[GRASS-SVN] r47599 - grass/trunk/vector/v.colors
svn_grass at osgeo.org
Fri Aug 12 06:57:02 EDT 2011
Author: martinl
Date: 2011-08-12 03:57:02 -0700 (Fri, 12 Aug 2011)
New Revision: 47599
Added:
grass/trunk/vector/v.colors/scan_attr.c
v.colors: add missing file (scan attributes) - see r47598
Added: grass/trunk/vector/v.colors/scan_attr.c
--- grass/trunk/vector/v.colors/scan_attr.c (rev 0)
+++ grass/trunk/vector/v.colors/scan_attr.c 2011-08-12 10:57:02 UTC (rev 47599)
@@ -0,0 +1,84 @@
+#include <grass/vector.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+int scan_attr(const struct Map_info *Map, int layer, const char *column_name,
+ double *fmin, double *fmax)
+ int ctype, is_fp, more, first;
+ double fval;
+ char buf[1024];
+ struct field_info *fi;
+ dbDriver *driver;
+ dbTable *table;
+ dbColumn *column;
+ dbString stmt;
+ dbCursor cursor;
+ dbValue *value;
+ *fmin = *fmax = -1;
+ fi = Vect_get_field(Map, layer);
+ if (!fi)
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ layer);
+ driver = db_start_driver_open_database(fi->driver, fi->database);
+ if (!driver)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ fi->database, fi->driver);
+ ctype = db_column_Ctype(driver, fi->table, column_name);
+ if (ctype == -1)
+ G_fatal_error(_("Column <%s> not found in table <%s>"),
+ column_name, fi->table);
+ if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE)
+ G_fatal_error(_("Column <%s> is not numeric"), column_name);
+ is_fp = ctype == DB_C_TYPE_DOUBLE;
+ G_snprintf(buf, 1023, "SELECT %s FROM %s", column_name, fi->table);
+ G_debug(3, "scan_attr() SQL: %s", buf);
+ db_init_string(&stmt);
+ db_append_string(&stmt, buf);
+ if (db_open_select_cursor(driver, &stmt, &cursor, DB_SEQUENTIAL) != DB_OK)
+ G_fatal_error(_("Unable to select data"));
+ table = db_get_cursor_table(&cursor);
+ column = db_get_table_column(table, 0);
+ value = db_get_column_value(column);
+ /* fetch the data */
+ first = TRUE;
+ while (TRUE) {
+ if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
+ return -1;
+ if (!more)
+ break;
+ if (is_fp)
+ fval = db_get_value_double(value);
+ else
+ fval = db_get_value_int(value);
+ if (first) {
+ *fmin = *fmax = fval;
+ first = FALSE;
+ continue;
+ if (fval <= *fmin)
+ *fmin = fval;
+ if (fval >= *fmax)
+ *fmax = fval;
+ db_close_database(driver);
+ return is_fp;
Property changes on: grass/trunk/vector/v.colors/scan_attr.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
