[GRASS-SVN] r47706 - in grass/trunk: locale/po raster/r.out.arc
    svn_grass at osgeo.org
    Wed Aug 17 09:20:56 EDT 2011
Author: neteler
Date: 2011-08-17 06:20:56 -0700 (Wed, 17 Aug 2011)
New Revision: 47706
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_hi.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_mr.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
   grass/trunk/raster/r.out.arc/main.c
parser simplification; typo
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_ar.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -32031,7 +32031,7 @@
 msgstr "اسÙ
 اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù اÙÙ
ÙØ¬Ùد"
 #: ../raster/r.out.arc/main.c:79
-msgid "Name of an output ARC-GID map (use out=- for stdout)"
+msgid "Name of an output ARC-GRID map (use out=- for stdout)"
 msgstr "اسÙ
 اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù Ø§ÙØ¬Ø¯Ùد"
 #: ../raster/r.out.arc/main.c:86
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_cs.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -32307,7 +32307,7 @@
 msgstr "Název existujícího rastru"
 msgstr ""
 "Název výstupního ARC-GRID souboru (pro standardní výstup pou¾ijte out=-)"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_de.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -32653,7 +32653,7 @@
 msgstr "Name einer existierenden Rasterkarte."
 msgstr "Name der Ausgabe ARCGRID-Datei (verwende out=- für stdout)"
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_el.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -30459,7 +30459,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_es.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -32574,8 +32574,8 @@
 msgstr "Nombre de una capa de mapa ráster existente"
-msgstr "Nombre de un mapa ARC-GID de salida (usar out=- para stdout)"
+msgstr "Nombre de un mapa ARC-GRID de salida (usar out=- para stdout)"
 msgid "Number of decimal places"
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_fr.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -34414,7 +34414,7 @@
 msgstr "Nom de la couche raster existante"
 msgstr "Nom de la couche ARC-GRID à créer (utiliser out=- pour stdout)"
Modified: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_hi.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -32511,7 +32511,7 @@
 #, fuzzy
 msgstr "à¤à¤¾ à¤à¥ लिà¤"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_it.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -31667,8 +31667,8 @@
 msgstr "Nome di una mappa raster esistente"
-msgstr "Nome di output di una mappa ARC-GID (usa out=- per lo standard output)"
+msgstr "Nome di output di una mappa ARC-GRID (usa out=- per lo standard output)"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_ja.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -31710,8 +31710,8 @@
 msgstr "æ¢åã®ã©ã¹ã¿ã¼ããã ã¬ã¤ã¤ã¼å"
-msgstr "åºåãã ARC-GID ãããå ï¼æ¨æºåºåã«ã¯ out= - ã使ç¨ããï¼"
+msgstr "åºåãã ARC-GRID ãããå ï¼æ¨æºåºåã«ã¯ out= - ã使ç¨ããï¼"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_ko.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -30793,7 +30793,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_lv.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -31886,7 +31886,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_mr.po
--- grass/trunk/locale/po/grassmods_mr.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_mr.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -31025,7 +31025,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_pl.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -31897,8 +31897,8 @@
 msgstr "Nazwa istniejÄ
cej warstwy mapy rastrowej"
-msgstr "Nazwa wyjÅciowej mapy ARC-GID (use out=- for stdout)"
+msgstr "Nazwa wyjÅciowej mapy ARC-GRID (use out=- for stdout)"
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_pt.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -33190,8 +33190,8 @@
 msgstr "Nome da camada raster existente"
-msgstr "Nome do mapa ARC-GID de saída (use 'out=-' para saída padrão)"
+msgstr "Nome do mapa ARC-GRID de saída (use 'out=-' para saída padrão)"
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -33088,8 +33088,8 @@
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_ru.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -32440,9 +32440,9 @@
 msgstr "ÐÐ¼Ñ ÑÑÑеÑÑвÑÑÑего ÑаÑÑÑового ÑлоÑ"
 msgstr ""
-"ÐÐ¼Ñ Ð²ÑÑ
одного ÑÐ»Ð¾Ñ ARC-GID (иÑполÑзÑйÑе out=- Ð´Ð»Ñ stdout (ÑÑандаÑÑного "
+"ÐÐ¼Ñ Ð²ÑÑ
одного ÑÐ»Ð¾Ñ ARC-GRID (иÑполÑзÑйÑе out=- Ð´Ð»Ñ stdout (ÑÑандаÑÑного "
 "вÑвода))"
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_sl.po	2011-08-17 13:20:56 UTC (rev 47706)
 msgstr "Ime obstojeèega rastrskega sloja"
 msgstr ""
 "Ime izhodne ARC-GRID datoteke (uporabi out=- za standardni izhod (stdout))"
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_th.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -31993,8 +31993,8 @@
 msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¸à¸±à¹à¸à¸à¹à¸à¸¡à¸¹à¸¥à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ à¸²à¸ à¸à¸µà¹à¸¡à¸µà¸à¸¢à¸¹à¹"
-msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹à¸à¸¥à¸¥à¸±à¸à¸à¹  ARC-GID (à¹à¸à¹ out=- สำหรัภstdout)"
+msgstr "à¸à¸·à¹à¸à¸à¸à¸ à¹à¸à¸à¸à¸µà¹à¸à¸¥à¸¥à¸±à¸à¸à¹  ARC-GRID (à¹à¸à¹ out=- สำหรัภstdout)"
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_tr.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -31174,7 +31174,7 @@
 msgstr "Mevcut bir raster harita katmanı adı"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_vi.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -32429,8 +32429,8 @@
 msgstr "Tên lá»p bản Äá» raster hiá»n có"
-msgstr "Tên bản Äá» ARC-GID Äầu ra (dùng out=- cho Äầu ra tiêu chuẩn)"
+msgstr "Tên bản Äá» ARC-GRID Äầu ra (dùng out=- cho Äầu ra tiêu chuẩn)"
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/locale/po/grassmods_zh.po	2011-08-17 13:20:56 UTC (rev 47706)
@@ -32196,7 +32196,7 @@
 msgstr "å·²ææ
æ ¼å¾å±çåç§°"
 msgstr "è¾åºçGRIDçåç§°(out=-ç¨äºæ åè¾åº)"
Modified: grass/trunk/raster/r.out.arc/main.c
--- grass/trunk/raster/r.out.arc/main.c	2011-08-17 13:19:57 UTC (rev 47705)
+++ grass/trunk/raster/r.out.arc/main.c	2011-08-17 13:20:56 UTC (rev 47706)
@@ -63,20 +63,12 @@
 	_("Converts a raster map layer into an ESRI ARCGRID file.");
     /* Define the different options */
-    parm.map = G_define_option();
-    parm.map->key = "input";
-    parm.map->type = TYPE_STRING;
-    parm.map->required = YES;
-    parm.map->gisprompt = "old,cell,raster";
-    parm.map->description = _("Name of an existing raster map layer");
+    parm.map = G_define_standard_option(G_OPT_R_INPUT);
-    parm.output = G_define_option();
-    parm.output->key = "output";
-    parm.output->type = TYPE_STRING;
-    parm.output->required = YES;
+    parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
     parm.output->gisprompt = "new_file,file,output";
     parm.output->description =
-	_("Name of an output ARC-GID map (use out=- for stdout)");
+	_("Name of an output ARC-GRID map (use out=- for stdout)");
     parm.dp = G_define_option();
     parm.dp->key = "dp";
