[GRASS-SVN] r47614 - grass/trunk/raster/r.colors.out
svn_grass at osgeo.org
Sun Aug 14 04:45:36 EDT 2011
Author: martinl
Date: 2011-08-14 01:45:36 -0700 (Sun, 14 Aug 2011)
New Revision: 47614
Removed:
grass/trunk/raster/r.colors.out/local_proto.h
grass/trunk/raster/r.colors.out/write_colors.c
grass/trunk/raster/r.colors.out/raster3d_main.c
grass/trunk/raster/r.colors.out/raster_main.c
r[3].colors.out updated to use Rast_print_colors()
Deleted: grass/trunk/raster/r.colors.out/local_proto.h
--- grass/trunk/raster/r.colors.out/local_proto.h 2011-08-14 08:38:30 UTC (rev 47613)
+++ grass/trunk/raster/r.colors.out/local_proto.h 2011-08-14 08:45:36 UTC (rev 47614)
@@ -1,8 +0,0 @@
-#include <stdlib.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/raster3d.h>
-#include <grass/raster.h>
-#include <grass/glocale.h>
-void write_colors(struct Colors *, struct FPRange*, const char *, int);
\ No newline at end of file
Modified: grass/trunk/raster/r.colors.out/raster3d_main.c
--- grass/trunk/raster/r.colors.out/raster3d_main.c 2011-08-14 08:38:30 UTC (rev 47613)
+++ grass/trunk/raster/r.colors.out/raster3d_main.c 2011-08-14 08:45:36 UTC (rev 47614)
@@ -1,13 +1,13 @@
- * MODULE: r.colors.out
+ * MODULE: r3.colors.out
* AUTHOR(S): Glynn Clements
- * PURPOSE: Allows export of the color table for a raster map layer.
+ * PURPOSE: Allows export of the color table for a 3D raster map.
- * COPYRIGHT: (C) 2008, 2010 Glynn Clements and the GRASS Development Team
+ * COPYRIGHT: (C) 2008, 2010-2011 Glynn Clements and the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -15,7 +15,12 @@
-#include "local_proto.h"
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/raster3d.h>
+#include <grass/glocale.h>
/* Run in raster3d mode */
int main(int argc, char **argv)
@@ -29,6 +34,9 @@
struct Flag *p;
} flag;
+ const char *file;
+ FILE * fp;
struct Colors colors;
struct FPRange range;
@@ -39,9 +47,10 @@
G_add_keyword(_("color table"));
G_add_keyword(_("export"));
module->description =
- _("Exports the color table associated with a raster3d map layer.");
+ _("Exports the color table associated with a 3D raster map.");
opt.map = G_define_standard_option(G_OPT_R3_MAP);
opt.file = G_define_standard_option(G_OPT_F_OUTPUT);
opt.file->key = "rules";
opt.file->label = _("Path to output rules file");
@@ -55,11 +64,24 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ file = opt.file->answer;
if (Rast3d_read_colors(opt.map->answer, "", &colors) < 0)
- G_fatal_error(_("Unable to read color table for raster3d map <%s>"), opt.map->answer);
+ G_fatal_error(_("Unable to read color table for raster3d map <%s>"),
+ opt.map->answer);
Rast3d_read_range(opt.map->answer, "", &range);
- write_colors(&colors, &range, opt.file->answer, flag.p->answer ? 1 : 0);
+ if (!file || strcmp(file, "-") == 0)
+ fp = stdout;
+ else {
+ fp = fopen(file, "w");
+ if (!fp)
+ G_fatal_error(_("Unable to open output file <%s>"), file);
+ Rast_print_colors(&colors, range.min, range.max, fp,
+ flag.p->answer ? 1 : 0);
exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.colors.out/raster_main.c
--- grass/trunk/raster/r.colors.out/raster_main.c 2011-08-14 08:38:30 UTC (rev 47613)
+++ grass/trunk/raster/r.colors.out/raster_main.c 2011-08-14 08:45:36 UTC (rev 47614)
@@ -5,9 +5,9 @@
+ * PURPOSE: Allows export of the color table for a raster map.
@@ -15,7 +15,11 @@
/* Run in raster mode */
@@ -29,6 +33,9 @@
struct Flag *p;
} flag;
+ const char *file;
+ FILE * fp;
@@ -39,7 +46,7 @@
- _("Exports the color table associated with a raster map layer.");
+ _("Exports the color table associated with a raster map.");
opt.map = G_define_standard_option(G_OPT_R_MAP);
@@ -56,11 +63,24 @@
exit(EXIT_FAILURE);
if (Rast_read_colors(opt.map->answer, "", &colors) < 0)
- G_fatal_error(_("Unable to read color table for raster map <%s>"), opt.map->answer);
+ G_fatal_error(_("Unable to read color table for raster map <%s>"),
+ opt.map->answer);
Rast_read_fp_range(opt.map->answer, "", &range);
+ fp = stdout;
+ else {
+ if (!fp)
exit(EXIT_SUCCESS);
Deleted: grass/trunk/raster/r.colors.out/write_colors.c
--- grass/trunk/raster/r.colors.out/write_colors.c 2011-08-14 08:38:30 UTC (rev 47613)
+++ grass/trunk/raster/r.colors.out/write_colors.c 2011-08-14 08:45:36 UTC (rev 47614)
@@ -1,93 +0,0 @@
- * AUTHOR(S): Glynn Clements
- * This program is free software under the GNU General
- * Public License (>=v2). Read the file COPYING that
- * comes with GRASS for details.
-static FILE *fp;
-static DCELL min, max;
-static void write_rule(DCELL *val, int r, int g, int b, int perc)
- static DCELL v0;
- static int r0 = -1, g0 = -1, b0 = -1;
- if (v0 == *val && r0 == r && g0 == g && b0 == b)
- return;
- v0 = *val, r0 = r, g0 = g, b0 = b;
- if (perc)
- fprintf(fp, "%g%% %d:%d:%d\n", 100 * (*val - min) / (max - min), r, g, b);
- else
- fprintf(fp, "%g %d:%d:%d\n", *val, r, g, b);
-void write_colors(struct Colors *colors, struct FPRange*range, const char *file,
- int perc)
- int i, count = 0;;
- Rast_get_fp_range_min_max(range, &min, &max);
- if (!file || strcmp(file, "-") == 0)
- fp = stdout;
- else {
- fp = fopen(file, "w");
- if (!fp)
- G_fatal_error(_("Unable to open output file <%s>"), file);
- if (colors->version < 0) {
- /* 3.0 format */
- CELL lo, hi;
- Rast_get_c_color_range(&lo, &hi, colors);
- for (i = lo; i <= hi; i++) {
- unsigned char r, g, b, set;
- DCELL val = (DCELL) i;
- Rast_lookup_c_colors(&i, &r, &g, &b, &set, 1, colors);
- write_rule(&val, r, g, b, perc);
- else {
- count = Rast_colors_count(colors);
- for (i = 0; i < count; i++) {
- DCELL val1, val2;
- unsigned char r1, g1, b1, r2, g2, b2;
- Rast_get_fp_color_rule(
- &val1, &r1, &g1, &b1,
- &val2, &r2, &g2, &b2,
- colors, count - 1 - i);
- write_rule(&val1, r1, g1, b1, perc);
- write_rule(&val2, r2, g2, b2, perc);
- int r, g, b;
- Rast_get_null_value_color(&r, &g, &b, colors);
- fprintf(fp, "nv %d:%d:%d\n", r, g, b);
- Rast_get_default_color(&r, &g, &b, colors);
- fprintf(fp, "default %d:%d:%d\n", r, g, b);
- if (fp != stdout)
- fclose(fp);
