[GRASS-SVN] r47655 - grass/trunk/vector/v.colors
Mon Aug 15 15:18:07 EDT 2011
Author: martinl
Date: 2011-08-15 12:18:07 -0700 (Mon, 15 Aug 2011)
New Revision: 47655
   grass/trunk/vector/v.colors/local_proto.h
   grass/trunk/vector/v.colors/main.c
   grass/trunk/vector/v.colors/make_colors.c
   grass/trunk/vector/v.colors/scan_attr.c
   grass/trunk/vector/v.colors/scan_cats.c
v.colors: fix rules to produce cat-based color tables
Modified: grass/trunk/vector/v.colors/local_proto.h
--- grass/trunk/vector/v.colors/local_proto.h	2011-08-15 17:50:23 UTC (rev 47654)
+++ grass/trunk/vector/v.colors/local_proto.h	2011-08-15 19:18:07 UTC (rev 47655)
@@ -1,13 +1,15 @@
 /* make_colors.c */
 void make_colors(struct Colors *, const char *, DCELL, DCELL, int);
+void load_colors(struct Colors *, const char *, DCELL, DCELL, int);
 /* scan_attr.c */
 int scan_attr(const struct Map_info *, int, const char *, const char *,
-	      const struct FPRange *, struct Colors *, int *, int *);
+	      const char *, const struct FPRange *, struct Colors *);
 /* scan_cats.c */
-void scan_cats(const struct Map_info *, int, const char *,
+void scan_cats(const struct Map_info *, int, const char *, const char *,
+	       const struct FPRange *, struct Colors *);
 /* write_rgb.c */
 void write_rgb_values(const struct Map_info *, int, const char *,
Modified: grass/trunk/vector/v.colors/main.c
--- grass/trunk/vector/v.colors/main.c	2011-08-15 17:50:23 UTC (rev 47654)
+++ grass/trunk/vector/v.colors/main.c	2011-08-15 19:18:07 UTC (rev 47655)
@@ -37,7 +37,7 @@
 	    *attrcol, *rgbcol, *range;
     } opt;
-    int layer, cmin, cmax;
+    int layer;
     int have_stats;
     int overwrite, remove, is_from_stdin, stat, have_colors;
     const char *mapset, *cmapset;
@@ -70,7 +70,8 @@
     opt.range->key = "range";
     opt.range->type = TYPE_DOUBLE;
     opt.range->required = NO;
-    opt.range->description = _("Manually set range (refers to 'column' option)");
+    opt.range->label = _("Manually set range (refers to 'column' option)");
+    opt.range->description = _("Ignored when 'rules' given");
     opt.range->key_desc = "min,max";
     opt.colr = G_define_standard_option(G_OPT_M_COLR);
@@ -233,23 +234,21 @@
         if (!read_color_rules(stdin, &colors, min, max, fp))
             exit(EXIT_FAILURE);
-    } else if (style) {
-	if (!G_find_color_rule(style))
+    } else if (style || rules) {
+	if (style && !G_find_color_rule(style))
 	    G_fatal_error(_("Color table <%s> not found"), style);
 	if (!attrcolumn) {
-	    scan_cats(&Map, layer, style, opt.range->answer ? &range : NULL,
-		      &colors, &cmin, &cmax);
+	    scan_cats(&Map, layer, style, rules,
+		      opt.range->answer ? &range : NULL,
+		      &colors);
 	else {
-	    scan_attr(&Map, layer, attrcolumn, style, opt.range->answer ? &range : NULL,
+	    scan_attr(&Map, layer, attrcolumn, style, rules,
+		      &colors);
-    else if (rules) {
-	if (!Rast_load_colors(&colors, rules, (CELL) cmin, (CELL) cmax))
-	    G_fatal_error(_("Unable to load rules file <%s>"), rules);
     else {
 	/* use color from another map (cmap) */
 	if (opt.rast->answer) {
Modified: grass/trunk/vector/v.colors/make_colors.c
--- grass/trunk/vector/v.colors/make_colors.c	2011-08-15 17:50:23 UTC (rev 47654)
+++ grass/trunk/vector/v.colors/make_colors.c	2011-08-15 19:18:07 UTC (rev 47655)
@@ -37,3 +37,16 @@
 	    Rast_make_colors(colors, style, (CELL) min, (CELL) max);
+void load_colors(struct Colors *colors, const char *rules, DCELL min, DCELL max, int is_fp)
+    int ret;
+    if (is_fp)
+	ret = Rast_load_fp_colors(colors, rules, (DCELL) min, (DCELL) max);
+    else
+	ret = Rast_load_colors(colors, rules, (CELL) min, (CELL) max);
+    if (ret == 0)
+	G_fatal_error(_("Unable to load rules file <%s>"), rules);
Modified: grass/trunk/vector/v.colors/scan_attr.c
--- grass/trunk/vector/v.colors/scan_attr.c	2011-08-15 17:50:23 UTC (rev 47654)
+++ grass/trunk/vector/v.colors/scan_attr.c	2011-08-15 19:18:07 UTC (rev 47655)
@@ -6,8 +6,8 @@
 #include "local_proto.h"
 int scan_attr(const struct Map_info *Map, int layer, const char *column_name,
-	      const char *style, const struct FPRange *range,
-	      struct Colors *colors, int *cmin, int *cmax)
+	      const char *style, const char *rules,
+	      const struct FPRange *range, struct Colors *colors)
     int ctype, is_fp, nrec, i, cat;
     int red, grn, blu;
@@ -19,9 +19,7 @@
     dbCatVal *cv;
     dbCatValArray cvarr;
-    *cmin = *cmax = -1;
     Rast_init_colors(colors);
-    Rast_init_colors(&vcolors);
     fi = Vect_get_field(Map, layer);
     if (!fi)
@@ -87,7 +85,10 @@
 			  (int) range->max, (int) fmin, (int) fmax);
-    make_colors(&vcolors, style, (DCELL) fmin, (DCELL) fmax, is_fp);
+    if (style)
+	make_colors(&vcolors, style, (DCELL) fmin, (DCELL) fmax, is_fp);
+    else if (rules)
+	load_colors(&vcolors, rules, (DCELL) fmin, (DCELL) fmax, is_fp);
     /* color table for categories */
     for (i = 0; i < cvarr.n_values; i++) {
@@ -113,16 +114,6 @@
 		cat, is_fp ? cv->val.d : cv->val.i, red, grn, blu);
 	Rast_add_c_color_rule((const CELL*) &cat, red, grn, blu,
 			      (const CELL*) &cat, red, grn, blu, colors);
-	if (i == 0) {
-	    *cmin = *cmax = cat;
-	else {
-	    if (cat <= *cmin)
-		*cmin = cat;
-	    if (cat >= *cmax)
-		*cmax = cat;
     db_close_database(driver);
Modified: grass/trunk/vector/v.colors/scan_cats.c
--- grass/trunk/vector/v.colors/scan_cats.c	2011-08-15 17:50:23 UTC (rev 47654)
+++ grass/trunk/vector/v.colors/scan_cats.c	2011-08-15 19:18:07 UTC (rev 47655)
@@ -6,13 +6,14 @@
 static void scan_layer(int, const struct line_cats *, int *, int *);
-void scan_cats(const struct Map_info *Map, int field, const char *style,
-	       const struct FPRange *range, struct Colors *colors, int *cmin, int *cmax)
+void scan_cats(const struct Map_info *Map, int field,
-    int ltype, lmin, lmax;
+    int ltype, lmin, lmax, cmin, cmax;
     struct line_cats *Cats;
+    cmin = cmax = -1;
     Cats = Vect_new_cats_struct();
     G_message(_("Reading features..."));
@@ -25,28 +26,32 @@
 	scan_layer(field, Cats, &lmin, &lmax);
-	if (*cmin == -1 || lmin <= *cmin)
-	    *cmin = lmin;
-	if (*cmax == -1 || lmax >= *cmax)
-	    *cmax = lmax;
+	if (cmin == -1 || lmin <= cmin)
+	    cmin = lmin;
+	if (cmax == -1 || lmax >= cmax)
+	    cmax = lmax;
     if (range) {
-	if (range->min >= *cmin && range->min <= *cmax)
-	    *cmin = range->min;
+	if (range->min >= cmin && range->min <= cmax)
+	    cmin = range->min;
 	else
 	    G_warning(_("Min value (%d) is out of range %d,%d"),
-		      (int) range->min, *cmin, *cmax);
+		      (int) range->min, cmin, cmax);
-	if (range->max <= *cmax && range->max >= *cmin)
-	    *cmax = range->max;
+	if (range->max <= cmax && range->max >= cmin)
+	    cmax = range->max;
 	else
 	    G_warning(_("Max value (%d) is out of range %d,%d"),
-		      (int) range->max, *cmin, *cmax);
+		      (int) range->max, cmin, cmax);
-    make_colors(colors, style, (DCELL) *cmin, (DCELL) *cmax, FALSE);
+    if (style)
+	make_colors(colors, style, (DCELL) cmin, (DCELL) cmax, FALSE);
+    else if (rules) {
+	load_colors(colors, rules, (DCELL) cmin, (DCELL) cmax, FALSE);
     Vect_destroy_cats_struct(Cats);
