dst, int offsDst,
int nElts)
int i;
@@ -52,18 +52,18 @@
void
-Rast3d_copyValues(const void *src, int offsSrc, int typeSrc, void *dst,
+Rast3d_copy_values(const void *src, int offsSrc, int typeSrc, void *dst,
int offsDst, int typeDst, int nElts)
int eltLength;
if ((typeSrc == FCELL_TYPE) && (typeDst == DCELL_TYPE)) {
- Rast3d_copyFloat2Double(src, offsSrc, dst, offsDst, nElts);
+ Rast3d_copy_float2Double(src, offsSrc, dst, offsDst, nElts);
return;
if ((typeSrc == DCELL_TYPE) && (typeDst == FCELL_TYPE)) {
- Rast3d_copyDouble2Float(src, offsSrc, dst, offsDst, nElts);
+ Rast3d_copy_double2Float(src, offsSrc, dst, offsDst, nElts);
return;
@@ -80,7 +80,7 @@
int Rast3d_length(int t)
if (!RASTER3D_IS_CORRECT_TYPE(t))
- Rast3d_fatalError("Rast3d_length: invalid type");
+ Rast3d_fatal_error("Rast3d_length: invalid type");
if (t == FCELL_TYPE)
return sizeof(FCELL);
@@ -89,10 +89,10 @@
return 0;
-int Rast3d_externLength(int t)
+int Rast3d_extern_length(int t)
- Rast3d_fatalError("Rast3d_externLength: invalid type");
+ Rast3d_fatal_error("Rast3d_extern_length: invalid type");
return RASTER3D_XDR_FLOAT_LENGTH;
Modified: grass/trunk/lib/raster3d/null.c
--- grass/trunk/lib/raster3d/null.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/null.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -9,7 +9,7 @@
-int Rast3d_isNullValueNum(const void *n, int type)
+int Rast3d_is_null_value_num(const void *n, int type)
return Rast_is_f_null_value(n);
@@ -32,7 +32,7 @@
* \return void
-void Rast3d_setNullValue(void *c, int nofElts, int type)
+void Rast3d_set_null_value(void *c, int nofElts, int type)
Rast_set_f_null_value((float *)c, nofElts);
Modified: grass/trunk/lib/raster3d/open.c
--- grass/trunk/lib/raster3d/open.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/open.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -9,21 +9,21 @@
-void *Rast3d_openCellOldNoHeader(const char *name, const char *mapset)
+void *Rast3d_open_cell_old_no_header(const char *name, const char *mapset)
RASTER3D_Map *map;
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
- Rast3d_initDefaults();
+ Rast3d_init_defaults();
- Rast3d_error(_("Rast3d_openCellOldNoHeader: error in Rast3d_maskOpenOld"));
+ Rast3d_error(_("Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"));
return (void *)NULL;
map = Rast3d_malloc(sizeof(RASTER3D_Map));
if (map == NULL) {
- Rast3d_error(_("Rast3d_openCellOldNoHeader: error in Rast3d_malloc"));
+ Rast3d_error(_("Rast3d_open_cell_old_no_header: error in Rast3d_malloc"));
@@ -34,12 +34,12 @@
map->data_fd = G_open_old_misc(RASTER3D_DIRECTORY, RASTER3D_CELL_ELEMENT, xname, xmapset);
if (map->data_fd < 0) {
- Rast3d_error(_("Rast3d_openCellOldNoHeader: error in G_open_old"));
+ Rast3d_error(_("Rast3d_open_cell_old_no_header: error in G_open_old"));
Rast3d_range_init(map);
- Rast3d_maskOff(map);
+ Rast3d_mask_off(map);
return map;
@@ -56,13 +56,13 @@
* cache-mode used and must be either RASTER3D_NO_CACHE, RASTER3D_USE_CACHE_DEFAULT,
* RASTER3D_USE_CACHE_X, RASTER3D_USE_CACHE_Y, RASTER3D_USE_CACHE_Z,
* RASTER3D_USE_CACHE_XY, RASTER3D_USE_CACHE_XZ, RASTER3D_USE_CACHE_YZ,
- * RASTER3D_USE_CACHE_XYZ, the result of <tt>Rast3d_cacheSizeEncode ()</tt> (cf.{g3d:G3d.cacheSizeEncode}), or any positive integer which
+ * RASTER3D_USE_CACHE_XYZ, the result of <tt>Rast3d_cache_size_encode ()</tt> (cf.{g3d:G3d.cacheSizeEncode}), or any positive integer which
* specifies the number of tiles buffered in the cache. <em>window</em> sets the
* window-region for the map. It is either a pointer to a window structure or
* RASTER3D_DEFAULT_WINDOW, which uses the window stored at initialization time or
- * set via <tt>Rast3d_setWindow ()</tt> (cf.{g3d:G3d.setWindow}).
+ * set via <tt>Rast3d_set_window ()</tt> (cf.{g3d:G3d.setWindow}).
* To modify the window for the map after it has already been opened use
- * <tt>Rast3d_setWindowMap ()</tt> (cf.{g3d:G3d.setWindowMap}).
+ * <tt>Rast3d_set_window_map ()</tt> (cf.{g3d:G3d.setWindowMap}).
* Returns a pointer to the cell structure ... if successful, NULL ...
* otherwise.
@@ -74,7 +74,7 @@
* \return void *
-void *Rast3d_openCellOld(const char *name, const char *mapset,
+void *Rast3d_open_cell_old(const char *name, const char *mapset,
RASTER3D_Region * window, int typeIntern, int cache)
RASTER3D_Map *map;
@@ -86,18 +86,18 @@
char *ltmp, *unit;
double north, south, east, west, top, bottom;
- map = Rast3d_openCellOldNoHeader(name, mapset);
+ map = Rast3d_open_cell_old_no_header(name, mapset);
if (map == NULL) {
- Rast3d_error(_("Rast3d_openCellOld: error in Rast3d_openCellOldNoHeader"));
+ Rast3d_error(_("Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"));
if (lseek(map->data_fd, (long)0, SEEK_SET) == -1) {
- Rast3d_error(_("Rast3d_openCellOld: can't rewind file"));
+ Rast3d_error(_("Rast3d_open_cell_old: can't rewind file"));
- if (!Rast3d_readHeader(map,
+ if (!Rast3d_read_header(map,
&proj, &zone,
&north, &south, &east, &west, &top, &bottom,
@@ -105,19 +105,19 @@
&tileX, &tileY, &tileZ,
&precision, &dataOffset, &useXdr, &hasIndex, &unit)) {
- Rast3d_error(_("Rast3d_openCellOld: error in Rast3d_readHeader"));
+ Rast3d_error(_("Rast3d_open_cell_old: error in Rast3d_read_header"));
return 0;
if (window == RASTER3D_DEFAULT_WINDOW)
- window = Rast3d_windowPtr();
+ window = Rast3d_window_ptr();
if (proj != window->proj) {
- Rast3d_error(_("Rast3d_openCellOld: projection does not match window projection"));
+ Rast3d_error(_("Rast3d_open_cell_old: projection does not match window projection"));
if (zone != window->zone) {
- Rast3d_error(_("Rast3d_openCellOld: zone does not match window zone"));
+ Rast3d_error(_("Rast3d_open_cell_old: zone does not match window zone"));
@@ -125,31 +125,31 @@
if (hasIndex) {
/* see RASTER3D_openCell_new () for format of header */
- if ((!Rast3d_readInts(map->data_fd, map->useXdr,
+ if ((!Rast3d_read_ints(map->data_fd, map->useXdr,
&(map->indexLongNbytes), 1)) ||
- (!Rast3d_readInts(map->data_fd, map->useXdr,
+ (!Rast3d_read_ints(map->data_fd, map->useXdr,
&(map->indexNbytesUsed), 1))) {
- Rast3d_error(_("Rast3d_openCellOld: can't read header"));
+ Rast3d_error(_("Rast3d_open_cell_old: can't read header"));
/* if our long is to short to store offsets we can't read the file */
if (map->indexNbytesUsed > sizeof(long))
- Rast3d_fatalError(_("Rast3d_openCellOld: index does not fit into long"));
+ Rast3d_fatal_error(_("Rast3d_open_cell_old: index does not fit into long"));
ltmp = Rast3d_malloc(map->indexLongNbytes);
if (ltmp == NULL) {
- Rast3d_error(_("Rast3d_openCellOld: error in Rast3d_malloc"));
+ Rast3d_error(_("Rast3d_open_cell_old: error in Rast3d_malloc"));
/* convert file long to long */
if (read(map->data_fd, ltmp, map->indexLongNbytes) !=
map->indexLongNbytes) {
- Rast3d_longDecode(ltmp, &(map->indexOffset), 1, map->indexLongNbytes);
+ Rast3d_long_decode(ltmp, &(map->indexOffset), 1, map->indexLongNbytes);
Rast3d_free(ltmp);
@@ -158,20 +158,20 @@
if (typeIntern == RASTER3D_TILE_SAME_AS_FILE)
typeIntern = type;
- if (!Rast3d_fillHeader(map, RASTER3D_READ_DATA, compression, useRle, useLzw,
+ if (!Rast3d_fill_header(map, RASTER3D_READ_DATA, compression, useRle, useLzw,
type, precision, cache,
hasIndex, map->useXdr, typeIntern,
nofHeaderBytes, tileX, tileY, tileZ,
proj, zone,
north, south, east, west, top, bottom,
rows, cols, depths, ew_res, ns_res, tb_res, unit)) {
- Rast3d_error(_("Rast3d_openCellOld: error in Rast3d_fillHeader"));
+ Rast3d_error(_("Rast3d_open_cell_old: error in Rast3d_fill_header"));
- Rast3d_regionCopy(&(map->window), window);
- Rast3d_adjustRegion(&(map->window));
- Rast3d_getNearestNeighborFunPtr(&(map->resampleFun));
+ Rast3d_region_copy(&(map->window), window);
+ Rast3d_adjust_region(&(map->window));
+ Rast3d_get_nearest_neighbor_fun_ptr(&(map->resampleFun));
return map;
@@ -188,7 +188,7 @@
* (cf.{g3d:G3d.cacheSizeEncode}), or any positive integer which
* specifies the number of tiles buffered in the cache. <em>region</em> specifies
* the 3d region.
@@ -202,7 +202,7 @@
* \return void *
-void *Rast3d_openCellNew(const char *name, int typeIntern, int cache,
+void *Rast3d_open_cell_new(const char *name, int typeIntern, int cache,
RASTER3D_Map *map;
@@ -210,9 +210,9 @@
long ldummy = 0;
- Rast3d_error(_("Rast3d_openCellNew: error in Rast3d_maskOpenOld"));
+ Rast3d_error(_("Rast3d_open_cell_new: error in Rast3d_mask_open_old"));
@@ -221,7 +221,7 @@
if (map == NULL) {
- Rast3d_error(_("Rast3d_openCellNew: error in Rast3d_malloc"));
+ Rast3d_error(_("Rast3d_open_cell_new: error in Rast3d_malloc"));
@@ -236,11 +236,11 @@
map->tempName = G_tempfile();
map->data_fd = open(map->tempName, O_RDWR | O_CREAT | O_TRUNC, 0666);
- Rast3d_error(_("Rast3d_openCellNew: could not open file"));
+ Rast3d_error(_("Rast3d_open_cell_new: could not open file"));
map->useXdr = RASTER3D_USE_XDR;
@@ -278,15 +278,15 @@
/* the index is appended at the end of the file at closing time. since */
/* we do not know this position yet we write dummy values */
- if ((!Rast3d_writeInts(map->data_fd, map->useXdr,
+ if ((!Rast3d_write_ints(map->data_fd, map->useXdr,
- (!Rast3d_writeInts(map->data_fd, map->useXdr, &dummy, 1))) {
- Rast3d_error(_("Rast3d_openCellNew: can't write header"));
+ (!Rast3d_write_ints(map->data_fd, map->useXdr, &dummy, 1))) {
+ Rast3d_error(_("Rast3d_open_cell_new: can't write header"));
if (write(map->data_fd, &ldummy, map->indexLongNbytes) !=
@@ -295,9 +295,9 @@
nofHeaderBytes = lseek(map->data_fd, (long)0, SEEK_CUR);
- Rast3d_adjustRegion(region);
+ Rast3d_adjust_region(region);
- if (!Rast3d_fillHeader(map, RASTER3D_WRITE_DATA, compression,
+ if (!Rast3d_fill_header(map, RASTER3D_WRITE_DATA, compression,
g3d_do_rle_compression, g3d_do_lzw_compression,
g3d_file_type, precision, cache, RASTER3D_HAS_INDEX,
map->useXdr, typeIntern, nofHeaderBytes,
@@ -309,16 +309,16 @@
region->rows, region->cols, region->depths,
region->ew_res, region->ns_res, region->tb_res,
g3d_unit_default)) {
- Rast3d_error(_("Rast3d_openCellNew: error in Rast3d_fillHeader"));
+ Rast3d_error(_("Rast3d_open_cell_new: error in Rast3d_fill_header"));
/*Set the map window to the map region */
- Rast3d_regionCopy(&(map->window), region);
+ Rast3d_region_copy(&(map->window), region);
/*Set the resampling function to nearest neighbor for data access */
return (void *)map;
Modified: grass/trunk/lib/raster3d/open2.c
--- grass/trunk/lib/raster3d/open2.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/open2.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -12,7 +12,7 @@
* the 3d region.
@@ -38,7 +38,7 @@
-void *Rast3d_openNewParam(const char *name, int typeIntern, int cache,
+void *Rast3d_open_new_param(const char *name, int typeIntern, int cache,
RASTER3D_Region * region, int type, int doLzw, int doRle,
int precision, int tileX, int tileY, int tileZ)
@@ -47,22 +47,22 @@
oldTileZ;
int oldType;
- Rast3d_getCompressionMode(&oldCompress, &oldLzw, &oldRle, &oldPrecision);
- Rast3d_setCompressionMode(oldCompress, doLzw, doRle, precision);
+ Rast3d_get_compression_mode(&oldCompress, &oldLzw, &oldRle, &oldPrecision);
+ Rast3d_set_compression_mode(oldCompress, doLzw, doRle, precision);
- Rast3d_getTileDimension(&oldTileX, &oldTileY, &oldTileZ);
- Rast3d_setTileDimension(tileX, tileY, tileZ);
+ Rast3d_get_tile_dimension(&oldTileX, &oldTileY, &oldTileZ);
+ Rast3d_set_tile_dimension(tileX, tileY, tileZ);
- oldType = Rast3d_getFileType();
- Rast3d_setFileType(type);
+ oldType = Rast3d_get_file_type();
+ Rast3d_set_file_type(type);
- map = Rast3d_openCellNew(name, typeIntern, cache, region);
+ map = Rast3d_open_cell_new(name, typeIntern, cache, region);
- Rast3d_setCompressionMode(oldCompress, oldLzw, oldRle, oldPrecision);
- Rast3d_setTileDimension(oldTileX, oldTileY, oldTileZ);
- Rast3d_setFileType(oldType);
+ Rast3d_set_compression_mode(oldCompress, oldLzw, oldRle, oldPrecision);
+ Rast3d_set_tile_dimension(oldTileX, oldTileY, oldTileZ);
+ Rast3d_set_file_type(oldType);
return map;
@@ -78,7 +78,7 @@
* the 3d region.
@@ -95,28 +95,28 @@
-void *Rast3d_openNewOptTileSize(const char *name, int cache, RASTER3D_Region * region, int type, int maxSize)
+void *Rast3d_open_new_opt_tile_size(const char *name, int cache, RASTER3D_Region * region, int type, int maxSize)
void *map;
int oldTileX, oldTileY, oldTileZ, oldType;
int tileX, tileY, tileZ;
- Rast3d_computeOptimalTileDimension(region, type, &tileX, &tileY, &tileZ, maxSize);
+ Rast3d_compute_optimal_tile_dimension(region, type, &tileX, &tileY, &tileZ, maxSize);
- map = Rast3d_openCellNew(name, RASTER3D_TILE_SAME_AS_FILE, cache, region);
+ map = Rast3d_open_cell_new(name, RASTER3D_TILE_SAME_AS_FILE, cache, region);
return map;
Modified: grass/trunk/lib/raster3d/param.c
--- grass/trunk/lib/raster3d/param.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/param.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -38,7 +38,7 @@
* \return void
-void Rast3d_setStandard3dInputParams()
+void Rast3d_set_standard3d_input_params()
param = Rast3d_malloc(sizeof(Rast3d_paramType));
@@ -53,7 +53,7 @@
-int Rast3d_getStandard3dParams(int *useTypeDefault, int *type,
+int Rast3d_get_standard3d_params(int *useTypeDefault, int *type,
int *useLzwDefault, int *doLzw,
int *useRleDefault, int *doRle,
int *usePrecisionDefault, int *precision,
@@ -65,25 +65,25 @@
*useTypeDefault = *useLzwDefault = *useRleDefault = 0;
*usePrecisionDefault = *useDimensionDefault = 0;
if (strcmp(param->type->answer, "double") == 0)
*type = DCELL_TYPE;
else if (strcmp(param->type->answer, "float") == 0)
*type = FCELL_TYPE;
else {
- *type = Rast3d_getFileType();
+ *type = Rast3d_get_file_type();
*useTypeDefault = 1;
- Rast3d_getCompressionMode(&doCompress, doLzw, doRle, precision);
+ Rast3d_get_compression_mode(&doCompress, doLzw, doRle, precision);
if (strcmp(param->precision->answer, "default") != 0) {
if (strcmp(param->precision->answer, "max") == 0)
*precision = -1;
else if ((sscanf(param->precision->answer, "%d", precision) != 1) ||
(*precision < 0)) {
- Rast3d_error(_("Rast3d_getStandard3dParams: precision value invalid"));
+ Rast3d_error(_("Rast3d_get_standard3d_params: precision value invalid"));
return 0;
@@ -112,11 +112,11 @@
else
*useLzwDefault = *useRleDefault = 1;
- Rast3d_getTileDimension(tileX, tileY, tileZ);
+ Rast3d_get_tile_dimension(tileX, tileY, tileZ);
if (strcmp(param->dimension->answer, "default") != 0) {
if (sscanf(param->dimension->answer, "%dx%dx%d",
tileX, tileY, tileZ) != 3) {
- Rast3d_error(_("Rast3d_getStandard3dParams: tile dimension value invalid"));
+ Rast3d_error(_("Rast3d_get_standard3d_params: tile dimension value invalid"));
return 0;
@@ -132,7 +132,7 @@
static struct Option *windowParam = NULL;
-void Rast3d_setWindowParams(void)
+void Rast3d_set_window_params(void)
windowParam = G_define_option();
windowParam->key = "region3";
@@ -145,7 +145,7 @@
-char *Rast3d_getWindowParams(void)
+char *Rast3d_get_window_params(void)
if (windowParam == NULL)
return NULL;
Modified: grass/trunk/lib/raster3d/putvalue.c
--- grass/trunk/lib/raster3d/putvalue.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/putvalue.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -5,7 +5,7 @@
* \brief
- * Is equivalent to Rast3d_putValue (map, x, y, z, &value, FCELL_TYPE).
+ * Is equivalent to Rast3d_put_value (map, x, y, z, &value, FCELL_TYPE).
* \param map
* \param x
@@ -15,23 +15,23 @@
* \return int
-int Rast3d_putFloat(RASTER3D_Map * map, int x, int y, int z, float value)
+int Rast3d_put_float(RASTER3D_Map * map, int x, int y, int z, float value)
float *tile;
if (map->typeIntern == DCELL_TYPE) {
- if (!Rast3d_putDouble(map, x, y, z, (double)value)) {
- Rast3d_error("Rast3d_putFloat: error in Rast3d_putDouble");
+ if (!Rast3d_put_double(map, x, y, z, (double)value)) {
+ Rast3d_error("Rast3d_put_float: error in Rast3d_put_double");
return 0;
return 1;
if (tile == NULL) {
- Rast3d_error("Rast3d_putFloat: error in Rast3d_getTilePtr");
+ Rast3d_error("Rast3d_put_float: error in Rast3d_get_tile_ptr");
return 0;
@@ -45,7 +45,7 @@
* \brief
- * Is equivalent to Rast3d_putValue (map, x, y, z, &value, DCELL_TYPE).
+ * Is equivalent to Rast3d_put_value (map, x, y, z, &value, DCELL_TYPE).
* \param map
* \param x
@@ -55,23 +55,23 @@
* \return int
-int Rast3d_putDouble(RASTER3D_Map * map, int x, int y, int z, double value)
+int Rast3d_put_double(RASTER3D_Map * map, int x, int y, int z, double value)
double *tile;
if (map->typeIntern == FCELL_TYPE) {
- if (!Rast3d_putFloat(map, x, y, z, (float)value)) {
- Rast3d_error("Rast3d_putDouble: error in Rast3d_putFloat");
+ if (!Rast3d_put_float(map, x, y, z, (float)value)) {
+ Rast3d_error("Rast3d_put_double: error in Rast3d_put_float");
return 0;
return 1;
if (tile == NULL) {
- Rast3d_error("Rast3d_putDouble: error in Rast3d_getTilePtr");
+ Rast3d_error("Rast3d_put_double: error in Rast3d_get_tile_ptr");
return 0;
@@ -99,18 +99,18 @@
int
-Rast3d_putValue(RASTER3D_Map * map, int x, int y, int z, const void *value, int type)
+Rast3d_put_value(RASTER3D_Map * map, int x, int y, int z, const void *value, int type)
- if (!Rast3d_putFloat(map, x, y, z, *((float *)value))) {
- Rast3d_error("Rast3d_putValue: error in Rast3d_putFloat");
+ if (!Rast3d_put_float(map, x, y, z, *((float *)value))) {
+ Rast3d_error("Rast3d_put_value: error in Rast3d_put_float");
return 0;
return 1;
- if (!Rast3d_putDouble(map, x, y, z, *((double *)value))) {
- Rast3d_error("Rast3d_putValue: error in Rast3d_putDouble");
+ if (!Rast3d_put_double(map, x, y, z, *((double *)value))) {
+ Rast3d_error("Rast3d_put_value: error in Rast3d_put_double");
return 0;
return 1;
Modified: grass/trunk/lib/raster3d/range.c
--- grass/trunk/lib/raster3d/range.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/range.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -14,7 +14,7 @@
void
-Rast3d_range_updateFromTile(RASTER3D_Map * map, const void *tile, int rows, int cols,
+Rast3d_range_update_from_tile(RASTER3D_Map * map, const void *tile, int rows, int cols,
int depths, int xRedundant, int yRedundant,
int zRedundant, int nofNum, int type)
@@ -22,7 +22,7 @@
struct FPRange *range;
range = &(map->range);
- cellType = Rast3d_g3dType2cellType(type);
+ cellType = Rast3d_g3d_type2cell_type(type);
Rast_row_update_fp_range(tile, map->tileSize, range, cellType);
@@ -58,7 +58,7 @@
int
-Rast3d_readRange(const char *name, const char *mapset, struct FPRange *drange)
+Rast3d_read_range(const char *name, const char *mapset, struct FPRange *drange)
/* adapted from Rast_read_fp_range */
int fd;
@@ -115,7 +115,7 @@
if (map->operation == RASTER3D_WRITE_DATA)
return 1;
- if (Rast3d_readRange(map->fileName, map->mapset, &(map->range)) == -1) {
+ if (Rast3d_read_range(map->fileName, map->mapset, &(map->range)) == -1) {
return 0;
Modified: grass/trunk/lib/raster3d/raster3d_intern.h
--- grass/trunk/lib/raster3d/raster3d_intern.h 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/raster3d_intern.h 2011-08-12 08:32:30 UTC (rev 47593)
@@ -61,8 +61,8 @@
-extern void Rast3d_fatalError(const char * /* msg */ , ...);
-extern void Rast3d_fatalError_noargs(const char * /* msg */ );
+extern void Rast3d_fatal_error(const char * /* msg */ , ...);
+extern void Rast3d_fatal_error_noargs(const char * /* msg */ );
Modified: grass/trunk/lib/raster3d/region.c
--- grass/trunk/lib/raster3d/region.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/region.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -19,7 +19,7 @@
* \return void
-void Rast3d_extract2dRegion(RASTER3D_Region * region3d, struct Cell_head *region2d)
+void Rast3d_extract2d_region(RASTER3D_Region * region3d, struct Cell_head *region2d)
region2d->proj = region3d->proj;
region2d->zone = region3d->zone;
@@ -46,7 +46,7 @@
* \return void
-void Rast3d_regionToCellHead(RASTER3D_Region * region3d, struct Cell_head *region2d)
+void Rast3d_region_to_cell_head(RASTER3D_Region * region3d, struct Cell_head *region2d)
@@ -86,7 +86,7 @@
void
-Rast3d_incorporate2dRegion(struct Cell_head *region2d, RASTER3D_Region * region3d)
+Rast3d_incorporate2d_region(struct Cell_head *region2d, RASTER3D_Region * region3d)
region3d->proj = region2d->proj;
region3d->zone = region2d->zone;
@@ -115,7 +115,7 @@
void
-Rast3d_regionFromToCellHead(struct Cell_head *region2d, RASTER3D_Region * region3d)
+Rast3d_region_from_to_cell_head(struct Cell_head *region2d, RASTER3D_Region * region3d)
@@ -149,16 +149,16 @@
* \return void
-void Rast3d_adjustRegion(RASTER3D_Region * region)
+void Rast3d_adjust_region(RASTER3D_Region * region)
struct Cell_head region2d;
- Rast3d_regionToCellHead(region, ®ion2d);
+ Rast3d_region_to_cell_head(region, ®ion2d);
G_adjust_Cell_head3(®ion2d, 1, 1, 1);
- Rast3d_regionFromToCellHead(®ion2d, region);
+ Rast3d_region_from_to_cell_head(®ion2d, region);
if (region->depths <= 0)
- Rast3d_fatalError("Rast3d_adjustRegion: depths <= 0");
+ Rast3d_fatal_error("Rast3d_adjust_region: depths <= 0");
region->tb_res = (region->top - region->bottom) / region->depths;
@@ -175,16 +175,16 @@
* \return void
-void Rast3d_adjustRegionRes(RASTER3D_Region * region)
+void Rast3d_adjust_region_res(RASTER3D_Region * region)
if (region->tb_res <= 0)
- Rast3d_fatalError("Rast3d_adjustRegionRes: tb_res <= 0");
+ Rast3d_fatal_error("Rast3d_adjust_region_res: tb_res <= 0");
region->depths = (region->top - region->bottom + region->tb_res / 2.0) /
region->tb_res;
@@ -205,7 +205,7 @@
* \return void
-void Rast3d_regionCopy(RASTER3D_Region * regionDest, RASTER3D_Region * regionSrc)
+void Rast3d_region_copy(RASTER3D_Region * regionDest, RASTER3D_Region * regionSrc)
*regionDest = *regionSrc;
@@ -214,7 +214,7 @@
int
-Rast3d_readRegionMap(const char *name, const char *mapset, RASTER3D_Region * region)
+Rast3d_read_region_map(const char *name, const char *mapset, RASTER3D_Region * region)
char fullName[GPATH_MAX];
@@ -226,7 +226,7 @@
mapset = G_find_grid3(name, "");
Rast3d_filename(fullName, RASTER3D_HEADER_ELEMENT, name, mapset);
- return Rast3d_readWindow(region, fullName);
+ return Rast3d_read_window(region, fullName);
@@ -245,7 +245,7 @@
* \return int
-int Rast3d_isValidLocation(RASTER3D_Region *region, double north, double east, double top)
+int Rast3d_is_valid_location(RASTER3D_Region *region, double north, double east, double top)
return ((north >= region->south) && (north <= region->north) &&
(east >= region->west) && (east <= region->east) &&
@@ -298,7 +298,7 @@
* Converts region-coordinates <em>(north, east,
* top)</em> into cell-coordinates <em>(x, y, z)</em>.
- * This function calls Rast3d_fatalError in case location is not in window.
+ * This function calls Rast3d_fatal_error in case location is not in window.
* \param map
* \param north
@@ -314,8 +314,8 @@
Rast3d_location2coord2(RASTER3D_Region *region, double north, double east, double top,
- if (!Rast3d_isValidLocation(region, north, east, top))
- Rast3d_fatalError("Rast3d_location2coord2: location not in region");
+ if (!Rast3d_is_valid_location(region, north, east, top))
+ Rast3d_fatal_error("Rast3d_location2coord2: location not in region");
Rast3d_location2coord(region, north, east, top, x, y, z);
Modified: grass/trunk/lib/raster3d/resample.c
--- grass/trunk/lib/raster3d/resample.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/resample.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -22,7 +22,7 @@
void
-Rast3d_nearestNeighbor(RASTER3D_Map * map, int x, int y, int z, void *value,
+Rast3d_nearest_neighbor(RASTER3D_Map * map, int x, int y, int z, void *value,
int type)
double north, east, top;
@@ -38,12 +38,12 @@
return;
@@ -53,13 +53,13 @@
* \brief
* Sets the resampling function to be used by
- * Rast3d_getValue () (cf.{g3d:G3d.getValue}). This function is defined
+ * Rast3d_get_value () (cf.{g3d:G3d.getValue}). This function is defined
* as follows:
* \return void
-void Rast3d_setResamplingFun(RASTER3D_Map * map, void (*resampleFun) ())
+void Rast3d_set_resampling_fun(RASTER3D_Map * map, void (*resampleFun) ())
map->resampleFun = resampleFun;
@@ -77,7 +77,7 @@
* \return void
-void Rast3d_getResamplingFun(RASTER3D_Map * map, void (**resampleFun) ())
+void Rast3d_get_resampling_fun(RASTER3D_Map * map, void (**resampleFun) ())
*resampleFun = map->resampleFun;
@@ -89,12 +89,12 @@
* \brief
* Returns
- * in <em>nnFunPtr</em> a pointer to Rast3d_nearestNeighbor () (cf.{g3d:G3d.nearestNeighbor}).
+ * in <em>nnFunPtr</em> a pointer to Rast3d_nearest_neighbor () (cf.{g3d:G3d.nearestNeighbor}).
* \return void
-void Rast3d_getNearestNeighborFunPtr(void (**nnFunPtr) ())
+void Rast3d_get_nearest_neighbor_fun_ptr(void (**nnFunPtr) ())
- *nnFunPtr = Rast3d_nearestNeighbor;
+ *nnFunPtr = Rast3d_nearest_neighbor;
Modified: grass/trunk/lib/raster3d/retile.c
--- grass/trunk/lib/raster3d/retile.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/retile.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -16,45 +16,45 @@
int tileXsave, tileYsave, tileZsave;
- saveType = Rast3d_getFileType();
- Rast3d_setFileType(Rast3d_fileTypeMap(map));
- Rast3d_getTileDimension(&tileXsave, &tileYsave, &tileZsave);
- typeIntern = Rast3d_tileTypeMap(map);
- Rast3d_getRegionStructMap(map, ®ion);
+ saveType = Rast3d_get_file_type();
+ Rast3d_set_file_type(Rast3d_file_type_map(map));
+ Rast3d_get_tile_dimension(&tileXsave, &tileYsave, &tileZsave);
+ typeIntern = Rast3d_tile_type_map(map);
+ Rast3d_get_region_struct_map(map, ®ion);
- map2 = Rast3d_openCellNew(nameOut, typeIntern, RASTER3D_NO_CACHE, ®ion);
+ map2 = Rast3d_open_cell_new(nameOut, typeIntern, RASTER3D_NO_CACHE, ®ion);
if (map2 == NULL)
- Rast3d_fatalError("Rast3d_retile: error in Rast3d_openCellNew");
+ Rast3d_fatal_error("Rast3d_retile: error in Rast3d_open_cell_new");
- Rast3d_setFileType(saveType);
- Rast3d_setTileDimension(tileXsave, tileYsave, tileZsave);
+ Rast3d_set_file_type(saveType);
+ Rast3d_set_tile_dimension(tileXsave, tileYsave, tileZsave);
- data = Rast3d_allocTiles(map2, 1);
+ data = Rast3d_alloc_tiles(map2, 1);
if (data == NULL)
- Rast3d_fatalError("Rast3d_retile: error in Rast3d_allocTiles");
+ Rast3d_fatal_error("Rast3d_retile: error in Rast3d_alloc_tiles");
- Rast3d_getNofTilesMap(map2, &nx, &ny, &nz);
+ Rast3d_get_nof_tiles_map(map2, &nx, &ny, &nz);
for (z = 0; z < nz; z++) {
G_percent(z, nz, 1);
for (y = 0; y < ny; y++)
for (x = 0; x < nx; x++) {
- Rast3d_getBlock(map, x * tileX, y * tileY, z * tileZ,
+ Rast3d_get_block(map, x * tileX, y * tileY, z * tileZ,
tileX, tileY, tileZ, data, typeIntern);
- if (!Rast3d_writeTile
- (map2, Rast3d_tile2tileIndex(map2, x, y, z), data,
+ if (!Rast3d_write_tile
+ (map2, Rast3d_tile2tile_index(map2, x, y, z), data,
typeIntern))
- Rast3d_fatalError
- ("Rast3d_retileNocache: error in Rast3d_writeTile");
+ ("Rast3d_retileNocache: error in Rast3d_write_tile");
G_percent(1, 1, 1);
- Rast3d_freeTiles(data);
- Rast3d_closeCell(map2);
+ Rast3d_free_tiles(data);
+ Rast3d_close_cell(map2);
@@ -87,28 +87,28 @@
- if (!Rast3d_tileUseCacheMap(map)) {
+ if (!Rast3d_tile_use_cache_map(map)) {
retileNocache(map, nameOut, tileX, tileY, tileZ);
return;
map2 =
- Rast3d_openCellNew(nameOut, typeIntern, RASTER3D_USE_CACHE_DEFAULT, ®ion);
+ Rast3d_open_cell_new(nameOut, typeIntern, RASTER3D_USE_CACHE_DEFAULT, ®ion);
if (map2 == NULL)
- Rast3d_coord2tileCoord(map2, 0, 0, 0,
+ Rast3d_coord2tile_coord(map2, 0, 0, 0,
&xTile, &yTile, &zTile, &xOffs, &yOffs, &zOffs);
prev = zTile;
@@ -116,30 +116,30 @@
x = 0;
y = 0;
- Rast3d_getCoordsMap(map, &rows, &cols, &depths);
+ Rast3d_get_coords_map(map, &rows, &cols, &depths);
for (z = 0; z < depths; z++) {
G_percent(z, depths, 1);
- Rast3d_coord2tileCoord(map2, x, y, z, &xTile, &yTile, &zTile,
+ Rast3d_coord2tile_coord(map2, x, y, z, &xTile, &yTile, &zTile,
if (zTile > prev) {
- if (!Rast3d_flushAllTiles(map2))
- Rast3d_fatalError("Rast3d_retile: error in Rast3d_flushAllTiles");
+ if (!Rast3d_flush_all_tiles(map2))
+ Rast3d_fatal_error("Rast3d_retile: error in Rast3d_flush_all_tiles");
prev++;
for (y = 0; y < rows; y++)
for (x = 0; x < cols; x++) {
- Rast3d_getValueRegion(map, x, y, z, &value, typeIntern);
- if (!Rast3d_putValue(map2, x, y, z, &value, typeIntern))
- Rast3d_fatalError("Rast3d_retile: error in Rast3d_putValue");
+ Rast3d_get_value_region(map, x, y, z, &value, typeIntern);
+ if (!Rast3d_put_value(map2, x, y, z, &value, typeIntern))
+ Rast3d_fatal_error("Rast3d_retile: error in Rast3d_put_value");
G_percent(1, 1, 1);
- if (!Rast3d_closeCell(map2))
- Rast3d_fatalError("Rast3d_retile: error in Rast3d_closeCell");
+ if (!Rast3d_close_cell(map2))
+ Rast3d_fatal_error("Rast3d_retile: error in Rast3d_close_cell");
Modified: grass/trunk/lib/raster3d/rle.c
--- grass/trunk/lib/raster3d/rle.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/rle.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -120,13 +120,13 @@
-int G_rle_count_only(char *src, int nofElts, int eltLength)
+int Rast3d_rle_count_only(char *src, int nofElts, int eltLength)
int length, nofEqual;
char *head, *tail, *headStop, *headStop2;
if (nofElts <= 0)
- Rast3d_fatalError("trying to encode 0-length list");
+ Rast3d_fatal_error("trying to encode 0-length list");
length = 0;
nofEqual = 1;
@@ -163,13 +163,13 @@
-void G_rle_encode(char *src, char *dst, int nofElts, int eltLength)
+void Rast3d_rle_encode(char *src, char *dst, int nofElts, int eltLength)
if (nofElts <= 0)
length = 0;
nofEqual = 1;
@@ -220,7 +220,7 @@
void
-G_rle_decode(char *src, char *dst, int nofElts, int eltLength,
+Rast3d_rle_decode(char *src, char *dst, int nofElts, int eltLength,
int *lengthEncode, int *lengthDecode)
int nofEqual;
@@ -247,7 +247,7 @@
src += eltLength;
- Rast3d_fatalError("G_rle_decode: string ends prematurely");
+ Rast3d_fatal_error("Rast3d_rle_decode: string ends prematurely");
Modified: grass/trunk/lib/raster3d/test/test_coordinate_transform.c
--- grass/trunk/lib/raster3d/test/test_coordinate_transform.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/test/test_coordinate_transform.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -41,8 +41,8 @@
/* We need to set up a specific region for the new g3d map.
* First we safe the default region. */
- Rast3d_getWindow(&default_region);
- Rast3d_regionCopy(®ion, &default_region);
+ Rast3d_get_window(&default_region);
+ Rast3d_region_copy(®ion, &default_region);
region.bottom = 0.0;
region.top = 1000;
@@ -54,12 +54,12 @@
region.cols = 10;
region.depths = 5;
- Rast3d_adjustRegion(®ion);
+ Rast3d_adjust_region(®ion);
- map = Rast3d_openNewOptTileSize("test_coordinate_transform", RASTER3D_USE_CACHE_XYZ, ®ion, FCELL_TYPE, 32);
+ map = Rast3d_open_new_opt_tile_size("test_coordinate_transform", RASTER3D_USE_CACHE_XYZ, ®ion, FCELL_TYPE, 32);
/* The window is the same as the map region ... of course */
- Rast3d_setWindowMap(map, ®ion);
+ Rast3d_set_window_map(map, ®ion);
G_message("Test the upper right corner, coordinates must be col = 9, row = 0, depth = 4");
@@ -143,7 +143,7 @@
sum++;
- Rast3d_closeCell(map);
+ Rast3d_close_cell(map);
G_remove("grid3", "test_coordinate_transform");
@@ -157,7 +157,7 @@
int sum = 0;
RASTER3D_Region region, new_region;
- Rast3d_getWindow(®ion);
+ Rast3d_get_window(®ion);
region.top = 1000;
region.south = 10000;
@@ -172,93 +172,93 @@
region.tb_res = 0;
/* Test region adjustment */
if(region.ew_res != 500) {
- G_message("Error in Rast3d_adjustRegion: region.ew_res != 500");
+ G_message("Error in Rast3d_adjust_region: region.ew_res != 500");
sum++;
if(region.ns_res != 500) {
sum++;
if(region.tb_res != 200) {
sum++;
/* Test the region copy */
- Rast3d_regionCopy(&new_region, ®ion);
+ Rast3d_region_copy(&new_region, ®ion);
if(region.bottom != new_region.bottom) {
- G_message("Error in Rast3d_regionCopy: region.bottom != new_region.bottom");
+ G_message("Error in Rast3d_region_copy: region.bottom != new_region.bottom");
sum++;
if(region.cols != new_region.cols) {
- G_message("Error in Rast3d_regionCopy: region.cols != new_region.cols");
+ G_message("Error in Rast3d_region_copy: region.cols != new_region.cols");
sum++;
if(region.depths != new_region.depths) {
- G_message("Error in Rast3d_regionCopy: region.depths != new_region.depths");
+ G_message("Error in Rast3d_region_copy: region.depths != new_region.depths");
sum++;
if(region.east != new_region.east) {
- G_message("Error in Rast3d_regionCopy: region.east != new_region.east");
+ G_message("Error in Rast3d_region_copy: region.east != new_region.east");
sum++;
if(region.ew_res != new_region.ew_res) {
- G_message("Error in Rast3d_regionCopy: region.ew_res != new_region.ew_res");
+ G_message("Error in Rast3d_region_copy: region.ew_res != new_region.ew_res");
sum++;
if(region.north != new_region.north) {
- G_message("Error in Rast3d_regionCopy: region.north != new_region.north");
+ G_message("Error in Rast3d_region_copy: region.north != new_region.north");
sum++;
if(region.ns_res != new_region.ns_res) {
- G_message("Error in Rast3d_regionCopy: region.ns_res != new_region.ns_res");
+ G_message("Error in Rast3d_region_copy: region.ns_res != new_region.ns_res");
sum++;
if(region.proj != new_region.proj) {
- G_message("Error in Rast3d_regionCopy: region.proj != new_region.proj");
+ G_message("Error in Rast3d_region_copy: region.proj != new_region.proj");
sum++;
if(region.rows != new_region.rows) {
- G_message("Error in Rast3d_regionCopy: region.rows != new_region.rows");
+ G_message("Error in Rast3d_region_copy: region.rows != new_region.rows");
sum++;
if(region.south != new_region.south) {
- G_message("Error in Rast3d_regionCopy: region.south != new_region.south");
+ G_message("Error in Rast3d_region_copy: region.south != new_region.south");
sum++;
if(region.tb_res != new_region.tb_res) {
- G_message("Error in Rast3d_regionCopy: region.tb_res != new_region.tb_res");
+ G_message("Error in Rast3d_region_copy: region.tb_res != new_region.tb_res");
sum++;
if(region.top != new_region.top) {
- G_message("Error in Rast3d_regionCopy: region.top != new_region.top");
+ G_message("Error in Rast3d_region_copy: region.top != new_region.top");
sum++;
if(region.west != new_region.west) {
- G_message("Error in Rast3d_regionCopy: region.west != new_region.west");
+ G_message("Error in Rast3d_region_copy: region.west != new_region.west");
sum++;
if(region.zone != new_region.zone) {
- G_message("Error in Rast3d_regionCopy: region.zone != new_region.zone");
+ G_message("Error in Rast3d_region_copy: region.zone != new_region.zone");
sum++;
Modified: grass/trunk/lib/raster3d/test/test_main.c
--- grass/trunk/lib/raster3d/test/test_main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/test/test_main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -85,7 +85,7 @@
exit(EXIT_FAILURE);
/* Initiate the defaults for testing */
/*Run the unit tests */
if (param.testunit->answer || param.full->answer) {
Modified: grass/trunk/lib/raster3d/test/test_put_get_value.c
--- grass/trunk/lib/raster3d/test/test_put_get_value.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/test/test_put_get_value.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -68,7 +68,7 @@
region.top = 1000;
@@ -80,12 +80,12 @@
region.cols = 10;
region.depths = 5;
- map = Rast3d_openNewOptTileSize("test_put_get_value_dcell", RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, 32);
+ map = Rast3d_open_new_opt_tile_size("test_put_get_value_dcell", RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, 32);
ROWS
1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6500 7000 7500 8000 8500 9000 north
@@ -108,12 +108,12 @@
for(x = 0; x < region.cols; x++) {
/* Add cols, rows and depths and put this in the map */
value = x + y + z;
- Rast3d_putValue(map, x, y, z, &value, DCELL_TYPE);
+ Rast3d_put_value(map, x, y, z, &value, DCELL_TYPE);
/* Write everything to the disk */
- Rast3d_flushAllTiles(map);
+ Rast3d_flush_all_tiles(map);
/* Reread the map and compare the expected results */
@@ -168,21 +168,21 @@
east = region.west + region.ew_res * col;
top = region.bottom + region.tb_res * depth;
- Rast3d_getRegionValue(map, north, east, top, &value, DCELL_TYPE);
- Rast3d_getValue(map, col, row, depth, &value_ref, DCELL_TYPE);
- /* Rast3d_getValueRegion does not work with coordinates outside the region */
+ Rast3d_get_region_value(map, north, east, top, &value, DCELL_TYPE);
+ Rast3d_get_value(map, col, row, depth, &value_ref, DCELL_TYPE);
+ /* Rast3d_get_value_region does not work with coordinates outside the region */
printf("Value %g == %g\n", value, value_ref);
if(value == 0 || value < 0 || value > 0) {
- G_message("Error in Rast3d_getRegionValue");
+ G_message("Error in Rast3d_get_region_value");
sum++;
if(value_ref == 0 || value_ref < 0 || value_ref > 0) {
- G_message("Error in Rast3d_getValue");
+ G_message("Error in Rast3d_get_value");
sum++;
G_remove("grid3", "test_put_get_value_dcell");
@@ -208,7 +208,7 @@
region.top = 1000;
@@ -220,24 +220,24 @@
region.cols = 10;
region.depths = 5;
- map = Rast3d_openNewOptTileSize("test_put_get_value_dcell", RASTER3D_USE_CACHE_XY, ®ion, FCELL_TYPE, 32);
+ map = Rast3d_open_new_opt_tile_size("test_put_get_value_dcell", RASTER3D_USE_CACHE_XY, ®ion, FCELL_TYPE, 32);
for(z = 0; z < region.depths; z++) {
for(y = 0; y < region.rows; y++) {
value = x + y + z;
- Rast3d_putValue(map, x, y, z, &value, FCELL_TYPE);
+ Rast3d_put_value(map, x, y, z, &value, FCELL_TYPE);
@@ -290,21 +290,21 @@
- Rast3d_getRegionValue(map, north, east, top, &value, FCELL_TYPE);
- Rast3d_getValue(map, 10, 15, 5, &value_ref, FCELL_TYPE);
+ Rast3d_get_region_value(map, north, east, top, &value, FCELL_TYPE);
+ Rast3d_get_value(map, 10, 15, 5, &value_ref, FCELL_TYPE);
sum++;
sum++;
G_remove("grid3", "test_put_get_value_fcell");
@@ -330,7 +330,7 @@
region.top = 1000;
@@ -342,22 +342,22 @@
region.cols = 10;
region.depths = 5;
- map = Rast3d_openNewOptTileSize("test_put_get_value_resample", RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, 32);
+ map = Rast3d_open_new_opt_tile_size("test_put_get_value_resample", RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, 32);
/* We modify the window for resampling tests */
- Rast3d_regionCopy(&window, ®ion);
+ Rast3d_region_copy(&window, ®ion);
/* Double the cols, rows and depths -> 8x resolution window */
window.rows = 30;
window.cols = 20;
window.depths = 10;
- Rast3d_adjustRegion(&window);
+ Rast3d_adjust_region(&window);
- Rast3d_setWindowMap(map, &window);
+ Rast3d_set_window_map(map, &window);
ROWS
@@ -385,12 +385,12 @@
value = x + y + z;
- Rast3d_putDouble(map, x, y, z, value);
+ Rast3d_put_double(map, x, y, z, value);
@@ -435,7 +435,7 @@
sum += test_resampling_dcell(map, north, east, top, col, row, depth, 2);
@@ -452,26 +452,26 @@
DCELL value_reg;
DCELL value_win;
- Rast3d_getWindowValue(map, north, east, top, &value_win, DCELL_TYPE);
- Rast3d_getValue(map, col * fact, row * fact, depth * fact, &value_ref, DCELL_TYPE);
- Rast3d_getValueRegion(map, col, row, depth, &value_reg, DCELL_TYPE);
+ Rast3d_get_window_value(map, north, east, top, &value_win, DCELL_TYPE);
+ Rast3d_get_value(map, col * fact, row * fact, depth * fact, &value_ref, DCELL_TYPE);
+ Rast3d_get_value_region(map, col, row, depth, &value_reg, DCELL_TYPE);
printf("Value %g == %g == %g == %g\n", value, value_win, value_ref, value_reg);
if(value != col + row + depth) {
sum++;
- G_message("Error in Rast3d_getWindowValue");
+ G_message("Error in Rast3d_get_window_value");
sum++;
sum++;
- G_message("Error in Rast3d_getValueRegion");
+ G_message("Error in Rast3d_get_value_region");
sum++;
@@ -488,26 +488,26 @@
FCELL value_reg;
FCELL value_win;
- Rast3d_getWindowValue(map, north, east, top, &value_win, FCELL_TYPE);
- Rast3d_getValue(map, col * fact, row * fact, depth * fact, &value_ref, FCELL_TYPE);
- Rast3d_getValueRegion(map, col, row, depth, &value_reg, FCELL_TYPE);
+ Rast3d_get_window_value(map, north, east, top, &value_win, FCELL_TYPE);
+ Rast3d_get_value(map, col * fact, row * fact, depth * fact, &value_ref, FCELL_TYPE);
+ Rast3d_get_value_region(map, col, row, depth, &value_reg, FCELL_TYPE);
sum++;
sum++;
sum++;
sum++;
Modified: grass/trunk/lib/raster3d/tilealloc.c
--- grass/trunk/lib/raster3d/tilealloc.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/tilealloc.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -23,13 +23,13 @@
* NULL ... otherwise.
-void *Rast3d_allocTilesType(RASTER3D_Map * map, int nofTiles, int type)
+void *Rast3d_alloc_tiles_type(RASTER3D_Map * map, int nofTiles, int type)
void *tiles;
tiles = Rast3d_malloc(map->tileSize * Rast3d_length(type) * nofTiles);
if (tiles == NULL) {
- Rast3d_error("Rast3d_allocTilesType: error in Rast3d_malloc");
+ Rast3d_error("Rast3d_alloc_tiles_type: error in Rast3d_malloc");
return NULL;
@@ -42,20 +42,20 @@
* \brief
- * Is equivalent to Rast3d_allocTilesType (map, nofTiles, Rast3d_fileTypeMap (map)).
+ * Is equivalent to Rast3d_alloc_tiles_type (map, nofTiles, Rast3d_file_type_map (map)).
* \param map
* \param nofTiles
* \return void *
-void *Rast3d_allocTiles(RASTER3D_Map * map, int nofTiles)
+void *Rast3d_alloc_tiles(RASTER3D_Map * map, int nofTiles)
void *tiles;
- tiles = Rast3d_allocTilesType(map, nofTiles, map->typeIntern);
+ tiles = Rast3d_alloc_tiles_type(map, nofTiles, map->typeIntern);
- Rast3d_error("Rast3d_allocTiles: error in Rast3d_allocTilesType");
+ Rast3d_error("Rast3d_alloc_tiles: error in Rast3d_alloc_tiles_type");
return NULL;
@@ -74,7 +74,7 @@
* \return void
-void Rast3d_freeTiles(void *tiles)
+void Rast3d_free_tiles(void *tiles)
Rast3d_free(tiles);
Modified: grass/trunk/lib/raster3d/tileio.c
--- grass/trunk/lib/raster3d/tileio.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/tileio.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -29,7 +29,7 @@
* is read from file and stored in the buffer provided by the map structure.
* The pointer to this buffer is returned. If the buffer already contains the
* tile with <em>tileIndex</em> reading is skipped. Data which was stored in
- * earlier calls to <tt>Rast3d_getTilePtr</tt> is destroyed. If the tile with <em>tileIndex</em> is not stored on the file corresponding to <em>map</em>, and <em>tileIndex</em> is a valid index the buffer is filled with NULL-values.<br>
+ * earlier calls to <tt>Rast3d_get_tile_ptr</tt> is destroyed. If the tile with <em>tileIndex</em> is not stored on the file corresponding to <em>map</em>, and <em>tileIndex</em> is a valid index the buffer is filled with NULL-values.<br>
* If <em>map</em> is old and the cache is used the tile with <em>tileIndex</em> is
* read from file and stored in one of the cache buffers. The pointer to buffer
* is returned. If no free cache buffer is available an unlocked cache-buffer
@@ -42,8 +42,8 @@
* as if <em>map</em> is old and the cache is not used. If the tile with <em>tileIndex</em>
* is already stored on file, it is read into the buffer, if not,
* the cells are set to null-values. If the buffer corresponding to the pointer
- * is used for writing, subsequent calls to <tt>Rast3d_getTilePtr</tt> may destroy the
- * values already stored in the buffer. Use <tt>Rast3d_flushTile</tt> to write the buffer
+ * is used for writing, subsequent calls to <tt>Rast3d_get_tile_ptr</tt> may destroy the
+ * values already stored in the buffer. Use <tt>Rast3d_flush_tile</tt> to write the buffer
* to the file before reusing it for a different index. The use of this buffer
* as write buffer is discouraged.<br>
* If <em>map</em> is new and the cache is used the functionality is the same as if
@@ -59,8 +59,8 @@
* Care has to be taken if this function is used in non-cache mode since it is
* implicitly invoked every time a read or write request is issued. The only
* I/O-functions for which it is safe to assume that they do not invoke
- * <tt>Rast3d_getTilePtr</tt> are <tt>Rast3d_readTile()</tt> and
- * <tt>Rast3d_writeTile()</tt> and their corresponding type-specific versions.
+ * <tt>Rast3d_get_tile_ptr</tt> are <tt>Rast3d_read_tile()</tt> and
+ * <tt>Rast3d_write_tile()</tt> and their corresponding type-specific versions.
* \param map
* \param tileIndex
@@ -68,19 +68,19 @@
-void *Rast3d_getTilePtr(RASTER3D_Map * map, int tileIndex)
+void *Rast3d_get_tile_ptr(RASTER3D_Map * map, int tileIndex)
void *ptr;
if ((tileIndex >= map->nTiles) || (tileIndex < 0)) {
- Rast3d_error("Rast3d_getTilePtr: tileIndex out of range");
+ Rast3d_error("Rast3d_get_tile_ptr: tileIndex out of range");
return NULL;
if (map->useCache) {
ptr = Rast3d_cache_elt_ptr(map->cache, tileIndex);
if (ptr == NULL) {
- Rast3d_error("Rast3d_getTilePtr: error in Rast3d_cache_elt_ptr");
+ Rast3d_error("Rast3d_get_tile_ptr: error in Rast3d_cache_elt_ptr");
return NULL;
return ptr;
@@ -90,8 +90,8 @@
return map->data;
map->currentIndex = tileIndex;
- if (!Rast3d_readTile(map, map->currentIndex, map->data, map->typeIntern)) {
- Rast3d_error("Rast3d_getTilePtr: error in Rast3d_readTile");
+ if (!Rast3d_read_tile(map, map->currentIndex, map->data, map->typeIntern)) {
+ Rast3d_error("Rast3d_get_tile_ptr: error in Rast3d_read_tile");
return NULL;
@@ -104,7 +104,7 @@
* \brief
- * Same functionality as <tt>Rast3d_getTilePtr()</tt> but does not return the pointer.
+ * Same functionality as <tt>Rast3d_get_tile_ptr()</tt> but does not return the pointer.
* \param map
* \param tileIndex
@@ -112,10 +112,10 @@
* 0 ... otherwise.
-int Rast3d_tileLoad(RASTER3D_Map * map, int tileIndex)
+int Rast3d_tile_load(RASTER3D_Map * map, int tileIndex)
- if (Rast3d_getTilePtr(map, tileIndex) == NULL) {
- Rast3d_error("Rast3d_tileLoad: error in Rast3d_getTilePtr");
+ if (Rast3d_get_tile_ptr(map, tileIndex) == NULL) {
+ Rast3d_error("Rast3d_tile_load: error in Rast3d_get_tile_ptr");
return 0;
@@ -124,7 +124,7 @@
-int Rast3d__removeTile(RASTER3D_Map * map, int tileIndex)
+int Rast3d__remove_tile(RASTER3D_Map * map, int tileIndex)
if (!map->useCache)
return 1;
Modified: grass/trunk/lib/raster3d/tilemath.c
--- grass/trunk/lib/raster3d/tilemath.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/tilemath.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -22,7 +22,7 @@
void
-Rast3d_tileIndex2tile(RASTER3D_Map * map, int tileIndex, int *xTile, int *yTile,
+Rast3d_tile_index2tile(RASTER3D_Map * map, int tileIndex, int *xTile, int *yTile,
int *zTile)
int tileIndex2d;
@@ -49,7 +49,7 @@
* \return int
-int Rast3d_tile2tileIndex(RASTER3D_Map * map, int xTile, int yTile, int zTile)
+int Rast3d_tile2tile_index(RASTER3D_Map * map, int xTile, int yTile, int zTile)
return map->nxy * zTile + map->nx * yTile + xTile;
@@ -75,7 +75,7 @@
void
-Rast3d_tileCoordOrigin(RASTER3D_Map * map, int xTile, int yTile, int zTile, int *x,
+Rast3d_tile_coord_origin(RASTER3D_Map * map, int xTile, int yTile, int zTile, int *x,
int *y, int *z)
*x = map->tileX * xTile;
@@ -100,12 +100,12 @@
* \return void
-void Rast3d_tileIndexOrigin(RASTER3D_Map * map, int tileIndex, int *x, int *y, int *z)
+void Rast3d_tile_index_origin(RASTER3D_Map * map, int tileIndex, int *x, int *y, int *z)
int xTile, yTile, zTile;
- Rast3d_tileIndex2tile(map, tileIndex, &xTile, &yTile, &zTile);
- Rast3d_tileCoordOrigin(map, xTile, yTile, zTile, x, y, z);
+ Rast3d_tile_index2tile(map, tileIndex, &xTile, &yTile, &zTile);
+ Rast3d_tile_coord_origin(map, xTile, yTile, zTile, x, y, z);
@@ -133,7 +133,7 @@
void
-Rast3d_coord2tileCoord(RASTER3D_Map * map, int x, int y, int z, int *xTile,
+Rast3d_coord2tile_coord(RASTER3D_Map * map, int x, int y, int z, int *xTile,
int *yTile, int *zTile, int *xOffs, int *yOffs,
int *zOffs)
@@ -164,14 +164,14 @@
void
-Rast3d_coord2tileIndex(RASTER3D_Map * map, int x, int y, int z, int *tileIndex,
+Rast3d_coord2tile_index(RASTER3D_Map * map, int x, int y, int z, int *tileIndex,
int *offset)
int xTile, yTile, zTile, xOffs, yOffs, zOffs;
- Rast3d_coord2tileCoord(map, x, y, z,
+ Rast3d_coord2tile_coord(map, x, y, z,
- *tileIndex = Rast3d_tile2tileIndex(map, xTile, yTile, zTile);
+ *tileIndex = Rast3d_tile2tile_index(map, xTile, yTile, zTile);
*offset = zOffs * map->tileXY + yOffs * map->tileX + xOffs;
@@ -192,7 +192,7 @@
* \return int
-int Rast3d_coordInRange(RASTER3D_Map * map, int x, int y, int z)
+int Rast3d_coord_in_range(RASTER3D_Map * map, int x, int y, int z)
return (x >= 0) && (x < map->region.cols) && (y >= 0) &&
(y < map->region.rows) && (z >= 0) && (z < map->region.depths);
@@ -212,7 +212,7 @@
* \return int
-int Rast3d_tileIndexInRange(RASTER3D_Map * map, int tileIndex)
+int Rast3d_tile_index_in_range(RASTER3D_Map * map, int tileIndex)
return (tileIndex < map->nTiles) && (tileIndex >= 0);
@@ -234,7 +234,7 @@
* \return int
-int Rast3d_tileInRange(RASTER3D_Map * map, int x, int y, int z)
+int Rast3d_tile_in_range(RASTER3D_Map * map, int x, int y, int z)
return (x >= 0) && (x < map->nx) && (y >= 0) && (y < map->ny) &&
(z >= 0) && (z < map->nz);
@@ -264,13 +264,13 @@
int
-Rast3d_computeClippedTileDimensions(RASTER3D_Map * map, int tileIndex, int *rows,
+Rast3d_compute_clipped_tile_dimensions(RASTER3D_Map * map, int tileIndex, int *rows,
int *cols, int *depths, int *xRedundant,
int *yRedundant, int *zRedundant)
int x, y, z;
- Rast3d_tileIndex2tile(map, tileIndex, &x, &y, &z);
+ Rast3d_tile_index2tile(map, tileIndex, &x, &y, &z);
if ((x != map->clipX) && (y != map->clipY) && (z != map->clipZ)) {
return map->tileSize;
@@ -329,7 +329,7 @@
void
-Rast3d_computeOptimalTileDimension(RASTER3D_Region *region, int type, int *tileX, int *tileY, int *tileZ, int maxSize)
+Rast3d_compute_optimal_tile_dimension(RASTER3D_Region *region, int type, int *tileX, int *tileY, int *tileZ, int maxSize)
int size = 0;
int x, y, z;
Modified: grass/trunk/lib/raster3d/tilenull.c
--- grass/trunk/lib/raster3d/tilenull.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/tilenull.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -20,9 +20,9 @@
* \return void
-void Rast3d_setNullTileType(RASTER3D_Map * map, void *tile, int type)
+void Rast3d_set_null_tile_type(RASTER3D_Map * map, void *tile, int type)
- Rast3d_setNullValue(tile, map->tileSize, type);
+ Rast3d_set_null_value(tile, map->tileSize, type);
@@ -31,14 +31,14 @@
* \brief
- * Is equivalent to Rast3d_setNullTileType (map, tile, Rast3d_fileTypeMap (map)).
+ * Is equivalent to Rast3d_set_null_tile_type (map, tile, Rast3d_file_type_map (map)).
* \param map
* \param tile
* \return void
-void Rast3d_setNullTile(RASTER3D_Map * map, void *tile)
+void Rast3d_set_null_tile(RASTER3D_Map * map, void *tile)
- Rast3d_setNullTileType(map, tile, map->typeIntern);
+ Rast3d_set_null_tile_type(map, tile, map->typeIntern);
Modified: grass/trunk/lib/raster3d/tileread.c
--- grass/trunk/lib/raster3d/tileread.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/tileread.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -15,14 +15,14 @@
int y, z, xLength, yLength, length;
- if (!Rast3d_initCopyFromXdr(map, type)) {
- Rast3d_error("Rast3d_xdrTile2tile: error in Rast3d_initCopyFromXdr");
+ if (!Rast3d_init_copy_from_xdr(map, type)) {
+ Rast3d_error("Rast3d_xdrTile2tile: error in Rast3d_init_copy_from_xdr");
return 0;
- if (!Rast3d_copyFromXdr(map->tileSize, tile)) {
- Rast3d_error("Rast3d_xdrTile2tile: error in Rast3d_copyFromXdr");
+ if (!Rast3d_copy_from_xdr(map->tileSize, tile)) {
+ Rast3d_error("Rast3d_xdrTile2tile: error in Rast3d_copy_from_xdr");
return 0;
return 1;
@@ -35,45 +35,45 @@
if (xRedundant) {
for (y = 0; y < rows; y++) {
- if (!Rast3d_copyFromXdr(cols, tile)) {
+ if (!Rast3d_copy_from_xdr(cols, tile)) {
return 0;
tile = G_incr_void_ptr(tile, cols * length);
- Rast3d_setNullValue(tile, xRedundant, type);
+ Rast3d_set_null_value(tile, xRedundant, type);
tile = G_incr_void_ptr(tile, xLength);
if (yRedundant) {
- Rast3d_setNullValue(tile, map->tileX * yRedundant, type);
+ Rast3d_set_null_value(tile, map->tileX * yRedundant, type);
tile = G_incr_void_ptr(tile, yLength);
if (!zRedundant)
return 1;
- Rast3d_setNullValue(tile, map->tileXY * zRedundant, type);
+ Rast3d_set_null_value(tile, map->tileXY * zRedundant, type);
return 1;
if (yRedundant) {
- if (!Rast3d_copyFromXdr(map->tileX * rows, tile)) {
+ if (!Rast3d_copy_from_xdr(map->tileX * rows, tile)) {
return 0;
tile = G_incr_void_ptr(tile, map->tileX * rows * length);
if (!zRedundant)
return 1;
return 1;
- if (!Rast3d_copyFromXdr(map->tileXY * depths, tile)) {
+ if (!Rast3d_copy_from_xdr(map->tileXY * depths, tile)) {
return 0;
@@ -81,7 +81,7 @@
return 1;
tile = G_incr_void_ptr(tile, map->tileXY * depths * length);
return 1;
@@ -107,12 +107,12 @@
static int Rast3d_readTileCompressed(RASTER3D_Map * map, int tileIndex, int nofNum)
- if (!G_fpcompress_readXdrNums(map->data_fd, xdr, nofNum,
+ if (!Rast3d_fpcompress_read_xdr_nums(map->data_fd, xdr, nofNum,
map->tileLength[tileIndex],
map->precision, tmpCompress,
map->type == FCELL_TYPE)) {
Rast3d_error
- ("Rast3d_readTileCompressed: error in G_fpcompress_readXdrNums");
+ ("Rast3d_readTileCompressed: error in Rast3d_fpcompress_read_xdr_nums");
return 0;
@@ -144,49 +144,49 @@
* 0 ... otherwise.
-int Rast3d_readTile(RASTER3D_Map * map, int tileIndex, void *tile, int type)
+int Rast3d_read_tile(RASTER3D_Map * map, int tileIndex, void *tile, int type)
- Rast3d_fatalError("Rast3d_readTile: tile index out of range");
+ Rast3d_fatal_error("Rast3d_read_tile: tile index out of range");
if (map->index[tileIndex] == -1) {
- Rast3d_setNullTileType(map, tile, type);
+ Rast3d_set_null_tile_type(map, tile, type);
return 1;
&zRedundant);
if (lseek(map->data_fd, map->index[tileIndex], SEEK_SET) == -1) {
- Rast3d_error("Rast3d_readTile: can't position file");
+ Rast3d_error("Rast3d_read_tile: can't position file");
return 0;
if (map->compression == RASTER3D_NO_COMPRESSION) {
if (!Rast3d_readTileUncompressed(map, tileIndex, nofNum)) {
- Rast3d_error("Rast3d_readTile: error in Rast3d_readTileUncompressed");
+ Rast3d_error("Rast3d_read_tile: error in Rast3d_readTileUncompressed");
return 0;
else if (!Rast3d_readTileCompressed(map, tileIndex, nofNum)) {
- Rast3d_error("Rast3d_readTile: error in Rast3d_readTileCompressed");
+ Rast3d_error("Rast3d_read_tile: error in Rast3d_readTileCompressed");
return 0;
if (!Rast3d_xdrTile2tile(map, tile, rows, cols, depths,
xRedundant, yRedundant, zRedundant, nofNum, type)) {
- Rast3d_error("Rast3d_readTile: error in Rast3d_xdrTile2tile");
+ Rast3d_error("Rast3d_read_tile: error in Rast3d_xdrTile2tile");
return 0;
- if (Rast3d_maskIsOff(map))
+ if (Rast3d_mask_is_off(map))
return 1;
- Rast3d_maskTile(map, tileIndex, tile, type);
+ Rast3d_mask_tile(map, tileIndex, tile, type);
return 1;
@@ -196,7 +196,7 @@
* \brief
- * Is equivalent to Rast3d_readTile (map, tileIndex, tile, FCELL_TYPE).
+ * Is equivalent to Rast3d_read_tile (map, tileIndex, tile, FCELL_TYPE).
* \param map
* \param tileIndex
@@ -204,10 +204,10 @@
* \return int
-int Rast3d_readTileFloat(RASTER3D_Map * map, int tileIndex, void *tile)
+int Rast3d_read_tile_float(RASTER3D_Map * map, int tileIndex, void *tile)
- if (!Rast3d_readTile(map, tileIndex, tile, FCELL_TYPE)) {
- Rast3d_error("Rast3d_readTileFloat: error in Rast3d_readTile");
+ if (!Rast3d_read_tile(map, tileIndex, tile, FCELL_TYPE)) {
+ Rast3d_error("Rast3d_read_tile_float: error in Rast3d_read_tile");
return 0;
@@ -220,7 +220,7 @@
* \brief
- * Is equivalent to Rast3d_readTile (map, tileIndex, tile, DCELL_TYPE).
+ * Is equivalent to Rast3d_read_tile (map, tileIndex, tile, DCELL_TYPE).
* \param map
* \param tileIndex
@@ -228,10 +228,10 @@
* \return int
-int Rast3d_readTileDouble(RASTER3D_Map * map, int tileIndex, void *tile)
+int Rast3d_read_tile_double(RASTER3D_Map * map, int tileIndex, void *tile)
- if (!Rast3d_readTile(map, tileIndex, tile, DCELL_TYPE)) {
- Rast3d_error("Rast3d_readTileDouble: error in Rast3d_readTile");
+ if (!Rast3d_read_tile(map, tileIndex, tile, DCELL_TYPE)) {
+ Rast3d_error("Rast3d_read_tile_double: error in Rast3d_read_tile");
return 0;
@@ -258,13 +258,13 @@
* 0 ... otherwise.
-int Rast3d_lockTile(RASTER3D_Map * map, int tileIndex)
+int Rast3d_lock_tile(RASTER3D_Map * map, int tileIndex)
if (!map->useCache)
- Rast3d_fatalError("Rast3d_lockTile: function invalid in non-cache mode");
+ Rast3d_fatal_error("Rast3d_lock_tile: function invalid in non-cache mode");
if (!Rast3d_cache_lock(map->cache, tileIndex)) {
- Rast3d_error("Rast3d_lockTile: error in Rast3d_cache_lock");
+ Rast3d_error("Rast3d_lock_tile: error in Rast3d_cache_lock");
return 0;
@@ -285,13 +285,13 @@
* 0 ... otherwise.
-int Rast3d_unlockTile(RASTER3D_Map * map, int tileIndex)
+int Rast3d_unlock_tile(RASTER3D_Map * map, int tileIndex)
if (!map->useCache)
- Rast3d_fatalError("Rast3d_unlockTile: function invalid in non-cache mode");
+ Rast3d_fatal_error("Rast3d_unlock_tile: function invalid in non-cache mode");
if (!Rast3d_cache_unlock(map->cache, tileIndex)) {
- Rast3d_error("Rast3d_unlockTile: error in Rast3d_cache_unlock");
+ Rast3d_error("Rast3d_unlock_tile: error in Rast3d_cache_unlock");
return 0;
@@ -311,13 +311,13 @@
* 0 ... otherwise.
-int Rast3d_unlockAll(RASTER3D_Map * map)
+int Rast3d_unlock_all(RASTER3D_Map * map)
if (!map->useCache)
- Rast3d_fatalError("Rast3d_unlockAll: function invalid in non-cache mode");
+ Rast3d_fatal_error("Rast3d_unlock_all: function invalid in non-cache mode");
if (!Rast3d_cache_unlock_all(map->cache)) {
- Rast3d_error("Rast3d_unlockAll: error in Rast3d_cache_unlock_all");
+ Rast3d_error("Rast3d_unlock_all: error in Rast3d_cache_unlock_all");
return 0;
@@ -336,10 +336,10 @@
* \return void
-void Rast3d_autolockOn(RASTER3D_Map * map)
+void Rast3d_autolock_on(RASTER3D_Map * map)
if (!map->useCache)
- Rast3d_fatalError("Rast3d_autoLockOn: function invalid in non-cache mode");
+ Rast3d_fatal_error("Rast3d_autoLockOn: function invalid in non-cache mode");
Rast3d_cache_autolock_on(map->cache);
@@ -356,10 +356,10 @@
* \return void
-void Rast3d_autolockOff(RASTER3D_Map * map)
+void Rast3d_autolock_off(RASTER3D_Map * map)
if (!map->useCache)
- Rast3d_fatalError("Rast3d_autoLockOff: function invalid in non-cache mode");
+ Rast3d_fatal_error("Rast3d_autoLockOff: function invalid in non-cache mode");
Rast3d_cache_autolock_off(map->cache);
@@ -372,11 +372,11 @@
* Sets the minimum
* number of unlocked tiles to <em>minUnlocked</em>. This function should be used
- * in combination with <tt>Rast3d_unlockAll ()</tt> in order to avoid situations where the
+ * in combination with <tt>Rast3d_unlock_all ()</tt> in order to avoid situations where the
* new minimum is larger than the actual number of unlocked tiles.
* <em>minUnlocked</em> must be one of RASTER3D_USE_CACHE_X, RASTER3D_USE_CACHE_Y,
* RASTER3D_USE_CACHE_Z, RASTER3D_USE_CACHE_XY, RASTER3D_USE_CACHE_XZ,
- * RASTER3D_USE_CACHE_YZ, RASTER3D_USE_CACHE_XYZ, the result of Rast3d_cacheSizeEncode()
+ * RASTER3D_USE_CACHE_YZ, RASTER3D_USE_CACHE_XYZ, the result of Rast3d_cache_size_encode()
* which explicitly specifies the number of tiles.
@@ -385,13 +385,13 @@
* \return void
-void Rast3d_minUnlocked(RASTER3D_Map * map, int minUnlocked)
+void Rast3d_min_unlocked(RASTER3D_Map * map, int minUnlocked)
if (!map->useCache)
- Rast3d_cache_set_minUnlock(map->cache,
- Rast3d__computeCacheSize(map, minUnlocked));
+ Rast3d_cache_set_min_unlock(map->cache,
+ Rast3d__compute_cache_size(map, minUnlocked));
@@ -407,14 +407,14 @@
* 0 ... otherwise.
-int Rast3d_beginCycle(RASTER3D_Map * map)
+int Rast3d_begin_cycle(RASTER3D_Map * map)
- if (!Rast3d_unlockAll(map)) {
- Rast3d_fatalError("Rast3d_beginCycle: error in Rast3d_unlockAll");
+ if (!Rast3d_unlock_all(map)) {
+ Rast3d_fatal_error("Rast3d_begin_cycle: error in Rast3d_unlock_all");
return 0;
- Rast3d_autolockOn(map);
+ Rast3d_autolock_on(map);
return 1;
@@ -431,8 +431,8 @@
* 0 ... otherwise.
-int Rast3d_endCycle(RASTER3D_Map * map)
+int Rast3d_end_cycle(RASTER3D_Map * map)
- Rast3d_autolockOff(map);
+ Rast3d_autolock_off(map);
return 1;
Modified: grass/trunk/lib/raster3d/tilewrite.c
--- grass/trunk/lib/raster3d/tilewrite.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/tilewrite.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -18,15 +18,15 @@
int y, z;
- if (!Rast3d_initCopyToXdr(map, type)) {
- Rast3d_error("Rast3d_tile2xdrTile: error in Rast3d_initCopyToXdr");
+ if (!Rast3d_init_copy_to_xdr(map, type)) {
+ Rast3d_error("Rast3d_tile2xdrTile: error in Rast3d_init_copy_to_xdr");
return 0;
if (nofNum == map->tileSize) {
- if (!Rast3d_copyToXdr(tile, map->tileSize)) {
- Rast3d_error("Rast3d_tile2xdrTile: error in Rast3d_copyToXdr");
+ if (!Rast3d_copy_to_xdr(tile, map->tileSize)) {
+ Rast3d_error("Rast3d_tile2xdrTile: error in Rast3d_copy_to_xdr");
return 0;
return 1;
@@ -35,8 +35,8 @@
if (xRedundant) {
- if (!Rast3d_copyToXdr(tile, cols)) {
+ if (!Rast3d_copy_to_xdr(tile, cols)) {
return 0;
tile = G_incr_void_ptr(tile, map->tileX * Rast3d_length(type));
@@ -52,8 +52,8 @@
if (yRedundant) {
- if (!Rast3d_copyToXdr(tile, map->tileX * rows)) {
+ if (!Rast3d_copy_to_xdr(tile, map->tileX * rows)) {
return 0;
tile = G_incr_void_ptr(tile, map->tileXY * Rast3d_length(type));
@@ -61,8 +61,8 @@
return 1;
- if (!Rast3d_copyToXdr(tile, map->tileXY * depths)) {
+ if (!Rast3d_copy_to_xdr(tile, map->tileXY * depths)) {
return 0;
return 1;
@@ -85,11 +85,11 @@
static int Rast3d_writeTileCompressed(RASTER3D_Map * map, int nofNum)
- if (!G_fpcompress_writeXdrNums(map->data_fd, xdr, nofNum, map->precision,
+ if (!Rast3d_fpcompress_write_xdr_nums(map->data_fd, xdr, nofNum, map->precision,
tmpCompress, map->type == FCELL_TYPE,
map->useRle, map->useLzw)) {
Rast3d_error
- ("Rast3d_writeTileCompressed: error in G_fpcompress_writeXdrNums");
+ ("Rast3d_writeTileCompressed: error in Rast3d_fpcompress_write_xdr_nums");
return 0;
@@ -127,13 +127,13 @@
* 0 ... otherwise.
-int Rast3d_writeTile(RASTER3D_Map * map, int tileIndex, const void *tile, int type)
+int Rast3d_write_tile(RASTER3D_Map * map, int tileIndex, const void *tile, int type)
int rows, cols, depths, xRedundant, yRedundant, zRedundant, nofNum;
/* valid tileIndex ? */
- Rast3d_fatalError("Rast3d_writeTile: tileIndex out of range");
+ Rast3d_fatal_error("Rast3d_write_tile: tileIndex out of range");
/* already written ? */
if (map->index[tileIndex] != -1)
@@ -142,16 +142,16 @@
/* save the file position */
map->index[tileIndex] = lseek(map->data_fd, (long)0, SEEK_END);
- Rast3d_error("Rast3d_writeTile: can't position file");
+ Rast3d_error("Rast3d_write_tile: can't position file");
return 0;
- nofNum = Rast3d_computeClippedTileDimensions(map, tileIndex,
+ nofNum = Rast3d_compute_clipped_tile_dimensions(map, tileIndex,
&rows, &cols, &depths,
&xRedundant, &yRedundant,
&zRedundant);
- Rast3d_range_updateFromTile(map, tile, rows, cols, depths,
+ Rast3d_range_update_from_tile(map, tile, rows, cols, depths,
type);
@@ -163,12 +163,12 @@
if (!Rast3d_writeTileUncompressed(map, nofNum)) {
- Rast3d_error("Rast3d_writeTile: error in Rast3d_writeTileUncompressed");
+ Rast3d_error("Rast3d_write_tile: error in Rast3d_writeTileUncompressed");
return 0;
else if (!Rast3d_writeTileCompressed(map, nofNum)) {
- Rast3d_error("Rast3d_writeTile: error in Rast3d_writeTileCompressed");
+ Rast3d_error("Rast3d_write_tile: error in Rast3d_writeTileCompressed");
return 0;
@@ -185,7 +185,7 @@
* \brief
- * Is equivalent to <tt>Rast3d_writeTile (map, tileIndex, tile, FCELL_TYPE).</tt>
+ * Is equivalent to <tt>Rast3d_write_tile (map, tileIndex, tile, FCELL_TYPE).</tt>
* \param map
* \param tileIndex
@@ -193,14 +193,14 @@
* \return int
-int Rast3d_writeTileFloat(RASTER3D_Map * map, int tileIndex, const void *tile)
+int Rast3d_write_tile_float(RASTER3D_Map * map, int tileIndex, const void *tile)
int status;
- if ((status = Rast3d_writeTile(map, tileIndex, tile, FCELL_TYPE)))
+ if ((status = Rast3d_write_tile(map, tileIndex, tile, FCELL_TYPE)))
return status;
- Rast3d_error("Rast3d_writeTileFloat: error in Rast3d_writeTile");
+ Rast3d_error("Rast3d_write_tile_float: error in Rast3d_write_tile");
return 0;
@@ -210,7 +210,7 @@
* \brief
- * Is equivalent to <tt>Rast3d_writeTile (map, tileIndex, tile, DCELL_TYPE).</tt>
+ * Is equivalent to <tt>Rast3d_write_tile (map, tileIndex, tile, DCELL_TYPE).</tt>
* \param map
* \param tileIndex
@@ -218,14 +218,14 @@
* \return int
-int Rast3d_writeTileDouble(RASTER3D_Map * map, int tileIndex, const void *tile)
+int Rast3d_write_tile_double(RASTER3D_Map * map, int tileIndex, const void *tile)
int status;
- if ((status = Rast3d_writeTile(map, tileIndex, tile, DCELL_TYPE)))
+ if ((status = Rast3d_write_tile(map, tileIndex, tile, DCELL_TYPE)))
return status;
- Rast3d_error("Rast3d_writeTileDouble: error in Rast3d_writeTile");
+ Rast3d_error("Rast3d_write_tile_double: error in Rast3d_write_tile");
return 0;
@@ -244,7 +244,7 @@
* from the cache (in non-cache mode the buffer provided by the map-structure is
* written).
* If this tile has already been written before the write request is ignored.
- * If the tile was never referred to before the invokation of Rast3d_flushTile, a
+ * If the tile was never referred to before the invokation of Rast3d_flush_tile, a
* tile filled with NULL-values is written.
* \param map
@@ -253,23 +253,23 @@
* 0 ... otherwise.
-int Rast3d_flushTile(RASTER3D_Map * map, int tileIndex)
+int Rast3d_flush_tile(RASTER3D_Map * map, int tileIndex)
const void *tile;
- tile = Rast3d_getTilePtr(map, tileIndex);
+ tile = Rast3d_get_tile_ptr(map, tileIndex);
if (tile == NULL) {
- Rast3d_error("Rast3d_flushTile: error in Rast3d_getTilePtr");
+ Rast3d_error("Rast3d_flush_tile: error in Rast3d_get_tile_ptr");
return 0;
- if (!Rast3d_writeTile(map, tileIndex, tile, map->typeIntern)) {
- Rast3d_error("Rast3d_flushTile: error in Rast3d_writeTile");
+ if (!Rast3d_write_tile(map, tileIndex, tile, map->typeIntern)) {
+ Rast3d_error("Rast3d_flush_tile: error in Rast3d_write_tile");
return 0;
- if (!Rast3d__removeTile(map, tileIndex)) {
- Rast3d_error("Rast3d_flushTile: error in Rast3d__removeTile");
+ if (!Rast3d__remove_tile(map, tileIndex)) {
+ Rast3d_error("Rast3d_flush_tile: error in Rast3d__remove_tile");
return 0;
@@ -305,20 +305,20 @@
int
-Rast3d_flushTileCube(RASTER3D_Map * map, int xMin, int yMin, int zMin, int xMax,
+Rast3d_flush_tile_cube(RASTER3D_Map * map, int xMin, int yMin, int zMin, int xMax,
int yMax, int zMax)
int x, y, z;
if (!map->useCache)
- Rast3d_fatalError
- ("Rast3d_flushTileCube: function invalid in non-cache mode");
+ ("Rast3d_flush_tile_cube: function invalid in non-cache mode");
for (x = xMin; x <= xMax; x++)
for (y = yMin; y <= yMax; y++)
for (z = zMin; z <= zMax; z++)
- if (!Rast3d_flushTile(map, Rast3d_tile2tileIndex(map, x, y, z))) {
- Rast3d_error("Rast3d_flushTileCube: error in Rast3d_flushTile");
+ if (!Rast3d_flush_tile(map, Rast3d_tile2tile_index(map, x, y, z))) {
+ Rast3d_error("Rast3d_flush_tile_cube: error in Rast3d_flush_tile");
return 0;
@@ -351,7 +351,7 @@
int
-Rast3d_flushTilesInCube(RASTER3D_Map * map, int xMin, int yMin, int zMin, int xMax,
+Rast3d_flush_tiles_in_cube(RASTER3D_Map * map, int xMin, int yMin, int zMin, int xMax,
int yMax, int zMax)
int xTileMin, yTileMin, zTileMin, xTileMax, yTileMax, zTileMax;
@@ -359,40 +359,40 @@
int regionMaxX, regionMaxY, regionMaxZ;
if (!map->useCache)
- Rast3d_fatalError
- ("Rast3d_flushTilesInCube: function invalid in non-cache mode");
+ ("Rast3d_flush_tiles_in_cube: function invalid in non-cache mode");
/*AV*/
/*BEGIN OF ORIGINAL CODE */
- * Rast3d_getCoordsMap (map, ®ionMaxX, ®ionMaxY, ®ionMaxZ);
+ * Rast3d_get_coords_map (map, ®ionMaxX, ®ionMaxY, ®ionMaxZ);
/*AV*/
/* BEGIN OF MY CODE */
- Rast3d_getCoordsMap(map, ®ionMaxY, ®ionMaxX, ®ionMaxZ);
+ Rast3d_get_coords_map(map, ®ionMaxY, ®ionMaxX, ®ionMaxZ);
/* END OF MY CODE */
if ((xMin < 0) && (xMax < 0))
- Rast3d_fatalError("Rast3d_flushTilesInCube: coordinate out of Range");
+ Rast3d_fatal_error("Rast3d_flush_tiles_in_cube: coordinate out of Range");
if ((xMin >= regionMaxX) && (xMax >= regionMaxX))
xMin = MIN(MAX(0, xMin), regionMaxX - 1);
if ((yMin < 0) && (yMax < 0))
if ((yMin >= regionMaxY) && (yMax >= regionMaxY))
yMin = MIN(MAX(0, yMin), regionMaxY - 1);
if ((zMin < 0) && (zMax < 0))
if ((zMin >= regionMaxZ) && (zMax >= regionMaxZ))
zMin = MIN(MAX(0, zMin), regionMaxZ - 1);
- Rast3d_coord2tileCoord(map, xMin, yMin, zMin,
+ Rast3d_coord2tile_coord(map, xMin, yMin, zMin,
&xTileMin, &yTileMin, &zTileMin,
@@ -403,7 +403,7 @@
if (zOffs != 0)
zTileMin++;
- Rast3d_coord2tileCoord(map, xMax + 1, yMax + 1, zMax + 1,
+ Rast3d_coord2tile_coord(map, xMax + 1, yMax + 1, zMax + 1,
&xTileMax, &yTileMax, &zTileMax,
@@ -411,9 +411,9 @@
yTileMax--;
zTileMax--;
- if (!Rast3d_flushTileCube(map, xTileMin, yTileMin, zTileMin,
+ if (!Rast3d_flush_tile_cube(map, xTileMin, yTileMin, zTileMin,
xTileMax, yTileMax, zTileMax)) {
- Rast3d_error("Rast3d_flushTilesInCube: error in Rast3d_flushTileCube");
+ Rast3d_error("Rast3d_flush_tiles_in_cube: error in Rast3d_flush_tile_cube");
return 0;
Modified: grass/trunk/lib/raster3d/volume.c
--- grass/trunk/lib/raster3d/volume.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/volume.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -14,23 +14,23 @@
double v[2][2][2][3];
- if (!(Rast3d_isValidLocation(map, v[0][0][0][0], v[0][0][0][1],
+ if (!(Rast3d_is_valid_location(map, v[0][0][0][0], v[0][0][0][1],
v[0][0][0][2]) &&
- Rast3d_isValidLocation(map, v[0][0][1][0], v[0][0][1][1],
+ Rast3d_is_valid_location(map, v[0][0][1][0], v[0][0][1][1],
v[0][0][1][2]) &&
- Rast3d_isValidLocation(map, v[0][1][0][0], v[0][1][0][1],
+ Rast3d_is_valid_location(map, v[0][1][0][0], v[0][1][0][1],
v[0][1][0][2]) &&
- Rast3d_isValidLocation(map, v[0][1][1][0], v[0][1][1][1],
+ Rast3d_is_valid_location(map, v[0][1][1][0], v[0][1][1][1],
v[0][1][1][2]) &&
- Rast3d_isValidLocation(map, v[1][0][0][0], v[1][0][0][1],
+ Rast3d_is_valid_location(map, v[1][0][0][0], v[1][0][0][1],
v[1][0][0][2]) &&
- Rast3d_isValidLocation(map, v[1][0][1][0], v[1][0][1][1],
+ Rast3d_is_valid_location(map, v[1][0][1][0], v[1][0][1][1],
v[1][0][1][2]) &&
- Rast3d_isValidLocation(map, v[1][1][0][0], v[1][1][0][1],
+ Rast3d_is_valid_location(map, v[1][1][0][0], v[1][1][0][1],
v[1][1][0][2]) &&
- Rast3d_isValidLocation(map, v[1][1][1][0], v[1][1][1][1],
+ Rast3d_is_valid_location(map, v[1][1][1][0], v[1][1][1][1],
v[1][1][1][2])))
- Rast3d_fatalError("verifyCubeVertices: volume vertex out of range");
+ Rast3d_fatal_error("verifyCubeVertices: volume vertex out of range");
return 0;
@@ -43,14 +43,14 @@
if ((nx <= 0) || (ny <= 0) || (nz <= 0))
- Rast3d_fatalError("verifyCubeEdges: Volume edge out of range");
+ Rast3d_fatal_error("verifyCubeEdges: Volume edge out of range");
return 0;
void
-Rast3d_getVolumeA(void *map, double u[2][2][2][3], int nx, int ny, int nz,
+Rast3d_get_volume_a(void *map, double u[2][2][2][3], int nx, int ny, int nz,
void *volumeBuf, int type)
typedef double doubleArray[3];
@@ -125,16 +125,16 @@
(int) dx / 2, (int) dy / 2, (int) dz / 2,
v[0], v[1], v[2],
x, y, z,
- Rast3d_getDoubleRegion (map, x, y, z));
+ Rast3d_get_double_region (map, x, y, z));
if (type == DCELL_TYPE)
*(doubleBuf + ((int)dz / 2) * nx * ny +
((int)dy / 2) * nx + (int)dx / 2) =
-Rast3d_getDoubleRegion(map, x, y, z);
+Rast3d_get_double_region(map, x, y, z);
else
*(floatBuf + ((int)dz / 2) * nx * ny +
-Rast3d_getFloatRegion(map, x, y, z);
+Rast3d_get_float_region(map, x, y, z);
@@ -143,7 +143,7 @@
void
-Rast3d_getVolume(void *map,
+Rast3d_get_volume(void *map,
double originNorth, double originWest, double originBottom,
double vxNorth, double vxWest, double vxBottom,
double vyNorth, double vyWest, double vyBottom,
@@ -184,19 +184,19 @@
u[1][1][1][1] = (u[1][0][0][1] - u[0][0][0][1]) + u[0][1][1][1];
u[1][1][1][2] = (u[1][0][0][2] - u[0][0][0][2]) + u[0][1][1][2];
- Rast3d_getVolumeA(map, u, nx, ny, nz, volumeBuf, type);
+ Rast3d_get_volume_a(map, u, nx, ny, nz, volumeBuf, type);
void
-Rast3d_getAlignedVolume(void *map,
+Rast3d_get_aligned_volume(void *map,
double originBottom, double lengthNorth,
double lengthWest, double lengthBottom, int nx, int ny,
int nz, void *volumeBuf, int type)
- Rast3d_getVolume(map,
+ Rast3d_get_volume(map,
originNorth, originWest, originBottom,
originNorth + lengthNorth, originWest, originBottom,
originNorth, originWest + lengthWest, originBottom,
@@ -207,7 +207,7 @@
void
-Rast3d_makeAlignedVolumeFile(void *map, const char *fileName,
+Rast3d_make_aligned_volume_file(void *map, const char *fileName,
int x, y, z, eltLength;
RASTER3D_Region region;
- volumeBuf = Rast3d_malloc(nx * ny * nz * sizeof(Rast3d_getFileType()));
+ volumeBuf = Rast3d_malloc(nx * ny * nz * sizeof(Rast3d_get_file_type()));
if (volumeBuf == NULL)
- Rast3d_fatalError("Rast3d_makeAlignedVolumeFile: error in Rast3d_malloc");
+ Rast3d_fatal_error("Rast3d_make_aligned_volume_file: error in Rast3d_malloc");
- Rast3d_getAlignedVolume(map,
+ Rast3d_get_aligned_volume(map,
lengthNorth, lengthWest, lengthBottom,
- nx, ny, nz, volumeBuf, Rast3d_getFileType());
+ nx, ny, nz, volumeBuf, Rast3d_get_file_type());
region.north = originNorth;
region.south = originNorth + lengthNorth;
@@ -238,30 +238,30 @@
region.cols = nx;
region.depths = nz;
- mapVolume = Rast3d_openCellNew(fileName, Rast3d_getFileType(),
+ mapVolume = Rast3d_open_cell_new(fileName, Rast3d_get_file_type(),
if (mapVolume == NULL)
- Rast3d_fatalError("Rast3d_makeAlignedVolumeFile: error in Rast3d_openCellNew");
+ Rast3d_fatal_error("Rast3d_make_aligned_volume_file: error in Rast3d_open_cell_new");
- eltLength = Rast3d_length(Rast3d_getFileType());
+ eltLength = Rast3d_length(Rast3d_get_file_type());
for (y = 0; y < ny; y++) {
/* Rast3d_putValueRegion? */
- if (!Rast3d_putValue(mapVolume, x, y, z,
+ if (!Rast3d_put_value(mapVolume, x, y, z,
G_incr_void_ptr(volumeBuf,
(z * ny * nx + y * nx +
x) * eltLength),
- Rast3d_fileTypeMap(mapVolume)))
- Rast3d_fatalError
- ("Rast3d_makeAlignedVolumeFile: error in Rast3d_putValue");
+ Rast3d_file_type_map(mapVolume)))
+ ("Rast3d_make_aligned_volume_file: error in Rast3d_put_value");
- if (!Rast3d_closeCell(mapVolume))
- Rast3d_fatalError("Rast3d_makeAlignedVolumeFile: error in Rast3d_closeCell");
+ if (!Rast3d_close_cell(mapVolume))
+ Rast3d_fatal_error("Rast3d_make_aligned_volume_file: error in Rast3d_close_cell");
Rast3d_free(volumeBuf);
Modified: grass/trunk/lib/raster3d/window.c
--- grass/trunk/lib/raster3d/window.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/window.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -21,10 +21,10 @@
* \return void
-void Rast3d_setWindowMap(RASTER3D_Map * map, RASTER3D_Region * window)
+void Rast3d_set_window_map(RASTER3D_Map * map, RASTER3D_Region * window)
- Rast3d_regionCopy(&(map->window), window);
- Rast3d_adjustRegion(&(map->window));
+ Rast3d_region_copy(&(map->window), window);
+ Rast3d_adjust_region(&(map->window));
@@ -40,10 +40,10 @@
* \return void
-void Rast3d_setWindow(RASTER3D_Region * window)
+void Rast3d_set_window(RASTER3D_Region * window)
- Rast3d_regionCopy(&g3d_window, window);
- Rast3d_adjustRegion(&g3d_window);
+ Rast3d_region_copy(&g3d_window, window);
+ Rast3d_adjust_region(&g3d_window);
@@ -58,14 +58,14 @@
* \return void
-void Rast3d_getWindow(RASTER3D_Region * window)
+void Rast3d_get_window(RASTER3D_Region * window)
- Rast3d_regionCopy(window, &g3d_window);
+ Rast3d_region_copy(window, &g3d_window);
-RASTER3D_Region *Rast3d_windowPtr()
+RASTER3D_Region *Rast3d_window_ptr()
return &g3d_window;
Modified: grass/trunk/lib/raster3d/windowio.c
--- grass/trunk/lib/raster3d/windowio.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/windowio.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -20,12 +20,12 @@
int (*windowInt) (), (*windowDouble) ();
if (doRead) {
- windowDouble = Rast3d_keyGetDouble;
- windowInt = Rast3d_keyGetInt;
+ windowDouble = Rast3d_key_get_double;
+ windowInt = Rast3d_key_get_int;
else {
- windowDouble = Rast3d_keySetDouble;
- windowInt = Rast3d_keySetInt;
+ windowDouble = Rast3d_key_set_double;
+ windowInt = Rast3d_key_set_int;
returnVal = 1;
@@ -136,7 +136,7 @@
* 0 ... otherwise.
-int Rast3d_readWindow(RASTER3D_Region * window, const char *windowName)
+int Rast3d_read_window(RASTER3D_Region * window, const char *windowName)
struct Cell_head win;
struct Key_Value *windowKeys;
@@ -165,7 +165,7 @@
Rast3d_getFullWindowPath(path, windowName);
if (access(path, R_OK) != 0) {
- G_warning("Rast3d_readWindow: unable to find [%s].", path);
+ G_warning("Rast3d_read_window: unable to find [%s].", path);
return 0;
@@ -180,7 +180,7 @@
&(window->depths), &(window->ew_res),
&(window->ns_res), &(window->tb_res))) {
Rast3d_error
- ("Rast3d_readWindow: error extracting window key(s) of file %s",
+ ("Rast3d_read_window: error extracting window key(s) of file %s",
path);
return 0;
@@ -273,7 +273,7 @@
* \return void
-void Rast3d_useWindowParams(void)
+void Rast3d_use_window_params(void)
- Rast3d_setWindowParams();
+ Rast3d_set_window_params();
Modified: grass/trunk/lib/raster3d/writeascii.c
--- grass/trunk/lib/raster3d/writeascii.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/lib/raster3d/writeascii.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -16,7 +16,7 @@
* \return void
-void Rast3d_writeAscii(void *map, const char *fname)
+void Rast3d_write_ascii(void *map, const char *fname)
FILE *fp;
DCELL d1 = 0;
@@ -25,8 +25,8 @@
int x, y, z;
int rows, cols, depths, typeIntern;
d1p = &d1;
f1p = (FCELL *) &d1;
@@ -34,13 +34,13 @@
if (fname == NULL)
fp = stdout;
else if ((fp = fopen(fname, "w")) == NULL)
- Rast3d_fatalError("Rast3d_writeAscii: can't open file to write\n");
+ Rast3d_fatal_error("Rast3d_write_ascii: can't open file to write\n");
fprintf(fp, "z y x %d %d (%d - %d)\n", z, y, 0, cols - 1);
- Rast3d_getValueRegion(map, x, y, z, d1p, typeIntern);
+ Rast3d_get_value_region(map, x, y, z, d1p, typeIntern);
if (typeIntern == FCELL_TYPE)
fprintf(fp, "%.18f ", *f1p);
Modified: grass/trunk/raster/r.colors/edit_colors.c
--- grass/trunk/raster/r.colors/edit_colors.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster/r.colors/edit_colors.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -184,7 +184,7 @@
int stat = -1;
if (remove) {
if (type == RASTER3D_TYPE) {
- stat = Rast3d_removeColor(name);
+ stat = Rast3d_remove_color(name);
} else {
stat = Rast_remove_colors(name, mapset);
@@ -197,7 +197,7 @@
G_suppress_warnings(TRUE);
- have_colors = Rast3d_readColors(name, mapset, &colors);
+ have_colors = Rast3d_read_colors(name, mapset, &colors);
} else {
have_colors = Rast_read_colors(name, mapset, &colors);
@@ -214,7 +214,7 @@
fp = 1; /* g3d maps are always floating point */
- Rast3d_readRange(name, mapset, &range);
+ Rast3d_read_range(name, mapset, &range);
} else {
fp = Rast_map_is_fp(name, mapset);
Rast_read_fp_range(name, mapset, &range);
@@ -274,7 +274,7 @@
if (cmapset == NULL)
G_fatal_error(_("Raster3d map <%s> not found"), cmap);
- if (Rast3d_readColors(cmap, cmapset, &colors) < 0)
+ if (Rast3d_read_colors(cmap, cmapset, &colors) < 0)
G_fatal_error(_("Unable to read color table for raster3d map <%s>"), cmap);
@@ -311,7 +311,7 @@
if (fp)
Rast_mark_colors_as_fp(&colors);
- Rast3d_writeColors(name, mapset, &colors);
+ Rast3d_write_colors(name, mapset, &colors);
} else {
Rast_write_colors(name, mapset, &colors);
Modified: grass/trunk/raster/r.colors/stats.c
--- grass/trunk/raster/r.colors/stats.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster/r.colors/stats.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -62,13 +62,13 @@
ncols = Rast_window_cols();
} else {
/* Initiate the default settings */
- Rast3d_initDefaults();
+ Rast3d_init_defaults();
- map3d = Rast3d_openCellOld(name, mapset, RASTER3D_DEFAULT_WINDOW,
+ map3d = Rast3d_open_cell_old(name, mapset, RASTER3D_DEFAULT_WINDOW,
RASTER3D_TILE_SAME_AS_FILE, RASTER3D_USE_CACHE_DEFAULT);
if (map3d == NULL)
- Rast3d_fatalError(_("Error opening 3d raster map"));
+ Rast3d_fatal_error(_("Error opening 3d raster map"));
nrows = map3d->window.rows;
ncols = map3d->window.cols;
@@ -126,7 +126,7 @@
if (type == RASTER_TYPE)
x = dcell[col];
else
- x = Rast3d_getDouble(map3d, col, row, depth);
+ x = Rast3d_get_double(map3d, col, row, depth);
if (Rast_is_d_null_value(&x))
continue;
@@ -152,6 +152,6 @@
if(dcell)
G_free(dcell);
} else {
- Rast3d_closeCell(map3d);
+ Rast3d_close_cell(map3d);
Modified: grass/trunk/raster/r.colors.out/raster3d_main.c
--- grass/trunk/raster/r.colors.out/raster3d_main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster/r.colors.out/raster3d_main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -55,9 +55,9 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (Rast3d_readColors(opt.map->answer, "", &colors) < 0)
+ if (Rast3d_read_colors(opt.map->answer, "", &colors) < 0)
G_fatal_error(_("Unable to read color table for raster3d map <%s>"), opt.map->answer);
- Rast3d_readRange(opt.map->answer, "", &range);
+ Rast3d_read_range(opt.map->answer, "", &range);
write_colors(&colors, &range, opt.file->answer, flag.p->answer ? 1 : 0);
Modified: grass/trunk/raster/r.mapcalc/map3.c
--- grass/trunk/raster/r.mapcalc/map3.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster/r.mapcalc/map3.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -21,8 +21,8 @@
void setup_region(void)
- Rast3d_getWindow(¤t_region3);
+ Rast3d_get_window(¤t_region3);
rows = current_region3.rows;
columns = current_region3.cols;
@@ -74,8 +74,8 @@
for (i = 0; i < columns; i++) {
double x;
- Rast3d_getValue(handle, i, row, depth, (char *)&x, DCELL_TYPE);
- if (Rast3d_isNullValueNum(&x, DCELL_TYPE))
+ Rast3d_get_value(handle, i, row, depth, (char *)&x, DCELL_TYPE);
+ if (Rast3d_is_null_value_num(&x, DCELL_TYPE))
SET_NULL_C(&((CELL *) buf)[i]);
else
((CELL *) buf)[i] = (CELL) x;
@@ -85,8 +85,8 @@
float x;
- Rast3d_getValue(handle, i, row, depth, (char *)&x, FCELL_TYPE);
- if (Rast3d_isNullValueNum(&x, FCELL_TYPE))
+ Rast3d_get_value(handle, i, row, depth, (char *)&x, FCELL_TYPE);
+ if (Rast3d_is_null_value_num(&x, FCELL_TYPE))
SET_NULL_F(&((FCELL *) buf)[i]);
else
((FCELL *) buf)[i] = x;
@@ -96,8 +96,8 @@
double x;
SET_NULL_D(&((DCELL *) buf)[i]);
else
((DCELL *) buf)[i] = x;
@@ -117,11 +117,11 @@
double x;
if (IS_NULL_C(&((CELL *) buf)[i]))
- Rast3d_setNullValue(&x, 1, DCELL_TYPE);
+ Rast3d_set_null_value(&x, 1, DCELL_TYPE);
else
x = ((CELL *) buf)[i];
- if (Rast3d_putValue(handle, i, row, depth, (char *)&x, DCELL_TYPE) <
+ if (Rast3d_put_value(handle, i, row, depth, (char *)&x, DCELL_TYPE) <
0)
G_fatal_error(_("Error writing data"));
@@ -131,11 +131,11 @@
float x;
if (IS_NULL_F(&((FCELL *) buf)[i]))
- Rast3d_setNullValue(&x, 1, FCELL_TYPE);
+ Rast3d_set_null_value(&x, 1, FCELL_TYPE);
else
x = ((FCELL *) buf)[i];
- if (Rast3d_putValue(handle, i, row, depth, (char *)&x, FCELL_TYPE) <
+ if (Rast3d_put_value(handle, i, row, depth, (char *)&x, FCELL_TYPE) <
0)
@@ -145,11 +145,11 @@
double x;
if (IS_NULL_D(&((DCELL *) buf)[i]))
else
x = ((DCELL *) buf)[i];
0)
@@ -175,7 +175,7 @@
if (!set)
set = G_malloc(columns);
- if (Rast3d_readColors((char *)m->name, (char *)m->mapset, &m->colors) < 0)
+ if (Rast3d_read_colors((char *)m->name, (char *)m->mapset, &m->colors) < 0)
G_fatal_error(_("Unable to read color file for raster map <%s@%s>"),
m->name, m->mapset);
@@ -184,7 +184,7 @@
static void init_cats(map * m)
- if (Rast3d_readCats((char *)m->name, (char *)m->mapset, &m->cats) < 0)
+ if (Rast3d_read_cats((char *)m->name, (char *)m->mapset, &m->cats) < 0)
G_fatal_error(_("Unable to read category file of raster map <%s@%s>"),
@@ -366,7 +366,7 @@
if (!m->handle)
return;
- if (!Rast3d_closeCell(m->handle))
+ if (!Rast3d_close_cell(m->handle))
G_fatal_error(_("Unable to close raster map <%s@%s>"),
@@ -397,11 +397,11 @@
void *handle;
setup_region(); /* TODO: setup_region should be called by evaluate() ? */
- handle = Rast3d_openCellOld(tmpname, mapset, ¤t_region3,
+ handle = Rast3d_open_cell_old(tmpname, mapset, ¤t_region3,
RASTER3D_TILE_SAME_AS_FILE, RASTER3D_NO_CACHE);
- result = (Rast3d_fileTypeMap(handle) == FCELL_TYPE)
+ result = (Rast3d_file_type_map(handle) == FCELL_TYPE)
? FCELL_TYPE : DCELL_TYPE;
- Rast3d_closeCell(handle);
+ Rast3d_close_cell(handle);
else
result = -1;
@@ -505,7 +505,7 @@
if (use_colors)
init_colors(m);
- m->handle = Rast3d_openCellOld((char *)name, (char *)mapset,
+ m->handle = Rast3d_open_cell_old((char *)name, (char *)mapset,
¤t_region3, DCELL_TYPE,
@@ -578,9 +578,9 @@
void *handle;
- Rast3d_setFileType(res_type == FCELL_TYPE ? FCELL_TYPE : DCELL_TYPE);
+ Rast3d_set_file_type(res_type == FCELL_TYPE ? FCELL_TYPE : DCELL_TYPE);
- handle = Rast3d_openNewOptTileSize((char *)name, RASTER3D_USE_CACHE_XYZ, ¤t_region3, res_type == FCELL_TYPE ? FCELL_TYPE : DCELL_TYPE, 32);
+ handle = Rast3d_open_new_opt_tile_size((char *)name, RASTER3D_USE_CACHE_XYZ, ¤t_region3, res_type == FCELL_TYPE ? FCELL_TYPE : DCELL_TYPE, 32);
if (!handle)
G_fatal_error(_("Unable to create raster map <%s>"), name);
@@ -607,7 +607,7 @@
void *handle = omaps[fd];
- if (!Rast3d_closeCell(handle))
+ if (!Rast3d_close_cell(handle))
G_fatal_error(_("Unable to close output raster map"));
@@ -623,10 +623,10 @@
const map *m = &maps[idx];
struct Categories cats;
- if (Rast3d_readCats((char *)m->name, (char *)m->mapset, &cats) < 0)
+ if (Rast3d_read_cats((char *)m->name, (char *)m->mapset, &cats) < 0)
return;
- Rast3d_writeCats((char *)dst, &cats);
+ Rast3d_write_cats((char *)dst, &cats);
Rast_free_cats(&cats);
@@ -635,10 +635,10 @@
struct Colors colr;
- if (Rast3d_readColors((char *)m->name, (char *)m->mapset, &colr) <= 0)
+ if (Rast3d_read_colors((char *)m->name, (char *)m->mapset, &colr) <= 0)
return;
- Rast3d_writeColors((char *)dst, G_mapset(), &colr);
+ Rast3d_write_colors((char *)dst, G_mapset(), &colr);
Rast_free_colors(&colr);
Modified: grass/trunk/raster/r.to.rast3/main.c
--- grass/trunk/raster/r.to.rast3/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster/r.to.rast3/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -55,8 +55,8 @@
/* Close files and exit */
if (map != NULL) {
/* should unopen map here! but this functionality is not jet implemented */
- if (!Rast3d_closeCell(map))
- Rast3d_fatalError(_("Could not close the map"));
+ if (!Rast3d_close_cell(map))
+ Rast3d_fatal_error(_("Could not close the map"));
if (fd != NULL) {
@@ -64,7 +64,7 @@
close_input_raster_map(fd[i]);
- Rast3d_fatalError(errorMsg);
+ Rast3d_fatal_error(errorMsg);
exit(EXIT_FAILURE);
@@ -131,31 +131,31 @@
G_incr_void_ptr(ptr, Rast_cell_size(globalRastMapType))) {
if (globalRastMapType == CELL_TYPE) {
if (Rast_is_null_value(ptr, globalRastMapType)) {
- Rast3d_setNullValue(&dvalue, 1, DCELL_TYPE);
+ Rast3d_set_null_value(&dvalue, 1, DCELL_TYPE);
} else {
dvalue = *(CELL *) ptr;
(map, x, y, z, (char *) &dvalue, DCELL_TYPE) < 0)
fatal_error(map, fd, depths,
"Error writing double data");
} else if (globalRastMapType == FCELL_TYPE) {
- Rast3d_setNullValue(&fvalue, 1, FCELL_TYPE);
+ Rast3d_set_null_value(&fvalue, 1, FCELL_TYPE);
} else {
fvalue = *(FCELL *) ptr;
(map, x, y, z, (char *) &fvalue, FCELL_TYPE) < 0)
"Error writing float data");
} else if (globalRastMapType == DCELL_TYPE) {
} else {
dvalue = *(DCELL *) ptr;
@@ -210,14 +210,14 @@
/*Check for output */
if (param.output->answer == NULL)
- Rast3d_fatalError(_("No output map"));
+ Rast3d_fatal_error(_("No output map"));
/* Get the tile size */
maxSize = atoi(param.tilesize->answer);
/* Figure out the region from the map */
/*Check if the g3d-region is equal to the 2d rows and cols */
rows = Rast_window_rows();
@@ -285,17 +285,17 @@
else
globalG3dMapType = FCELL_TYPE;
- map = Rast3d_openNewOptTileSize(param.output->answer, RASTER3D_USE_CACHE_XY, ®ion, globalG3dMapType, maxSize);
+ map = Rast3d_open_new_opt_tile_size(param.output->answer, RASTER3D_USE_CACHE_XY, ®ion, globalG3dMapType, maxSize);
if (map == NULL)
fatal_error(map, fd, opencells, _("Error opening 3d raster map"));
/*if requested set the Mask on */
if (param.mask->answer) {
- if (Rast3d_maskFileExists()) {
+ if (Rast3d_mask_file_exists()) {
changemask = 0;
- if (Rast3d_maskIsOff(map)) {
- Rast3d_maskOn(map);
+ if (Rast3d_mask_is_off(map)) {
+ Rast3d_mask_on(map);
changemask = 1;
@@ -306,9 +306,9 @@
/*We set the Mask off, if it was off before */
- if (Rast3d_maskIsOn(map) && changemask)
- Rast3d_maskOff(map);
+ if (Rast3d_mask_is_on(map) && changemask)
+ Rast3d_mask_off(map);
/*Loop over all output maps! close */
@@ -319,11 +319,11 @@
G_free(fd);
/* Flush all tile */
- if (!Rast3d_flushAllTiles(map))
- Rast3d_fatalError("Error flushing tiles with Rast3d_flushAllTiles");
+ if (!Rast3d_flush_all_tiles(map))
+ Rast3d_fatal_error("Error flushing tiles with Rast3d_flush_all_tiles");
- Rast3d_fatalError(_("Error closing 3d raster map"));
+ Rast3d_fatal_error(_("Error closing 3d raster map"));
map = NULL;
Modified: grass/trunk/raster/r.to.rast3elev/main.c
--- grass/trunk/raster/r.to.rast3elev/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster/r.to.rast3elev/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -132,8 +132,8 @@
if (db.map != NULL) {
- if (!Rast3d_closeCell(db.map))
+ if (!Rast3d_close_cell(db.map))
if (db.input)
@@ -142,7 +142,7 @@
if (db.elev)
close_input_raster_map(db.elev);
exit(EXIT_FAILURE);
@@ -224,7 +224,7 @@
input_rast = Rast_allocate_buf(db.inputmaptype);
elev_rast = Rast_allocate_buf(db.elevmaptype);
- Rast3d_setNullValue(&null, 1, DCELL_TYPE);
+ Rast3d_set_null_value(&null, 1, DCELL_TYPE);
G_debug(3,
@@ -279,11 +279,11 @@
height <= ((z + 1) * tbres + bottom))
value = inval;
/*If the elevation is null, set the RASTER3D value null */
- if (Rast3d_isNullValueNum(&height, DCELL_TYPE))
+ if (Rast3d_is_null_value_num(&height, DCELL_TYPE))
value = null;
/*Write the value to the 3D map */
- if (Rast3d_putDouble(db.map, x, y, z, value) < 0)
+ if (Rast3d_put_double(db.map, x, y, z, value) < 0)
fatal_error(db, _("Error writing RASTER3D double data"));
} else {
@@ -296,7 +296,7 @@
else if (db.useUpperVal == 2)
value = db.upper;
else
- value = Rast3d_getDouble(db.map, x, y, z);
+ value = Rast3d_get_double(db.map, x, y, z);
/*lower cells */
if (height > ((z + 1) * tbres + bottom)) {
@@ -305,18 +305,18 @@
else if (db.useLowerVal == 2)
value = db.lower;
else
/*If exactly at the border, fill upper AND lower cell */
if (height >= (z * tbres + bottom) &&
value = inval;
@@ -399,7 +399,7 @@
else
G_fatal_error(_("The upper value is not valid"));
} else {
- Rast3d_setNullValue(&db.upper, 1, DCELL_TYPE);
+ Rast3d_set_null_value(&db.upper, 1, DCELL_TYPE);
/*Set the lower value */
@@ -409,12 +409,12 @@
else
G_fatal_error(_("The lower value is not valid"));
} else {
- Rast3d_setNullValue(&db.lower, 1, DCELL_TYPE);
+ Rast3d_set_null_value(&db.lower, 1, DCELL_TYPE);
/* Figure out the current g3d region */
@@ -437,7 +437,7 @@
/*open RASTER3D output map */
db.map = NULL;
- db.map = Rast3d_openNewOptTileSize(param.output->answer, RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, maxSize);
+ db.map = Rast3d_open_new_opt_tile_size(param.output->answer, RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, maxSize);
if (db.map == NULL)
fatal_error(db, _("Error opening 3d raster map"));
@@ -445,10 +445,10 @@
changemask = 0;
- if (Rast3d_maskIsOff(db.map)) {
- Rast3d_maskOn(db.map);
+ if (Rast3d_mask_is_off(db.map)) {
+ Rast3d_mask_on(db.map);
changemask = 1;
@@ -487,18 +487,18 @@
- if (Rast3d_maskIsOn(db.map) && changemask)
- Rast3d_maskOff(db.map);
+ if (Rast3d_mask_is_on(db.map) && changemask)
+ Rast3d_mask_off(db.map);
G_debug(2, "Close 3d raster map");
- if (!Rast3d_flushAllTiles(db.map))
+ if (!Rast3d_flush_all_tiles(db.map))
G_debug(2, "\nDone\n");
Modified: grass/trunk/raster/r.univar/r3.univar_main.c
--- grass/trunk/raster/r.univar/r3.univar_main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster/r.univar/r3.univar_main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -108,10 +108,10 @@
exit(EXIT_FAILURE);
/* Set the defaults */
/* get the current region */
- Rast3d_getWindow(®ion);
+ Rast3d_get_window(®ion);
cols = region.cols;
rows = region.rows;
@@ -144,18 +144,18 @@
/* open 3D zoning raster with default region */
if ((zonemap = param.zonefile->answer) != NULL) {
if (NULL == (mapset = G_find_grid3(zonemap, "")))
- Rast3d_fatalError(_("Requested g3d map <%s> not found"), zonemap);
+ Rast3d_fatal_error(_("Requested g3d map <%s> not found"), zonemap);
zmap =
- Rast3d_openCellOld(zonemap, G_find_grid3(zonemap, ""), ®ion,
+ Rast3d_open_cell_old(zonemap, G_find_grid3(zonemap, ""), ®ion,
if (zmap == NULL)
- Rast3d_fatalError(_("Error opening g3d map <%s>"), zonemap);
+ Rast3d_fatal_error(_("Error opening g3d map <%s>"), zonemap);
- zmap_type = Rast3d_tileTypeMap(zmap);
+ zmap_type = Rast3d_tile_type_map(zmap);
- if (Rast3d_readCats(zonemap, mapset, &(zone_info.cats)))
+ if (Rast3d_read_cats(zonemap, mapset, &(zone_info.cats)))
G_warning("no category support for zoning raster");
Rast3d_range_init(zmap);
@@ -183,16 +183,16 @@
infile = param.inputfile->answer;
if (NULL == G_find_grid3(infile, ""))
- Rast3d_fatalError(_("Requested g3d map <%s> not found"), infile);
+ Rast3d_fatal_error(_("Requested g3d map <%s> not found"), infile);
map =
- Rast3d_openCellOld(infile, G_find_grid3(infile, ""), ®ion,
+ Rast3d_open_cell_old(infile, G_find_grid3(infile, ""), ®ion,
if (map == NULL)
- Rast3d_fatalError(_("Error opening g3d map <%s>"), infile);
+ Rast3d_fatal_error(_("Error opening g3d map <%s>"), infile);
- map_type = Rast3d_tileTypeMap(map);
+ map_type = Rast3d_tile_type_map(map);
i = 0;
while (param.percentile->answers[i])
@@ -219,8 +219,8 @@
zone = 0;
if (zone_info.n_zones) {
if (zmap_type == FCELL_TYPE) {
- Rast3d_getValue(zmap, x, y, z, &val_f, FCELL_TYPE);
- if (Rast3d_isNullValueNum(&val_f, FCELL_TYPE))
+ Rast3d_get_value(zmap, x, y, z, &val_f, FCELL_TYPE);
+ if (Rast3d_is_null_value_num(&val_f, FCELL_TYPE))
continue;
if (val_f < 0)
zone = val_f - 0.5;
@@ -228,8 +228,8 @@
zone = val_f + 0.5;
else if (zmap_type == DCELL_TYPE) {
- Rast3d_getValue(zmap, x, y, z, &val_d, DCELL_TYPE);
- if (Rast3d_isNullValueNum(&val_d, DCELL_TYPE))
+ Rast3d_get_value(zmap, x, y, z, &val_d, DCELL_TYPE);
+ if (Rast3d_is_null_value_num(&val_d, DCELL_TYPE))
continue;
if (val_d < 0)
zone = val_d - 0.5;
@@ -239,8 +239,8 @@
zone -= zone_info.min;
if (map_type == FCELL_TYPE) {
- Rast3d_getValue(map, x, y, z, &val_f, map_type);
- if (!Rast3d_isNullValueNum(&val_f, map_type)) {
+ Rast3d_get_value(map, x, y, z, &val_f, map_type);
+ if (!Rast3d_is_null_value_num(&val_f, map_type)) {
if (param.extended->answer) {
if (stats[zone].n >= stats[zone].n_alloc) {
size_t msize;
@@ -273,8 +273,8 @@
stats[zone].size++;
else if (map_type == DCELL_TYPE) {
- Rast3d_getValue(map, x, y, z, &val_d, map_type);
- if (!Rast3d_isNullValueNum(&val_d, map_type)) {
+ Rast3d_get_value(map, x, y, z, &val_d, map_type);
+ if (!Rast3d_is_null_value_num(&val_d, map_type)) {
size_t msize;
@@ -311,9 +311,9 @@
/* close maps */
- Rast3d_closeCell(map);
+ Rast3d_close_cell(map);
- Rast3d_closeCell(zmap);
+ Rast3d_close_cell(zmap);
/* create the output */
if (param.table->answer)
Modified: grass/trunk/raster3d/r3.cross.rast/main.c
--- grass/trunk/raster3d/r3.cross.rast/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.cross.rast/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -51,8 +51,8 @@
if (map != NULL) {
- Rast3d_fatalError(_("Could not close RASTER3D map"));
+ Rast3d_fatal_error(_("Could not close RASTER3D map"));
/*unopen the output map */
@@ -62,7 +62,7 @@
if (elevfd != -1)
close_output_map(elevfd);
exit(EXIT_FAILURE);
@@ -136,7 +136,7 @@
depths = region.depths;
/*Typ of the RASTER3D Tile */
- typeIntern = Rast3d_tileTypeMap(map);
+ typeIntern = Rast3d_tile_type_map(map);
/*Allocate mem for the output maps row */
@@ -182,10 +182,10 @@
/* Get the voxel value */
- Rast3d_getRegionValue(map, north, east, elevation, &fcell[col], FCELL_TYPE);
+ Rast3d_get_region_value(map, north, east, elevation, &fcell[col], FCELL_TYPE);
if (typeIntern == DCELL_TYPE)
- Rast3d_getRegionValue(map, north, east, elevation, &dcell[col], DCELL_TYPE);
+ Rast3d_get_region_value(map, north, east, elevation, &dcell[col], DCELL_TYPE);
/*Write the data to the output map */
@@ -241,12 +241,12 @@
G_debug(3, "Open 3D raster map %s", param.input->answer);
if (NULL == G_find_grid3(param.input->answer, ""))
- Rast3d_fatalError(_("3d raster map <%s> not found"),
+ Rast3d_fatal_error(_("3d raster map <%s> not found"),
@@ -269,17 +269,17 @@
/*Open the 3d raster map */
- map = Rast3d_openCellOld(param.input->answer,
+ map = Rast3d_open_cell_old(param.input->answer,
G_find_grid3(param.input->answer, ""),
®ion, RASTER3D_TILE_SAME_AS_FILE,
if (map == NULL)
- Rast3d_fatalError(_("Error opening 3d raster map <%s>"),
+ Rast3d_fatal_error(_("Error opening 3d raster map <%s>"),
/*Get the output type */
- output_type = Rast3d_fileTypeMap(map);
+ output_type = Rast3d_file_type_map(map);
if (output_type == FCELL_TYPE || output_type == DCELL_TYPE) {
@@ -307,10 +307,10 @@
changemask = 0;
changemask = 1;
@@ -324,9 +324,9 @@
Rast_close(outfd);
@@ -338,8 +338,8 @@
- Rast3d_fatalError(_("Could not close RASTER3D map <%s>"),
+ Rast3d_fatal_error(_("Could not close RASTER3D map <%s>"),
return (EXIT_SUCCESS);
Modified: grass/trunk/raster3d/r3.gwflow/main.c
--- grass/trunk/raster3d/r3.gwflow/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.gwflow/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -185,10 +185,10 @@
/*Set the defaults */
/*get the current region */
/*allocate the geometry structure for geometry and area calculation */
geom = N_init_geom_data_3d(®ion, geom);
@@ -364,19 +364,19 @@
depths = region->depths;
/*Open the new map */
- map = Rast3d_openNewOptTileSize(name, RASTER3D_USE_CACHE_XY, region, DCELL_TYPE, 32);
+ map = Rast3d_open_new_opt_tile_size(name, RASTER3D_USE_CACHE_XY, region, DCELL_TYPE, 32);
if (map == NULL)
- Rast3d_fatalError(_("Error opening g3d map <%s>"), name);
+ Rast3d_fatal_error(_("Error opening g3d map <%s>"), name);
G_message(_("Write the result to g3d map <%s>"), name);
changemask = 0;
changemask = 1;
@@ -398,25 +398,25 @@
d1 = N_get_array_3d_d_value(phead_start, x, y, z);
else {
- Rast3d_setNullValue(&d1, 1, DCELL_TYPE);
+ Rast3d_set_null_value(&d1, 1, DCELL_TYPE);
- Rast3d_putDouble(map, x, y, z, d1);
+ Rast3d_put_double(map, x, y, z, d1);
- Rast3d_fatalError(map, NULL, 0, _("Error closing g3d file"));
+ Rast3d_fatal_error(map, NULL, 0, _("Error closing g3d file"));
return;
Modified: grass/trunk/raster3d/r3.in.ascii/main.c
--- grass/trunk/raster3d/r3.in.ascii/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.in.ascii/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -55,17 +55,17 @@
int rowOrder;
int depthOrder;
-extern void *Rast3d_openNewParam();
+extern void *Rast3d_open_new_param();
void fatalError(char *errorMsg)
if (map != NULL) {
/* should unopen map here! */
@@ -192,7 +192,7 @@
rewind(fp);
- Rast3d_getWindow(region);
+ Rast3d_get_window(region);
readHeaderString(fp, "north:", &(region->north));
readHeaderString(fp, "south:", &(region->south));
@@ -223,11 +223,11 @@
char buff[256];
int tileX, tileY, tileZ;
- Rast3d_getTileDimensionsMap(map, &tileX, &tileY, &tileZ);
- Rast3d_minUnlocked(map, RASTER3D_USE_CACHE_X);
+ Rast3d_get_tile_dimensions_map(map, &tileX, &tileY, &tileZ);
+ Rast3d_min_unlocked(map, RASTER3D_USE_CACHE_X);
- Rast3d_unlockAll(map);
+ Rast3d_unlock_all(map);
G_message(_("Loading data ... (%dx%dx%d)"), region->cols, region->rows,
region->depths);
@@ -239,7 +239,7 @@
G_percent(z, region->depths, 1);
if ((z % tileZ) == 0)
for (y = 0; y < region->rows; y++) /* go south to north */
for (x = 0; x < region->cols; x++) {
@@ -270,7 +270,7 @@
/* Check for null value */
if (convertNull && strncmp(buff, nullValue, strlen(nullValue)) == 0) {
- Rast3d_setNullValue(&value, 1, DCELL_TYPE);
+ Rast3d_set_null_value(&value, 1, DCELL_TYPE);
} else {
if (sscanf(buff, "%lf", &value) != 1) {
G_warning(_("Invalid value detected."));
@@ -280,10 +280,10 @@
/* Write the data */
- Rast3d_putDouble(map, col, row, depth, value);
+ Rast3d_put_double(map, col, row, depth, value);
- if (!Rast3d_flushTilesInCube(map,
+ if (!Rast3d_flush_tiles_in_cube(map,
0, 0, MAX(0, depth - tileZ),
region->rows - 1, region->cols - 1, depth))
fatalError("asciiTog3d: error flushing tiles");
@@ -294,11 +294,11 @@
"expected data. [%.4f ...]"), value);
G_percent(1, 1, 1);
@@ -329,13 +329,13 @@
_("Converts a 3D ASCII raster text file into a (binary) 3D raster map.");
setParams();
- Rast3d_setStandard3dInputParams();
+ Rast3d_set_standard3d_input_params();
exit(EXIT_FAILURE);
getParams(&input, &output, &convertNull, nullValue);
- if (!Rast3d_getStandard3dParams(&useTypeDefault, &type,
+ if (!Rast3d_get_standard3d_params(&useTypeDefault, &type,
&useLzwDefault, &doLzw,
&useRleDefault, &doRle,
&usePrecisionDefault, &precision,
@@ -343,12 +343,12 @@
&tileZ))
fatalError("main: error getting standard parameters");
fp = openAscii(input, ®ion);
/*Open the new RASTER3D map */
- map = Rast3d_openNewParam(output, RASTER3D_TILE_SAME_AS_FILE, RASTER3D_USE_CACHE_XY,
+ map = Rast3d_open_new_param(output, RASTER3D_TILE_SAME_AS_FILE, RASTER3D_USE_CACHE_XY,
®ion,
type, doLzw, doRle, precision, tileX, tileY,
tileZ);
@@ -359,13 +359,13 @@
/*Create the new RASTER3D Map */
asciiToG3d(fp, ®ion, convertNull, nullValue);
fatalError(_("Error closing new 3d raster map"));
/* write input name to map history */
- Rast3d_readHistory(output, G_mapset(), &history);
+ Rast3d_read_history(output, G_mapset(), &history);
Rast_set_history(&history, HIST_DATSRC_1, input);
- Rast3d_writeHistory(output, &history);
+ Rast3d_write_history(output, &history);
map = NULL;
if (fclose(fp))
Modified: grass/trunk/raster3d/r3.in.v5d/main.c
--- grass/trunk/raster3d/r3.in.v5d/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.in.v5d/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -49,7 +49,7 @@
@@ -159,8 +159,8 @@
value = data1[cnt++];
if (convertNull && (value == MISSING))
- Rast3d_setNullValue(&value, 1, FCELL_TYPE);
- Rast3d_putFloat(map, x, y, z, value);
+ Rast3d_set_null_value(&value, 1, FCELL_TYPE);
+ Rast3d_put_float(map, x, y, z, value);
@@ -197,13 +197,13 @@
_("Import 3-dimensional Vis5D files.");
setParams();
exit(1);
getParams(&input, &output, &convertNull, &nullValue);
@@ -211,14 +211,14 @@
&tileZ))
- map = Rast3d_openCellNew(output, FCELL_TYPE, RASTER3D_USE_CACHE_XY, ®ion);
+ map = Rast3d_open_cell_new(output, FCELL_TYPE, RASTER3D_USE_CACHE_XY, ®ion);
if (map == NULL)
convert(input, ®ion, convertNull, nullValue);
map = NULL;
Modified: grass/trunk/raster3d/r3.info/r3.info.main.c
--- grass/trunk/raster3d/r3.info/r3.info.main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.info/r3.info.main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -128,16 +128,16 @@
/*We need to open the map */
g3map =
- Rast3d_openCellOld(name, mapset, RASTER3D_DEFAULT_WINDOW,
+ Rast3d_open_cell_old(name, mapset, RASTER3D_DEFAULT_WINDOW,
if (NULL == g3map)
G_fatal_error(_("Unable to open 3D raster map <%s>"), name);
/*Get the maptype */
- data_type = Rast3d_fileTypeMap(g3map);
- head_ok = Rast3d_readRegionMap(name, mapset, &cellhd) >= 0;
- hist_ok = Rast3d_readHistory(name, mapset, &hist) >= 0;
- cats_ok = Rast3d_readCats(name, mapset, &cats) >= 0;
+ data_type = Rast3d_file_type_map(g3map);
+ head_ok = Rast3d_read_region_map(name, mapset, &cellhd) >= 0;
+ hist_ok = Rast3d_read_history(name, mapset, &hist) >= 0;
+ cats_ok = Rast3d_read_cats(name, mapset, &cats) >= 0;
/*Check the Timestamp */
time_ok = G_read_grid3_timestamp(name, mapset, &ts) > 0;
@@ -485,7 +485,7 @@
/*Close the opened map */
- if (!Rast3d_closeCell(g3map))
+ if (!Rast3d_close_cell(g3map))
G_fatal_error(_("Unable to close 3D raster map <%s>"), name);
Modified: grass/trunk/raster3d/r3.mask/main.c
--- grass/trunk/raster3d/r3.mask/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.mask/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -51,71 +51,71 @@
double value;
float floatNull;
- cacheSize = Rast3d_cacheSizeEncode(RASTER3D_USE_CACHE_XY, 1);
+ cacheSize = Rast3d_cache_size_encode(RASTER3D_USE_CACHE_XY, 1);
if (NULL == G_find_grid3(name, ""))
- Rast3d_fatalError(_("3D raster map <%s> not found"), name);
+ Rast3d_fatal_error(_("3D raster map <%s> not found"), name);
- map = Rast3d_openCellOld(name, G_mapset(), RASTER3D_DEFAULT_WINDOW,
+ map = Rast3d_open_cell_old(name, G_mapset(), RASTER3D_DEFAULT_WINDOW,
DCELL_TYPE, cacheSize);
if (map == NULL)
- Rast3d_fatalError(_("Unable to open 3D raster map <%s>"), name);
+ Rast3d_fatal_error(_("Unable to open 3D raster map <%s>"), name);
- Rast3d_getRegionStructMap(map, ®ion);
+ Rast3d_get_region_struct_map(map, ®ion);
- mask = Rast3d_openNewParam(Rast3d_maskFile(), FCELL_TYPE, cacheSize,
+ mask = Rast3d_open_new_param(Rast3d_mask_file(), FCELL_TYPE, cacheSize,
®ion, FCELL_TYPE, RASTER3D_NO_LZW, RASTER3D_USE_RLE, 0,
tileX, tileY, tileZ);
if (mask == NULL)
- Rast3d_fatalError(_("Unable to open 3D raster mask file"));
+ Rast3d_fatal_error(_("Unable to open 3D raster mask file"));
- Rast3d_minUnlocked(mask, RASTER3D_USE_CACHE_X);
- Rast3d_autolockOn(mask);
- Rast3d_unlockAll(mask);
+ Rast3d_min_unlocked(mask, RASTER3D_USE_CACHE_X);
+ Rast3d_autolock_on(mask);
+ Rast3d_unlock_all(mask);
- Rast3d_setNullValue(&floatNull, 1, FCELL_TYPE);
+ Rast3d_set_null_value(&floatNull, 1, FCELL_TYPE);
for (z = 0; z < region.depths; z++) {
if ((z % tileZ) == 0) {
for (y = 0; y < region.rows; y++) /* We count from north to south in the cube coordinate system */
for (x = 0; x < region.cols; x++) {
- value = Rast3d_getDoubleRegion(map, x, y, z);
+ value = Rast3d_get_double_region(map, x, y, z);
if (Rast3d_mask_d_select((DCELL *) & value, maskRules))
- Rast3d_putFloat(mask, x, y, z, (float)floatNull); /* mask-out value */
+ Rast3d_put_float(mask, x, y, z, (float)floatNull); /* mask-out value */
else
- Rast3d_putFloat(mask, x, y, z, (float)0.0); /* not mask-out value */
+ Rast3d_put_float(mask, x, y, z, (float)0.0); /* not mask-out value */
(mask, 0, 0, MAX(0, z - tileZ), region.rows - 1,
region.cols - 1, z))
- Rast3d_fatalError(_("makeMask: error flushing tiles in cube"));
+ Rast3d_fatal_error(_("makeMask: error flushing tiles in cube"));
- if (!Rast3d_flushAllTiles(mask))
- Rast3d_fatalError(_("makeMask: error flushing all tiles"));
+ if (!Rast3d_flush_all_tiles(mask))
+ Rast3d_fatal_error(_("makeMask: error flushing all tiles"));
- Rast3d_autolockOff(mask);
+ Rast3d_autolock_off(mask);
- if (!Rast3d_closeCell(mask))
- Rast3d_fatalError(_("Unable to close 3D raster mask file"));
- Rast3d_fatalError(_("Unable to close raster map <%s>"), name);
+ if (!Rast3d_close_cell(mask))
+ Rast3d_fatal_error(_("Unable to close 3D raster mask file"));
+ Rast3d_fatal_error(_("Unable to close raster map <%s>"), name);
@@ -153,7 +153,7 @@
exit(EXIT_FAILURE);
G_fatal_error(_("Cannot create mask file: RASTER3D_MASK already exists"));
getParams(&name, &maskRules);
Modified: grass/trunk/raster3d/r3.mkdspf/main.c
--- grass/trunk/raster3d/r3.mkdspf/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.mkdspf/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -139,9 +139,9 @@
exit(EXIT_FAILURE);
- Rast3d_getWindow(&g3reg);
+ Rast3d_get_window(&g3reg);
G_message(_("Region from getWindow: %d %d %d"),
g3reg.rows, g3reg.cols, g3reg.depths);
@@ -150,17 +150,17 @@
check_get_any_dspname(out->answer, name->answer, G_mapset())))
exit(EXIT_FAILURE);
- Rast3d_setErrorFun(Rast3d_printError);
+ Rast3d_set_error_fun(Rast3d_print_error);
/* open g3 file for reading and writing */
if (NULL == (mapset = G_find_file2("grid3", name->answer, "")))
G_fatal_error(_("Not able to find grid3 file for [%s]"),
name->answer);
- g3map = Rast3d_openCellOld(name->answer, mapset, &g3reg,
+ g3map = Rast3d_open_cell_old(name->answer, mapset, &g3reg,
- g3map = Rast3d_openCellOld (name->answer, mapset, RASTER3D_DEFAULT_WINDOW,
+ g3map = Rast3d_open_cell_old (name->answer, mapset, RASTER3D_DEFAULT_WINDOW,
@@ -174,7 +174,7 @@
/* TODO: look at this - should use current 3dregion rather than
region represented by original 3dgrid file */
- Rast3d_getRegionStructMap (g3map, &g3reg);
+ Rast3d_get_region_struct_map (g3map, &g3reg);
/* DONT USE Headfax any more ?
@@ -227,7 +227,7 @@
fprintf(stderr, "\n");
/* tries to write a header! */
- Rast3d_closeCell(g3map);
+ Rast3d_close_cell(g3map);
fclose(Headfax.dspfoutfp);
Modified: grass/trunk/raster3d/r3.mkdspf/r3_data.c
--- grass/trunk/raster3d/r3.mkdspf/r3_data.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.mkdspf/r3_data.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -9,7 +9,7 @@
float *data, int n_lev)
#ifdef NO_RESAMPLE
- Rast3d_getBlock(g3map, 0, 0, n_lev,
+ Rast3d_get_block(g3map, 0, 0, n_lev,
Headfax->xdim, Headfax->ydim, 1, (char *)data, FCELL_TYPE);
#else
/* Rast3d_getBlockRegion might be handy */
Modified: grass/trunk/raster3d/r3.null/main.c
--- grass/trunk/raster3d/r3.null/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.null/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -81,7 +81,7 @@
*changeNull = (params.null->answer != NULL);
if (*changeNull)
if (sscanf(params.null->answer, "%lf", newNullVal) != 1)
- Rast3d_fatalError(_("Illegal value for null"));
+ Rast3d_fatal_error(_("Illegal value for null"));
@@ -96,78 +96,78 @@
int doCompress, doLzw, doRle, precision;
int cacheSize;
fprintf(stderr, "name %s Mapset %s \n", name, G_mapset());
if (map == NULL)
- Rast3d_getCompressionMode(&doCompress, &doLzw, &doRle, &precision);
+ Rast3d_get_compression_mode(&doCompress, &doLzw, &doRle, &precision);
- mapOut = Rast3d_openNewParam(name, DCELL_TYPE, RASTER3D_USE_CACHE_XY,
- ®ion, Rast3d_fileTypeMap(map),
- doLzw, doRle, Rast3d_tilePrecisionMap(map), tileX,
+ mapOut = Rast3d_open_new_param(name, DCELL_TYPE, RASTER3D_USE_CACHE_XY,
+ ®ion, Rast3d_file_type_map(map),
+ doLzw, doRle, Rast3d_tile_precision_map(map), tileX,
tileY, tileZ);
if (mapOut == NULL)
- Rast3d_fatalError(_("modifyNull: error opening tmp file"));
+ Rast3d_fatal_error(_("modifyNull: error opening tmp file"));
- Rast3d_minUnlocked(mapOut, RASTER3D_USE_CACHE_X);
- Rast3d_autolockOn(mapOut);
- Rast3d_unlockAll(mapOut);
+ Rast3d_min_unlocked(mapOut, RASTER3D_USE_CACHE_X);
+ Rast3d_autolock_on(mapOut);
+ Rast3d_unlock_all(mapOut);
- if (Rast3d_isNullValueNum(&value, DCELL_TYPE)) {
+ if (Rast3d_is_null_value_num(&value, DCELL_TYPE)) {
if (changeNull) {
value = newNullVal;
else if (Rast3d_mask_d_select((DCELL *) & value, maskRules)) {
- Rast3d_putDouble(mapOut, x, y, z, value);
+ Rast3d_put_double(mapOut, x, y, z, value);
(mapOut, 0, 0, MAX(0, z - tileZ), region.rows - 1,
- Rast3d_fatalError(_("modifyNull: error flushing tiles in cube"));
+ Rast3d_fatal_error(_("modifyNull: error flushing tiles in cube"));
- if (!Rast3d_flushAllTiles(mapOut))
- Rast3d_fatalError(_("modifyNull: error flushing all tiles"));
+ if (!Rast3d_flush_all_tiles(mapOut))
+ Rast3d_fatal_error(_("modifyNull: error flushing all tiles"));
- Rast3d_autolockOff(mapOut);
+ Rast3d_autolock_off(mapOut);
- Rast3d_fatalError(_("Unable to close raster map"));
- if (!Rast3d_closeCell(mapOut))
- Rast3d_fatalError(_("modifyNull: Unable to close tmp file"));
+ Rast3d_fatal_error(_("Unable to close raster map"));
+ if (!Rast3d_close_cell(mapOut))
+ Rast3d_fatal_error(_("modifyNull: Unable to close tmp file"));
Modified: grass/trunk/raster3d/r3.out.ascii/main.c
--- grass/trunk/raster3d/r3.out.ascii/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.out.ascii/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -58,12 +58,12 @@
if (map != NULL) {
@@ -237,7 +237,7 @@
cols = region.cols;
for (z = 0; z < depths; z++) {
G_percent(z, depths, 1);
@@ -265,17 +265,17 @@
if (typeIntern == FCELL_TYPE) {
- Rast3d_getValue(map, col, row, depth, &fvalue, FCELL_TYPE);
+ Rast3d_get_value(map, col, row, depth, &fvalue, FCELL_TYPE);
- if (Rast3d_isNullValueNum(&fvalue, FCELL_TYPE))
+ if (Rast3d_is_null_value_num(&fvalue, FCELL_TYPE))
fprintf(fp, "%s ", param.null_val->answer);
else
fprintf(fp, "%.*f ", decim, fvalue);
} else {
- Rast3d_getValue(map, col, row, depth, &dvalue, DCELL_TYPE);
+ Rast3d_get_value(map, col, row, depth, &dvalue, DCELL_TYPE);
- if (Rast3d_isNullValueNum(&dvalue, DCELL_TYPE))
+ if (Rast3d_is_null_value_num(&dvalue, DCELL_TYPE))
else
fprintf(fp, "%.*lf ", decim, dvalue);
@@ -327,30 +327,30 @@
if (NULL == G_find_grid3(input, ""))
- Rast3d_fatalError(_("Requested 3d raster map not found"));
+ Rast3d_fatal_error(_("Requested 3d raster map not found"));
/* Figure out the current region settings */
/* Open the map and use XY cache mode */
- map = Rast3d_openCellOld(input, G_find_grid3(input, ""), ®ion,
+ map = Rast3d_open_cell_old(input, G_find_grid3(input, ""), ®ion,
if (map == NULL)
/* Open the output ascii file */
fp = openAscii(output, region);
changemask = 0;
changemask = 1;
@@ -361,13 +361,13 @@
/*We set the Mask off, if it was off bevor */
if (output)
Modified: grass/trunk/raster3d/r3.out.v5d/main.c
--- grass/trunk/raster3d/r3.out.v5d/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.out.v5d/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -50,11 +50,11 @@
if (map != NULL) {
fatalError("Error closing 3d raster map");
@@ -140,7 +140,7 @@
depths=region.depths;
/* END OF ORIGINAL CODE WHICH IS NOT NECESSARY FOR ME, COMMENTED IT */
G_debug(3, "cols: %i rows: %i depths: %i\n", cols, rows, depths);
@@ -225,10 +225,10 @@
for (x = 0; x < cols; x++) {
for (y = 0; y < rows; y++) { /* north to south */
- if (Rast3d_isNullValueNum(f1p, FCELL_TYPE)) {
+ if (Rast3d_is_null_value_num(f1p, FCELL_TYPE)) {
g[cnt] = MISSING;
cnt++;
@@ -238,7 +238,7 @@
else { /*double */
- if (Rast3d_isNullValueNum(d1p, DCELL_TYPE)) {
+ if (Rast3d_is_null_value_num(d1p, DCELL_TYPE)) {
g[cnt] = MISSING;
cnt++;
@@ -309,17 +309,17 @@
trueCoords = coords->answer;
- map = Rast3d_openCellOld(input, G_find_grid3(input, ""), RASTER3D_DEFAULT_WINDOW,
+ map = Rast3d_open_cell_old(input, G_find_grid3(input, ""), RASTER3D_DEFAULT_WINDOW,
if (map == NULL)
/* Use default region */
- /* Rast3d_getRegionStructMap(map, ®ion); */
+ /* Rast3d_get_region_struct_map(map, ®ion); */
/* Figure out the region from current settings: */
G_debug(3, "cols: %i rows: %i layers: %i\n", region.cols, region.rows,
region.depths);
@@ -327,7 +327,7 @@
convert(output, region.rows, region.cols, region.depths, trueCoords);
map = NULL;
Modified: grass/trunk/raster3d/r3.out.vtk/errorHandling.c
--- grass/trunk/raster3d/r3.out.vtk/errorHandling.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.out.vtk/errorHandling.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -40,7 +40,7 @@
/*close all open maps and free memory */
release_input_maps_struct(in);
- Rast3d_fatalError("Break because of errors.");
+ Rast3d_fatal_error("Break because of errors.");
@@ -61,7 +61,7 @@
int close_input_raster3d_map(void *map)
if (map != NULL) {
- if (!Rast3d_closeCell(map)) {
+ if (!Rast3d_close_cell(map)) {
G_warning(_("unable to close input 3d raster map"));
return 1;
@@ -102,7 +102,7 @@
free(in);
if (error > 0)
- Rast3d_fatalError("Error while closing the input maps");
+ Rast3d_fatal_error("Error while closing the input maps");
return;
Modified: grass/trunk/raster3d/r3.out.vtk/main.c
--- grass/trunk/raster3d/r3.out.vtk/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.out.vtk/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -114,14 +114,14 @@
if (param.structgrid->answer) {
if (!param.top->answer || !param.bottom->answer)
- Rast3d_fatalError(_("You have to specify top and bottom map"));
+ Rast3d_fatal_error(_("You have to specify top and bottom map"));
mapset = NULL;
name = NULL;
name = param.top->answer;
mapset = G_find_raster2(name, "");
if (mapset == NULL) {
- Rast3d_fatalError(_("Top cell map <%s> not found"),
+ Rast3d_fatal_error(_("Top cell map <%s> not found"),
param.top->answer);
@@ -130,7 +130,7 @@
name = param.bottom->answer;
- Rast3d_fatalError(_("Bottom cell map <%s> not found"),
+ Rast3d_fatal_error(_("Bottom cell map <%s> not found"),
param.bottom->answer);
@@ -139,7 +139,7 @@
if (param.input->answers != NULL) {
for (i = 0; param.input->answers[i] != NULL; i++) {
if (NULL == G_find_grid3(param.input->answers[i], ""))
- Rast3d_fatalError(_("Requested 3d raster map <%s> not found"),
+ Rast3d_fatal_error(_("Requested 3d raster map <%s> not found"),
param.input->answers[i]);
@@ -149,10 +149,10 @@
for (i = 0; i < 3; i++) {
if (param.rgbmaps->answers[i] != NULL) {
if (NULL == G_find_grid3(param.rgbmaps->answers[i], ""))
- Rast3d_fatalError(_("Requested g3d RGB map <%s> not found"),
+ Rast3d_fatal_error(_("Requested g3d RGB map <%s> not found"),
param.rgbmaps->answers[i]);
} else {
- Rast3d_fatalError(_("Please provide three g3d RGB maps"));
+ Rast3d_fatal_error(_("Please provide three g3d RGB maps"));
@@ -162,10 +162,10 @@
if (param.vectormaps->answers[i] != NULL) {
if (NULL == G_find_grid3(param.vectormaps->answers[i], ""))
- Rast3d_fatalError(_("Requested g3d vector map <%s> not found"),
+ Rast3d_fatal_error(_("Requested g3d vector map <%s> not found"),
param.vectormaps->answers[i]);
} else {
- Rast3d_fatalError(_("Please provide three g3d vector maps [x,y,z]"));
+ Rast3d_fatal_error(_("Please provide three g3d vector maps [x,y,z]"));
@@ -199,7 +199,7 @@
maprgb = NULL;
/*Open the map */
maprgb =
- Rast3d_openCellOld(param.rgbmaps->answers[i],
+ Rast3d_open_cell_old(param.rgbmaps->answers[i],
G_find_grid3(param.rgbmaps->answers[i], ""),
@@ -211,10 +211,10 @@
changemask[i] = 0;
- if (Rast3d_maskIsOff(maprgb)) {
- Rast3d_maskOn(maprgb);
+ if (Rast3d_mask_is_off(maprgb)) {
+ Rast3d_mask_on(maprgb);
changemask[i] = 1;
@@ -243,12 +243,12 @@
- if (Rast3d_maskIsOn(maprgb) && changemask[i])
- Rast3d_maskOff(maprgb);
+ if (Rast3d_mask_is_on(maprgb) && changemask[i])
+ Rast3d_mask_off(maprgb);
/* Close the 3d raster map */
- if (!Rast3d_closeCell(maprgb)) {
+ if (!Rast3d_close_cell(maprgb)) {
fatal_error(_("Error closing g3d rgb map."), in);
@@ -284,7 +284,7 @@
mapvect = NULL;
/*Open the map */
mapvect =
- Rast3d_openCellOld(param.vectormaps->answers[i],
+ Rast3d_open_cell_old(param.vectormaps->answers[i],
""), ®ion,
@@ -296,10 +296,10 @@
changemask[i] = 0;
- if (Rast3d_maskIsOff(mapvect)) {
- Rast3d_maskOn(mapvect);
+ if (Rast3d_mask_is_off(mapvect)) {
+ Rast3d_mask_on(mapvect);
changemask[i] = 1;
@@ -328,13 +328,13 @@
- if (Rast3d_maskIsOn(mapvect) && changemask[i])
- Rast3d_maskOff(mapvect);
+ if (Rast3d_mask_is_on(mapvect) && changemask[i])
+ Rast3d_mask_off(mapvect);
- if (!Rast3d_closeCell(mapvect)) {
+ if (!Rast3d_close_cell(mapvect)) {
fatal_error(_("Error closing g3d vector map."), in);
/*Set the pointer to null so we know later that these files are already closed */
@@ -423,8 +423,8 @@
fp = stdout;
/*initiate the input mpas structure */
in = create_input_maps_struct();
@@ -503,7 +503,7 @@
/*Open the map */
in->map =
- Rast3d_openCellOld(param.input->answers[i],
+ Rast3d_open_cell_old(param.input->answers[i],
G_find_grid3(param.input->answers[i], ""),
@@ -515,10 +515,10 @@
changemask = 0;
- if (Rast3d_maskIsOff(in->map)) {
- Rast3d_maskOn(in->map);
+ if (Rast3d_mask_is_off(in->map)) {
+ Rast3d_mask_on(in->map);
changemask = 1;
@@ -529,13 +529,13 @@
- if (Rast3d_maskIsOn(in->map) && changemask)
- Rast3d_maskOff(in->map);
+ if (Rast3d_mask_is_on(in->map) && changemask)
+ Rast3d_mask_off(in->map);
- if (!Rast3d_closeCell(in->map)) {
+ if (!Rast3d_close_cell(in->map)) {
in->map = NULL;
fatal_error(_("Error closing 3d raster map, the VTK file may be incomplete."),
in);
Modified: grass/trunk/raster3d/r3.out.vtk/writeVTKData.c
--- grass/trunk/raster3d/r3.out.vtk/writeVTKData.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.out.vtk/writeVTKData.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -79,14 +79,14 @@
double dvalue;
if (type == FCELL_TYPE) {
- Rast3d_getValue(map, x, y, z, &fvalue, type);
+ Rast3d_get_value(map, x, y, z, &fvalue, type);
val = nullval;
else
val = (double) fvalue;
} else {
- Rast3d_getValue(map, x, y, z, &dvalue, type);
+ Rast3d_get_value(map, x, y, z, &dvalue, type);
val = nullval;
else
val = dvalue;
@@ -338,7 +338,7 @@
fprintf(fp, "SCALARS %s float 1\n", varname);
fprintf(fp, "LOOKUP_TABLE default\n");
percentage = 0;
@@ -398,9 +398,9 @@
cols = region.cols;
- typeIntern[0] = Rast3d_tileTypeMap(map_r);
- typeIntern[1] = Rast3d_tileTypeMap(map_g);
- typeIntern[2] = Rast3d_tileTypeMap(map_b);
+ typeIntern[0] = Rast3d_tile_type_map(map_r);
+ typeIntern[1] = Rast3d_tile_type_map(map_g);
+ typeIntern[2] = Rast3d_tile_type_map(map_b);
percentage = 0;
@@ -473,9 +473,9 @@
cols = region.cols;
- typeIntern[0] = Rast3d_tileTypeMap(map_x);
- typeIntern[1] = Rast3d_tileTypeMap(map_y);
- typeIntern[2] = Rast3d_tileTypeMap(map_z);
+ typeIntern[0] = Rast3d_tile_type_map(map_x);
+ typeIntern[1] = Rast3d_tile_type_map(map_y);
+ typeIntern[2] = Rast3d_tile_type_map(map_z);
percentage = 0;
Modified: grass/trunk/raster3d/r3.retile/main.c
--- grass/trunk/raster3d/r3.retile/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.retile/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -50,8 +50,8 @@
if (map != NULL) {
- Rast3d_fatalError(_("Unable to close the 3d raster map"));
+ Rast3d_fatal_error(_("Unable to close the 3d raster map"));
if (fd != NULL) {
@@ -59,7 +59,7 @@
Rast_unopen(fd[i]);
exit(EXIT_FAILURE);
@@ -115,29 +115,29 @@
mapset = G_find_grid3(param.input->answer, "");
if (mapset == NULL)
if(!param.cache->answer)
- map = Rast3d_openCellOld(param.input->answer, mapset, RASTER3D_DEFAULT_WINDOW,
+ map = Rast3d_open_cell_old(param.input->answer, mapset, RASTER3D_DEFAULT_WINDOW,
else
if (map == NULL)
- Rast3d_fatalError(_("Unable to open 3d raster map <%s>"),
+ Rast3d_fatal_error(_("Unable to open 3d raster map <%s>"),
/* Get the tile dimension */
- Rast3d_getTileDimension(&tileX, &tileY, &tileZ);
+ Rast3d_get_tile_dimension(&tileX, &tileY, &tileZ);
if (strcmp(param.tiling->answer, "default") != 0) {
if (sscanf(param.tiling->answer, "%dx%dx%d",
&tileX, &tileY, &tileZ) != 3) {
- Rast3d_fatalError(_("Rast3d_getStandard3dParams: tile dimension value invalid"));
+ Rast3d_fatal_error(_("Rast3d_get_standard3d_params: tile dimension value invalid"));
@@ -149,7 +149,7 @@
Rast3d_retile(map, param.output->answer, tileX, tileY, tileZ);
fatal_error(map, NULL, 0, _("Error closing 3d raster map"));
map = NULL;
Modified: grass/trunk/raster3d/r3.showdspf/main_ogl.c
--- grass/trunk/raster3d/r3.showdspf/main_ogl.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.showdspf/main_ogl.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -163,7 +163,7 @@
/* opens grid3 file to read in original data
/* open g3 file for reading */
if (NULL == (mapset = G_find_file2("grid3", g3->answer, ""))) {
@@ -171,7 +171,7 @@
G_fatal_error(buff);
- g3map = Rast3d_openCellOld(g3->answer, mapset, RASTER3D_DEFAULT_WINDOW,
+ g3map = Rast3d_open_cell_old(g3->answer, mapset, RASTER3D_DEFAULT_WINDOW,
if (NULL == g3map) {
@@ -184,7 +184,7 @@
Rast3d_range_min_max(g3map, &dmin, &dmax);
- Rast3d_getRegionStructMap(g3map, &g3reg);
+ Rast3d_get_region_struct_map(g3map, &g3reg);
viz_make_header(&G3header, dmin, dmax, &g3reg);
init_caps(&D_Cap, &g3reg);
Modified: grass/trunk/raster3d/r3.showdspf/r3_data.c
--- grass/trunk/raster3d/r3.showdspf/r3_data.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.showdspf/r3_data.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -10,7 +10,7 @@
int n_lev;
return 0;
Modified: grass/trunk/raster3d/r3.stats/main.c
--- grass/trunk/raster3d/r3.stats/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.stats/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -591,10 +591,10 @@
cols = region.cols;
rows = region.rows;
@@ -609,16 +609,16 @@
infile = inputfile->answer;
- Rast3d_fatalError(_("3D raster map <%s> not found"), infile);
+ Rast3d_fatal_error(_("3D raster map <%s> not found"), infile);
map =
if (map == NULL)
- Rast3d_fatalError(_("Unable to open 3D raster map <%s>"), infile);
+ Rast3d_fatal_error(_("Unable to open 3D raster map <%s>"), infile);
/* calculate statistics for groups of equal values */
if ((equal->answer)) {
@@ -631,8 +631,8 @@
/*the first entry */
if (eqvals == NULL)
eqvals =
@@ -645,8 +645,8 @@
if (eqvals == NULL)
eqvals =
@@ -690,15 +690,15 @@
check_range_value(stats, (double)val_f);
n++;
check_range_value(stats, val_d);
n++;
Modified: grass/trunk/raster3d/r3.to.rast/main.c
--- grass/trunk/raster3d/r3.to.rast/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/raster3d/r3.to.rast/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -51,8 +51,8 @@
if (map != NULL) {
- Rast3d_fatalError(_("Unable to close 3Draster map"));
+ Rast3d_fatal_error(_("Unable to close 3Draster map"));
if (fd != NULL) {
@@ -60,7 +60,7 @@
Rast_unopen(fd[i]);
exit(EXIT_FAILURE);
@@ -118,7 +118,7 @@
G_debug(2, "g3d_to_raster: Writing %i raster maps with %i rows %i cols.",
depths, rows, cols);
fcell = Rast_allocate_f_buf();
@@ -134,14 +134,14 @@
- Rast3d_getValue(map, x, y, z, &f1, typeIntern);
- if (Rast3d_isNullValueNum(&f1, FCELL_TYPE))
+ Rast3d_get_value(map, x, y, z, &f1, typeIntern);
+ if (Rast3d_is_null_value_num(&f1, FCELL_TYPE))
Rast_set_null_value(&fcell[x], 1, FCELL_TYPE);
else
fcell[x] = f1;
} else {
- Rast3d_getValue(map, x, y, z, &d1, typeIntern);
- if (Rast3d_isNullValueNum(&d1, DCELL_TYPE))
+ Rast3d_get_value(map, x, y, z, &d1, typeIntern);
+ if (Rast3d_is_null_value_num(&d1, DCELL_TYPE))
Rast_set_null_value(&dcell[x], 1, DCELL_TYPE);
else
dcell[x] = d1;
@@ -218,46 +218,46 @@
G_debug(3, _("Open 3D raster map <%s>"), param.input->answer);
/*Set the resolution of the output maps */
if (param.res->answer) {
/*Open the map with current region */
RASTER3D_DEFAULT_WINDOW, RASTER3D_TILE_SAME_AS_FILE,
if (map == NULL)
/*Get the region of the map */
/*set this region as current 3d window for map */
- Rast3d_setWindowMap(map, ®ion);
+ Rast3d_set_window_map(map, ®ion);
/*Set the 2d region appropriate */
- Rast3d_extract2dRegion(®ion, ®ion2d);
+ Rast3d_extract2d_region(®ion, ®ion2d);
/*Make the new 2d region the default */
Rast_set_window(®ion2d);
} else {
if (map == NULL)
- Rast3d_fatalError(_("Error opening 3D raster map <%s>"),
+ Rast3d_fatal_error(_("Error opening 3D raster map <%s>"),
@@ -275,16 +275,16 @@
region.rows = region2d.rows;
region.cols = region2d.cols;
- Rast3d_adjustRegion(®ion);
+ Rast3d_adjust_region(®ion);
/* save the input map region for later use (history meta-data) */
- Rast3d_getRegionStructMap(map, &inputmap_bounds);
+ Rast3d_get_region_struct_map(map, &inputmap_bounds);
/*prepare the filehandler */
@@ -316,10 +316,10 @@
changemask = 0;
changemask = 1;
@@ -364,9 +364,9 @@
@@ -378,7 +378,7 @@
G_free(fd);
map = NULL;
Modified: grass/trunk/vector/v.colors/main.c
--- grass/trunk/vector/v.colors/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/vector/v.colors/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -240,7 +240,7 @@
if (!cmapset)
G_fatal_error(_("3D raster map <%s> not found"), cmap);
G_fatal_error(_("Unable to read color table for 3D raster map <%s>"), cmap);
Modified: grass/trunk/vector/v.to.rast3/main.c
--- grass/trunk/vector/v.to.rast3/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/vector/v.to.rast3/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -64,9 +64,9 @@
exit(EXIT_FAILURE);
Vect_set_open_level(2);
Vect_open_old2(&Map, in_opt->answer, "", field_opt->answer);
@@ -97,7 +97,7 @@
db_close_database_shutdown_driver(Driver);
- map = Rast3d_openNewOptTileSize(out_opt->answer,
+ map = Rast3d_open_new_opt_tile_size(out_opt->answer,
RASTER3D_USE_CACHE_DEFAULT, ®ion, FCELL_TYPE, 32);
if (map == NULL)
@@ -122,7 +122,7 @@
continue;
/* Check if the coordinates are located in the cube */
- if (!Rast3d_isValidLocation(&(map->region), Points->y[0], Points->x[0], Points->z[0])) {
+ if (!Rast3d_is_valid_location(&(map->region), Points->y[0], Points->x[0], Points->z[0])) {
continue;
/* Convert the north, east and top coorindate into row, col and depth*/
@@ -145,12 +145,12 @@
G_debug(3, "col,row,depth,val: %d %d %d %f", col, row, depth, value);
- Rast3d_putFloat(map, col, row, depth, (float)value);
+ Rast3d_put_float(map, col, row, depth, (float)value);
Vect_close(&Map);
G_fatal_error(_("Unable to close new 3d raster map"));
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/vector/v.vol.rst/main.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -449,8 +449,8 @@
G_get_set_window(&cellhd);
- Rast3d_getWindow(¤t_region);
- Rast3d_readWindow(¤t_region, NULL);
+ Rast3d_get_window(¤t_region);
+ Rast3d_read_window(¤t_region, NULL);
ew_res = current_region.ew_res;
ns_res = current_region.ns_res;
Modified: grass/trunk/vector/v.vol.rst/user1.c
--- grass/trunk/vector/v.vol.rst/user1.c 2011-08-12 00:00:12 UTC (rev 47592)
+++ grass/trunk/vector/v.vol.rst/user1.c 2011-08-12 08:32:30 UTC (rev 47593)
@@ -423,7 +423,7 @@
/*** Write elevation results ***/
if (outz != NULL) {
- cf1 = Rast3d_openNewOptTileSize(outz, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
+ cf1 = Rast3d_open_new_opt_tile_size(outz, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
if (cf1 == NULL) {
sprintf(buff, "Can't open %s for writing ", outz);
clean_fatal_error(buff);
@@ -449,8 +449,8 @@
bmask = 1;
value = data[cnt];
if (!bmask)
- if (Rast3d_putFloat(cf1, x, y, iarc, value) == 0) {
+ if (Rast3d_put_float(cf1, x, y, iarc, value) == 0) {
sprintf(buff,
"Error writing cell (%d,%d,%d) with value %f",
x, y, iarc, value);
@@ -464,7 +464,7 @@
/* Close the file */
- if (Rast3d_closeCell(cf1) == 0) {
+ if (Rast3d_close_cell(cf1) == 0) {
sprintf(buff, "Error closing output file %s ", outz);
@@ -473,7 +473,7 @@
/*** Write out the gradient results ***/
if (gradient != NULL) {
- cf2 = Rast3d_openNewOptTileSize(gradient, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
+ cf2 = Rast3d_open_new_opt_tile_size(gradient, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
if (cf2 == NULL) {
sprintf(buff, "Can't open %s for writing ", gradient);
@@ -499,8 +499,8 @@
bmask = 1;
value = data[cnt];
if (!bmask)
- if (Rast3d_putFloat(cf2, x, y, iarc, value) == 0) {
+ if (Rast3d_put_float(cf2, x, y, iarc, value) == 0) {
sprintf(buff,
x, y, iarc, value);
@@ -514,7 +514,7 @@
- if (Rast3d_closeCell(cf2) == 0) {
+ if (Rast3d_close_cell(cf2) == 0) {
sprintf(buff, "Error closing output file %s ", gradient);
@@ -523,7 +523,7 @@
/*** Write out aspect1 results ***/
if (aspect1 != NULL) {
- cf3 = Rast3d_openNewOptTileSize(aspect1, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
+ cf3 = Rast3d_open_new_opt_tile_size(aspect1, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
if (cf3 == NULL) {
sprintf(buff, "Can't open %s for writing ", aspect1);
@@ -549,8 +549,8 @@
bmask = 1;
value = data[cnt];
if (!bmask)
- if (Rast3d_putFloat(cf3, x, y, iarc, value) == 0) {
+ if (Rast3d_put_float(cf3, x, y, iarc, value) == 0) {
sprintf(buff,
x, y, iarc, value);
@@ -564,7 +564,7 @@
- if (Rast3d_closeCell(cf3) == 0) {
+ if (Rast3d_close_cell(cf3) == 0) {
sprintf(buff, "Error closing output file %s ", aspect1);
@@ -573,7 +573,7 @@
/*** Write out aspect2 results ***/
if (aspect2 != NULL) {
- cf4 = Rast3d_openNewOptTileSize(aspect2, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
+ cf4 = Rast3d_open_new_opt_tile_size(aspect2, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
if (cf4 == NULL) {
sprintf(buff, "Can't open %s for writing ", aspect2);
@@ -599,8 +599,8 @@
bmask = 1;
value = data[cnt];
if (!bmask)
- if (Rast3d_putFloat(cf4, x, y, iarc, value) == 0) {
+ if (Rast3d_put_float(cf4, x, y, iarc, value) == 0) {
sprintf(buff,
x, y, iarc, value);
@@ -614,7 +614,7 @@
- if (Rast3d_closeCell(cf4) == 0) {
+ if (Rast3d_close_cell(cf4) == 0) {
sprintf(buff, "Error closing output file %s ", aspect2);
@@ -623,7 +623,7 @@
/*** Write out ncurv results ***/
if (ncurv != NULL) {
- cf5 = Rast3d_openNewOptTileSize(ncurv, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
+ cf5 = Rast3d_open_new_opt_tile_size(ncurv, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
if (cf5 == NULL) {
sprintf(buff, "Can't open %s for writing ", ncurv);
@@ -649,8 +649,8 @@
bmask = 1;
value = data[cnt];
if (!bmask)
- if (Rast3d_putFloat(cf5, x, y, iarc, value) == 0) {
+ if (Rast3d_put_float(cf5, x, y, iarc, value) == 0) {
sprintf(buff,
x, y, iarc, value);
@@ -664,7 +664,7 @@
- if (Rast3d_closeCell(cf5) == 0) {
+ if (Rast3d_close_cell(cf5) == 0) {
sprintf(buff, "Error closing output file %s ", ncurv);
@@ -673,7 +673,7 @@
/*** Write out gcurv results ***/
if (gcurv != NULL) {
- cf6 = Rast3d_openNewOptTileSize(gcurv, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
+ cf6 = Rast3d_open_new_opt_tile_size(gcurv, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
if (cf6 == NULL) {
sprintf(buff, "Can't open %s for writing ", gcurv);
@@ -699,8 +699,8 @@
bmask = 1;
value = data[cnt];
if (!bmask)
- if (Rast3d_putFloat(cf6, x, y, iarc, value) == 0) {
+ if (Rast3d_put_float(cf6, x, y, iarc, value) == 0) {
sprintf(buff,
x, y, iarc, value);
@@ -714,7 +714,7 @@
- if (Rast3d_closeCell(cf6) == 0) {
+ if (Rast3d_close_cell(cf6) == 0) {
sprintf(buff, "Error closing output file %s ", gcurv);
@@ -723,7 +723,7 @@
/*** Write mcurv results ***/
if (mcurv != NULL) {
- cf7 = Rast3d_openNewOptTileSize(mcurv, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
+ cf7 = Rast3d_open_new_opt_tile_size(mcurv, RASTER3D_USE_CACHE_DEFAULT, ¤t_region, FCELL_TYPE, 32);
if (cf7 == NULL) {
sprintf(buff, "Can't open %s for writing ", mcurv);
@@ -749,8 +749,8 @@
bmask = 1;
value = data[cnt];
if (!bmask)
- if (Rast3d_putFloat(cf7, x, y, iarc, value) == 0) {
+ if (Rast3d_put_float(cf7, x, y, iarc, value) == 0) {
sprintf(buff,
x, y, iarc, value);
@@ -764,7 +764,7 @@
- if (Rast3d_closeCell(cf7) == 0) {
+ if (Rast3d_close_cell(cf7) == 0) {
sprintf(buff, "Error closing output file %s ", mcurv);
