[GRASS-SVN] r47650 - grass/trunk/gui/wxpython/docs
svn_grass at osgeo.org
Mon Aug 15 12:24:28 EDT 2011
Author: annakrat
Date: 2011-08-15 09:24:27 -0700 (Mon, 15 Aug 2011)
New Revision: 47650
Added:
grass/trunk/gui/wxpython/docs/wxGUI_nviz_tools_light.jpg
grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html
grass/trunk/gui/wxpython/docs/wxGUI_nviz_tools_surface.jpg
grass/trunk/gui/wxpython/docs/wxGUI_nviz_tools_vector.jpg
grass/trunk/gui/wxpython/docs/wxGUI_nviz_tools_view.jpg
grass/trunk/gui/wxpython/docs/wxGUI_nviz_tools_volume.jpg
wxNviz: update manual page
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html 2011-08-15 16:21:55 UTC (rev 47649)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html 2011-08-15 16:24:27 UTC (rev 47650)
@@ -13,7 +13,8 @@
<p>
To start the wxGUI 3D view mode, choose '3D view' from the map
-toolbar.
+toolbar. You can switch between 2D and 3D view. The region in
+3D view is updated according to displayed region in 2D view.
<p>
wxNviz is emphasized on the ease and speed of viewer positioning and
provided flexibility for using a wide range of data. A low resolution
@@ -81,9 +82,10 @@
has several tabs:
<ul>
- <li><b>View</b> for view controling,</li>
+ <li><b>View</b> for view controlling,</li>
<li><b>Data</b> for data properties,</li>
<li><b>Appearance</b> for appearance settings (lighting, fringes, ...).</li>
+ <li><b>Analysis</b> for various data analyses (only cutting planes so far).</li>
</ul>
<h3>View</h3>
@@ -92,15 +94,26 @@
perspective</em> of the view. The position box shows a puck with a
direction line pointing to the center. The direction line indicates
the look direction (azimuth). You click and drag the puck to change
- the current eye position. The box annotations are North, South,
- East, and West. You can also set exact position using <em>Look
- at</em> choice control.
+ the current eye position. Another way to change eye position is
+ to press the buttons around the position box representing cardinal
+ and ordinal directions.
+<p>
+There are four other buttons for view control in the bottom of this panel
+(following label <em>Look:</em>):
+<ul>
+ <li><em>here</em> requires you to click on Map Display Window to determine
+ the point to look at.</li>
+ <li><em>center</em> changes the point you are looking at to the center.</li>
+ <li><em>top</em> moves the current eye position above the map center.</li>
+ <li><em>reset</em> returns all current view settings to their default values.</li>
+</ul>
<center>
<br><img src="wxGUI_nviz_tools_view.jpg" border="1"><br><br>
</center>
-You can adjust the viewer's height above the scene, angle of view or
+You can adjust the viewer's height above the scene, perspective and
twist value to rotate the scene about the horizontal axis. An angle of
0 is flat. The scene rotates between -90 and 90 degrees.
@@ -109,43 +122,24 @@
example, if the easting and northing are in meters and the elevation
in feet, a vertical exaggeration of 0.305 would produce a true
(unexaggerated) surface.
<p>
-<em>Reset</em> returns all current settings to their default values.
+View parameters can be controlled by sliders or edited directly in text box.
+It's possible to enter values which are out of slider's range (and it will
+adjust then).
-<h3>Data properties - Surface</h3>
+<h3>Data properties</h3>
+This tab allows to control parameters related to map layers. It consists
+of four collapsible panels - <em>Surface</em>, <em>Constant surface</em>,
+<em>Vector</em> and <em>Volume</em>.
+<h4>Surface</h4>
Each active raster map layer from the current layer tree is displayed
-as surface in the 3D space. Separate raster data or constants can be
-used for various attributes of the surface:
-<ul>
- <li><b>topography</b> - raster map or constant values used as elevation (z
- values) for the current surface.</li>
- <li><b>color</b> - raster map or constant color to drape over the current
- surface. This option is useful for draping imagery such as aerial
- photography over a DEM.</li>
- <li><b>mask</b> - raster map that controls the areas displayed from
- the current surface.</li>
- <li><b>transparency</b> - raster map or constant value that controls
- the transparency of the current surface. The default is completely
- opaque. Range from 0 (opaque) to 255 (transparent).</li>
- <li><b>shininess</b> - raster map or constant value that controls
- the shininess (reflectivity) of the current surface. Range from 0 to
- 255.</li>
- <li><b>emission</b> - raster map or constant value that controls the
- light emitted from the current surface. Range from 0 to 255.</li>
-</ul>
-This panel controls how loaded surfaces are drawn. The top half of the
-panel has options to set, unset or modify attributes of the current
-surface. The bottom half has drawing style options, masking or
-changing surface position in the space.
-<center>
- <br><img src="wxGUI_nviz_tools_surface.jpg" border="1"><br><br>
-</center>
+as surface in the 3D space. This panel controls how loaded surfaces are drawn.
+To change parameters of a surface, it must be selected in the very top part of the
+panel.
+<p>
+The top half of the panel has drawing style options.
Surface can be drawn as a wire mesh or using filled polygons (most
realistic). You can set draw <b>mode</b> to <em>coarse</em> (fast
display mode), <em>fine</em> (draws surface as filled polygons with
@@ -170,10 +164,43 @@
cells. The surface appears faceted.
<p>
-To set given draw settings for all loaded surfaces press button "All".
+To set given draw settings for all loaded surfaces press button "Set to all".
-<h3>Data properties - Vector</h3>
+<p>
+The bottom half of the panel has options to set, unset or modify attributes
+of the current surface. Separate raster data or constants can be
+used for various attributes of the surface:
+<ul>
+ <li><b>color</b> - raster map or constant color to drape over the current
+ surface. This option is useful for draping imagery such as aerial
+ photography over a DEM.</li>
+ <li><b>mask</b> - raster map that controls the areas displayed from
+ the current surface.</li>
+ <li><b>transparency</b> - raster map or constant value that controls
+ the transparency of the current surface. The default is completely
+ opaque. Range from 0 (opaque) to 100 (transparent).</li>
+ <li><b>shininess</b> - raster map or constant value that controls
+ the shininess (reflectivity) of the current surface. Range from 0 to
+ 100.</li>
+</ul>
+<p>
+In the very bottom part of the panel position of surface can be set.
+To move the surface right (looking from the south) choose <em>X</em> axis
+and set some positive value. To reset the surface position press
+<em>Reset</em> button.
+<center>
+ <br><img src="wxGUI_nviz_tools_surface.jpg" border="1"><br><br>
+</center>
+<h4>Constant surface</h4>
+It is possible to add constant surface and set its properties like
+fine resolution, value (height), color and transparency. It behaves
+similarly to surface but it has less options.
+<h4>Vector</h4>
2D vector data can be draped on the selected surfaces with various
markers to represent point data; you can use attribute of vector
features to determine size, color, shape of glyph.
@@ -186,14 +213,12 @@
You can define the width (in pixels) of the line features, the color
used for lines or point markers.
-<center>
- <br><img src="wxGUI_nviz_tools_vector.jpg" border="1"><br><br>
-</center>
+<p>
If vector map is 2D you can display vector features as flat at a
specified elevation or drape it over a surface(s) at a specified
height. Use the height control to set the flat elevation or the drape
-height above the surface(s).
+height above the surface(s). In case of multiple surfaces it is possible
+to specify which surfaces is the vector map draped over.
<p>
For display purposes, it is better to set the height slightly above
@@ -201,10 +226,10 @@
disappear into the surface(s).
<p>
-For 2D/3D vector points you can also set the size of the markers and
-the width (in pixels) of the line used to draw the point markers (only
-applies to wire-frame markers). Currently are implemented these
-markers:
+For 2D/3D vector points you can also set the size of the markers.
+<!-- and the width (in pixels) of the line used to draw the point markers (only
+applies to wire-frame markers). -->
+ Currently are implemented these markers:
<ul>
<li><b>x</b> sets the current points markers to a 2D "X",</li>
@@ -216,14 +241,40 @@
<li><b>asterisk</b> - 3D line-star.</li>
</ul>
-<h3>Data properties - Volume</h3>
+<p>
+Thematic mapping can be used to determine marker color and size
+(and line color and width).
-Volumes can be displayed either as isosurfaces or slices. Various
-attributes of the isosurface can be defined, similarly to surface
+<center>
+ <br><img src="wxGUI_nviz_tools_vector.jpg" border="1"><br><br>
+</center>
+<h4>Volume</h4>
+Volumes (3D raster maps) can be displayed either as isosurfaces or slices.
+Similarly to surface panel you can define draw <b>shading</b>
+- <em>gouraud</em> (draws the volumes with a smooth shading to blend
+individual cell colors together) and <em>flat</em> (draws the volumes
+with flat shading with one color for every two cells. The volume
+appears faceted). As mentioned above currently are supported two
+visualization modes:
+<ul>
+ <li><b>isosurface</b> - the levels of values for drawing the
+ volume(s) as isosurfaces,</li>
+ <li>and <b>slice</b> - drawing the volume
+ as cross-sections.</li>
+</ul>
+<p>
+The middle part of the panel has controls to add, delete, move up/down selected
+isosurface or slice. The bottom part differs for isosurface and slice.
+When choosing isosurface, this part the of panel has options to set, unset
+or modify attributes of the current isosurface.
+Various attributes of the isosurface can be defined, similarly to surface
attributes:
<ul>
- <li><b>level</b> - reference isosurface level (height in map
+ <li><b>isosurface value</b> - reference isosurface value (height in map
units).</li>
current volume.</li>
@@ -231,40 +282,68 @@
the current volume.</li>
the transparency of the current volume. The default is completely
the shininess (reflectivity) of the current volume. Range from 0 to
- 255.</li>
- light emitted from the current volume. Range from 0 to 255.</li>
+ 100.</li>
</ul>
+In case of volume slice the bottom part of the panel controls the slice
+attributes (which axis is slice parallel to, position of slice edges,
+transparency). Press button <em>Reset</em> to reset slice position
+attributes.
<p>
-This panel controls how loaded volumes are drawn. Volume can be drawn
-in two different modes: <b>isosurface</b> or <b>slice</b>. The top
-part of the panel has drawing style options. The middle part has
-controls to add, delete, move up/down selected isosurface or
-slices. The bottom part has options to set, unset or modify attributes
-of the current isosurface or slice.
+Volumes can be moved the same way like surfaces do.
<center>
<br><img src="wxGUI_nviz_tools_volume.jpg" border="1"><br><br>
</center>
-Similarly to surface panel you can define draw <b>shading</b>
-- <em>gouraud</em> (draws the volumes with a smooth shading to blend
-individual cell colors together) and <em>flat</em> (draws the volumes
-with flat shading with one color for every two cells. The volume
-appears faceted). As mentioned above currently are supported two
-visualization modes:
+<h3>Analysis</h3>
+<em>Analysis</em> tab contains <em>Cutting planes</em> panel.
+<h4>Cutting planes</h4>
+Cutting planes allow to cut surfaces along a plane. You can switch
+between six planes; to disable cutting planes switch to <em>None</em>.
+Initially the plane is vertical, you can change it to horizontal by setting
+<em>tilt</em> 90 degrees. The <em>X</em> and <em>Y</em> values specify
+the rotation center of plane. You can see better what <em>X</em> and <em>Y</em>
+do when changing <em>rotation</em>.
+<em>Height</em> parameter has sense only when changing
+<em>tilt</em> too. Press button <em>Reset</em> to reset current cutting plane.
+<p>
+In case of multiple surfaces you can visualize the cutting plane by
+<em>Shading</em>. Shading is visible only when more than one surface
+is loaded and these surfaces must have the same fine resolution set.
+<h3>Appearance</h3>
+Appearance tab consists of three collapsible panels:
<ul>
- <li><b>isosurface</b> - the levels of values for drawing the
- volume(s) as isosurfaces,</li>
- <li>and <b>slice</b> - the levels of values for drawing the volume
- as cross-sections.</li>
+ <li><em>Lighting</em> for adjusting light source</li>
+ <li><em>Fringe</em> for drawing fringes
+ <li><em>Decorations</em> to display north arrow and scale bar</li>
</ul>
+<p>
+The <em>lighting</em> panel enables to change the position of light
+source, light color, brightness and ambient. Light position is controlled
+similarly to eye position. If option <em>Show light model</em> is enabled
+light model is displayed to visualize the light settings.
+<center>
+ <br><img src="wxGUI_nviz_tools_light.jpg" border="1"><br><br>
+</center>
+<p>
+The <em>Fringe</em> panel allows to draw fringes in different directions
+(North & East, South & East, South & West, North & West). It is possible
+to set fringe color and height of the bottom edge.
+<p>
+The <em>Decorations</em> panel enables to display north arrow and simple
+scale bar. North arrow and scale bar length is determined in map units.
+You can display more than one scale bar.
<h2>Settings</h2>
This panel has controls which allows user to set default surface,
@@ -278,13 +357,9 @@
<ul>
<li>Improve intuitive navigation (mouse, fly mode)</li>
<li>Animation capabilities</li>
- <li>Arbitrary cutting planes</li>
<li>Labels, decoration, etc.</li>
- <li>Scripting capabilities</li>
- <li>Better workspace support (view settings, lighting)
<li>Surface - mask by zero/elevation, more interactive positioning</li>
<li>Vector points - implement display mode flat/surface for 2D points</li>
- <li>Volume - slice draw mode</li>
<li>...</li>
</ul>
Added: grass/trunk/gui/wxpython/docs/wxGUI_nviz_tools_light.jpg
(Binary files differ)
Property changes on: grass/trunk/gui/wxpython/docs/wxGUI_nviz_tools_light.jpg
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: grass/trunk/gui/wxpython/docs/wxGUI_nviz_tools_surface.jpg
Modified: grass/trunk/gui/wxpython/docs/wxGUI_nviz_tools_vector.jpg
Modified: grass/trunk/gui/wxpython/docs/wxGUI_nviz_tools_view.jpg
Modified: grass/trunk/gui/wxpython/docs/wxGUI_nviz_tools_volume.jpg
