[GRASS-SVN] r47598 - grass/trunk/vector/v.colors
Fri Aug 12 06:55:39 EDT 2011
Author: martinl
Date: 2011-08-12 03:55:39 -0700 (Fri, 12 Aug 2011)
New Revision: 47598
   grass/trunk/vector/v.colors/local_proto.h
   grass/trunk/vector/v.colors/main.c
   grass/trunk/vector/v.colors/scan_cats.c
v.colors: added support for attribute numeric column
Modified: grass/trunk/vector/v.colors/local_proto.h
--- grass/trunk/vector/v.colors/local_proto.h	2011-08-12 09:20:22 UTC (rev 47597)
+++ grass/trunk/vector/v.colors/local_proto.h	2011-08-12 10:55:39 UTC (rev 47598)
@@ -1 +1,6 @@
-void scan_cats(const struct Map_info *, int, int *, int*);
+/* scan_attr */
+int scan_attr(const struct Map_info *, int, const char *,
+	       double *, double *);
+/* scan_cats */
+void scan_cats(const struct Map_info *, int, double *, double*);
Modified: grass/trunk/vector/v.colors/main.c
--- grass/trunk/vector/v.colors/main.c	2011-08-12 09:20:22 UTC (rev 47597)
+++ grass/trunk/vector/v.colors/main.c	2011-08-12 10:55:39 UTC (rev 47598)
@@ -19,9 +19,9 @@
 #include <stdlib.h>
 #include <grass/gis.h>
+#include <grass/vector.h>
 #include <grass/raster.h>
 #include <grass/raster3d.h>
-#include <grass/vector.h>
 #include <grass/glocale.h>
 #include "local_proto.h"
@@ -34,14 +34,15 @@
     } flag;
     struct {
-        struct Option *map, *field, *colr, *rast, *volume, *rules;
+	struct Option *map, *field, *colr, *rast, *volume, *rules, *attrcol, *rgbcol;
     } opt;
-    int min, max, layer;
-    int have_stats;
+    int layer;
+    double fmin, fmax;
+    int have_stats, is_fp;
     int overwrite, remove, is_from_stdin, stat, have_colors;
     const char *mapset, *cmapset;
-    const char *name, *style, *rules, *cmap;
+    const char *name, *style, *rules, *cmap, *attrcolumn;
     struct Map_info Map;
     struct Colors colors, colors_tmp;
@@ -58,8 +59,15 @@
     opt.map = G_define_standard_option(G_OPT_V_MAP);
     opt.field = G_define_standard_option(G_OPT_V_FIELD);
+    opt.attrcol = G_define_standard_option(G_OPT_DB_COLUMN);
+    opt.attrcol->description = _("Name of column containing numeric data");
+    opt.colr = G_define_standard_option(G_OPT_M_COLR);
-    opt.colr = G_define_standard_option(G_OPT_M_COLR);
+    opt.rgbcol = G_define_standard_option(G_OPT_DB_COLUMN);
+    opt.rgbcol->key = "rgb_column";
+    opt.rgbcol->label = _("Name of color column to populate RGB values");
+    opt.rgbcol->description = _("If no column given, write color table instead");
     opt.rast = G_define_standard_option(G_OPT_R_INPUT);
     opt.rast->key = "raster";
@@ -131,6 +139,7 @@
     name = opt.map->answer;
     style = opt.colr->answer;
     rules = opt.rules->answer;
+    attrcolumn = opt.attrcol->answer;
     have_stats = FALSE;
     if (!name)
@@ -192,7 +201,13 @@
     if (layer < 1)
 	G_fatal_error(_("Layer <%s> not found"), opt.field->answer);
-    scan_cats(&Map, layer, &min, &max);
+    if (!attrcolumn) {
+	is_fp = FALSE;
+	scan_cats(&Map, layer, &fmin, &fmax);
+    else {
+	is_fp = scan_attr(&Map, layer, attrcolumn, &fmin, &fmax);
     if (is_from_stdin) {
@@ -201,7 +216,11 @@
     } else if (style) {
 	if (strcmp(style, "random") == 0) {
-	    Rast_make_random_colors(&colors, (CELL) min, (CELL) max);
+	    if (is_fp)
+		G_fatal_error(_("Color table 'random' is not supported for "
+				"floating point attributes"));
+	    else
+		Rast_make_random_colors(&colors, (CELL) fmin, (CELL) fmax);
 	} else if (strcmp(style, "grey.eq") == 0) {
 	    G_fatal_error(_("Color table <%s> not supported"), "grey.eq");
@@ -217,13 +236,17 @@
 	      Rast_make_histogram_log_colors(&colors, &statf, (CELL) min,
 	      (CELL) max);
-	} else if (G_find_color_rule(style))
-	    Rast_make_colors(&colors, style, (CELL) min, (CELL) max);
+	} else if (G_find_color_rule(style)) {
+	    if (is_fp)
+		Rast_make_fp_colors(&colors, style, (CELL) fmin, (CELL) fmax);
+	    else
+		Rast_make_colors(&colors, style, (DCELL) fmin, (DCELL) fmax);
         else
             G_fatal_error(_("Unknown color request '%s'"), style);
     else if (rules) {
-	if (!Rast_load_fp_colors(&colors, rules, min, max))
+	if (!Rast_load_fp_colors(&colors, rules, fmin, fmax))
 	    G_fatal_error(_("Unable to load rules file <%s>"), rules);
     else {
Modified: grass/trunk/vector/v.colors/scan_cats.c
--- grass/trunk/vector/v.colors/scan_cats.c	2011-08-12 09:20:22 UTC (rev 47597)
+++ grass/trunk/vector/v.colors/scan_cats.c	2011-08-12 10:55:39 UTC (rev 47598)
@@ -5,7 +5,7 @@
 static void scan_layer(int, const struct line_cats *, int *, int *);
-void scan_cats(const struct Map_info *Map, int field, int *min, int* max)
+void scan_cats(const struct Map_info *Map, int field, double *min, double* max)
     int ltype, cmin, cmax;
     struct line_cats *Cats;
