[GRASS-SVN] r47748 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Aug 18 11:57:53 EDT 2011
Author: martinl
Date: 2011-08-18 08:57:53 -0700 (Thu, 18 Aug 2011)
New Revision: 47748
grass/trunk/lib/vector/Vlib/field.c
vlib: fix Vect_default_field_info() for external data (ogr)
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c 2011-08-18 15:56:43 UTC (rev 47747)
+++ grass/trunk/lib/vector/Vlib/field.c 2011-08-18 15:57:53 UTC (rev 47748)
@@ -9,14 +9,14 @@
OGR_L_GetFIDColumn() is working or solution found if FID not
available
- (C) 2001-2009 by the GRASS Development Team
+ (C) 2001-2009, 2011 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
\author Original author CERL, probably Dave Gerdes or Mike Higgins.
\author Update to GRASS 5.7 by Radim Blazek and David D. Gray.
- \author Various updates by Martin Landa <landa.martin gmail.com>, 2009
+ \author Various updates by Martin Landa <landa.martin gmail.com>, 2009-2011
#include <stdlib.h>
@@ -278,28 +278,32 @@
\param field_name layer name
\param type how many tables are linked to map: GV_1TABLE / GV_MTABLE
- \return pointer to new field_info structure
+ \return pointer to allocated field_info structure
struct field_info *Vect_default_field_info(struct Map_info *Map,
int field, const char *field_name, int type)
struct field_info *fi;
- char buf[1000], buf2[1000];
+ char buf[GNAME_MAX], buf2[GNAME_MAX];
const char *schema;
- const char *drv, *db;
dbConnection connection;
G_debug(1, "Vect_default_field_info(): map = %s field = %d", Map->name,
field);
- db_get_connection(&connection);
- drv = G__getenv2("DB_DRIVER", G_VAR_MAPSET);
- db = G__getenv2("DB_DATABASE", G_VAR_MAPSET);
- G_debug(2, "drv = %s db = %s", drv, db);
+ if (Map->format == GV_FORMAT_OGR_DIRECT) {
+ G_zero(&connection, sizeof(dbConnection));
+ connection.driverName = G_store("ogr");
+ connection.databaseName = G_store(Map->fInfo.ogr.dsn);
+ else {
+ db_get_connection(&connection);
+ G_debug(2, "drv = %s db = %s", connection.driverName, connection.databaseName);
if (!connection.driverName && !connection.databaseName) {
- /* Set default values and create dbf db dir */
+ /* Set default values */
db_set_default_connection();
@@ -316,16 +320,9 @@
G_fatal_error(_("Default database is not set"));
- drv = connection.driverName;
- db = connection.databaseName;
fi = (struct field_info *)G_malloc(sizeof(struct field_info));
fi->number = field;
- if (field_name != NULL)
- fi->name = G_store(field_name);
- else
- fi->name = NULL;
/* Table name */
if (type == GV_1TABLE) {
@@ -337,7 +334,6 @@
else
sprintf(buf, "%s_%d", Map->name, field);
schema = connection.schemaName;
if (schema && strlen(schema) > 0) {
sprintf(buf2, "%s.%s", schema, buf);
@@ -347,11 +343,17 @@
fi->table = G_store(buf);
+ /* Field name */
+ if (field_name)
+ fi->name = G_store(field_name);
+ else
+ fi->name = G_store(buf);
fi->key = G_store(GV_KEY_COLUMN); /* Should be: id/fid/gfid/... ? */
- fi->database = G_store(db);
- fi->driver = G_store(drv);
+ fi->database = G_store(connection.databaseName);
+ fi->driver = G_store(connection.driverName);
- return (fi);
+ return fi;
@@ -542,7 +544,7 @@
" compiled in"));
#else
#if GDAL_VERSION_NUM > 1320 && HAVE_OGR /* seems to be fixed after 1320 release */
- int layer, nLayers;
+ int nLayers;
char *ogr_fid_col;
G_debug(3, "GDAL_VERSION_NUM: %d", GDAL_VERSION_NUM);
@@ -559,7 +561,6 @@
if (Map->fInfo.ogr.layer == NULL) {
/* get layer number */
- layer = -1;
nLayers = OGR_DS_GetLayerCount(Map->fInfo.ogr.ds); /* Layers = Maps in OGR DB */
G_debug(3, "%d layers (maps) found in data source", nLayers);
