[GRASS-SVN] r47749 - grass/trunk/db/drivers/postgres
svn_grass at osgeo.org
Thu Aug 18 11:58:41 EDT 2011
Author: martinl
Date: 2011-08-18 08:58:41 -0700 (Thu, 18 Aug 2011)
New Revision: 47749
grass/trunk/db/drivers/postgres/describe.c
pg-dbmi: cosmetics in messages
Modified: grass/trunk/db/drivers/postgres/describe.c
--- grass/trunk/db/drivers/postgres/describe.c 2011-08-18 15:57:53 UTC (rev 47748)
+++ grass/trunk/db/drivers/postgres/describe.c 2011-08-18 15:58:41 UTC (rev 47749)
@@ -51,7 +51,6 @@
ncols = PQnfields(res);
/* Count columns of known type */
kcols = 0;
for (i = 0; i < ncols; i++) {
@@ -100,13 +99,14 @@
/* PG types defined in globals.h (and pg_type.h) */
if (sqltype == DB_SQL_TYPE_UNKNOWN) {
if (gpgtype == PG_TYPE_POSTGIS_GEOM) {
- G_warning(_("pg driver: PostGIS column '%s', type 'geometry' will not be converted"),
+ G_warning(_("PostgreSQL driver: PostGIS column '%s', type 'geometry' "
+ "will not be converted"),
fname);
continue;
else {
/* Warn, ignore and continue */
- G_warning(_("pg driver: column '%s', type %d is not supported"),
+ G_warning(_("PostgreSQL driver: column '%s', type %d is not supported"),
fname, pgtype);
continue;
@@ -171,7 +171,8 @@
/* Convert internal type to PG_TYPE_* */
- /* TODO: we should load field names from pg_type table instead of using copy of #defines */
+ /* TODO: we should load field names from pg_type table
+ instead of using copy of #defines */
switch (*gpgtype) {
case PG_TYPE_BIT:
case PG_TYPE_INT2:
