[GRASS-SVN] r47739 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Aug 18 04:59:00 EDT 2011
Author: annakrat
Date: 2011-08-18 01:59:00 -0700 (Thu, 18 Aug 2011)
New Revision: 47739
grass/trunk/gui/wxpython/gui_modules/colorrules.py
wxGUI: vector rules: creating temporary columns fixed
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-17 22:29:12 UTC (rev 47738)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-18 08:59:00 UTC (rev 47739)
@@ -852,7 +852,7 @@
# vector attribute column to use for storing colors
'storeColumn' : '',
# vector attribute column for temporary storing colors
- 'tmpColumn' : ''
+ 'tmpColumn' : 'tmp_0'
self.columnsProp = {'color': {'name': 'GRASSRGB', 'type1': 'varchar(11)', 'type2': ['character']},
'size' : {'name': 'GRASSSIZE', 'type1': 'integer', 'type2': ['integer']},
@@ -1072,6 +1072,9 @@
def OnSelectionInput(self, event):
"""!Vector map selected"""
if event:
+ if self.inmap:
+ # switch to another map -> delete temporary column
+ self.DeleteTemporaryColumn()
self.inmap = event.GetString()
if self.inmap:
@@ -1123,9 +1126,9 @@
self.properties['table'] = self.dbInfo.layers[layer]['table']
if self.attributeType == 'color':
- self.AddTemporaryColumn(name = 'tmpColumn', type = 'varchar(20)')
+ self.AddTemporaryColumn(type = 'varchar(11)')
else:
- self.AddTemporaryColumn(name = 'tmpColumn', type = 'integer')
+ self.AddTemporaryColumn(type = 'integer')
# initialize column selection comboboxes
@@ -1140,22 +1143,31 @@
self.btnOK.Enable(enable)
self.btnApply.Enable(enable)
- def AddTemporaryColumn(self, name, type):
+ def AddTemporaryColumn(self, type):
"""!Add temporary column to not overwrite the original values,
- need to be deleted when closing dialog"""
+ need to be deleted when closing dialog and unloading map
+ @param type type of column (e.g. vachar(11))"""
+ # because more than one dialog with the same map can be opened we must test column name and
+ # create another one
+ while self.properties['tmpColumn'] in self.dbInfo.GetTableDesc(self.properties['table']).keys():
+ name, idx = self.properties['tmpColumn'].split('_')
+ idx = int(idx)
+ idx += 1
+ self.properties['tmpColumn'] = name + '_' + str(idx)
ret = gcmd.RunCommand('v.db.addcolumn',
map = self.inmap,
layer = self.properties['layer'],
- column = '%s %s' % (name, type))
- self.properties[name] = name
+ column = '%s %s' % (self.properties['tmpColumn'], type))
- def DeleteTemporaryColumn(self, name):
+ def DeleteTemporaryColumn(self):
"""!Delete temporary column"""
ret = gcmd.RunCommand('v.db.dropcolumn',
map = self.inmap,
- column = name)
+ column = self.properties['tmpColumn'])
def OnLayerSelection(self, event):
# reset choices in column selection comboboxes if layer changes
vlayer = int(self.layerSelect.GetStringSelection())
@@ -1476,13 +1488,13 @@
"""!Apply selected color table, close the dialog
and delete temporary column"""
if self.OnApply(event):
self.Destroy()
- self.DeleteTemporaryColumn(name = self.properties['tmpColumn'])
def OnCancel(self, event):
"""!Do not apply any changes and close the dialog"""
self.Destroy()
class ThematicVectorTable(VectorColorTable):
def __init__(self, parent, vectorType, **kwargs):
