[GRASS-SVN] r47649 - grass/trunk/vector/v.colors
svn_grass at osgeo.org
Mon Aug 15 12:21:55 EDT 2011
Author: martinl
Date: 2011-08-15 09:21:55 -0700 (Mon, 15 Aug 2011)
New Revision: 47649
Added:
grass/trunk/vector/v.colors/make_colors.c
grass/trunk/vector/v.colors/local_proto.h
grass/trunk/vector/v.colors/main.c
grass/trunk/vector/v.colors/scan_attr.c
grass/trunk/vector/v.colors/scan_cats.c
v.colors: fix 'random' color table
Modified: grass/trunk/vector/v.colors/local_proto.h
--- grass/trunk/vector/v.colors/local_proto.h 2011-08-15 16:14:07 UTC (rev 47648)
+++ grass/trunk/vector/v.colors/local_proto.h 2011-08-15 16:21:55 UTC (rev 47649)
@@ -1,8 +1,11 @@
-/* scan_attr */
+/* make_colors.c */
+void make_colors(struct Colors *, const char *, DCELL, DCELL, int);
+/* scan_attr.c */
int scan_attr(const struct Map_info *, int, const char *, const char *,
const struct FPRange *, struct Colors *, int *, int *);
-/* scan_cats */
+/* scan_cats.c */
void scan_cats(const struct Map_info *, int, const char *,
Modified: grass/trunk/vector/v.colors/main.c
--- grass/trunk/vector/v.colors/main.c 2011-08-15 16:14:07 UTC (rev 47648)
+++ grass/trunk/vector/v.colors/main.c 2011-08-15 16:21:55 UTC (rev 47649)
@@ -15,7 +15,6 @@
-#include <string.h>
#include <stdlib.h>
#include <grass/gis.h>
@@ -246,25 +245,6 @@
scan_attr(&Map, layer, attrcolumn, style, opt.range->answer ? &range : NULL,
&colors, &cmin, &cmax);
- if (strcmp(style, "random") == 0) {
- Rast_make_random_colors(&colors, (CELL) cmin, (CELL) cmax);
- } else if (strcmp(style, "grey.eq") == 0) {
- G_fatal_error(_("Color table <%s> not supported"), "grey.eq");
- if (!have_stats)
- have_stats = get_stats(name, mapset, &statf);
- Rast_make_histogram_eq_colors(&colors, &statf);
- } else if (strcmp(style, "grey.log") == 0) {
- G_fatal_error(_("Color table <%s> not supported"), "grey.log");
- if (!have_stats)
- Rast_make_histogram_log_colors(&colors, &statf, (CELL) min,
- (CELL) max);
else if (rules) {
if (!Rast_load_colors(&colors, rules, (CELL) cmin, (CELL) cmax))
Added: grass/trunk/vector/v.colors/make_colors.c
--- grass/trunk/vector/v.colors/make_colors.c (rev 0)
+++ grass/trunk/vector/v.colors/make_colors.c 2011-08-15 16:21:55 UTC (rev 47649)
@@ -0,0 +1,39 @@
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+void make_colors(struct Colors *colors, const char *style, DCELL min, DCELL max, int is_fp)
+ G_debug(3, "make_colors(): range=%f,%f is_fp=%d", min, max, is_fp);
+ if (strcmp(style, "random") == 0) {
+ if (is_fp)
+ G_fatal_error(_("Color table '%s' is not supported for "
+ "floating point attributes"), style);
+ Rast_make_random_colors(colors, (CELL) min, (CELL) max);
+ } else if (strcmp(style, "grey.eq") == 0) {
+ G_fatal_error(_("Color table <%s> not supported"), "grey.eq");
+ if (!have_stats)
+ have_stats = get_stats(name, mapset, &statf);
+ Rast_make_histogram_eq_colors(&colors, &statf);
+ } else if (strcmp(style, "grey.log") == 0) {
+ G_fatal_error(_("Color table <%s> not supported"), "grey.log");
+ if (!have_stats)
+ Rast_make_histogram_log_colors(&colors, &statf, (CELL) min,
+ (CELL) max);
+ else {
+ if (is_fp)
+ Rast_make_fp_colors(colors, style, min, max);
+ else
+ Rast_make_colors(colors, style, (CELL) min, (CELL) max);
Property changes on: grass/trunk/vector/v.colors/make_colors.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
Modified: grass/trunk/vector/v.colors/scan_attr.c
--- grass/trunk/vector/v.colors/scan_attr.c 2011-08-15 16:14:07 UTC (rev 47648)
+++ grass/trunk/vector/v.colors/scan_attr.c 2011-08-15 16:21:55 UTC (rev 47649)
@@ -68,9 +68,6 @@
G_warning(_("Max value (%f) is out of range %f,%f"),
range->max, fmin, fmax);
- G_debug(3, "scan_attr(): range=%f,%f", fmin, fmax);
- Rast_make_fp_colors(&vcolors, style, (DCELL) fmin, (DCELL) fmax);
else {
fmin = cvarr.value[0].val.i;
@@ -89,10 +86,8 @@
G_warning(_("Max value (%d) is out of range %d,%d"),
(int) range->max, (int) fmin, (int) fmax);
- G_debug(3, "scan_attr(): range=%d,%d", (int) fmin, (int) fmax);
- Rast_make_colors(&vcolors, style, (CELL) fmin, (CELL) fmax);
+ make_colors(&vcolors, style, (DCELL) fmin, (DCELL) fmax, is_fp);
/* color table for categories */
for (i = 0; i < cvarr.n_values; i++) {
@@ -129,7 +124,7 @@
*cmax = cat;
db_close_database(driver);
return is_fp;
Modified: grass/trunk/vector/v.colors/scan_cats.c
--- grass/trunk/vector/v.colors/scan_cats.c 2011-08-15 16:14:07 UTC (rev 47648)
+++ grass/trunk/vector/v.colors/scan_cats.c 2011-08-15 16:21:55 UTC (rev 47649)
@@ -45,8 +45,7 @@
(int) range->max, *cmin, *cmax);
- G_debug(3, "scan_cats(): range=%d,%d", *cmin, *cmax);
- Rast_make_colors(colors, style, (CELL) *cmin, (CELL) *cmax);
+ make_colors(colors, style, (DCELL) *cmin, (DCELL) *cmax, FALSE);
Vect_destroy_cats_struct(Cats);
