[GRASS-SVN] r47613 - in grass/trunk/vector: . v.colors.out
svn_grass at osgeo.org
Sun Aug 14 04:38:30 EDT 2011
Author: martinl
Date: 2011-08-14 01:38:30 -0700 (Sun, 14 Aug 2011)
New Revision: 47613
Added:
grass/trunk/vector/v.colors.out/
grass/trunk/vector/v.colors.out/Makefile
grass/trunk/vector/v.colors.out/local_proto.h
grass/trunk/vector/v.colors.out/main.c
grass/trunk/vector/v.colors.out/scan_cats.c
grass/trunk/vector/v.colors.out/v.colors.out.html
grass/trunk/vector/Makefile
v.colors.out implemented
Modified: grass/trunk/vector/Makefile
--- grass/trunk/vector/Makefile 2011-08-14 08:33:11 UTC (rev 47612)
+++ grass/trunk/vector/Makefile 2011-08-14 08:38:30 UTC (rev 47613)
@@ -11,6 +11,7 @@
v.class \
v.clean \
v.colors \
+ v.colors.out \
v.convert \
v.db.connect \
v.db.select \
Property changes on: grass/trunk/vector/v.colors.out
___________________________________________________________________
Added: svn:ignore
+ OBJ.*
Added: grass/trunk/vector/v.colors.out/Makefile
--- grass/trunk/vector/v.colors.out/Makefile (rev 0)
+++ grass/trunk/vector/v.colors.out/Makefile 2011-08-14 08:38:30 UTC (rev 47613)
@@ -0,0 +1,12 @@
+MODULE_TOPDIR = ../..
+PGM = v.colors.out
+LIBES = $(VECTORLIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(VECTORDEP) $(GISDEP) $(RASTERDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass/trunk/vector/v.colors.out/Makefile
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass/trunk/vector/v.colors.out/local_proto.h
--- grass/trunk/vector/v.colors.out/local_proto.h (rev 0)
+++ grass/trunk/vector/v.colors.out/local_proto.h 2011-08-14 08:38:30 UTC (rev 47613)
@@ -0,0 +1,2 @@
+/* scan_cats.c */
+void scan_cats(const char *, const char *, int *, int *);
Property changes on: grass/trunk/vector/v.colors.out/local_proto.h
+ text/x-chdr
+ native
Added: grass/trunk/vector/v.colors.out/main.c
--- grass/trunk/vector/v.colors.out/main.c (rev 0)
+++ grass/trunk/vector/v.colors.out/main.c 2011-08-14 08:38:30 UTC (rev 47613)
@@ -0,0 +1,95 @@
+ * MODULE: v.colors.out
+ * AUTHOR(S): Modified r.colors.out by Martin Landa <landa.martin gmail.com>
+ * PURPOSE: Allows export of the color table for a vector map.
+ * COPYRIGHT: (C) 2011 by the GRASS Development Team
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+int main(int argc, char **argv)
+ struct GModule *module;
+ struct
+ struct Option *map, *field, *file;
+ } opt;
+ struct
+ struct Flag *p;
+ } flag;
+ struct Colors colors;
+ int min, max;
+ const char *file, *name, *layer;
+ FILE *fp;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("vector"));
+ G_add_keyword(_("color table"));
+ G_add_keyword(_("export"));
+ module->description =
+ _("Exports the color table associated with a vector map.");
+ opt.map = G_define_standard_option(G_OPT_V_MAP);
+ opt.field = G_define_standard_option(G_OPT_V_FIELD);
+ opt.file = G_define_standard_option(G_OPT_F_OUTPUT);
+ opt.file->key = "rules";
+ opt.file->label = _("Path to output rules file");
+ opt.file->description = _("\"-\" to write to stdout");
+ opt.file->answer = "-";
+ flag.p = G_define_flag();
+ flag.p->key = 'p';
+ flag.p->description = _("Output values as percentages");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ name = opt.map->answer;
+ layer = opt.field->answer;
+ file = opt.file->answer;
+ if (Vect_read_colors(name, "", &colors) < 0)
+ G_fatal_error(_("Unable to read color table for vector map <%s>"),
+ opt.map->answer);
+ min = max = -1;
+ if (flag.p->answer) {
+ scan_cats(name, layer, &min, &max);
+ if (!file || strcmp(file, "-") == 0)
+ fp = stdout;
+ else {
+ fp = fopen(file, "w");
+ if (!fp)
+ G_fatal_error(_("Unable to open output file <%s>"), file);
+ Rast_print_colors(&colors, (DCELL) min, (DCELL) max, fp,
+ flag.p->answer ? 1 : 0);
+ exit(EXIT_SUCCESS);
Property changes on: grass/trunk/vector/v.colors.out/main.c
+ text/x-csrc
+ native
Added: grass/trunk/vector/v.colors.out/scan_cats.c
--- grass/trunk/vector/v.colors.out/scan_cats.c (rev 0)
+++ grass/trunk/vector/v.colors.out/scan_cats.c 2011-08-14 08:38:30 UTC (rev 47613)
@@ -0,0 +1,58 @@
+static void scan_layer(int, const struct line_cats *, int *, int *);
+void scan_cats(const char *name, const char *layer,
+ int *cmin, int *cmax)
+ int ltype, lmin, lmax, ilayer;
+ struct Map_info Map;
+ struct line_cats *Cats;
+ *cmin = *cmax = -1;
+ Vect_open_old2(&Map, name, "", layer);
+ ilayer = Vect_get_field_number(&Map, layer);
+ if (ilayer < 1)
+ G_fatal_error(_("Layer <%s> not found"), layer);
+ Cats = Vect_new_cats_struct();
+ G_message(_("Reading features..."));
+ while(TRUE) {
+ ltype = Vect_read_next_line(&Map, NULL, Cats);
+ if (ltype == -1)
+ G_fatal_error(_("Unable to read vector map"));
+ if (ltype == -2)
+ break; /* EOF */
+ scan_layer(ilayer, Cats, &lmin, &lmax);
+ if (*cmin == -1 || lmin <= *cmin)
+ *cmin = lmin;
+ if (*cmax == -1 || lmax >= *cmax)
+ *cmax = lmax;
+ Vect_destroy_cats_struct(Cats);
+void scan_layer(int field, const struct line_cats *Cats, int *cmin, int *cmax)
+ int n, cat;
+ for (n = 0; n < Cats->n_cats; n++) {
+ if (Cats->field[n] == field) {
+ cat = Cats->cat[n];
+ if (*cmin == -1 || cat <= *cmin)
+ *cmin = cat;
+ if (*cmax == -1 || cat >= *cmax)
+ *cmax = cat;
Property changes on: grass/trunk/vector/v.colors.out/scan_cats.c
+ text/x-csrc
+ native
Added: grass/trunk/vector/v.colors.out/v.colors.out.html
--- grass/trunk/vector/v.colors.out/v.colors.out.html (rev 0)
+++ grass/trunk/vector/v.colors.out/v.colors.out.html 2011-08-14 08:38:30 UTC (rev 47613)
@@ -0,0 +1,29 @@
+<h2>DESCRIPTION</h2>
+<em>v.colors.out</em> allows the user to export the color table for a
+vector map to a file which is suitable as input
+to <em><a href="v.colors.html">v.colors</a></em>.
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+v.colors.out map=soils_general rules=rules.txt
+v.colors map=soils_wake rules=rules.txt
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+ <a href="v.colors.html">v.colors</a>,
+ <a href="r.colors.html">r.colors</a>,
+ <a href="r3.colors.html">r3.colors</a>,
+ <a href="r.colors.out.html">r.colors.out</a>,
+ <a href="r3.colors.out.html">r3.colors.out</a>,
+</em>
+<h2>AUTHOR</h2>
+Martin Landa, Czech Technical University in Prague, Czech Republic
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass/trunk/vector/v.colors.out/v.colors.out.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
