[GRASS-SVN] r47623 -
grass-addons/grass7/gui/wxpython/wx.stream/gui_modules
svn_grass at osgeo.org
Sun Aug 14 07:11:31 EDT 2011
Author: madi
Date: 2011-08-14 04:11:31 -0700 (Sun, 14 Aug 2011)
New Revision: 47623
grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py
grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
Added Map Display from layer manager
Modified: grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py
--- grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py 2011-08-14 11:09:49 UTC (rev 47622)
+++ grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py 2011-08-14 11:11:31 UTC (rev 47623)
@@ -24,7 +24,6 @@
sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython', 'gui_modules'))
import wx
-#import wx.aui
import wx.lib.flatnotebook as FN
from debug import Debug as Debug
@@ -82,15 +81,13 @@
wx.Frame.__init__(self, parent = parent, id = id, title = title, name = "RStream", size = (600, 900), **kwargs)
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
- # create the AuiNotebook instance
- #nb = wx.aui.AuiNotebook(self)
self.nb = FN.FlatNotebook(parent = self, id = wx.ID_ANY,
style = FN.FNB_NO_NAV_BUTTONS |
FN.FNB_FANCY_TABS | FN.FNB_NO_X_BUTTON)
- # add some pages to the notebook
- self.pages = [(TabPanelOne(self.nb), "Network extraction"),
+ # add pages to the notebook
+ self.pages = [(TabPanelOne(self.nb, self.parent), "Network extraction"),
(TabPanel(self.nb), "Network ordering"),
(TabPanel(self.nb), "Tab 3")]
@@ -109,7 +106,7 @@
self.SetSizer(self.sizer)
- #self.mapdisp = self.parent.curr_page.maptree.mapdisplay
+ self.mapdisp = self.parent.curr_page.maptree.mapdisplay
def OnClose(self, event):
self.Destroy()
Modified: grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
--- grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py 2011-08-14 11:09:49 UTC (rev 47622)
+++ grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py 2011-08-14 11:11:31 UTC (rev 47623)
@@ -9,9 +9,7 @@
See http://grass.osgeo.org/wiki/Wx.stream_GSoC_2011
Classes:
- - SPD
- - SPDCanvas
- - TabPanelOne
+ - RStreamFrame
(C) 2011 by Margherita Di Leo, and the GRASS Development Team
This program is free software under the GNU General Public License
@@ -38,71 +36,16 @@
import globalvar
import utils
import menuform
-import mapdisp_window
-from wxgui import GMFrame # for SPD class
-from render import MapLayer
+# First panel # Network extraction
-# SPD = Select Point Display
-class SPD(GMFrame, wx.Frame):
- """!Secondary Map Display that allows user to select the point which is the centre of preview region
- def __init__(self, parent, grwiz = None, id = wx.ID_ANY,
- title = _("Select the centre of Preview region"),
- size = (700, 300), Map = None, lmgr = None):
- GMFrame.__init__(self, parent, id = wx.ID_ANY, title = "SPDMapWindow",
- workspace = None,
- size = globalvar.GM_WINDOW_SIZE, style = wx.DEFAULT_FRAME_STYLE)
- # init variables
- self.parent = parent # TabPanelOne
-class SPDCanvas(MapLayer):
- def __init__(self, type, cmd, name = None,
- active = True, hidden = False, opacity = 1.0):
- """!Represents map layer in the map canvas
- @param type layer type ('raster', 'vector', 'command', etc.)
- @param cmd GRASS command to render layer,
- given as list, e.g. ['d.rast', 'map=elevation at PERMANENT']
- @param name layer name, e.g. 'elevation at PERMANENT' (for layer tree) or None
- @param active layer is active, will be rendered only if True
- @param hidden layer is hidden, won't be listed in Layer Manager if True
- @param opacity layer opacity <0;1>
- MapLayer.__init__(self, type, cmd, name,
- active, hidden, opacity)
- def GetMapset(self):
- """!Get mapset of map layer
- @return mapset name
- @return '' on error (no name given)
- if not self.name:
- return ''
- try:
- return self.name.split('@')[1]
- except IndexError:
- return self.name
class TabPanelOne(wx.Panel):
- """!First panel for Network extraction
- def __init__(self, parent):
+ def __init__(self, parent, layerManager):
wx.Panel.__init__(self, parent, id = wx.ID_ANY)
+ self.layerManager = layerManager
self.thre = 0
self.r_elev = 'r_elev'
@@ -110,7 +53,7 @@
self.r_stre = 'r_stre'
self.v_net = 'v_net'
self.r_drain = 'r_drain'
self.panel = wx.Panel(self)
self._layout()
@@ -359,7 +302,6 @@
def OnPreview(self, event):
"""!Allows to watch a preview of the analysis on a small region
- pass
info_region = grass.read_command('g.region', flags = 'p')
# message box
@@ -370,23 +312,10 @@
print "OK"
# get current Map Display
- self.mapdisp = SPD(parent = self)
- SPDCanvas(type = 'command', cmd = ['d.rast', 'map = self.r_elev']).Render() # FIXME #
- # Debug
- print type(dir(SPDCanvas))
- lista = []
- lista.append(dir(SPDCanvas))
- for i in dir(SPDCanvas):
- print i
+ mapdisp = self.layerManager.GetLayerTree().GetMapDisplay()
+ mapdisp.Raise()
+ #grass.run_command('d.rast', map = self.r_elev)
# Get position by panel on mouse click
@@ -401,10 +330,8 @@
#-------------Network extraction-------------
def OnRun(self, event):
- """!Calculates flow accumulation if it is missing, and runs stream extraction
- #radioval1 = self.cb1.GetValue()
+ # radioval1 = self.cb1.GetValue()
radioval2 = self.cb2.GetValue()
radioval3 = self.cb3.GetValue()
