[GRASS-SVN] r47653 - in grass/branches/releasebranch_6_4: lib/gpde
	raster/r.univar2
    svn_grass at osgeo.org
    Mon Aug 15 12:34:07 EDT 2011
Author: neteler
Date: 2011-08-15 09:34:07 -0700 (Mon, 15 Aug 2011)
New Revision: 47653
   grass/branches/releasebranch_6_4/lib/gpde/N_arrays_io.c
   grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c
msg standardization
Modified: grass/branches/releasebranch_6_4/lib/gpde/N_arrays_io.c
--- grass/branches/releasebranch_6_4/lib/gpde/N_arrays_io.c	2011-08-15 16:33:59 UTC (rev 47652)
+++ grass/branches/releasebranch_6_4/lib/gpde/N_arrays_io.c	2011-08-15 16:34:07 UTC (rev 47653)
@@ -16,9 +16,10 @@
+#include <math.h>
 #include "grass/N_pde.h"
 #include "grass/glocale.h"
-#include <math.h>
 /* ******************** 2D ARRAY FUNCTIONS *********************** */
@@ -292,7 +293,7 @@
     if (NULL == G_find_grid3(name, ""))
-	G3d_fatalError(_("Requested g3d map <%s> not found"), name);
+	G3d_fatalError(_("3D raster map <%s> not found"), name);
     /*Open all maps with default region */
     map =
@@ -300,7 +301,7 @@
 			G3D_TILE_SAME_AS_FILE, G3D_USE_CACHE_DEFAULT);
     if (map == NULL)
-	G3d_fatalError(_("Error opening g3d map <%s>"), name);
+	G3d_fatalError(_("Unable to open 3D raster map <%s>"), name);
     type = G3d_tileTypeMap(map);
Modified: grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c
--- grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c	2011-08-15 16:33:59 UTC (rev 47652)
+++ grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c	2011-08-15 16:34:07 UTC (rev 47653)
@@ -144,23 +144,23 @@
     /* open 3D zoning raster with default region */
     if ((zonemap = param.zonefile->answer) != NULL) {
 	if (NULL == (mapset = G_find_grid3(zonemap, "")))
-	    G3d_fatalError(_("Requested g3d map <%s> not found"), zonemap);
+	    G3d_fatalError(_("3D raster map <%s> not found"), zonemap);
 	zmap =
 	    G3d_openCellOld(zonemap, G_find_grid3(zonemap, ""), ®ion,
 	if (zmap == NULL)
-	    G3d_fatalError(_("Error opening g3d map <%s>"), zonemap);
+	    G3d_fatalError(_("Unable to open 3D raster map <%s>"), zonemap);
 	zmap_type = G3d_tileTypeMap(zmap);
 	if (G3d_readCats(zonemap, mapset, &(zone_info.cats)))
-	    G_warning("no category support for zoning raster");
+	    G_warning("No category support for zoning raster");
 	G3d_range_init(zmap);
 	if (!G3d_range_load(zmap))
-	    G_fatal_error(_("Unable it load G3d range"));
+	    G_fatal_error(_("Unable to load 3D raster range"));
 	G3d_range_min_max(zmap, &dmin, &dmax);
 	/* properly round dmin and dmax */
@@ -183,14 +183,14 @@
     infile = param.inputfile->answer;
     if (NULL == G_find_grid3(infile, ""))
-	G3d_fatalError(_("Requested g3d map <%s> not found"), infile);
+	G3d_fatalError(_("3D raster map <%s> not found"), infile);
     map =
 	G3d_openCellOld(infile, G_find_grid3(infile, ""), ®ion,
     if (map == NULL)
-	G3d_fatalError(_("Error opening g3d map <%s>"), infile);
+	G3d_fatalError(_("Unable to open 3D raster map <%s>"), infile);
     map_type = G3d_tileTypeMap(map);
