[GRASS-SVN] r47594 - in grass/trunk: include lib/gpde lib/ogsf
lib/raster3d lib/raster3d/test raster/r.colors
raster/r.mapcalc raster/r.to.rast3 raster/r.to.rast3elev
raster/r.univar raster3d/r3.cross.rast raster3d/r3.gwflow
raster3d/r3.in.ascii raster3d/r3.in.v5d raster3d/r3.info
raster3d/r3.mask raster3d/r3.mkdspf raster3d/r3.null
raster3d/r3.out.ascii raster3d/r3.out.v5d raster3d/r3.out.vtk
raster3d/r3.retile raster3d/r3.to.rast vector/v.to.rast3
vector/v.vol.rst
svn_grass at osgeo.org
Fri Aug 12 04:47:59 EDT 2011
Author: martinl
Date: 2011-08-12 01:47:59 -0700 (Fri, 12 Aug 2011)
New Revision: 47594
grass/trunk/include/raster3ddefs.h
grass/trunk/lib/gpde/N_arrays_io.c
grass/trunk/lib/ogsf/gvl_file.c
grass/trunk/lib/raster3d/cache1.c
grass/trunk/lib/raster3d/changeprecision.c
grass/trunk/lib/raster3d/changetype.c
grass/trunk/lib/raster3d/close.c
grass/trunk/lib/raster3d/filecompare.c
grass/trunk/lib/raster3d/mask.c
grass/trunk/lib/raster3d/retile.c
grass/trunk/lib/raster3d/test/test_coordinate_transform.c
grass/trunk/lib/raster3d/test/test_put_get_value.c
grass/trunk/lib/raster3d/volume.c
grass/trunk/raster/r.colors/stats.c
grass/trunk/raster/r.mapcalc/map3.c
grass/trunk/raster/r.to.rast3/main.c
grass/trunk/raster/r.to.rast3elev/main.c
grass/trunk/raster/r.univar/r3.univar_main.c
grass/trunk/raster3d/r3.cross.rast/main.c
grass/trunk/raster3d/r3.gwflow/main.c
grass/trunk/raster3d/r3.in.ascii/main.c
grass/trunk/raster3d/r3.in.v5d/main.c
grass/trunk/raster3d/r3.info/r3.info.main.c
grass/trunk/raster3d/r3.mask/main.c
grass/trunk/raster3d/r3.mkdspf/main.c
grass/trunk/raster3d/r3.null/main.c
grass/trunk/raster3d/r3.out.ascii/main.c
grass/trunk/raster3d/r3.out.v5d/main.c
grass/trunk/raster3d/r3.out.vtk/errorHandling.c
grass/trunk/raster3d/r3.out.vtk/main.c
grass/trunk/raster3d/r3.retile/main.c
grass/trunk/raster3d/r3.to.rast/main.c
grass/trunk/vector/v.to.rast3/main.c
grass/trunk/vector/v.vol.rst/user1.c
raster3dlib: doxygenize close.c
Rast3d_close_cell() ranamed to Rast3d_close()
Modified: grass/trunk/include/raster3ddefs.h
--- grass/trunk/include/raster3ddefs.h 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/include/raster3ddefs.h 2011-08-12 08:47:59 UTC (rev 47594)
@@ -73,7 +73,7 @@
int Rast3d_read_cats(const char *, const char *, struct Categories *);
/* g3dclose.c */
-int Rast3d_close_cell(RASTER3D_Map *);
+int Rast3d_close(RASTER3D_Map *);
/* g3dcolor.c */
int Rast3d_remove_color(const char *);
Modified: grass/trunk/lib/gpde/N_arrays_io.c
--- grass/trunk/lib/gpde/N_arrays_io.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/gpde/N_arrays_io.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -360,7 +360,7 @@
/* Close files and exit */
- if (!Rast3d_close_cell(map))
+ if (!Rast3d_close(map))
Rast3d_fatal_error(map, NULL, 0, _("Error closing g3d file"));
return data;
@@ -460,7 +460,7 @@
if (!Rast3d_flush_all_tiles(map))
Rast3d_fatal_error("Error flushing tiles with Rast3d_flush_all_tiles");
return;
Modified: grass/trunk/lib/ogsf/gvl_file.c
--- grass/trunk/lib/ogsf/gvl_file.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/ogsf/gvl_file.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -467,7 +467,7 @@
int close_g3d_file(void *map)
/* close opened g3d file */
- if (Rast3d_close_cell((RASTER3D_Map *) map) != 1) {
+ if (Rast3d_close((RASTER3D_Map *) map) != 1) {
G_warning(_("Unable to close 3D raster map <%s>"),
((RASTER3D_Map *) map)->fileName);
return (-1);
Modified: grass/trunk/lib/raster3d/cache1.c
--- grass/trunk/lib/raster3d/cache1.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/raster3d/cache1.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -158,7 +158,7 @@
read_fn * eltLoadFun, void *eltLoadFunData)
return Rast3d_cache_new(nofElts, sizeOfElts, nofNames,
- cache_dummy_fun, NULL, eltLoadFun, eltLoadFunData);
+ cache_dummy_fun, NULL, eltLoadFun, eltLoadFunData);
Modified: grass/trunk/lib/raster3d/changeprecision.c
--- grass/trunk/lib/raster3d/changeprecision.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/raster3d/changeprecision.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -71,6 +71,6 @@
Rast3d_free_tiles(data);
- if (!Rast3d_close_cell(map2))
- Rast3d_fatal_error("Rast3d_change_precision: error in Rast3d_close_cell");
+ if (!Rast3d_close(map2))
+ Rast3d_fatal_error("Rast3d_change_precision: error in Rast3d_close");
Modified: grass/trunk/lib/raster3d/changetype.c
--- grass/trunk/lib/raster3d/changetype.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/raster3d/changetype.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -76,6 +76,6 @@
Rast3d_free_tiles(data2);
- Rast3d_fatal_error("Rast3d_change_type: error in Rast3d_close_cell");
+ Rast3d_fatal_error("Rast3d_change_type: error in Rast3d_close");
Modified: grass/trunk/lib/raster3d/close.c
--- grass/trunk/lib/raster3d/close.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/raster3d/close.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -1,3 +1,17 @@
+ \file lib/raster3d/close.c
+ \brief 3D Raster Library - Close 3D raster file
+ (C) 1999-2009, 2011 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ \author USACERL and many others
#ifdef __MINGW32__
# include <windows.h>
#endif
@@ -7,12 +21,11 @@
#include <unistd.h>
#include <grass/raster.h>
+#include <grass/glocale.h>
#include "raster3d_intern.h"
-static int Rast3d_closeNew(RASTER3D_Map * map)
+static int close_new(RASTER3D_Map * map)
char path[GPATH_MAX];
struct Categories cats;
@@ -31,10 +44,9 @@
/*Use the G3d function to write the history file,
* otherwise the path is wrong */
if (!Rast3d_write_history(map->fileName, &hist)) {
- Rast3d_error("Rast3d_closeNew: can't write raster3d history");
+ G_warning(_("Unable to write history for 3D raster map <%s>"), map);
Rast3d_range_write(map);
close(map->data_fd);
@@ -47,9 +59,8 @@
if (link(map->tempName, path) < 0) {
#endif
if (rename(map->tempName, path)) {
- Rast3d_error
- ("Rast3d_closeNew: can't move temp raster map %s\nto 3d data file %s",
- map->tempName, path);
+ G_warning(_("Unable to move temp raster map <%s> to 3d data file <%s>"),
+ map->tempName, path);
return 0;
@@ -59,20 +70,18 @@
return 1;
-static int Rast3d_closeCellNew(RASTER3D_Map * map)
+static int close_cell_new(RASTER3D_Map * map)
long ltmp;
if (map->useCache)
if (!Rast3d_flush_all_tiles(map)) {
- Rast3d_error("Rast3d_closeCellNew: error in Rast3d_flush_all_tiles");
+ G_warning(_("Unable to flush all tiles"));
return 0;
if (!Rast3d_flush_index(map)) {
- Rast3d_error("Rast3d_closeCellNew: error in Rast3d_flush_index");
+ G_warning(_("Unable to flush index"));
return 0;
@@ -82,79 +91,72 @@
if (lseek(map->data_fd,
(long)(map->offset - sizeof(int) - sizeof(long)),
SEEK_SET) == -1) {
- Rast3d_error("Rast3d_closeCellNew: can't position file");
+ G_warning(_("Unable to position file"));
return 0;
if (!Rast3d_write_ints(map->data_fd, map->useXdr, &(map->indexNbytesUsed), 1)) {
- Rast3d_error("Rast3d_closeCellNew: can't write header");
+ G_warning(_("Unable to write header for 3D raster map <%s>"), map);
return 0;
Rast3d_long_encode(&(map->indexOffset), (unsigned char *)<mp, 1);
if (write(map->data_fd, <mp, sizeof(long)) != sizeof(long)) {
return 0;
- if (!Rast3d_closeNew(map) != 0) {
- Rast3d_error("Rast3d_closeCellNew: error in Rast3d_closeNew");
+ if (!close_new(map) != 0) {
+ G_warning(_("Unable to create 3D raster map <%s>"), map);
return 0;
return 1;
-static int Rast3d_closeOld(RASTER3D_Map * map)
+static int close_old(RASTER3D_Map * map)
if (close(map->data_fd) != 0) {
- Rast3d_error("Rast3d_closeOld: could not close file");
+ G_warning(_("Unable to close 3D raster map <%s>"), map);
return 0;
return 1;
-static int Rast3d_closeCellOld(RASTER3D_Map * map)
+static int close_cell_old(RASTER3D_Map * map)
- if (!Rast3d_closeOld(map) != 0) {
- Rast3d_error("Rast3d_closeCellOld: error in Rast3d_closeOld");
+ if (!close_old(map) != 0) {
return 0;
return 1;
- * \brief
- * Closes g3d-file. If <em>map</em> is new
- * and cache-mode is used for <em>map</em> then every tile which is not flushed
- * before closing is flushed.
- * \param map
- * \return 1 ... if successful,
- * 0 ... otherwise.
+ \brief Close 3D raster map files
+ Closes g3d-file. If <em>map</em> is new and cache-mode is used for
+ <em>map</em> then every tile which is not flushed before closing is
+ flushed.
+ \param map name of 3D raster map
-int Rast3d_close_cell(RASTER3D_Map * map)
+ \return 1 success
+ \return 0 failure
+int Rast3d_close(RASTER3D_Map * map)
if (map->operation == RASTER3D_WRITE_DATA) {
- if (!Rast3d_closeCellNew(map)) {
- Rast3d_error("Rast3d_close_cell: error in Rast3d_closeCellNew");
+ if (!close_cell_new(map)) {
return 0;
else {
- if (!Rast3d_closeCellOld(map) != 0) {
- Rast3d_error("Rast3d_close_cell: error in Rast3d_closeCellOld");
+ if (!close_cell_old(map) != 0) {
return 0;
@@ -164,7 +166,7 @@
if (map->useCache) {
if (!Rast3d_dispose_cache(map)) {
- Rast3d_error("Rast3d_close_cell: error in Rast3d_dispose_cache");
+ G_warning(_("Error in cache"));
return 0;
@@ -186,11 +188,12 @@
map->compression, map->useRle, map->useLzw,
map->precision, map->offset, map->useXdr,
map->hasIndex, map->unit)) {
- Rast3d_error("Rast3d_close_cell: error in Rast3d_write_header");
return 0;
Rast3d_free(map->unit);
Rast3d_free(map);
return 1;
Modified: grass/trunk/lib/raster3d/filecompare.c
--- grass/trunk/lib/raster3d/filecompare.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/raster3d/filecompare.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -425,8 +425,8 @@
if ((!Rast3d_tile_use_cache_map(map)) || (!Rast3d_tile_use_cache_map(map2))) {
compareFilesNocache(map, map2);
- Rast3d_close_cell(map);
- Rast3d_close_cell(map2);
+ Rast3d_close(map);
+ Rast3d_close(map2);
return;
@@ -488,6 +488,6 @@
printf("Files are identical up to precision.\n");
Modified: grass/trunk/lib/raster3d/mask.c
--- grass/trunk/lib/raster3d/mask.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/raster3d/mask.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -41,7 +41,7 @@
Rast3d_maskMapExistsVar = 0;
- if (!Rast3d_close_cell(Rast3d_maskMap)) {
+ if (!Rast3d_close(Rast3d_maskMap)) {
Rast3d_error("Rast3d_mask_close: error closing mask");
return 0;
Modified: grass/trunk/lib/raster3d/retile.c
--- grass/trunk/lib/raster3d/retile.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/raster3d/retile.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -54,7 +54,7 @@
G_percent(1, 1, 1);
@@ -140,6 +140,6 @@
G_percent(1, 1, 1);
if (!Rast3d_flush_all_tiles(map2))
Rast3d_fatal_error("Rast3d_retile: error in Rast3d_flush_all_tiles");
- Rast3d_fatal_error("Rast3d_retile: error in Rast3d_close_cell");
+ Rast3d_fatal_error("Rast3d_retile: error in Rast3d_close");
Modified: grass/trunk/lib/raster3d/test/test_coordinate_transform.c
--- grass/trunk/lib/raster3d/test/test_coordinate_transform.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/raster3d/test/test_coordinate_transform.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -143,7 +143,7 @@
sum++;
G_remove("grid3", "test_coordinate_transform");
Modified: grass/trunk/lib/raster3d/test/test_put_get_value.c
--- grass/trunk/lib/raster3d/test/test_put_get_value.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/raster3d/test/test_put_get_value.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -182,7 +182,7 @@
sum++;
G_remove("grid3", "test_put_get_value_dcell");
@@ -304,7 +304,7 @@
sum++;
G_remove("grid3", "test_put_get_value_fcell");
@@ -435,7 +435,7 @@
sum += test_resampling_dcell(map, north, east, top, col, row, depth, 2);
Modified: grass/trunk/lib/raster3d/volume.c
--- grass/trunk/lib/raster3d/volume.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/lib/raster3d/volume.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -260,8 +260,8 @@
- if (!Rast3d_close_cell(mapVolume))
- Rast3d_fatal_error("Rast3d_make_aligned_volume_file: error in Rast3d_close_cell");
+ if (!Rast3d_close(mapVolume))
+ Rast3d_fatal_error("Rast3d_make_aligned_volume_file: error in Rast3d_close");
Rast3d_free(volumeBuf);
Modified: grass/trunk/raster/r.colors/stats.c
--- grass/trunk/raster/r.colors/stats.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster/r.colors/stats.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -152,6 +152,6 @@
if(dcell)
G_free(dcell);
} else {
- Rast3d_close_cell(map3d);
+ Rast3d_close(map3d);
Modified: grass/trunk/raster/r.mapcalc/map3.c
--- grass/trunk/raster/r.mapcalc/map3.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster/r.mapcalc/map3.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -366,7 +366,7 @@
if (!m->handle)
return;
- if (!Rast3d_close_cell(m->handle))
+ if (!Rast3d_close(m->handle))
G_fatal_error(_("Unable to close raster map <%s@%s>"),
m->name, m->mapset);
@@ -401,7 +401,7 @@
RASTER3D_TILE_SAME_AS_FILE, RASTER3D_NO_CACHE);
result = (Rast3d_file_type_map(handle) == FCELL_TYPE)
? FCELL_TYPE : DCELL_TYPE;
- Rast3d_close_cell(handle);
+ Rast3d_close(handle);
else
result = -1;
@@ -607,7 +607,7 @@
void *handle = omaps[fd];
- if (!Rast3d_close_cell(handle))
+ if (!Rast3d_close(handle))
G_fatal_error(_("Unable to close output raster map"));
Modified: grass/trunk/raster/r.to.rast3/main.c
--- grass/trunk/raster/r.to.rast3/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster/r.to.rast3/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -55,7 +55,7 @@
if (map != NULL) {
/* should unopen map here! but this functionality is not jet implemented */
Rast3d_fatal_error(_("Could not close the map"));
@@ -322,7 +322,7 @@
Rast3d_fatal_error(_("Error closing 3d raster map"));
map = NULL;
Modified: grass/trunk/raster/r.to.rast3elev/main.c
--- grass/trunk/raster/r.to.rast3elev/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster/r.to.rast3elev/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -132,7 +132,7 @@
if (db.map != NULL) {
- if (!Rast3d_close_cell(db.map))
+ if (!Rast3d_close(db.map))
@@ -497,7 +497,7 @@
/* Flush all tile */
if (!Rast3d_flush_all_tiles(db.map))
G_debug(2, "\nDone\n");
Modified: grass/trunk/raster/r.univar/r3.univar_main.c
--- grass/trunk/raster/r.univar/r3.univar_main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster/r.univar/r3.univar_main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -311,9 +311,9 @@
/* close maps */
if (zone_info.n_zones)
- Rast3d_close_cell(zmap);
+ Rast3d_close(zmap);
/* create the output */
if (param.table->answer)
Modified: grass/trunk/raster3d/r3.cross.rast/main.c
--- grass/trunk/raster3d/r3.cross.rast/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.cross.rast/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -51,7 +51,7 @@
if (map != NULL) {
Rast3d_fatal_error(_("Could not close RASTER3D map"));
@@ -338,7 +338,7 @@
Rast3d_fatal_error(_("Could not close RASTER3D map <%s>"),
param.input->answer);
Modified: grass/trunk/raster3d/r3.gwflow/main.c
--- grass/trunk/raster3d/r3.gwflow/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.gwflow/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -415,7 +415,7 @@
return;
Modified: grass/trunk/raster3d/r3.in.ascii/main.c
--- grass/trunk/raster3d/r3.in.ascii/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.in.ascii/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -62,7 +62,7 @@
if (map != NULL) {
/* should unopen map here! */
Rast3d_fatal_error(errorMsg);
@@ -359,7 +359,7 @@
/*Create the new RASTER3D Map */
asciiToG3d(fp, ®ion, convertNull, nullValue);
fatalError(_("Error closing new 3d raster map"));
/* write input name to map history */
Modified: grass/trunk/raster3d/r3.in.v5d/main.c
--- grass/trunk/raster3d/r3.in.v5d/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.in.v5d/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -218,7 +218,7 @@
convert(input, ®ion, convertNull, nullValue);
fatalError(_("Error closing 3d raster map"));
map = NULL;
Modified: grass/trunk/raster3d/r3.info/r3.info.main.c
--- grass/trunk/raster3d/r3.info/r3.info.main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.info/r3.info.main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -485,7 +485,7 @@
/*Close the opened map */
- if (!Rast3d_close_cell(g3map))
+ if (!Rast3d_close(g3map))
G_fatal_error(_("Unable to close 3D raster map <%s>"), name);
Modified: grass/trunk/raster3d/r3.mask/main.c
--- grass/trunk/raster3d/r3.mask/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.mask/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -112,9 +112,9 @@
Rast3d_autolock_off(mask);
Rast3d_unlock_all(mask);
- if (!Rast3d_close_cell(mask))
+ if (!Rast3d_close(mask))
Rast3d_fatal_error(_("Unable to close 3D raster mask file"));
Rast3d_fatal_error(_("Unable to close raster map <%s>"), name);
Modified: grass/trunk/raster3d/r3.mkdspf/main.c
--- grass/trunk/raster3d/r3.mkdspf/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.mkdspf/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -227,7 +227,7 @@
fprintf(stderr, "\n");
/* tries to write a header! */
- Rast3d_close_cell(g3map);
+ Rast3d_close(g3map);
fclose(Headfax.dspfoutfp);
Modified: grass/trunk/raster3d/r3.null/main.c
--- grass/trunk/raster3d/r3.null/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.null/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -164,9 +164,9 @@
Rast3d_autolock_off(mapOut);
Rast3d_unlock_all(mapOut);
Rast3d_fatal_error(_("Unable to close raster map"));
- if (!Rast3d_close_cell(mapOut))
+ if (!Rast3d_close(mapOut))
Rast3d_fatal_error(_("modifyNull: Unable to close tmp file"));
Modified: grass/trunk/raster3d/r3.out.ascii/main.c
--- grass/trunk/raster3d/r3.out.ascii/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.out.ascii/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -58,7 +58,7 @@
if (map != NULL) {
@@ -367,7 +367,7 @@
if (output)
Modified: grass/trunk/raster3d/r3.out.v5d/main.c
--- grass/trunk/raster3d/r3.out.v5d/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.out.v5d/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -50,7 +50,7 @@
if (map != NULL) {
fatalError("Error closing 3d raster map");
@@ -327,7 +327,7 @@
convert(output, region.rows, region.cols, region.depths, trueCoords);
map = NULL;
Modified: grass/trunk/raster3d/r3.out.vtk/errorHandling.c
--- grass/trunk/raster3d/r3.out.vtk/errorHandling.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.out.vtk/errorHandling.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -61,7 +61,7 @@
int close_input_raster3d_map(void *map)
if (map != NULL) {
- if (!Rast3d_close_cell(map)) {
+ if (!Rast3d_close(map)) {
G_warning(_("unable to close input 3d raster map"));
return 1;
Modified: grass/trunk/raster3d/r3.out.vtk/main.c
--- grass/trunk/raster3d/r3.out.vtk/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.out.vtk/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -248,7 +248,7 @@
Rast3d_mask_off(maprgb);
/* Close the 3d raster map */
- if (!Rast3d_close_cell(maprgb)) {
+ if (!Rast3d_close(maprgb)) {
fatal_error(_("Error closing g3d rgb map."), in);
@@ -334,7 +334,7 @@
- if (!Rast3d_close_cell(mapvect)) {
+ if (!Rast3d_close(mapvect)) {
fatal_error(_("Error closing g3d vector map."), in);
/*Set the pointer to null so we know later that these files are already closed */
@@ -535,7 +535,7 @@
- if (!Rast3d_close_cell(in->map)) {
+ if (!Rast3d_close(in->map)) {
in->map = NULL;
fatal_error(_("Error closing 3d raster map, the VTK file may be incomplete."),
in);
Modified: grass/trunk/raster3d/r3.retile/main.c
--- grass/trunk/raster3d/r3.retile/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.retile/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -50,7 +50,7 @@
if (map != NULL) {
Rast3d_fatal_error(_("Unable to close the 3d raster map"));
@@ -149,7 +149,7 @@
Rast3d_retile(map, param.output->answer, tileX, tileY, tileZ);
fatal_error(map, NULL, 0, _("Error closing 3d raster map"));
map = NULL;
Modified: grass/trunk/raster3d/r3.to.rast/main.c
--- grass/trunk/raster3d/r3.to.rast/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/raster3d/r3.to.rast/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -51,7 +51,7 @@
if (map != NULL) {
Rast3d_fatal_error(_("Unable to close 3Draster map"));
@@ -378,7 +378,7 @@
G_free(fd);
map = NULL;
Modified: grass/trunk/vector/v.to.rast3/main.c
--- grass/trunk/vector/v.to.rast3/main.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/vector/v.to.rast3/main.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -150,7 +150,7 @@
Vect_close(&Map);
G_fatal_error(_("Unable to close new 3d raster map"));
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.vol.rst/user1.c
--- grass/trunk/vector/v.vol.rst/user1.c 2011-08-12 08:32:30 UTC (rev 47593)
+++ grass/trunk/vector/v.vol.rst/user1.c 2011-08-12 08:47:59 UTC (rev 47594)
@@ -464,7 +464,7 @@
/* Close the file */
- if (Rast3d_close_cell(cf1) == 0) {
+ if (Rast3d_close(cf1) == 0) {
sprintf(buff, "Error closing output file %s ", outz);
clean_fatal_error(buff);
@@ -514,7 +514,7 @@
- if (Rast3d_close_cell(cf2) == 0) {
+ if (Rast3d_close(cf2) == 0) {
sprintf(buff, "Error closing output file %s ", gradient);
@@ -564,7 +564,7 @@
- if (Rast3d_close_cell(cf3) == 0) {
+ if (Rast3d_close(cf3) == 0) {
sprintf(buff, "Error closing output file %s ", aspect1);
@@ -614,7 +614,7 @@
- if (Rast3d_close_cell(cf4) == 0) {
+ if (Rast3d_close(cf4) == 0) {
sprintf(buff, "Error closing output file %s ", aspect2);
@@ -664,7 +664,7 @@
- if (Rast3d_close_cell(cf5) == 0) {
+ if (Rast3d_close(cf5) == 0) {
sprintf(buff, "Error closing output file %s ", ncurv);
@@ -714,7 +714,7 @@
- if (Rast3d_close_cell(cf6) == 0) {
+ if (Rast3d_close(cf6) == 0) {
sprintf(buff, "Error closing output file %s ", gcurv);
@@ -764,7 +764,7 @@
- if (Rast3d_close_cell(cf7) == 0) {
+ if (Rast3d_close(cf7) == 0) {
sprintf(buff, "Error closing output file %s ", mcurv);
