[GRASS-SVN] r47621 - grass/trunk/visualization/nviz2/cmd
Sun Aug 14 05:57:37 EDT 2011
Author: martinl
Date: 2011-08-14 02:57:37 -0700 (Sun, 14 Aug 2011)
New Revision: 47621
   grass/trunk/visualization/nviz2/cmd/vector.c
nviz_cmd: support for vector color tables
Modified: grass/trunk/visualization/nviz2/cmd/vector.c
--- grass/trunk/visualization/nviz2/cmd/vector.c	2011-08-14 09:57:03 UTC (rev 47620)
+++ grass/trunk/visualization/nviz2/cmd/vector.c	2011-08-14 09:57:37 UTC (rev 47621)
@@ -114,8 +114,11 @@
     int i, layer, color, width, flat, height;
     int *vect_list, nvects;
+    int have_colors;
     char *color_column, *width_column;
+    struct Colors colors;
     vect_list = GV_get_vect_list(&nvects);
     for (i = 0; i < nvects; i++) {
@@ -136,10 +139,14 @@
 	/* style (mode -- use memory by default) */
 	if (GV_set_style(vect_list[i], TRUE, color, width, flat) < 0)
 	    return 0;
-	if (color_column || width_column)
+	/* check for vector color table */
+	have_colors = Vect_read_colors(params->vlines->answers[i], "",
+				       &colors);
+	if (have_colors || color_column || width_column)
 	    if (GV_set_style_thematic(vect_list[i], layer, color_column,
-				      width_column) < 0)
+				      width_column, have_colors ? &colors : NULL) < 0)
 		return 0;
 	/* height */
@@ -161,12 +168,14 @@
 int vpoints_set_attrb(const struct GParams *params)
-    int i, layer;
+    int i, layer, have_colors;
     int *site_list, nsites;
     int marker, color, width;
     float size;
     char *marker_str, *color_column, *size_column, *width_column, *marker_column;
     site_list = GP_get_site_list(&nsites);
     for (i = 0; i < nsites; i++) {
@@ -187,10 +196,16 @@
 	if (GP_set_style(site_list[i], color, width, size, marker) < 0)
 	    return 0;
+	have_colors = Vect_read_colors(params->vpoints->answers[i], "",
+				       &colors);
-	if (color_column || width_column || size_column || marker_column) {
-	    if (GP_set_style_thematic(site_list[i], layer, color_column, width_column,
-				      size_column, marker_column) < 0)
+	if (have_colors || color_column || width_column ||
+	    size_column || marker_column) {
+	    if (GP_set_style_thematic(site_list[i], layer, color_column,
+				      width_column, size_column, marker_column,
+				      have_colors ? &colors : NULL) < 0)
 		return 0;
