[GRASS-SVN] r47654 - grass/trunk/lib/raster
svn_grass at osgeo.org
Mon Aug 15 13:50:23 EDT 2011
Author: martinl
Date: 2011-08-15 10:50:23 -0700 (Mon, 15 Aug 2011)
New Revision: 47654
grass/trunk/lib/raster/color_rules.c
rasterlib: add doxygen documentation for color_rules.c
Modified: grass/trunk/lib/raster/color_rules.c
--- grass/trunk/lib/raster/color_rules.c 2011-08-15 16:34:07 UTC (rev 47653)
+++ grass/trunk/lib/raster/color_rules.c 2011-08-15 17:50:23 UTC (rev 47654)
@@ -1,25 +1,17 @@
+ \file lib/raster/color_read.c
+ \brief Raster Library - Read and parse color rules file
+ (C) 2007 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ \author Glynn Clements
- * MODULE: gis library
- * AUTHOR(S): Glynn Clements <glynn at gclements.plus.com>
- * COPYRIGHT: (C) 2007 Glynn Clements and the GRASS Development Team
- * NOTE: Based upon r.colors/rules.c
- * The colors are stored in ./colors/
- * This program is free software; you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation; either version 2 of the License, or
- * (at your option) any later version.
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
#include <stdio.h>
#include <grass/gis.h>
@@ -43,6 +35,20 @@
CR_ERROR_VALUE,
+ \brief Read color rule
+ \param min, max min & max values (used only when color rules are in percentage)
+ \param buf
+ \param val value
+ \param[out] r,g,b color values
+ \param norm
+ \param nval
+ \param dflt
+ \return 0 on failure
+ \return 1 on success
int Rast_parse_color_rule(DCELL min, DCELL max, const char *buf,
DCELL * val, int *r, int *g, int *b,
int *norm, int *nval, int *dflt)
@@ -103,6 +109,13 @@
return CR_ERROR_VALUE;
+ \brief Parse color rule
+ \param code
+ \return pointer to buffer with error message
const char *Rast_parse_color_rule_error(int code)
switch (code) {
@@ -123,6 +136,20 @@
+ \param closure
+ \param val value
+ \param norm
+ \param nval
+ \param dflt
int Rast_read_color_rule(void *closure, DCELL min, DCELL max,
@@ -158,6 +185,17 @@
return 0;
+ \brief Read color rules from file
+ \param[out] colors pointer to Colors structure
+ \param read_rule pointer to read_rule_fn structure
+ \param closure
int Rast_read_color_rules(struct Colors *colors, DCELL min, DCELL max,
read_rule_fn * read_rule, void *closure)
@@ -245,12 +283,32 @@
return ret;
+ \brief Load color rules from file
+ \param path path to the color rules file
int Rast_load_colors(struct Colors *colors, const char *path, CELL min,
CELL max)
return load_rules_file(colors, path, (DCELL) min, (DCELL) max);
+ \brief Load color floating-point rules from file
int Rast_load_fp_colors(struct Colors *colors, const char *path, DCELL min,
DCELL max)
@@ -268,12 +326,26 @@
G_fatal_error(_("Unable to load color rules <%s>"), name);
+ \brief Load color rules from predefined color table
+ \param name name of color table to load
void Rast_make_colors(struct Colors *colors, const char *name, CELL min,
CELL max)
return load_rules_name(colors, name, (DCELL) min, (DCELL) max);
+ \brief Load color rules from predefined floating-point color table
void Rast_make_fp_colors(struct Colors *colors, const char *name, DCELL min,
DCELL max)
