[GRASS-SVN] r47707 - grass/trunk/ps/ps.map
svn_grass at osgeo.org
Wed Aug 17 09:31:44 EDT 2011
Author: hamish
Date: 2011-08-17 06:31:44 -0700 (Wed, 17 Aug 2011)
New Revision: 47707
grass/trunk/ps/ps.map/ps.map.html
grass/trunk/ps/ps.map/r_instructions.c
full RGB support for the setcolor instruction (#192) & document hidden setcolor functionality; i18n
Modified: grass/trunk/ps/ps.map/ps.map.html
--- grass/trunk/ps/ps.map/ps.map.html 2011-08-17 13:20:56 UTC (rev 47706)
+++ grass/trunk/ps/ps.map/ps.map.html 2011-08-17 13:31:44 UTC (rev 47707)
@@ -1160,11 +1160,12 @@
<B>setcolor</B> 2,5,8 white
<B>setcolor</B> 10 green
</PRE>
-Of course,
-<EM>setcolor</EM>
+Of course, <EM>setcolor</EM>
can be requested more than once to override the default color for additional
categories. More than one category can be changed for each request by listing
-all the category values separated by commas (but with no spaces).
+all the category values separated by commas (but with no spaces). Also ranges
+can be included, for example "1,2,6-10,12". Colors for "<tt>null</tt>" and the
+"<tt>default</tt>" (i.e. out-of-range) color may also be reassigned.
<P>
Modified: grass/trunk/ps/ps.map/r_instructions.c
--- grass/trunk/ps/ps.map/r_instructions.c 2011-08-17 13:20:56 UTC (rev 47706)
+++ grass/trunk/ps/ps.map/r_instructions.c 2011-08-17 13:31:44 UTC (rev 47707)
@@ -3,7 +3,6 @@
#include <grass/colors.h>
#include <grass/imagery.h>
#include <grass/glocale.h>
#include "local_proto.h"
#define KEY(x) (strcmp(key,x)==0)
@@ -60,11 +59,11 @@
fclose(inputfd);
if (sscanf(data, "%s", name) != 1) {
- error(key, data, "no file specified");
+ error(key, data, _("no file specified"));
inputfd = stdin;
else if ((inputfd = fopen(name, "r")) == NULL) {
- error(key, data, "unable to open");
+ error(key, data, _("unable to open"));
inputfd = stdin;
else
@@ -95,7 +94,7 @@
else {
- error(key, data, "illegal maploc request");
+ error(key, data, _("illegal maploc request"));
gobble_input();
continue;
@@ -109,36 +108,27 @@
n = sscanf(data, "%d", &copies);
if (n != 1 || copies < 1 || copies > 20) {
ps_copies = 1;
- error(key, data, "illegal copies request");
+ error(key, data, _("illegal copies request"));
ps_copies = copies;
continue;
if (KEY("setcolor")) {
- float R, G, B;
- int r, g, b;
- int color;
+ int ret, r, g, b;
int count;
DCELL *val_list;
DCELL dmin, dmax;
char colorbuf[100];
char catsbuf[100];
- if (PS->cell_fd < 0) {
- error(key, data, "no raster map selected yet");
- continue;
+ if (PS->cell_fd < 0)
+ error(key, data, _("no raster map selected yet"));
if (sscanf(data, "%s %[^\n]", catsbuf, colorbuf) == 2) {
- color = get_color_number(colorbuf);
- if (color < 0) {
- error(key, data, "illegal color");
- continue;
- get_color_rgb(color, &R, &G, &B);
- r = 255.0 * R;
- g = 255.0 * G;
- b = 255.0 * B;
+ ret = G_str_to_color(colorbuf, &r, &g, &b);
+ if (ret != 1)
+ error(key, colorbuf, _("illegal color request"));
if (strncmp(catsbuf, "null", 4) == 0) {
Rast_set_null_value_color(r, g, b, &(PS->colors));
@@ -148,10 +138,9 @@
Rast_set_default_color(r, g, b, &(PS->colors));
continue;
- if ((count = parse_val_list(catsbuf, &val_list)) < 0) {
- error(key, data, "illegal value list");
- continue;
+ if ((count = parse_val_list(catsbuf, &val_list)) < 0)
+ error(key, data, _("illegal value list"));
for (i = 0; i < count; i += 2) {
dmin = val_list[i];
dmax = val_list[i + 1];
@@ -186,7 +175,7 @@
if (KEY("scalebar")) {
if (G_projection() == PROJECTION_LL) {
error(key, data,
- "scalebar is not appropriate for this projection");
+ _("scalebar is not appropriate for this projection"));
gobble_input();
PS->do_scalebar = 1;
@@ -194,7 +183,7 @@
strcpy(sb->type, "f"); /* default to fancy scalebar */
read_scalebar();
if (sb->length <= 0.) {
- error(key, data, "Bad scalebar length");
+ error(key, data, _("Bad scalebar length"));
gobble_input();
continue;
@@ -210,7 +199,7 @@
read_text(east, north, text);
else {
gobble_input();
- error(key, data, "illegal text request");
+ error(key, data, _("illegal text request"));
continue;
@@ -224,7 +213,7 @@
read_point(e, n);
else {
gobble_input();
- error(key, data, "illegal point request");
+ error(key, data, _("illegal point request"));
continue;
@@ -238,7 +227,7 @@
read_eps(e, n);
else {
gobble_input();
- error(key, data, "illegal eps request");
+ error(key, data, _("illegal eps request"));
continue;
@@ -255,7 +244,7 @@
read_line(e1, n1, e2, n2);
else {
gobble_input();
- error(key, data, "illegal line request");
+ error(key, data, _("illegal line request"));
continue;
@@ -272,7 +261,7 @@
read_rectangle(e1, n1, e2, n2);
else {
gobble_input();
- error(key, data, "illegal rectangle request");
+ error(key, data, _("illegal rectangle request"));
continue;
@@ -283,7 +272,7 @@
read_comment(name);
break;
case 2:
- error(key, data, "illegal comments request");
+ error(key, data, _("illegal comments request"));
break;
default:
read_comment("");
@@ -299,7 +288,7 @@
strcpy(PS->scaletext, data);
else {
PS->scaletext[0] = 0;
- error(key, data, "illegal scale request");
+ error(key, data, _("illegal scale request"));
continue;
@@ -330,7 +319,7 @@
if (KEY("outline")) {
gobble_input();
else
@@ -359,7 +348,7 @@
read_group();
else
- error(key, data, "group not found");
+ error(key, data, _("group not found"));
continue;
@@ -401,7 +390,7 @@
sscanf(data, "%d", &(PS->grid));
if (PS->grid < 0) {
PS->grid = 0;
- error(key, data, "illegal grid spacing");
+ error(key, data, _("illegal grid spacing"));
gobble_input();
else
@@ -412,7 +401,7 @@
if (KEY("geogrid")) {
if (G_projection() == PROJECTION_XY) {
error(key, data,
- "geogrid is not available for this projection");
+ _("geogrid is not available for this projection"));
gobble_input();
/* if (G_projection() == PROJECTION_LL)
@@ -422,7 +411,7 @@
sscanf(data, "%d %s", &(PS->geogrid), PS->geogridunit);
if (PS->geogrid < 0) {
PS->geogrid = 0;
- error(key, data, "illegal geo-grid spacing");
+ error(key, data, _("illegal geo-grid spacing"));
gobble_input();
else
@@ -454,11 +443,11 @@
continue;
else {
- error(key, data, "illegal color request");
+ error(key, data, _("illegal color request"));
if (*key)
- error(key, "", "illegal request");
+ error(key, "", _("illegal request"));
