[GRASS-SVN] r47612 - in grass/trunk: include lib/raster
Sun Aug 14 04:33:11 EDT 2011
Author: martinl
Date: 2011-08-14 01:33:11 -0700 (Sun, 14 Aug 2011)
New Revision: 47612
Added:
   grass/trunk/lib/raster/color_out.c
   grass/trunk/include/rasterdefs.h
rasterlib: Rast_print_colors() added (taken from r.colors.out)
Modified: grass/trunk/include/rasterdefs.h
--- grass/trunk/include/rasterdefs.h	2011-08-14 08:16:03 UTC (rev 47611)
+++ grass/trunk/include/rasterdefs.h	2011-08-14 08:33:11 UTC (rev 47612)
@@ -174,6 +174,9 @@
 /* color_org.c */
 void Rast__organize_colors(struct Colors *);
+/* color_out.c */
+void Rast_print_colors(struct Colors *, DCELL, DCELL, FILE *, int);
 /* color_rand.c */
 void Rast_make_random_colors(struct Colors *, CELL, CELL);
Added: grass/trunk/lib/raster/color_out.c
--- grass/trunk/lib/raster/color_out.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_out.c	2011-08-14 08:33:11 UTC (rev 47612)
@@ -0,0 +1,87 @@
+  \file lib/raster/color_out.c
+  \brief Raster Library - Print color table
+  (C) 2010-2011 by the GRASS Development Team
+  This program is free software under the GNU General Public
+  License (>=v2). Read the file COPYING that comes with GRASS
+  for details.
+  \author Glynn Clements
+#include <grass/raster.h>
+static void write_rule(DCELL *val, DCELL *min, DCELL *max, int r, int g, int b,
+		       FILE *fp, int perc)
+    static DCELL v0;
+    static int r0 = -1, g0 = -1, b0 = -1;
+    if (v0 == *val && r0 == r && g0 == g && b0 == b)
+	return;
+    v0 = *val, r0 = r, g0 = g, b0 = b;
+    if (perc)
+	fprintf(fp, "%g%% %d:%d:%d\n", 100 * (*val - *min) / (*max - *min), r, g, b);
+    else
+	fprintf(fp, "%g %d:%d:%d\n", *val, r, g, b);
+  \brief Print color table
+  \param colors pointer to Colors structure
+  \param min,max minimum and maximum value for percentage output (used only when <em>perc<em> is non-zero)
+  \param fp file where to print color table rules
+  \param perc TRUE for percentage output
+void Rast_print_colors(struct Colors *colors, DCELL min, DCELL max, FILE *fp,
+		       int perc)
+    int i, count;
+    count = 0;
+    if (colors->version < 0) {
+	/* 3.0 format */
+	CELL lo, hi;
+	Rast_get_c_color_range(&lo, &hi, colors);
+	for (i = lo; i <= hi; i++) {
+	    unsigned char r, g, b, set;
+	    DCELL val = (DCELL) i;
+	    Rast_lookup_c_colors(&i, &r, &g, &b, &set, 1, colors);
+	    write_rule(&val, &min, &max, r, g, b, fp, perc);
+    else {
+	count = Rast_colors_count(colors);
+	for (i = 0; i < count; i++) {
+	    DCELL val1, val2;
+	    unsigned char r1, g1, b1, r2, g2, b2;
+	    Rast_get_fp_color_rule(
+		&val1, &r1, &g1, &b1,
+		&val2, &r2, &g2, &b2,
+		colors, count - 1 - i);
+	    write_rule(&val1, &min, &max, r1, g1, b1, fp, perc);
+	    write_rule(&val2, &min, &max, r2, g2, b2, fp, perc);
+	int r, g, b;
+	Rast_get_null_value_color(&r, &g, &b, colors);
+	fprintf(fp, "nv %d:%d:%d\n", r, g, b);
+	Rast_get_default_color(&r, &g, &b, colors);
+	fprintf(fp, "default %d:%d:%d\n", r, g, b);
+    if (fp != stdout)
+	fclose(fp);
Property changes on: grass/trunk/lib/raster/color_out.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
