[GRASS-SVN] r47843 - grass-addons/grass7/gui/wxpython/wx.wms
svn_grass at osgeo.org
Tue Aug 23 03:55:48 EDT 2011
Author: sudeepsingh
Date: 2011-08-23 00:55:48 -0700 (Tue, 23 Aug 2011)
New Revision: 47843
grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
EPSG code checking done
Modified: grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
--- grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py 2011-08-22 21:21:36 UTC (rev 47842)
+++ grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py 2011-08-23 07:55:48 UTC (rev 47843)
@@ -116,6 +116,7 @@
self.Bind(wx.EVT_TEXT_ENTER, self.OnServerListEnter, self.ServerList)
self.Bind(wx.EVT_COMBOBOX, self.OnServerList, self.ServerList)
+ self.Bind(wx.EVT_COMBOBOX, self.OnEPSGList, self.epsgList)
self.Bind(wx.EVT_TREE_SEL_CHANGED, self.OnLayerTreeSelChanged, self.LayerTree)
self.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnLayerTreeActivated, self.LayerTree)
self.Bind(wx.EVT_BUTTON, self.OnGetCapabilities, self.GetCapabilities)
@@ -149,6 +150,7 @@
self.Bind(wx.EVT_CLOSE, self.OnQuit)
self.AddServerisClosed = True
self.layerName = ""
+ self.selectedEPSG = None
#items = ["a", "b", "c"]
#itemId = self.LayerTree.AppendItem(self.layerTreeRoot, "item")
@@ -262,6 +264,7 @@
ld.appendLayerTree(layerDataDict, self.LayerTree, self.layerTreeRoot)
self.keyToEPSGCodes = ld.setKeyToEPSGCodes(layerDataDict)
print self.keyToEPSGCodes
print 'check4'
#for res in reslist:
# self.LayerTree.AppendItem(self.layerTreeRoot, res)
@@ -316,11 +319,28 @@
StatusBar_fields = [message]
self.StatusBar.SetStatusText(StatusBar_fields[0], 0)
return
+ if(self.selectedEPSG == None):
+ message = 'No EPSG code selected'
+ print message
+ grass.warning(message)
+ StatusBar_fields = [message]
+ self.StatusBar.SetStatusText(StatusBar_fields[0], 0)
+ self.ShowMessage(message, 'Warning')
+ return
+ if(not self.selectedEPSG.isdigit()):
+ message = 'EPSG code selected is not a number'
+ print message
+ return
self.url_in = self.selectedURL
getMap_request_url = self.url_in
- getMap_request_url += '?service=WMS&request=GetMap&version=1.1.1&format=image/png&width=800&height=600&srs=EPSG:3059&layers='
+ getMap_request_url += '?service=WMS&request=GetMap&version=1.1.1&format=image/png&width=800&height=600&srs=EPSG:'+self.selectedEPSG+'&layers='
getMap_request_url += self.layerName+'&bbox=584344,397868,585500,398500'
print getMap_request_url
@@ -426,7 +446,18 @@
#Sudeep's Code Ends
event.Skip()
+ def OnEPSGList(self,event):
+ info = self.epsgList.GetValue()
+ if(not info.isdigit()):
+ message = 'Please select an EPSG Code'
+ print message
+ seld.show_message(message)
+ return
+ self.selectedEPSG = info
+ print 'epsg = '+info
def OnServerList(self, event): # wxGlade: wmsFrame.<event_handler>
print "Event handler `OnServerList' not implemented"
@@ -470,6 +501,7 @@
def OnLayerTreeSelChanged(self, event): # wxGlade: wmsFrame.<event_handler>
#self.layerName = self.LayerTree.GetItemText(event.GetItem())
#print "Event handler `OnLayerTreeSelChanged' not implemented"
+ self.epsgList.Clear()
self.selectedLayerList = []
keys =[]
self.layerName = ""
@@ -495,15 +527,19 @@
self.selectedLayerList += [layerName]
self.layerName += ","+layerName
keys += [key]
+ lEPSG = self.keyToEPSGCodes[key]
+ self.epsgList.Append('<'+layerName+'>')
+ self.epsgList.AppendItems(lEPSG)
self.layerName = self.layerName[1:]
print self.layerName
- self.epsgList.Clear()
- for key in keys:
- lEPSG = self.keyToEPSGCodes[key]
- self.epsgList.AppendItems(lEPSG)
+ #for key in keys:
+ # lEPSG = self.keyToEPSGCodes[key]
+ # self.epsgList.AppendItems(lEPSG)
event.Skip()
