[GRASS-SVN] r47652 - in grass/branches/develbranch_6: lib/gpde
raster/r.univar2
svn_grass at osgeo.org
Mon Aug 15 12:33:59 EDT 2011
Author: neteler
Date: 2011-08-15 09:33:59 -0700 (Mon, 15 Aug 2011)
New Revision: 47652
grass/branches/develbranch_6/lib/gpde/N_arrays_io.c
grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c
msg standardization
Modified: grass/branches/develbranch_6/lib/gpde/N_arrays_io.c
--- grass/branches/develbranch_6/lib/gpde/N_arrays_io.c 2011-08-15 16:26:45 UTC (rev 47651)
+++ grass/branches/develbranch_6/lib/gpde/N_arrays_io.c 2011-08-15 16:33:59 UTC (rev 47652)
@@ -16,9 +16,10 @@
+#include <math.h>
#include "grass/N_pde.h"
#include "grass/glocale.h"
-#include <math.h>
/* ******************** 2D ARRAY FUNCTIONS *********************** */
@@ -292,7 +293,7 @@
if (NULL == G_find_grid3(name, ""))
- G3d_fatalError(_("Requested g3d map <%s> not found"), name);
+ G3d_fatalError(_("3D raster map <%s> not found"), name);
/*Open all maps with default region */
map =
@@ -300,7 +301,7 @@
G3D_TILE_SAME_AS_FILE, G3D_USE_CACHE_DEFAULT);
if (map == NULL)
- G3d_fatalError(_("Error opening g3d map <%s>"), name);
+ G3d_fatalError(_("Unable to open 3D raster map <%s>"), name);
type = G3d_tileTypeMap(map);
Modified: grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c
--- grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c 2011-08-15 16:26:45 UTC (rev 47651)
+++ grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c 2011-08-15 16:33:59 UTC (rev 47652)
@@ -144,23 +144,23 @@
/* open 3D zoning raster with default region */
if ((zonemap = param.zonefile->answer) != NULL) {
if (NULL == (mapset = G_find_grid3(zonemap, "")))
- G3d_fatalError(_("Requested g3d map <%s> not found"), zonemap);
+ G3d_fatalError(_("3D raster map <%s> not found"), zonemap);
zmap =
G3d_openCellOld(zonemap, G_find_grid3(zonemap, ""), ®ion,
if (zmap == NULL)
- G3d_fatalError(_("Error opening g3d map <%s>"), zonemap);
+ G3d_fatalError(_("Unable to open 3D raster map <%s>"), zonemap);
zmap_type = G3d_tileTypeMap(zmap);
if (G3d_readCats(zonemap, mapset, &(zone_info.cats)))
- G_warning("no category support for zoning raster");
+ G_warning("No category support for zoning raster");
G3d_range_init(zmap);
if (!G3d_range_load(zmap))
- G_fatal_error(_("Unable it load G3d range"));
+ G_fatal_error(_("Unable to load 3D raster range"));
G3d_range_min_max(zmap, &dmin, &dmax);
/* properly round dmin and dmax */
@@ -183,14 +183,14 @@
infile = param.inputfile->answer;
if (NULL == G_find_grid3(infile, ""))
- G3d_fatalError(_("Requested g3d map <%s> not found"), infile);
+ G3d_fatalError(_("3D raster map <%s> not found"), infile);
map =
G3d_openCellOld(infile, G_find_grid3(infile, ""), ®ion,
if (map == NULL)
- G3d_fatalError(_("Error opening g3d map <%s>"), infile);
+ G3d_fatalError(_("Unable to open 3D raster map <%s>"), infile);
map_type = G3d_tileTypeMap(map);
