[GRASS-SVN] r47740 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Aug 18 08:19:57 EDT 2011
Author: annakrat
Date: 2011-08-18 05:19:57 -0700 (Thu, 18 Aug 2011)
New Revision: 47740
grass/trunk/gui/wxpython/gui_modules/colorrules.py
wxGUI: vector color rules: fix label displaying range
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-18 08:59:00 UTC (rev 47739)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-18 12:19:57 UTC (rev 47740)
@@ -412,7 +412,7 @@
row = 0
# label with range
- self.cr_label = wx.StaticText(parent, id = wx.ID_ANY, label = '')
+ self.cr_label = wx.StaticText(parent, id = wx.ID_ANY)
bodySizer.Add(item = self.cr_label, pos = (row, 0), span = (1, 3),
flag = wx.ALL, border = 5)
row += 1
@@ -465,10 +465,8 @@
def OnCloseWindow(self, event):
"""!Window closed
- Also remove associated rendered images
- self.Map.Clean()
- self.Destroy()
+ self.OnCancel(event)
def OnApply(self, event):
"""!Apply selected color table
@@ -488,15 +486,19 @@
def OnOK(self, event):
"""!Apply selected color table and close the dialog"""
if self.OnApply(event):
- self.Destroy()
def OnCancel(self, event):
- """!Do not apply any changes and close the dialog"""
+ """!Do not apply any changes, remove associated
+ rendered images and close the dialog"""
+ self.Map.Clean()
self.Destroy()
def LoadTable(self, mapType = 'raster'):
- """!Load current color table (using `r.colors.out`)"""
+ """!Load current color table (using `r(v).colors.out`)
+ @param mapType map type (raster or vector)"""
self.rulesPanel.Clear()
if mapType == 'raster':
cmd = ['r.colors.out',
@@ -509,7 +511,7 @@
'map=%s' % self.inmap,
'rules=-']
- if self.properties['sourceColumn'] != 'cat':
+ if self.properties['sourceColumn'] and self.properties['sourceColumn'] != 'cat':
cmd.append('column=%s' % self.properties['sourceColumn'])
cmd = utils.CmdToTuple(cmd)
@@ -519,11 +521,11 @@
else:
self.OnPreview()
return
rulesNumber = len(ctable.splitlines())
self.rulesPanel.AddRules(rulesNumber)
- count = 0
+ minim = maxim = count = 0
for line in ctable.splitlines():
value, color = map(lambda x: x.strip(), line.split(' '))
self.rulesPanel.ruleslines[count]['value'] = value
@@ -533,10 +535,22 @@
for c in color.split(':'):
rgb.append(int(c))
self.rulesPanel.mainPanel.FindWindowById(count + 2000).SetColour(rgb)
+ # range
+ try:
+ if float(value) < minim:
+ minim = float(value)
+ if float(value) > maxim:
+ maxim = float(value)
+ except ValueError: # nv, default
+ pass
count += 1
+ if self.mapType == 'vector':
+ # raster min, max is known from r.info
+ self.properties['min'], self.properties['max'] = minim, maxim
+ self.SetRangeLabel()
self.OnPreview(tmp = True)
def CreateColorTable(self, force = False, mapType = 'raster'):
"""!Creates color table
@@ -852,7 +866,11 @@
# vector attribute column to use for storing colors
'storeColumn' : '',
# vector attribute column for temporary storing colors
- 'tmpColumn' : 'tmp_0'
+ 'tmpColumn' : 'tmp_0',
+ # min value of attribute column/vector color table
+ 'min': None,
+ # max value of attribute column/vector color table
+ 'max': None
self.columnsProp = {'color': {'name': 'GRASSRGB', 'type1': 'varchar(11)', 'type2': ['character']},
'size' : {'name': 'GRASSSIZE', 'type1': 'integer', 'type2': ['integer']},
@@ -865,7 +883,7 @@
self.Bind(wx.EVT_COMBOBOX, self.OnSourceColumnSelection, self.sourceColumn)
self.Bind(wx.EVT_COMBOBOX, self.OnFromColSelection, self.fromColumn)
self.Bind(wx.EVT_COMBOBOX, self.OnToColSelection, self.toColumn)
- self.Bind(wx.EVT_BUTTON, self.OnAddColumn, self.addColumn)
+ self.Bind(wx.EVT_BUTTON, self.OnAddColumn, self.addColumn)
self._initLayer()
if self.colorTable:
@@ -1113,6 +1131,8 @@
for combo in (self.layerSelect, self.sourceColumn, self.fromColumn, self.toColumn):
combo.SetValue("")
combo.Clear()
+ for prop in ('sourceColumn', 'loadColumn', 'storeColumn'):
+ self.properties[prop] = ''
self.EnableVectorAttributes(False)
else: # db connection exist
@@ -1243,16 +1263,13 @@
if self.colorTable:
ColorTable.LoadTable(self, mapType = 'vector')
else:
- self.LoadRulesFromColumn(sourceColumn = self.properties['sourceColumn'],
- loadColumn = self.properties['loadColumn'],
- rulesPanel = self.rulesPanel,
- type = self.attributeType)
+ self.LoadRulesFromColumn()
- def LoadRulesFromColumn(self, sourceColumn, loadColumn, rulesPanel, type):
+ def LoadRulesFromColumn(self):
"""!Load current column (GRASSRGB, size column)"""
- rulesPanel.Clear()
- if not sourceColumn:
+ self.rulesPanel.Clear()
+ if not self.properties['sourceColumn']:
self.preview.EraseMap()
return
@@ -1260,9 +1277,9 @@
parent = self)
wx.Yield()
- columns = sourceColumn
- if loadColumn:
- columns += ',' + loadColumn
+ columns = self.properties['sourceColumn']
+ if self.properties['loadColumn']:
+ columns += ',' + self.properties['loadColumn']
if self.inmap:
outFile = tempfile.NamedTemporaryFile(mode = 'w+b')
@@ -1280,9 +1297,6 @@
busy.Destroy()
return
-## if type == 'color':
-## ctype = self.dbInfo.GetTableDesc(self.properties['table'])\
-## [sourceColumn]['ctype']
outFile.seek(0)
i = 0
minim = maxim = 0.0
@@ -1291,55 +1305,60 @@
record = outFile.readline().replace('\n', '')
if not record:
break
- rulesPanel.ruleslines[i] = {}
+ self.rulesPanel.ruleslines[i] = {}
- if not loadColumn:
+ if not self.properties['loadColumn']:
col1 = record
col2 = None
else:
col1, col2 = record.split(sep)
-## if ctype not in (int, float):
-## col1 = "'" + col1 + "'"
-## else:
if float(col1) < minim:
minim = float(col1)
if float(col1) > maxim:
maxim = float(col1)
- rulesPanel.ruleslines[i]['value'] = col1
- rulesPanel.ruleslines[i][type] = col2
+ self.rulesPanel.ruleslines[i]['value'] = col1
+ self.rulesPanel.ruleslines[i][self.attributeType] = col2
i += 1
- rulesPanel.AddRules(i, start = True)
- ret = rulesPanel.LoadRules()
-## self.SetRangeLabel(type, ctype, minim, maxim)
+ self.rulesPanel.AddRules(i, start = True)
+ ret = self.rulesPanel.LoadRules()
if ret:
self.OnPreview()
else:
busy.Destroy()
- def SetRangeLabel(self, type, ctype, minim, maxim):
+ def SetRangeLabel(self):
"""!Set labels with info about attribute column range"""
- if type == 'color':
- if minim or maxim:
- if ctype == int:
- self.rgb_range_label.SetLabel(_("range: %.1f to %.1f") % (minim, maxim))
- elif ctype == float:
- self.rgb_range_label.SetLabel(_("range: %d to %d") % (minim, maxim))
+ if self.properties['sourceColumn']:
+ ctype = self.dbInfo.GetTableDesc(self.properties['table'])[self.properties['sourceColumn']]['ctype']
+ else:
+ ctype = int
+ range = ''
+ if self.properties['min'] or self.properties['max']:
+ if ctype == float:
+ range = _("(range: %.1f to %.1f)") % (self.properties['min'], self.properties['max'])
+ elif ctype == int:
+ range = _("(range: %d to %d)") % (self.properties['min'], self.properties['max'])
+ if range:
+ if self.colorTable:
+ self.cr_label.SetLabel(_("Enter vector attribute values or percents %s:") % range)
else:
- self.rgb_range_label.SetLabel('')
- elif type == 'size':
- if ctype == int:
- self.size_range_label.SetLabel(_("range: %.1f to %.1f") % (minim, maxim))
- self.size_range_label.SetLabel(_("range: %d to %d") % (minim, maxim))
+ self.cr_label.SetLabel(_("Enter vector attribute values %s:") % range)
+ else:
+ self.cr_label.SetLabel(_("Enter vector attribute values or percents:"))
else:
- self.size_range_label.SetLabel('')
+ self.cr_label.SetLabel(_("Enter vector attribute values:"))
def OnFromColSelection(self, event):
"""!Selection in combobox (for loading values) changed"""
@@ -1484,16 +1503,10 @@
input = gtemp)
return True
- def OnOK(self, event):
- """!Apply selected color table, close the dialog
- and delete temporary column"""
- if self.OnApply(event):
- self.DeleteTemporaryColumn()
- self.Destroy()
+ self.Map.Clean()
self.Destroy()
class ThematicVectorTable(VectorColorTable):
