[GRASS-SVN] r47615 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Sun Aug 14 05:01:35 EDT 2011
Author: martinl
Date: 2011-08-14 02:01:34 -0700 (Sun, 14 Aug 2011)
New Revision: 47615
grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: sync colorrules.py with trunk
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2011-08-14 08:45:36 UTC (rev 47614)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2011-08-14 09:01:34 UTC (rev 47615)
@@ -5,7 +5,11 @@
vector rgb_column attributes.
Classes:
+ - RulesPanel
- ColorTable
+ - RasterColorTable
+ - VectorColorTable
+ - ThematicVectorTable
- BuferedWindow
(C) 2008, 2010-2011 by the GRASS Development Team
@@ -14,12 +18,14 @@
@author Michael Barton (Arizona State University)
@author Martin Landa <landa.martin gmail.com> (various updates)
- at author Anna Kratochvilova (load/save raster color tables)
+ at author Anna Kratochvilova <kratochanna gmail.com> (split to base and derived classes)
import os
import sys
import shutil
+import copy
+import tempfile
import wx
import wx.lib.colourselect as csel
@@ -33,155 +39,305 @@
import gselect
import render
import utils
+import menuform
from debug import Debug as Debug
from preferences import globalSettings as UserSettings
+from nviz_mapdisp import wxUpdateProperties
+class RulesPanel:
+ def __init__(self, parent, mapType, columnType, properties, panelWidth = 180):
+ """!Create rules panel
+ @param mapType raster/vector
+ @param columnType color/size for choosing widget type
+ @param properties properties of classes derived from ColorTabel
+ @param panelWidth width of scroll panel"""
+ self.ruleslines = {}
+ self.mapType = mapType
+ self.columnType = columnType
+ self.properties = properties
+ self.parent = parent
+ self.mainPanel = scrolled.ScrolledPanel(parent, id = wx.ID_ANY,
+ size = (panelWidth, 300),
+ style = wx.TAB_TRAVERSAL | wx.SUNKEN_BORDER)
+ self.mainPanel.SetupScrolling(scroll_x = False)
+ self.mainSizer = wx.FlexGridSizer(cols = 3, vgap = 6, hgap = 4)
+ # put small border at the top of panel
+ for i in range(3):
+ self.mainSizer.Add(item = wx.Size(3, 3))
+ self.mainPanel.SetSizer(self.mainSizer)
+ self.mainPanel.SetAutoLayout(True)
+ if self.mapType == 'vector' and self.columnType == 'color':
+ self.label = wx.StaticText(parent, id = wx.ID_ANY, label = _("Set color for attribute values:"))
+ elif self.mapType == 'vector' and self.columnType == 'size':
+ if self.parent.vectorType == 'points':
+ label = label = _("Set size for attribute values:")
+ else:
+ label = label = _("Set width for attribute values:")
+ self.label = wx.StaticText(parent, id = wx.ID_ANY, label = label)
+ # determines how many rules should be added
+ self.numRules = wx.SpinCtrl(parent, id = wx.ID_ANY,
+ min = 1, max = 1e6)
+ # add rules
+ self.btnAdd = wx.Button(parent, id = wx.ID_ADD)
+ self.btnAdd.Bind(wx.EVT_BUTTON, self.OnAddRules)
+ def Clear(self):
+ """!Clear and widgets and delete information"""
+ self.ruleslines.clear()
+ self.mainPanel.DestroyChildren()
+ def OnAddRules(self, event):
+ """!Add rules button pressed"""
+ nrules = self.numRules.GetValue()
+ self.AddRules(nrules)
+ def AddRules(self, nrules, start = False):
+ """!Add rules
+ @param start set widgets (not append)"""
+ snum = len(self.ruleslines.keys())
+ if start:
+ snum = 0
+ for num in range(snum, snum + nrules):
+ # enable
+ enable = wx.CheckBox(parent = self.mainPanel, id = num)
+ enable.SetValue(True)
+ enable.Bind(wx.EVT_CHECKBOX, self.OnRuleEnable)
+ # value
+ txt_ctrl = wx.TextCtrl(parent = self.mainPanel, id = 1000 + num,
+ size = (80, -1),
+ style = wx.TE_NOHIDESEL)
+ if self.mapType == 'vector':
+ txt_ctrl.SetToolTipString(_("Enter vector attribute values (e.g. 5) "
+ "or ranges (e.g. 5 to 10)"))
+ txt_ctrl.Bind(wx.EVT_TEXT, self.OnRuleValue)
+ if self.columnType == 'color':
+ # color
+ columnCtrl = csel.ColourSelect(self.mainPanel, id = 2000 + num,
+ size = globalvar.DIALOG_COLOR_SIZE)
+ columnCtrl.Bind(csel.EVT_COLOURSELECT, self.OnRuleColor)
+ if not start:
+ self.ruleslines[enable.GetId()] = { 'value' : '',
+ 'color': "0:0:0" }
+ if self.columnType == 'size':
+ # size
+ columnCtrl = wx.SpinCtrl(self.mainPanel, id = 2000 + num,
+ size = (50, -1), min = 1, max = 1e3,
+ initial = 5)
+ columnCtrl.Bind(wx.EVT_SPINCTRL, self.OnRuleSize)
+ if not start:
+ 'size': 5 }
+ self.mainSizer.Add(item = enable, proportion = 0,
+ flag = wx.ALIGN_CENTER_VERTICAL)
+ self.mainSizer.Add(item = txt_ctrl, proportion = 0,
+ flag = wx.ALIGN_CENTER | wx.RIGHT, border = 5)
+ self.mainSizer.Add(item = columnCtrl, proportion = 0,
+ flag = wx.ALIGN_CENTER | wx.RIGHT, border = 10)
+ self.mainPanel.Layout()
+ def OnRuleEnable(self, event):
+ """!Rule enabled/disabled"""
+ id = event.GetId()
+ if event.IsChecked():
+ self.mainPanel.FindWindowById(id + 1000).Enable()
+ self.mainPanel.FindWindowById(id + 2000).Enable()
+ value = self.SQLConvert(self.mainPanel.FindWindowById(id + 1000).GetValue(), self.columnType)
+ else:
+ value = self.mainPanel.FindWindowById(id + 1000).GetValue()
+ color = self.mainPanel.FindWindowById(id + 2000).GetValue()
+ # color
+ color_str = str(color[0]) + ':' \
+ + str(color[1]) + ':' \
+ + str(color[2])
+ self.ruleslines[id] = {'value' : value,
+ 'color' : color_str }
+ else:
+ # size
+ 'size' : float(color) }
+ else:
+ self.mainPanel.FindWindowById(id + 1000).Disable()
+ self.mainPanel.FindWindowById(id + 2000).Disable()
+ del self.ruleslines[id]
+ def OnRuleColor(self, event):
+ """!Rule color changed"""
+ num = event.GetId()
+ rgba_color = event.GetValue()
+ rgb_string = str(rgba_color[0]) + ':' \
+ + str(rgba_color[1]) + ':' \
+ + str(rgba_color[2])
+ self.ruleslines[num-2000]['color'] = rgb_string
+ def OnRuleSize(self, event):
+ """!Rule size changed"""
+ size = event.GetInt()
+ self.ruleslines[num - 2000]['size'] = size
+ def OnRuleValue(self, event):
+ """!Rule value changed"""
+ vals = event.GetString().strip()
+ if vals == '':
+ return
+ self.SetVectorRule(num, vals)
+ else:
+ self.SetRasterRule(num, vals)
+ def SetRasterRule(self, num, vals):
+ """!Set raster rule"""
+ self.ruleslines[num-1000]['value'] = vals
+ def SetVectorRule(self, num, vals):
+ """!Set vector rule"""
+ tc = self.mainPanel.FindWindowById(num)
+ source, target = 'source_rgb', 'rgb'
+ else:
+ source, target = 'source_size', 'size'
+ if self.properties[source] == '' or self.properties[target] == '':
+ tc.SetValue('')
+ gcmd.GMessage(parent = self,
+ message = _("Please select attribute column "
+ "and RGB color column first"))
+ else:
+ try:
+ self.ruleslines[num-1000]['value'] = self.SQLConvert(vals, self.columnType)
+ except ValueError:
+ tc.SetValue('')
+ self.ruleslines[num-1000]['value'] = ''
+ return
+ def Enable(self, enable = True):
+ """!Enable/Disable all widgets"""
+ for child in self.mainPanel.GetChildren():
+ child.Enable(enable)
+ self.btnAdd.Enable(enable)
+ self.numRules.Enable(enable)
+ def LoadRules(self):
+ """!Fill rule widgets from ruleslines"""
+ message = ""
+ for item in range(len(self.ruleslines)):
+ self.mainPanel.FindWindowById(item + 1000).SetValue(self.ruleslines[item]['value'])
+ r, g, b = (0, 0, 0) # default
+ if self.ruleslines[item][self.columnType] == '':
+ self.ruleslines[item][self.columnType] = '%d:%d:%d' % (r, g, b)
+ elif self.columnType == 'size':
+ self.ruleslines[item][self.columnType] = 100
+ try:
+ r, g, b = map(int, self.ruleslines[item][self.columnType].split(':'))
+ except ValueError, e:
+ message = _("Bad color format. Use color format '0:0:0'")
+ self.mainPanel.FindWindowById(item + 2000).SetValue((r, g, b))
+ else:
+ value = float(self.ruleslines[item][self.columnType])
+ self.mainPanel.FindWindowById(item + 2000).SetValue(value)
+ if message:
+ gcmd.GMessage(parent = self.parent, message = message)
+ return False
+ return True
+ def SQLConvert(self, vals, type = 'color'):
+ """!Prepare value for SQL query"""
+ if type == 'color':
+ source = 'source_rgb'
+ elif type == 'size':
+ source = 'source_size'
+ valslist = []
+ valslist = vals.split('to')
+ if len(valslist) == 1:
+ sqlrule = '%s=%s' % (self.properties[source], valslist[0])
+ elif len(valslist) > 1:
+ sqlrule = '%s>=%s AND %s<=%s' % (self.properties[source], valslist[0],
+ self.properties[source], valslist[1])
+ else:
+ return None
+ return sqlrule
class ColorTable(wx.Frame):
- def __init__(self, parent, raster, id = wx.ID_ANY, title = _("Set color table"),
+ def __init__(self, parent, title, id = wx.ID_ANY,
style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
**kwargs):
"""!Dialog for interactively entering rules for map management
commands
@param raster True to raster otherwise vector
+ @param nviz True if ColorTable is called from nviz thematic mapping
self.parent = parent # GMFrame
- self.raster = raster
wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+ # instance of render.Map to be associated with display
+ self.Map = render.Map()
# input map to change
self.inmap = ''
- if self.raster:
- # raster properties
- self.properties = {
- # min cat in raster map
- 'min' : None,
- # max cat in raster map
- 'max' : None,
- else:
- # vector properties
- # list of database layers for vector (minimum of 1)
- 'layers' : ['1'],
- # list of database columns for vector
- 'columns' : [],
- # vector layer for attribute table to use for setting color
- 'layer' : 1,
- # vector attribute table used for setting color
- 'table' : '',
- # vector attribute column for assigning colors
- 'column' : '',
- # vector attribute column to use for storing colors
- 'rgb' : '',
- # rules for creating colortable
- self.ruleslines = {}
- # instance of render.Map to be associated with display
- self.Map = render.Map()
# reference to layer with preview
self.layer = None
+ # layout
+ self._doLayout()
- if self.raster:
- self.SetTitle(_('Create new color table for raster map'))
- crlabel = _('Enter raster category values or percents')
- else:
- self.SetTitle(_('Create new color table for vector map'))
- crlabel = _('Enter vector attribute values or ranges (n or n1 to n2)')
- # top controls
- if self.raster:
- maplabel = _('Select raster map:')
- else:
- maplabel = _('Select vector map:')
- inputBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label = " %s " % maplabel)
- self.inputSizer = wx.StaticBoxSizer(inputBox, wx.VERTICAL)
- if self.raster:
- elem = 'cell'
- else:
- elem = 'vector'
- self.selectionInput = gselect.Select(parent = self, id = wx.ID_ANY,
- size = globalvar.DIALOG_GSELECT_SIZE,
- type = elem)
- self.ovrwrtcheck = wx.CheckBox(parent = self, id = wx.ID_ANY,
- label = _('replace existing color table'))
- self.ovrwrtcheck.SetValue(UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'))
- if self.raster:
- self.btnSave = wx.Button(parent = self, id = wx.ID_SAVE)
- self.btnSave.SetToolTipString(_('Save color table to file'))
- if not self.raster:
- self.cb_vl_label = wx.StaticText(parent = self, id = wx.ID_ANY,
- label = _('Layer:'))
- self.cb_vc_label = wx.StaticText(parent = self, id = wx.ID_ANY,
- label = _('Attribute column:'))
- self.cb_vrgb_label = wx.StaticText(parent = self, id = wx.ID_ANY,
- label = _('RGB color column:'))
- self.cb_vlayer = gselect.LayerSelect(self)
- self.cb_vcol = gselect.ColumnSelect(self)
- self.cb_vrgb = gselect.ColumnSelect(self)
- # color table and preview window
- self.cr_label = wx.StaticText(parent = self, id = wx.ID_ANY,
- label = crlabel)
- self.cr_panel = self._colorRulesPanel()
- # add two rules as default
- self.AddRules(2)
- self.numRules = wx.SpinCtrl(parent = self, id = wx.ID_ANY,
- min = 1, max = 1e6)
- # initialize preview display
- self.InitDisplay()
- self.preview = BufferedWindow(self, id = wx.ID_ANY, size = (400, 300),
- Map = self.Map)
- self.preview.EraseMap()
- self.btnCancel = wx.Button(parent = self, id = wx.ID_CANCEL)
- self.btnApply = wx.Button(parent = self, id = wx.ID_APPLY)
- self.btnOK = wx.Button(parent = self, id = wx.ID_OK)
- self.btnOK.SetDefault()
- self.btnOK.Enable(False)
- self.btnApply.Enable(False)
- self.btnPreview = wx.Button(parent = self, id = wx.ID_ANY,
- label = _("Preview"))
- self.btnPreview.Enable(False)
- self.btnAdd = wx.Button(parent = self, id = wx.ID_ADD)
- self.helpbtn = wx.Button(parent = self, id = wx.ID_HELP)
# bindings
- self.Bind(wx.EVT_BUTTON, self.OnHelp, self.helpbtn)
+ self.Bind(wx.EVT_BUTTON, self.OnHelp, self.btnHelp)
self.selectionInput.Bind(wx.EVT_TEXT, self.OnSelectionInput)
self.Bind(wx.EVT_BUTTON, self.OnCancel, self.btnCancel)
self.Bind(wx.EVT_BUTTON, self.OnApply, self.btnApply)
self.Bind(wx.EVT_BUTTON, self.OnOK, self.btnOK)
+ self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
self.Bind(wx.EVT_BUTTON, self.OnPreview, self.btnPreview)
- self.Bind(wx.EVT_BUTTON, self.OnAddRules, self.btnAdd)
- self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
- # additional bindings for raster/vector color management
- if self.raster:
- self.Bind(wx.EVT_BUTTON, self.OnSaveTable, self.btnSave)
- else:
- self.Bind(wx.EVT_COMBOBOX, self.OnLayerSelection, self.cb_vlayer)
- self.Bind(wx.EVT_COMBOBOX, self.OnColumnSelection, self.cb_vcol)
- self.Bind(wx.EVT_COMBOBOX, self.OnRGBColSelection, self.cb_vrgb)
- # set map layer from layer tree
+ def _initLayer(self):
+ """!Set initial layer when opening dialog"""
+ # set map layer from layer tree, first selected,
+ # if not the right type, than select another
try:
- layer = self.parent.curr_page.maptree.layer_selected
+ sel = self.parent.curr_page.maptree.layer_selected
+ if sel and self.parent.curr_page.maptree.GetPyData(sel)[0]['type'] == self.type:
+ layer = sel
+ else:
+ layer = self.parent.curr_page.maptree.FindItemByData(key = 'type', value = self.type)
except:
layer = None
if layer:
@@ -190,150 +346,88 @@
type = mapLayer.GetType()
self.selectionInput.SetValue(name)
self.inmap = name
- self.OnSelectionInput(None)
+ def _createPreview(self, parent):
+ """!Create preview"""
+ # initialize preview display
+ self.InitDisplay()
+ self.preview = BufferedWindow(parent, id = wx.ID_ANY, size = (400, 300),
+ Map = self.Map)
+ self.preview.EraseMap()
- # layout
- self.__doLayout()
- self.SetMinSize(self.GetSize())
+ def _createButtons(self):
+ """!Create buttons for leaving dialog"""
+ self.btnHelp = wx.Button(parent = self, id = wx.ID_HELP)
+ self.btnCancel = wx.Button(parent = self, id = wx.ID_CANCEL)
+ self.btnApply = wx.Button(parent = self, id = wx.ID_APPLY)
+ self.btnOK = wx.Button(parent = self, id = wx.ID_OK)
- self.CentreOnScreen()
- self.Show()
+ self.btnOK.SetDefault()
+ self.btnOK.Enable(False)
+ self.btnApply.Enable(False)
- def __doLayout(self):
- sizer = wx.BoxSizer(wx.VERTICAL)
+ # layout
+ btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+ btnSizer.Add(self.btnHelp,
+ flag = wx.LEFT | wx.RIGHT, border = 5)
+ btnSizer.Add(self.btnCancel,
+ btnSizer.Add(self.btnApply,
+ btnSizer.Add(self.btnOK,
- # input
- self.inputSizer.Add(item = self.selectionInput,
- flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border = 5)
- replaceSizer = wx.BoxSizer(wx.HORIZONTAL)
- replaceSizer.Add(item = self.ovrwrtcheck, proportion = 1,
- flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL, border = 1)
- if self.raster:
- replaceSizer.Add(item = self.btnSave, proportion = 0,
- flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
- self.inputSizer.Add(item = replaceSizer, proportion = 1,
- flag = wx.ALL | wx.EXPAND, border = 0)
- # body & preview
+ return btnSizer
+ def _createBody(self, parent):
+ """!Create dialog body consisting of rules and preview"""
bodySizer = wx.GridBagSizer(hgap = 5, vgap = 5)
row = 0
+ # label with range
+ self.cr_label = wx.StaticText(parent, id = wx.ID_ANY, label = '')
bodySizer.Add(item = self.cr_label, pos = (row, 0), span = (1, 3),
flag = wx.ALL, border = 5)
+ row += 1
- vSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
- vSizer.Add(self.cb_vl_label, pos = (0, 0),
- flag = wx.ALIGN_CENTER_VERTICAL)
- vSizer.Add(self.cb_vlayer, pos = (0, 1),
- vSizer.Add(self.cb_vc_label, pos = (0, 2),
- vSizer.Add(self.cb_vcol, pos = (0, 3),
- vSizer.Add(self.cb_vrgb_label, pos = (1, 2),
- vSizer.Add(self.cb_vrgb, pos = (1, 3),
+ # color table
+ self.colorRulesPanel = RulesPanel(parent = parent, mapType = self.type,
+ columnType = 'color', properties = self.properties)
+ if self.type == 'vector':
+ bodySizer.Add(item = self.colorRulesPanel.label, pos = (row, 0), span = (1, 2),
+ flag = wx.ALL, border = 5)
row += 1
- bodySizer.Add(item = vSizer, pos = (row, 0), span = (1, 3))
- row += 1
- bodySizer.Add(item = self.cr_panel, pos = (row, 0), span = (1, 2))
+ bodySizer.Add(item = self.colorRulesPanel.mainPanel, pos = (row, 0), span = (1, 2),
+ # add two rules as default
+ self.colorRulesPanel.AddRules(2)
+ # preview window
+ self._createPreview(parent = parent)
bodySizer.Add(item = self.preview, pos = (row, 2),
flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 10)
bodySizer.AddGrowableRow(row)
bodySizer.AddGrowableCol(2)
+ row += 1
- row += 1
- bodySizer.Add(item = self.numRules, pos = (row, 0),
+ # add rules button and spin to sizer
+ bodySizer.Add(item = self.colorRulesPanel.numRules, pos = (row, 0),
+ bodySizer.Add(item = self.colorRulesPanel.btnAdd, pos = (row, 1))
- bodySizer.Add(item = self.btnAdd, pos = (row, 1))
+ # preview button
+ self.btnPreview = wx.Button(parent, id = wx.ID_ANY,
+ label = _("Preview"))
bodySizer.Add(item = self.btnPreview, pos = (row, 2),
flag = wx.ALIGN_RIGHT)
+ self.btnPreview.Enable(False)
+ self.btnPreview.SetToolTipString(_("Show preview of map "
+ "(current Map Display extent is used)."))
+ return bodySizer
- btnSizer = wx.BoxSizer(wx.HORIZONTAL)
- btnSizer.Add(self.helpbtn,
- flag = wx.LEFT | wx.RIGHT, border = 5)
- btnSizer.Add(self.btnCancel,
- btnSizer.Add(self.btnApply,
- btnSizer.Add(self.btnOK,
- sizer.Add(item = self.inputSizer, proportion = 0,
- flag = wx.ALL | wx.EXPAND, border = 5)
- sizer.Add(item = bodySizer, proportion = 1,
- sizer.Add(item = wx.StaticLine(parent = self, id = wx.ID_ANY,
- style = wx.LI_HORIZONTAL),
- proportion = 0,
- flag = wx.EXPAND | wx.ALL, border = 5)
- sizer.Add(item = btnSizer, proportion = 0,
- flag = wx.ALL | wx.ALIGN_RIGHT, border = 5)
- self.SetSizer(sizer)
- sizer.Fit(self)
- self.Layout()
- def _colorRulesPanel(self):
- """!Create rules panel"""
- cr_panel = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY,
- size = (180, 300),
- style = wx.TAB_TRAVERSAL | wx.SUNKEN_BORDER)
- cr_panel.SetupScrolling(scroll_x = False)
- self.cr_sizer = wx.GridBagSizer(vgap = 2, hgap = 4)
- cr_panel.SetSizer(self.cr_sizer)
- cr_panel.SetAutoLayout(True)
- return cr_panel
- def OnAddRules(self, event):
- """!Add rules button pressed"""
- nrules = self.numRules.GetValue()
- self.AddRules(nrules)
- def AddRules(self, nrules):
- """!Add rules"""
- snum = len(self.ruleslines.keys())
- for num in range(snum, snum + nrules):
- # enable
- enable = wx.CheckBox(parent = self.cr_panel, id = num)
- enable.SetValue(True)
- self.Bind(wx.EVT_CHECKBOX, self.OnRuleEnable, enable)
- # value
- txt_ctrl = wx.TextCtrl(parent = self.cr_panel, id = 1000 + num,
- size = (90, -1),
- style = wx.TE_NOHIDESEL)
- self.Bind(wx.EVT_TEXT, self.OnRuleValue, txt_ctrl)
- # color
- color_ctrl = csel.ColourSelect(self.cr_panel, id = 2000 + num,
- size = globalvar.DIALOG_COLOR_SIZE)
- self.Bind(csel.EVT_COLOURSELECT, self.OnRuleColor, color_ctrl)
- self.ruleslines[enable.GetId()] = { 'value' : '',
- 'color': "0:0:0" }
- self.cr_sizer.Add(item = enable, pos = (num, 0),
- self.cr_sizer.Add(item = txt_ctrl, pos = (num, 1),
- flag = wx.ALIGN_CENTER | wx.RIGHT, border = 5)
- self.cr_sizer.Add(item = color_ctrl, pos = (num, 2),
- flag = wx.ALIGN_CENTER | wx.RIGHT, border = 10)
- self.cr_panel.Layout()
- self.cr_panel.SetupScrolling(scroll_x = False)
def InitDisplay(self):
"""!Initialize preview display, set dimensions and region
@@ -341,29 +435,163 @@
self.height = self.Map.height = 300
self.Map.geom = self.width, self.height
- def OnErase(self, event):
- """!Erase the histogram display
- self.PreviewWindow.Draw(self.HistWindow.pdc, pdctype = 'clear')
def OnCloseWindow(self, event):
"""!Window closed
Also remove associated rendered images
self.Map.Clean()
self.Destroy()
+ def OnApply(self, event):
+ """!Apply selected color table
+ @return True on success otherwise False
+ ret = self.CreateColorTable()
+ if ret:
+ display = self.parent.GetLayerTree().GetMapDisplay()
+ if display and display.IsAutoRendered():
+ display.GetWindow().UpdateMap(render = True)
+ return ret
+ def OnOK(self, event):
+ """!Apply selected color table and close the dialog"""
+ if self.OnApply(event):
+ self.Destroy()
+ def OnCancel(self, event):
+ """!Do not apply any changes and close the dialog"""
+ self.Destroy()
+ def DoPreview(self, ltype, cmdlist):
+ """!Update preview (based on computational region)"""
+ if not self.layer:
+ self.layer = self.Map.AddLayer(type = ltype, name = 'preview', command = cmdlist,
+ l_active = True, l_hidden = False, l_opacity = 1.0,
+ l_render = False)
+ else:
+ self.layer.SetCmd(cmdlist)
+ # apply new color table and display preview
+ self.CreateColorTable(force = True)
+ self.preview.UpdatePreview()
+ def RunHelp(self, cmd):
+ """!Show GRASS manual page"""
+ gcmd.RunCommand('g.manual',
+ quiet = True,
+ parent = self,
+ entry = cmd)
+ def _IsNumber(self, s):
+ """!Check if 's' is a number"""
+ try:
+ float(s)
+ return True
+ return False
+class RasterColorTable(ColorTable):
+ def __init__(self, parent, **kwargs):
+ """!Dialog for interactively entering color rules for raster maps"""
+ self.type = 'raster'
+ # raster properties
+ self.properties = {
+ # min cat in raster map
+ 'min' : None,
+ # max cat in raster map
+ 'max' : None,
+ ColorTable.__init__(self, parent,
+ title = _('Create new color table for raster map'), **kwargs)
+ # additional bindings for raster color management
+ self.Bind(wx.EVT_BUTTON, self.OnSaveTable, self.btnSave)
+ self._initLayer()
+ self.SetMinSize(self.GetSize())
+ self.CentreOnScreen()
+ self.Show()
+ def _createMapSelection(self, parent):
+ """!Create map selection part of dialog"""
+ # top controls
+ maplabel = _('Select raster map:')
+ inputBox = wx.StaticBox(parent, id = wx.ID_ANY,
+ label = " %s " % maplabel)
+ inputSizer = wx.StaticBoxSizer(inputBox, wx.VERTICAL)
+ self.selectionInput = gselect.Select(parent, id = wx.ID_ANY,
+ size = globalvar.DIALOG_GSELECT_SIZE,
+ type = 'cell')
+ self.ovrwrtcheck = wx.CheckBox(parent, id = wx.ID_ANY,
+ label = _('replace existing color table'))
+ self.ovrwrtcheck.SetValue(UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'))
+ self.btnSave = wx.Button(parent, id = wx.ID_SAVE)
+ self.btnSave.SetToolTipString(_('Save color table to file'))
+ # layout
+ inputSizer.Add(item = self.selectionInput,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border = 5)
+ replaceSizer = wx.BoxSizer(wx.HORIZONTAL)
+ replaceSizer.Add(item = self.ovrwrtcheck, proportion = 1,
+ flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL, border = 1)
+ replaceSizer.Add(item = self.btnSave, proportion = 0,
+ flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+ inputSizer.Add(item = replaceSizer, proportion = 1,
+ flag = wx.ALL | wx.EXPAND, border = 0)
+ return inputSizer
+ def _doLayout(self):
+ """!Do main layout"""
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ # map selection
+ mapSelection = self._createMapSelection(parent = self)
+ sizer.Add(item = mapSelection, proportion = 0,
+ flag = wx.ALL | wx.EXPAND, border = 5)
+ # body & preview
+ bodySizer = self._createBody(parent = self)
+ sizer.Add(item = bodySizer, proportion = 1,
+ # buttons
+ btnSizer = self._createButtons()
+ sizer.Add(item = wx.StaticLine(parent = self, id = wx.ID_ANY,
+ style = wx.LI_HORIZONTAL), proportion = 0,
+ flag = wx.EXPAND | wx.ALL, border = 5)
+ sizer.Add(item = btnSizer, proportion = 0,
+ flag = wx.ALL | wx.ALIGN_RIGHT, border = 5)
+ self.SetSizer(sizer)
+ sizer.Layout()
+ sizer.Fit(self)
+ self.Layout()
def OnSelectionInput(self, event):
- """!Raster/vector map selected"""
+ """!Raster map selected"""
if event:
self.inmap = event.GetString()
if self.inmap:
- if self.raster:
- mapType = 'cell'
- else:
- mapType = 'vector'
- if not grass.find_file(name = self.inmap, element = mapType)['file']:
+ if not grass.find_file(name = self.inmap, element = 'cell')['file']:
self.inmap = None
if not self.inmap:
@@ -373,134 +601,40 @@
self.OnLoadTable(event)
return
- if self.raster:
- info = grass.raster_info(map = self.inmap)
- if info:
- self.properties['min'] = info['min']
- self.properties['max'] = info['max']
- self.OnLoadTable(event)
- else:
- self.inmap = ''
- self.properties['min'] = self.properties['max'] = None
- self.cr_label.SetLabel(_('Enter raster category values or percents'))
- return
- if info['datatype'] == 'CELL':
- mapRange = _('range')
- else:
- mapRange = _('fp range')
- self.cr_label.SetLabel(_('Enter raster category values or percents (%(range)s = %(min)d-%(max)d)') %
- { 'range' : mapRange,
- 'min' : self.properties['min'],
- 'max' : self.properties['max'] })
+ info = grass.raster_info(map = self.inmap)
+ if info:
+ self.properties['min'] = info['min']
+ self.properties['max'] = info['max']
+ self.OnLoadTable(event)
else:
- # initialize layer selection combobox
- self.cb_vlayer.InsertLayers(self.inmap)
- # initialize attribute table for layer=1
- layer = int(self.properties['layer'])
- self.properties['table'] = gselect.VectorDBInfo(self.inmap).layers[layer]['table']
- # initialize column selection comboboxes
- self.cb_vcol.InsertColumns(vector = self.inmap, layer = layer)
- self.cb_vrgb.InsertColumns(vector = self.inmap, layer = layer)
- self.Update()
- self.btnPreview.Enable(True)
- self.btnOK.Enable(True)
- self.btnApply.Enable(True)
- def OnLayerSelection(self, event):
- # reset choices in column selection comboboxes if layer changes
- self.vlayer = int(event.GetString())
- self.vtable = gselect.VectorDBInfo(self.inmap).layers[str(self.vlayer)]
- self.cb_vcol.InsertColumns(vector = self.inmap, layer = self.vlayer)
- self.cb_vrgb.InsertColumns(vector = self.inmap, layer = self.vlayer)
- self.Update()
- def OnColumnSelection(self, event):
- self.properties['column'] = event.GetString()
- def OnRGBColSelection(self, event):
- self.properties['rgb'] = event.GetString()
- def OnRuleEnable(self, event):
- """!Rule enabled/disabled"""
- id = event.GetId()
- if event.IsChecked():
- value = self.FindWindowById(id+1000).GetValue()
- color = self.FindWindowById(id+2000).GetValue()
- color_str = str(color[0]) + ':' \
- + str(color[1]) + ':' + \
- str(color[2])
- self.ruleslines[id] = {
- 'value' : value,
- 'color' : color_str }
- else:
- del self.ruleslines[id]
- def OnRuleValue(self, event):
- """!Rule value changed"""
- num = event.GetId()
- vals = event.GetString().strip()
- if vals == '':
+ self.inmap = ''
+ self.properties['min'] = self.properties['max'] = None
+ self.cr_label.SetLabel(_('Enter raster category values or percents'))
return
- tc = self.FindWindowById(num)
- if self.raster:
- self.ruleslines[num-1000]['value'] = vals
+ if info['datatype'] == 'CELL':
+ mapRange = _('range')
else:
- if self.properties['column'] == '' or self.properties['rgb'] == '':
- tc.SetValue('')
- gcmd.GMessage(parent = self,
- message = _("Please select attribute column "
- "and RGB color column first"))
- else:
- try:
- self.ruleslines[num-1000]['value'] = self.SQLConvert(vals)
- except ValueError:
- tc.SetValue('')
- self.ruleslines[num-1000]['value'] = ''
- return
+ mapRange = _('fp range')
+ self.cr_label.SetLabel(_('Enter raster category values or percents (%(range)s = %(min)d-%(max)d)') %
+ { 'range' : mapRange,
+ 'min' : self.properties['min'],
+ 'max' : self.properties['max'] })
+ self.btnPreview.Enable()
+ self.btnOK.Enable()
+ self.btnApply.Enable()
+ def OnLoadTable(self, event):
+ """!Load current color table (using `r.colors.out`)"""
- def OnRuleColor(self, event):
- """!Rule color changed"""
+ self.colorRulesPanel.Clear()
- rgba_color = event.GetValue()
- rgb_string = str(rgba_color[0]) + ':' \
- + str(rgba_color[1]) + ':' + \
- str(rgba_color[2])
- self.ruleslines[num-2000]['color'] = rgb_string
- def SQLConvert(self, vals):
- valslist = []
- valslist = vals.split('to')
- if len(valslist) == 1:
- sqlrule = '%s=%s' % (self.properties['column'], valslist[0])
- elif len(valslist) > 1:
- sqlrule = '%s>=%s AND %s<=%s' % (self.properties['column'], valslist[0],
- self.properties['column'], valslist[1])
- else:
- return None
- return sqlrule
- def OnLoadTable(self, event):
- """!Load current color table (using `r.colors.out`)"""
- self.ruleslines.clear()
- self.cr_panel.DestroyChildren()
if self.inmap:
ctable = gcmd.RunCommand('r.colors.out',
parent = self,
@@ -512,22 +646,64 @@
return
rulesNumber = len(ctable.splitlines())
- self.AddRules(rulesNumber)
+ self.colorRulesPanel.AddRules(rulesNumber)
count = 0
for line in ctable.splitlines():
value, color = map(lambda x: x.strip(), line.split(' '))
- self.ruleslines[count]['value'] = value
- self.ruleslines[count]['color'] = color
- self.FindWindowById(count + 1000).SetValue(value)
+ self.colorRulesPanel.ruleslines[count]['value'] = value
+ self.colorRulesPanel.ruleslines[count]['color'] = color
+ self.colorRulesPanel.mainPanel.FindWindowById(count + 1000).SetValue(value)
rgb = list()
for c in color.split(':'):
rgb.append(int(c))
- self.FindWindowById(count + 2000).SetColour(rgb)
+ self.colorRulesPanel.mainPanel.FindWindowById(count + 2000).SetColour(rgb)
count += 1
self.OnPreview(tmp = False)
+ def OnPreview(self, event = None, tmp = True):
+ if not self.inmap:
+ return
+ cmdlist = ['d.rast',
+ 'map=%s' % self.inmap]
+ ltype = 'raster'
+ # find existing color table and copy to temp file
+ try:
+ name, mapset = self.inmap.split('@')
+ name = self.inmap
+ mapset = grass.find_file(self.inmap, element = 'cell')['mapset']
+ if not mapset:
+ return
+ old_colrtable = None
+ if mapset == grass.gisenv()['MAPSET']:
+ old_colrtable = grass.find_file(name = name, element = 'colr')['file']
+ else:
+ old_colrtable = grass.find_file(name = name, element = 'colr2/' + mapset)['file']
+ if old_colrtable:
+ colrtemp = utils.GetTempfile()
+ shutil.copyfile(old_colrtable, colrtemp)
+ ColorTable.DoPreview(self, ltype, cmdlist)
+ # restore previous color table
+ if tmp:
+ if old_colrtable:
+ shutil.copyfile(colrtemp, old_colrtable)
+ os.remove(colrtemp)
+ else:
+ gcmd.RunCommand('r.colors',
+ parent = self,
+ flags = 'r',
+ map = self.inmap)
def OnSaveTable(self, event):
"""!Save color table to file"""
rulestxt = ''
@@ -549,107 +725,494 @@
fd.write(rulestxt)
fd.close()
dlg.Destroy()
- def OnApply(self, event):
- """!Apply selected color table
+ def OnHelp(self, event):
+ cmd = 'r.colors'
+ ColorTable.RunHelp(self, cmd = cmd)
+ def CreateColorTable(self, force = False):
+ """!Creates color table
- @return True on success otherwise False
+ @return False on failure
- ret = self.CreateColorTable()
- display = self.parent.GetLayerTree().GetMapDisplay()
- if display and display.IsAutoRendered():
- display.GetWindow().UpdateMap(render = True)
+ rulestxt = ''
- return ret
+ for rule in self.colorRulesPanel.ruleslines.itervalues():
+ if not rule['value']: # skip empty rules
+ continue
+ if rule['value'] not in ('nv', 'default') and \
+ rule['value'][-1] != '%' and \
+ not self._IsNumber(rule['value']):
+ gcmd.GError(_("Invalid rule value '%s'. Unable to apply color table.") % rule['value'],
+ parent = self)
+ return False
+ rulestxt += rule['value'] + ' ' + rule['color'] + '\n'
+ if not rulestxt:
+ gcmd.GMessage(parent = self, message = _("No color rules given."))
+ return False
+ gtemp = utils.GetTempfile()
+ output = open(gtemp, "w")
+ try:
+ output.write(rulestxt)
+ finally:
+ output.close()
+ if not force and not self.ovrwrtcheck.IsChecked():
+ flags = 'w'
+ else:
+ flags = ''
+ ret = gcmd.RunCommand('r.colors',
+ flags = flags,
+ map = self.inmap,
+ rules = gtemp)
+ if ret != 0:
+ gcmd.GMessage(_("Color table already exists. "
+ "Check out 'replace existing color table' to "
+ "overwrite it."),
+ parent = self)
+ return False
+ return True
+class VectorColorTable(ColorTable):
+ """!Dialog for interactively entering color rules for vector maps"""
+ self.type = 'vector'
+ # vector properties
+ # list of database layers for vector (minimum of 1)
+ 'layers' : [],
+ # list of database columns for vector
+ 'columns' : [],
+ # vector layer for attribute table to use for setting color
+ 'layer' : 1,
+ # vector attribute table used for setting color
+ 'table' : '',
+ # vector attribute column for assigning colors
+ 'source_rgb' : '',
+ # vector attribute column to use for storing colors
+ 'rgb' : '',
+ # vector attribute column for assigning size
+ 'source_size' : '',
+ # vector attribute column to use for storing size
+ 'size' : '',
+ ColorTable.__init__(self, parent = parent,
+ title = _('Create new color table for vector map'), **kwargs)
+ # additional bindings for vector color management
+ self.Bind(wx.EVT_COMBOBOX, self.OnLayerSelection, self.cb_vlayer)
+ self.Bind(wx.EVT_COMBOBOX, self.OnColumnSelection, self.cb_color_att)
+ self.Bind(wx.EVT_COMBOBOX, self.OnRGBColSelection, self.cb_rgb_col)
+ self.Bind(wx.EVT_BUTTON, self.OnAddColumn, self.btn_add_RGB)
+ self._initLayer()
+ self.cr_label.SetLabel(_("Enter vector attribute values (e.g. 5) "
+ self.Show()
- def OnOK(self, event):
- """!Apply selected color table and close the dialog"""
- if self.OnApply(event):
- self.Destroy()
+ # top controls
+ maplabel = _('Select vector map:')
+ type = 'vector')
+ # layout
- def OnCancel(self, event):
- """!Do not apply any changes and close the dialog"""
- self.Destroy()
+ return inputSizer
+ def _createVectorAttrb(self, parent):
+ """!Create part of dialog with layer/column selection"""
+ inputBox = wx.StaticBox(parent = parent, id = wx.ID_ANY,
+ label = " %s " % _("Select vector columns"))
+ cb_vl_label = wx.StaticText(parent, id = wx.ID_ANY,
+ label = _('Layer:'))
+ cb_vc_label = wx.StaticText(parent, id = wx.ID_ANY,
+ label = _('Attribute column:'))
+ cb_vrgb_label = wx.StaticText(parent, id = wx.ID_ANY,
+ label = _('RGB color column:'))
+ self.rgb_range_label = wx.StaticText(parent, id = wx.ID_ANY)
+ self.cb_vlayer = gselect.LayerSelect(parent)
+ self.cb_color_att = gselect.ColumnSelect(parent)
+ self.cb_rgb_col = gselect.ColumnSelect(parent)
+ self.btn_add_RGB = wx.Button(parent, id = wx.ID_ANY,
+ label = _('Add column'))
+ self.btn_add_RGB.SetToolTipString(_("Add GRASSRGB column to current attribute table."))
- def OnPreview(self, event = None, tmp = True):
- """!Update preview (based on computational region)"""
+ # layout
+ vSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+ vSizer.Add(cb_vl_label, pos = (0, 0),
+ vSizer.Add(self.cb_vlayer, pos = (0, 1),
+ vSizer.Add(cb_vc_label, pos = (1, 0),
+ vSizer.Add(self.cb_color_att, pos = (1, 1),
+ vSizer.Add(self.rgb_range_label, pos = (1, 2),
+ vSizer.Add(cb_vrgb_label, pos = (2, 0),
+ vSizer.Add(self.cb_rgb_col, pos = (2, 1),
+ vSizer.Add(self.btn_add_RGB, pos = (2, 2),
+ inputSizer.Add(item = vSizer,
+ return inputSizer
+ # map selection
+ # set vector attributes
+ vectorAttrb = self._createVectorAttrb(parent = self)
+ sizer.Add(item = vectorAttrb, proportion = 0,
+ # body & preview
+ # buttons
+ sizer.Layout()
+ sizer.Fit(self)
+ self.Layout()
+ def SetInfoString(self):
+ """!Show information about vector map column type/range"""
+ driver, db = self.dbInfo.GetDbSettings(int(self.properties['layer']))
+ nrows = grass.db_describe(table = self.properties['table'], driver = driver, database = db)['nrows']
+ self.properties['min'] = self.properties['max'] = ''
+ type = self.dbInfo.GetTableDesc(self.properties['table'])\
+ [self.properties['source_rgb']]['type']
+ ctype = self.dbInfo.GetTableDesc(self.properties['table'])\
+ [self.properties['source_rgb']]['ctype']
+ if ctype == int or ctype == float:
+ if nrows < 500: # not too large
+ ret = gcmd.RunCommand('v.db.select',
+ quiet = True,
+ read = True,
+ flags = 'c',
+ map = self.inmap,
+ layer = self.properties['layer'],
+ columns = self.properties['source_rgb']).strip('\n')
+ records = ret.split('\n')
+ try:
+ self.properties['min'] = min(map(float, records))
+ self.properties['max'] = max(map(float, records))
+ if self.properties['min'] or self.properties['max']:
+ if ctype == int:
+ self.cr_label.SetLabel(_("Enter vector attribute values or ranges (type: %s, range: %d - %d)")
+ % (type, self.properties['min'], self.properties['max']))
+ elif ctype == float:
+ self.cr_label.SetLabel(_("Enter vector attribute values or ranges (type: %s, range: %.1f - %.1f )")
+ else:
+ self.cr_label.SetLabel(_("Enter vector attribute values or ranges (type: %s)") % type)
+ def CheckMapset(self):
+ """!Check if current vector is in current mapset"""
+ if grass.find_file(name = self.inmap,
+ element = 'vector')['mapset'] == grass.gisenv()['MAPSET']:
+ return True
+ else:
+ return False
+ def NoConnection(self, vectorName):
+ dlg = wx.MessageDialog(parent = self,
+ message = _("Database connection for vector map <%s> "
+ "is not defined in DB file. Do you want to create and "
+ "connect new attribute table?") % vectorName,
+ caption = _("No database connection defined"),
+ style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION | wx.CENTRE)
+ if dlg.ShowModal() == wx.ID_YES:
+ dlg.Destroy()
+ menuform.GUI(parent = self).ParseCommand(['v.db.addtable', 'map=' + self.inmap],
+ completed = (self.CreateTable, self.inmap, ''))
+ else:
+ dlg.Destroy()
+ def OnSelectionInput(self, event):
+ """!Vector map selected"""
+ if event:
+ self.inmap = event.GetString()
+ if self.inmap:
+ if not grass.find_file(name = self.inmap, element = 'vector')['file']:
+ self.inmap = None
+ self.UpdateDialog()
+ def UpdateDialog(self):
+ """!Update dialog after map selection"""
if not self.inmap:
+ self.colorRulesPanel.ruleslines.Clear()
return
- # raster
- if self.raster:
- cmdlist = ['d.rast',
- 'map=%s' % self.inmap]
- ltype = 'raster'
+ # check for db connection
+ self.dbInfo = gselect.VectorDBInfo(self.inmap)
+ if not len(self.dbInfo.layers):
+ wx.CallAfter(self.NoConnection, self.inmap)
+ for combo in (self.cb_vlayer, self.cb_color_att, self.cb_rgb_col):
+ combo.SetValue("")
+ combo.Disable()
+ combo.Clear()
+ enable = False
+ else:
+ # initialize layer selection combobox
+ combo.Enable()
+ self.cb_vlayer.InsertLayers(self.inmap)
+ # initialize attribute table for layer=1
+ self.properties['layer'] = self.cb_vlayer.GetString(0)
+ self.cb_vlayer.SetStringSelection(self.properties['layer'])
+ layer = int(self.properties['layer'])
+ self.properties['table'] = self.dbInfo.layers[layer]['table']
- # find existing color table and copy to temp file
- try:
- name, mapset = self.inmap.split('@')
- name = self.inmap
- mapset = grass.find_file(self.inmap, element = 'cell')['mapset']
- if not mapset:
- return
- old_colrtable = None
- if mapset == grass.gisenv()['MAPSET']:
- old_colrtable = grass.find_file(name = name, element = 'colr')['file']
+ # initialize column selection comboboxes
+ self.OnLayerSelection(event = None)
+ if self.CheckMapset():
+ enable = True
+ self.btn_add_RGB.Enable(True)
else:
- old_colrtable = grass.find_file(name = name, element = 'colr2/' + mapset)['file']
+ enable = False
+ wx.CallAfter(gcmd.GMessage, parent = self,
+ message = _("Selected map <%s> is not in current mapset <%s>. "
+ "Attribute table cannot be edited. "
+ "Color rules will not be saved.") %
+ (self.inmap, grass.gisenv()['MAPSET']))
+ self.btn_add_RGB.Enable(False)
- if old_colrtable:
- colrtemp = utils.GetTempfile()
- shutil.copyfile(old_colrtable, colrtemp)
- # vector
+ self.btnPreview.Enable(enable)
+ self.btnOK.Enable(enable)
+ self.btnApply.Enable(enable)
+ def OnLayerSelection(self, event):
+ # reset choices in column selection comboboxes if layer changes
+ vlayer = int(self.cb_vlayer.GetStringSelection())
+ self.cb_color_att.InsertColumns(vector = self.inmap, layer = vlayer, dbInfo = self.dbInfo)
+ self.cb_color_att.SetSelection(0)
+ self.properties['source_rgb'] = self.cb_color_att.GetString(0)
+ self.cb_rgb_col.InsertColumns(vector = self.inmap, layer = vlayer, type = ["character"], dbInfo = self.dbInfo)
+# self.cb_rgb_col.Delete(self.cb_rgb_col.FindString(self.properties['source_rgb']))
+ found = self.cb_rgb_col.FindString('GRASSRGB')
+ if found != wx.NOT_FOUND:
+ self.cb_rgb_col.SetSelection(found)
+ self.properties['rgb'] = self.cb_rgb_col.GetString(found)
else:
- cmdlist = ['d.vect',
- '-a',
- 'map=%s' % self.inmap,
- 'rgb_column=%s' % self.properties["rgb"],
- 'type=point,line,boundary,area']
- ltype = 'vector'
+ self.properties['rgb'] = ''
+## self.SetInfoString()
- if not self.layer:
- self.layer = self.Map.AddLayer(type = ltype, name = 'preview', command = cmdlist,
- l_active = True, l_hidden = False, l_opacity = 1.0,
- l_render = False)
+ self.LoadTable(attColumn = self.properties['source_rgb'],
+ rgbColumn = self.properties['rgb'], rulesPanel = self.colorRulesPanel)
+ self.Update()
+ def OnColumnSelection(self, event):
+ self.properties['source_rgb'] = event.GetString()
+ def OnAddColumn(self, event):
+ """!Add GRASSRGB column if it doesn't exist"""
+ if 'GRASSRGB' not in self.cb_rgb_col.GetItems():
+ ret = gcmd.RunCommand('v.db.addcolumn',
+ map = self.inmap,
+ columns = 'GRASSRGB varchar(20)')
+ self.cb_rgb_col.InsertColumns(self.inmap, self.properties['layer'], type = ["character"])
+ self.cb_rgb_col.SetStringSelection('GRASSRGB')
+ self.properties['rgb'] = self.cb_rgb_col.GetStringSelection()
+ self.LoadTable(attColumn = self.properties['source_rgb'], rgbColumn = self.properties['rgb'],
+ rulesPanel = self.colorRulesPanel, type = 'color')
else:
- self.layer.SetCmd(cmdlist)
+ message = _("GRASSRGB column already exists."))
+ def CreateTable(self, dcmd, layer, params, propwin):
+ """!Create attribute table"""
+ if dcmd:
+ cmd = utils.CmdToTuple(dcmd)
+ ret = gcmd.RunCommand(cmd[0], **cmd[1])
+ if ret == 0:
+ self.OnSelectionInput(None)
+ return True
+ combo.Disable()
+ return False
+ def LoadTable(self, attColumn, rgbColumn, rulesPanel, type = 'color'):
+ """!Load current column (GRASSRGB, size column)"""
- # apply new color table and display preview
- self.CreateColorTable(force = True)
- self.preview.UpdatePreview()
+ rulesPanel.Clear()
+ if not attColumn or not rgbColumn:
+ return
- # restore previous color table
- if self.raster and tmp:
- if old_colrtable:
- shutil.copyfile(colrtemp, old_colrtable)
- os.remove(colrtemp)
+ busy = wx.BusyInfo(message = _("Please wait, loading data from attribute table..."),
+ parent = self)
+ wx.Yield()
+ if self.inmap:
+ outFile = tempfile.NamedTemporaryFile(mode='w+b')
+ sep = '|'
+ quiet = True,
+ flags = 'c',
+ map = self.inmap,
+ columns = attColumn + ',' + rgbColumn,
+ fs = sep,
+ stdout = outFile)
+ else:
+ self.OnPreview(event)
+ busy.Destroy()
+ return
+ [self.properties['source_size']]['ctype']
+ outFile.seek(0)
+ i = 0
+ minim = maxim = 0.0
+ while True:
+ # os.linesep doesn't work here (MSYS)
+ record = outFile.readline().replace('\n', '')
+ if not record:
+ break
+ rulesPanel.ruleslines[i] = {}
+ value = record.split(sep)[0]
+ if ctype not in (int, float):
+ value = "'" + value + "'"
else:
- gcmd.RunCommand('r.colors',
- parent = self,
- flags = 'r',
- map = self.inmap)
+ if float(value) < minim:
+ minim = float(value)
+ if float(value) > maxim:
+ maxim = float(value)
+ rulesPanel.ruleslines[i]['value'] = value
+ rulesPanel.ruleslines[i][type] = record.split(sep)[1]
+ i += 1
+ rulesPanel.AddRules(i, start = True)
+ ret = rulesPanel.LoadRules()
+ self.SetRangeLabel(type, ctype, minim, maxim)
+ if ret:
+ self.OnPreview()
+ else:
+ busy.Destroy()
+ def SetRangeLabel(self, type, ctype, minim, maxim):
+ """!Set labels with info about attribute column range"""
+ if minim or maxim:
+ if ctype == int:
+ self.rgb_range_label.SetLabel(_("range: %.1f to %.1f") % (minim, maxim))
+ self.rgb_range_label.SetLabel(_("range: %d to %d") % (minim, maxim))
+ else:
+ self.rgb_range_label.SetLabel('')
+ if ctype == int:
+ self.size_range_label.SetLabel(_("range: %.1f to %.1f") % (minim, maxim))
+ self.size_range_label.SetLabel(_("range: %d to %d") % (minim, maxim))
+ else:
+ self.size_range_label.SetLabel('')
+ def OnRGBColSelection(self, event):
+ self.properties['rgb'] = event.GetString()
+ def OnPreview(self, event = None):
+ if not self.inmap or not self.properties["rgb"]:
+ return
+ cmdlist = ['d.vect',
+ '-a',
+ 'map=%s' % self.inmap,
+ 'rgb_column=%s' % self.properties["rgb"],
+ 'type=point,line,boundary,area']
+ ltype = 'vector'
- if self.raster:
- cmd = 'r.colors'
- else:
- cmd = 'vcolors'
- gcmd.RunCommand('g.manual',
- quiet = True,
- parent = self,
- entry = cmd)
+ cmd = 'v.colors'
- def _IsNumber(self, s):
- """!Check if 's' is a number"""
- try:
- float(s)
- return True
- return False
@@ -658,24 +1221,14 @@
rulestxt = ''
- for rule in self.ruleslines.itervalues():
continue
- if self.raster:
- if rule['value'] not in ('nv', 'default') and \
- rule['value'][-1] != '%' and \
- not self._IsNumber(rule['value']):
- gcmd.GError(_("Invalid rule value '%s'. Unable to apply color table.") % rule['value'],
- parent = self)
- return False
- rulestxt += rule['value'] + ' ' + rule['color'] + '\n'
- else:
- rulestxt += "UPDATE %s SET %s='%s' WHERE %s ;\n" % (self.properties['table'],
- self.properties['rgb'],
- rule['color'],
- rule['value'])
+ rulestxt += "UPDATE %s SET %s='%s' WHERE %s ;\n" % (self.properties['table'],
+ self.properties['rgb'],
+ rule['color'],
+ rule['value'])
if not rulestxt:
return False
@@ -686,31 +1239,408 @@
finally:
output.close()
- if self.raster:
- if not force and \
- not self.ovrwrtcheck.IsChecked():
- flags = 'w'
+ gcmd.RunCommand('db.execute',
+ parent = self,
+ input = gtemp)
+ return True
+## def ColorFromString(self, rgb):
+## """!Convert color string '255:255:255' to tuple"""
+## try:
+## r, g, b = rgb.split(':')
+## return (r, g, b)
+## except ValueError:
+## return False
+class ThematicVectorTable(VectorColorTable):
+ def __init__(self, parent, vectorType, **kwargs):
+ """!Dialog for interactively entering color/size rules
+ for vector maps for thematic mapping in nviz"""
+ self.vectorType = vectorType
+ VectorColorTable.__init__(self, parent = parent, **kwargs)
+ # additional bingings
+ self.Bind(wx.EVT_COMBOBOX, self.OnSizeSourceSelection, self.cb_size_att)
+ self.Bind(wx.EVT_COMBOBOX, self.OnSizeSelection, self.cb_size_col)
+ self.Bind(wx.EVT_BUTTON, self.OnAddSizeColumn, self.btn_add_size)
+ self.Bind(wx.EVT_CHECKBOX, self.OnColorChecked, self.rgb_check)
+ self.Bind(wx.EVT_CHECKBOX, self.OnSizeChecked, self.size_check)
+ self.SetTitle(_("Thematic mapping for vector map in 3D view"))
+ """!Update dialog according to selected map"""
+ VectorColorTable.UpdateDialog(self)
+ for combo in (self.cb_size_att, self.cb_size_col):
+ combo.Disable()
+ combo.Clear()
+ enable = False
+ else:
+ for combo in (self.cb_vlayer, self.cb_size_att, self.cb_size_col):
+ combo.Enable()
+ self.btn_add_size.Enable(True)
else:
- flags = ''
+ VectorColorTable.OnLayerSelection(self, event)
+ self.cb_size_att.InsertColumns(vector = self.inmap, layer = vlayer, dbInfo = self.dbInfo)
+ self.cb_size_att.SetSelection(0)
+ self.properties['source_size'] = self.cb_size_att.GetString(0)
+ self.cb_size_col.InsertColumns(vector = self.inmap, layer = vlayer,
+ type = ["integer", "double precision"], dbInfo = self.dbInfo)
+ for item in self.cb_size_col.GetItems():
+ if item.lower().find('size') >= 0:
+ self.cb_size_col.SetStringSelection(item)
+ self.properties['size'] = item
+ else:
+ self.properties['size'] = ''
+ self.LoadTable(attColumn = self.properties['source_size'], rgbColumn = self.properties['size'],
+ rulesPanel = self.sizeRulesPanel, type = 'size')
+ self.Update()
+ def OnSizeSelection(self, event):
+ self.properties['size'] = event.GetString()
+ def OnSizeSourceSelection(self, event):
+ self.properties['source_size'] = event.GetString()
+ self.inmap = self.parent.GetLayerData(nvizType = 'vector', nameOnly = True)
+ self.selectionInput.SetValue(self.inmap)
+ self.selectionInput.Disable()
+ # map selection
+ # body & preview
+ # buttons
+ sizer.Layout()
+ sizer.Fit(self)
+ self.Layout()
+ bodySizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+ row = 0
+ # label with instructions - don't want it now
+ self.cr_label = wx.StaticText(parent, id = wx.ID_ANY)
+ self.cr_label.Hide()
+ # color table
+ columnType = 'color', properties = self.properties,
+ panelWidth = 200)
+ # size table
+ self.sizeRulesPanel = RulesPanel(parent = parent, mapType = self.type,
+ columnType = 'size', properties = self.properties,
+ panelWidth = 200)
+ bodySizer.Add(item = self.colorRulesPanel.label, pos = (row, 0), span = (1, 2))
+ bodySizer.Add(item = self.sizeRulesPanel.label, pos = (row, 2), span = (1, 2))
+ row += 1
+ bodySizer.Add(item = self.colorRulesPanel.mainPanel, pos = (row, 0), span = (1, 2))
+ bodySizer.Add(item = self.sizeRulesPanel.mainPanel, pos = (row, 2), span = (1, 2))
+ self.sizeRulesPanel.AddRules(2)
+ # preview window
+ bodySizer.Add(item = self.preview, pos = (row, 4),
+ flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 10)
+ bodySizer.AddGrowableRow(row)
+ bodySizer.AddGrowableCol(4)
+ row += 1
+ bodySizer.Add(item = self.sizeRulesPanel.numRules, pos = (row, 2),
+ bodySizer.Add(item = self.sizeRulesPanel.btnAdd, pos = (row, 3),
+ flag = wx.ALIGN_LEFT)
+ # preview button
+ bodySizer.Add(item = self.btnPreview, pos = (row, 4),
+ flag = wx.ALIGN_RIGHT)
+ return bodySizer
+ layer_label = wx.StaticText(parent, id = wx.ID_ANY, label = _('Layer:'))
+ self.rgb_check = wx.CheckBox(parent, id = wx.ID_ANY, label = _('Use color for thematic mapping:'))
+ if self.vectorType == 'points':
+ label = _('Use symbol size for thematic mapping:')
+ else:
+ label = _('Use line width for thematic mapping:')
+ self.size_check = wx.CheckBox(parent, id = wx.ID_ANY, label = label)
+ self.rgb_check.SetValue(True)
+ self.size_check.SetValue(True)
+ color_att_label = wx.StaticText(parent, id = wx.ID_ANY,
+ size_att_label = wx.StaticText(parent, id = wx.ID_ANY,
+ rgb_col_label = wx.StaticText(parent, id = wx.ID_ANY,
+ label = _('Symbol size column:')
+ else:
+ label = _('Line with column:')
+ size_col_label = wx.StaticText(parent, id = wx.ID_ANY, label = label)
+ self.size_range_label = wx.StaticText(parent, id = wx.ID_ANY)
+ cb_size = (150, -1)
+ self.cb_vlayer = gselect.LayerSelect(parent, size = cb_size)
+ self.cb_color_att = gselect.ColumnSelect(parent, size = cb_size)
+ self.cb_size_att = gselect.ColumnSelect(parent, size = cb_size)
+ self.cb_rgb_col = gselect.ColumnSelect(parent, size = cb_size)
+ self.cb_size_col = gselect.ColumnSelect(parent, size = cb_size)
+ self.btn_add_size = wx.Button(parent, id = wx.ID_ANY,
+ label = _("Add size column to current attribute table.")
+ else:
+ label = _("Add width column to current attribute table.")
+ self.btn_add_size.SetToolTipString(label)
+ # layout
+ vSizer.AddGrowableCol(2)
+ vSizer.Add(layer_label, pos = (0, 0),
+ vSizer.Add(self.rgb_check, pos = (1, 0), span = (1, 3),
+ vSizer.Add(self.size_check, pos = (1, 3), span = (1, 3),
+ vSizer.Add(color_att_label, pos = (2, 0),
+ vSizer.Add(size_att_label, pos = (2, 3),
+ vSizer.Add(rgb_col_label, pos = (4, 0),
+ vSizer.Add(size_col_label, pos = (4, 3),
+ vSizer.Add(self.cb_color_att, pos = (2, 1),
+ vSizer.Add(self.cb_size_att, pos = (2, 4),
+ vSizer.Add(self.rgb_range_label, pos = (3, 1),
+ vSizer.Add(self.size_range_label, pos = (3, 4),
+ vSizer.Add(self.cb_rgb_col, pos = (4, 1),
+ vSizer.Add(self.cb_size_col, pos = (4, 4),
+ vSizer.Add(self.btn_add_RGB, pos = (4, 2),
+ vSizer.Add(self.btn_add_size, pos = (4, 5),
+ return inputSizer
+ def OnAddSizeColumn(self, event):
+ """!Add size column if it doesn't exist"""
+ name = 'GRASSSIZE'
+ else:
+ name = 'GRASSWIDTH'
+ map = self.inmap,
+ columns = '%s integer' % name)
+ self.cb_size_col.InsertColumns(self.inmap, self.properties['layer'], type = ["integer"])
+ self.cb_size_col.SetStringSelection(name)
+ self.properties['size'] = name
+ def OnColorChecked(self, event):
+ """!Use color for thematic mapping"""
+ if self.rgb_check.IsChecked():
+ self.colorRulesPanel.Enable(True)
+ else:
+ self.colorRulesPanel.Enable(False)
+ def OnSizeChecked(self, event):
+ """!Use size for thematic mapping"""
+ if self.size_check.IsChecked():
+ self.sizeRulesPanel.Enable(True)
+ else:
+ self.sizeRulesPanel.Enable(False)
+ return
+ '-a',
+ if self.size_check.IsChecked() and self.properties["size"]:
+ cmdlist.append('size_column=%s' % self.properties["size"])
+ else:
+ cmdlist.append('width_column=%s' % self.properties["size"])
- ret = gcmd.RunCommand('r.colors',
- flags = flags,
- map = self.inmap,
- rules = gtemp)
- if ret != 0:
- gcmd.GMessage(_("Color table already exists. "
- "Check out 'replace existing color table' to "
- "overwrite it."),
- parent = self)
- return False
+ if self.rgb_check.IsChecked() and self.properties["rgb"]:
+ cmdlist.append('rgb_column=%s' % self.properties["rgb"])
+ ltype = 'vector'
+ ret = VectorColorTable.CreateColorTable(self)
+ if not ret:
+ ret = self.CreateSizeTable()
+ if not ret:
+ gcmd.GMessage(parent = self, message = _("No size rules given."))
+ data = self.parent.GetLayerData(nvizType = 'vector')
+ data['vector']['points']['thematic']['layer'] = int(self.properties['layer'])
+ if self.size_check.IsChecked() and self.properties['size']:
+ data['vector'][self.vectorType]['thematic']['sizecolumn'] = self.properties['size']
else:
- gcmd.RunCommand('db.execute',
- parent = self,
- input = gtemp)
+ data['vector'][self.vectorType]['thematic']['sizecolumn'] = None
+ if self.rgb_check.IsChecked() and self.properties['rgb']:
+ data['vector'][self.vectorType]['thematic']['rgbcolumn'] = self.properties['rgb']
+ else:
+ data['vector'][self.vectorType]['thematic']['rgbcolumn'] = None
+ data['vector'][self.vectorType]['thematic']['update'] = None
+ event = wxUpdateProperties(data = data)
+ wx.PostEvent(self.parent.mapWindow, event)
+ self.parent.mapWindow.Refresh(False)
+ return ret
+ def CreateSizeTable(self, force = False):
+ """!Creates size table
+ VectorColorTable.CreateColorTable(self)
+ rulestxt = ''
+ for rule in self.sizeRulesPanel.ruleslines.itervalues():
+ continue
+ self.properties['size'],
+ rule['size'],
+ rule['value'])
+ if not rulestxt:
+ return False
+ try:
+ finally:
+ output.close()
+ parent = self,
+ input = gtemp)
return True
class BufferedWindow(wx.Window):
"""!A Buffered window class"""
def __init__(self, parent, id,
@@ -843,10 +1773,11 @@
oldencoding = ""
if self.render:
- # make sure that extents are updated
- self.Map.region = self.Map.GetRegion()
- self.Map.SetRegion()
+ # extent is taken from current map display
+ try:
+ self.Map.region = copy.deepcopy(self.parent.parent.curr_page.maptree.Map.region)
+ except AttributeError:
+ self.Map.region = self.Map.GetRegion()
# render new map images
self.mapfile = self.Map.Render(force = self.render)
self.img = self.GetImage()
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2011-08-14 08:45:36 UTC (rev 47614)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2011-08-14 09:01:34 UTC (rev 47615)
@@ -1010,9 +1010,9 @@
cmd = self.GetMenuCmd(event)
if cmd[0] == 'r.colors':
- ctable = colorrules.ColorTable(self, raster = True)
+ ctable = colorrules.RasterColorTable(self)
else:
- ctable = colorrules.ColorTable(self, raster = False)
+ ctable = colorrules.VectorColorTable(self)
ctable.CentreOnScreen()
ctable.Show()
