[GRASS-SVN] r47622 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Sun Aug 14 07:09:50 EDT 2011
Author: martinl
Date: 2011-08-14 04:09:49 -0700 (Sun, 14 Aug 2011)
New Revision: 47622
grass/trunk/display/d.vect/area.c
grass/trunk/display/d.vect/lines.c
grass/trunk/display/d.vect/local_proto.h
grass/trunk/display/d.vect/main.c
grass/trunk/display/d.vect/shape.c
d.vect: use color table if available
-a flag used only for rgb_column
Modified: grass/trunk/display/d.vect/area.c
--- grass/trunk/display/d.vect/area.c 2011-08-14 09:57:37 UTC (rev 47621)
+++ grass/trunk/display/d.vect/area.c 2011-08-14 11:09:49 UTC (rev 47622)
@@ -15,7 +15,7 @@
int display_area(struct Map_info *Map, struct cat_list *Clist, const struct Cell_head *window,
const struct color_rgb *bcolor, const struct color_rgb *fcolor, int chcat,
- int id_flag, int table_colors_flag, int cats_color_flag,
+ int id_flag, int cats_color_flag,
int default_width, double width_scale,
struct Colors *zcolors,
dbCatValArray *cvarr_rgb, struct Colors *colors,
@@ -169,7 +169,7 @@
/* custom colors */
- if (table_colors_flag) {
+ if (colors || cvarr_rgb) {
custom_rgb = get_table_color(cat, area, colors, cvarr_rgb,
&red, &grn, &blu, &nerror_rgb);
@@ -190,7 +190,7 @@
if (fcolor || zcolors) {
- if (!table_colors_flag && !cats_color_flag && !zcolors) {
+ if (!cvarr_rgb && !cats_color_flag && !zcolors) {
D_RGB_color(fcolor->r, fcolor->g, fcolor->b);
D_polygon_abs(Points->x, Points->y, Points->n_points);
Modified: grass/trunk/display/d.vect/lines.c
--- grass/trunk/display/d.vect/lines.c 2011-08-14 09:57:37 UTC (rev 47621)
+++ grass/trunk/display/d.vect/lines.c 2011-08-14 11:09:49 UTC (rev 47622)
@@ -39,7 +39,7 @@
int display_lines(struct Map_info *Map, int type, struct cat_list *Clist,
const struct color_rgb *color, const struct color_rgb *fcolor, int chcat,
const char *symbol_name, double size, int sqrt_flag,
struct Colors* zcolors,
@@ -117,7 +117,7 @@
Vect_rewind(Map);
- if (color && !table_colors_flag && !cats_color_flag)
+ if (color && !cvarr_rgb && !cats_color_flag)
D_RGB_color(color->r, color->g, color->b);
if (Vect_level(Map) >= 2)
@@ -194,14 +194,15 @@
custom_rgb = FALSE;
- if (table_colors_flag || nrec_width > 0 || nrec_size > 0 || nrec_rot > 0)
+ if (colors || cvarr_rgb ||
+ nrec_width > 0 || nrec_size > 0 || nrec_rot > 0)
/* only first category */
Vect_cat_get(Cats,
(Clist->field > 0 ? Clist->field : (Cats->n_cats > 0 ? Cats->field[0] : 1)),
&cat);
/* custom colors */
custom_rgb = get_table_color(cat, line, colors, cvarr_rgb,
@@ -280,7 +281,7 @@
rotation = 0.0;
else if (color || custom_rgb || zcolors) {
else {
if (custom_rgb)
Modified: grass/trunk/display/d.vect/local_proto.h
--- grass/trunk/display/d.vect/local_proto.h 2011-08-14 09:57:37 UTC (rev 47621)
+++ grass/trunk/display/d.vect/local_proto.h 2011-08-14 11:09:49 UTC (rev 47622)
@@ -13,8 +13,7 @@
/* area.c */
int display_area(struct Map_info *, struct cat_list *, const struct Cell_head *,
const struct color_rgb *, const struct color_rgb *, int, int,
- int, int,
- int, double,
+ int, int, double,
struct Colors *,
dbCatValArray *, struct Colors *, dbCatValArray *, int);
@@ -30,8 +29,7 @@
int display_lines(struct Map_info *, int, struct cat_list *,
const char *, double, int,
- int, int, int,
- int, double,
+ int, int, int, double,
struct Colors *,
dbCatValArray *, struct Colors *, dbCatValArray *, int,
dbCatValArray *, int, dbCatValArray *, int);
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2011-08-14 09:57:37 UTC (rev 47621)
+++ grass/trunk/display/d.vect/main.c 2011-08-14 11:09:49 UTC (rev 47622)
@@ -173,6 +173,7 @@
rgbcol_opt->key = "rgb_column";
rgbcol_opt->guisection = _("Colors");
rgbcol_opt->description = _("Name of color definition column (for use with -a flag)");
+ rgbcol_opt->answer = "GRASSRGB";
zcol_opt = G_define_standard_option(G_OPT_M_COLR);
zcol_opt->key = "zcolor";
@@ -335,7 +336,7 @@
table_acolors_flag->key = 'a';
table_acolors_flag->guisection = _("Colors");
table_acolors_flag->description =
- _("Get colors from color table or attribute column (see 'rgb_column')");
+ _("Get colors from attribute table (see 'rgb_column' option)");
cats_acolors_flag = G_define_flag();
cats_acolors_flag->key = 'c';
Modified: grass/trunk/display/d.vect/shape.c
--- grass/trunk/display/d.vect/shape.c 2011-08-14 09:57:37 UTC (rev 47621)
+++ grass/trunk/display/d.vect/shape.c 2011-08-14 11:09:49 UTC (rev 47622)
@@ -16,14 +16,14 @@
dbCatValArray cvarr_rgb, cvarr_width, cvarr_size, cvarr_rot;
struct field_info *fi;
dbDriver *driver;
- int nrec_rgb, nrec_width, nrec_size, nrec_rot, has_color_table;
+ int nrec_rgb, nrec_width, nrec_size, nrec_rot, have_colors;
struct Colors colors, zcolors;
struct bound_box box;
stat = 0;
nrec_rgb = nrec_width = nrec_size = nrec_rot = 0;
- open_db = (table_colors_flag && rgb_column) || width_column || size_column || rot_column;
+ open_db = table_colors_flag || width_column || size_column || rot_column;
if (open_db) {
field = Clist->field > 0 ? Clist->field : 1;
fi = Vect_get_field(Map, field);
@@ -38,39 +38,38 @@
fi->database, fi->driver);
+ /* fisrt search for color table */
+ have_colors = Vect_read_colors(Vect_get_name(Map), Vect_get_mapset(Map),
+ &colors);
- /* fisrt search for color table */
- has_color_table = Vect_read_colors(Vect_get_name(Map), Vect_get_mapset(Map),
- &colors);
- if (!has_color_table) {
- /* read RRR:GGG:BBB color strings from table */
- if (!rgb_column || *rgb_column == '\0')
- G_fatal_error(_("Color definition column not specified"));
+ /* read RRR:GGG:BBB color strings from table */
+ if (!rgb_column || *rgb_column == '\0')
+ G_fatal_error(_("Color definition column not specified"));
+ db_CatValArray_init(&cvarr_rgb);
+ nrec_rgb = db_select_CatValArray(driver, fi->table, fi->key,
+ rgb_column, NULL, &cvarr_rgb);
+ G_debug(3, "nrec_rgb (%s) = %d", rgb_column, nrec_rgb);
- db_CatValArray_init(&cvarr_rgb);
- nrec_rgb = db_select_CatValArray(driver, fi->table, fi->key,
- rgb_column, NULL, &cvarr_rgb);
- G_debug(3, "nrec_rgb (%s) = %d", rgb_column, nrec_rgb);
- if (cvarr_rgb.ctype != DB_C_TYPE_STRING)
- G_fatal_error(_("Color definition column (%s) not a string. "
- "Column must be of form RRR:GGG:BBB where RGB values range 0-255."),
- rgb_column);
- if (nrec_rgb < 0)
- G_fatal_error(_("Unable to select data (%s) from table"),
- rgb_column);
- G_debug(2, "\n%d records selected from table", nrec_rgb);
- for (i = 0; i < cvarr_rgb.n_values; i++) {
- G_debug(4, "cat = %d %s = %s", cvarr_rgb.value[i].cat,
- rgb_column, db_get_string(cvarr_rgb.value[i].val.s));
+ if (cvarr_rgb.ctype != DB_C_TYPE_STRING)
+ G_fatal_error(_("Color definition column (%s) not a string. "
+ "Column must be of form RRR:GGG:BBB where RGB values range 0-255."),
+ rgb_column);
+ if (nrec_rgb < 0)
+ G_fatal_error(_("Unable to select data (%s) from table"),
+ rgb_column);
+ G_debug(2, "\n%d records selected from table", nrec_rgb);
+ for (i = 0; i < cvarr_rgb.n_values; i++) {
+ G_debug(4, "cat = %d %s = %s", cvarr_rgb.value[i].cat,
+ rgb_column, db_get_string(cvarr_rgb.value[i].val.s));
if (width_column) {
@@ -184,20 +183,22 @@
if (type & GV_AREA)
stat += display_area(Map, Clist, window,
bcolor, fcolor, chcat,
- id_flag, table_colors_flag, cats_colors_flag,
+ id_flag, cats_colors_flag,
default_width, width_scale,
z_color_flag ? &zcolors : NULL,
- &cvarr_rgb, has_color_table ? &colors : NULL,
+ table_colors_flag ? &cvarr_rgb : NULL,
+ have_colors ? &colors : NULL,
&cvarr_width, nrec_width);
stat += display_lines(Map, type, Clist,
icon, size, sqrt_flag,
&cvarr_width, nrec_width,
&cvarr_size, nrec_size,
&cvarr_rot, nrec_rot);
@@ -228,31 +229,30 @@
G_debug(3, "\tb: %d, g: %d, r: %d", *blu, *grn, *red);
- else {
- /* read RGB colors from db for current area # */
- if (db_CatValArray_get_value(cvarr, cat, &cv) == DB_OK) {
- sprintf(colorstring, "%s", db_get_string(cv->val.s));
- if (*colorstring != '\0') {
- G_debug(3, "element %d: colorstring: %s", line,
- colorstring);
- if (G_str_to_color(colorstring, red, grn, blu) == 1) {
- custom_rgb = TRUE;
- G_debug(3, "element:%d cat %d r:%d g:%d b:%d",
- line, cat, *red, *grn, *blu);
- else {
- G_important_message(_("Error in color definition (%s) - feature %d with category %d"),
- colorstring, line, cat);
- nerror_rgb++;
+ /* read RGB colors from db for current area # */
+ if (cvarr && db_CatValArray_get_value(cvarr, cat, &cv) == DB_OK) {
+ sprintf(colorstring, "%s", db_get_string(cv->val.s));
+ if (*colorstring != '\0') {
+ G_debug(3, "element %d: colorstring: %s", line,
+ colorstring);
+ if (G_str_to_color(colorstring, red, grn, blu) == 1) {
+ custom_rgb = TRUE;
+ G_debug(3, "element:%d cat %d r:%d g:%d b:%d",
+ line, cat, *red, *grn, *blu);
else {
nerror_rgb++;
+ else {
+ G_important_message(_("Error in color definition (%s) - feature %d with category %d"),
+ colorstring, line, cat);
+ nerror_rgb++;
*nerror = nerror_rgb;
