[GRASS-SVN] r47844 -
grass-addons/grass7/raster/r.modis/r.modis.import
svn_grass at osgeo.org
Tue Aug 23 04:52:59 EDT 2011
Author: lucadelu
Date: 2011-08-23 01:52:59 -0700 (Tue, 23 Aug 2011)
New Revision: 47844
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
add g.region to restore old region after analisys; cleanup comments
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2011-08-23 07:55:48 UTC (rev 47843)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2011-08-23 08:52:59 UTC (rev 47844)
@@ -256,13 +256,11 @@
col = prod['color']
val = []
qa = []
for v,q in suf.iteritems():
val.append(findfile(pref,v))
if q:
qa.append(findfile(pref,q))
- # TODO: save region here
for n in range(len(val)):
valname = val[n]['name']
valfull = val[n]['fullname']
@@ -277,13 +275,14 @@
if an == 'noqa':
#grass.run_command('g.remove', quiet = True, rast = valfull)
try:
+ grass.run_command('g.rename', quiet = True, overwrite = write,
+ rast=(valname,valname + '.orig'))
- rast= (valname + '.2', valname + '.check'))
+ rast= (valname + '.2', valname))
except:
pass
- #TODO check in modis.py to adjust the xml file of mosaic
metadata(parse, valname, col)
- metadata(parse, valname + '.check', col)
+ metadata(parse, valname, col)
metadata(parse, qafull, 'byr')
if an == 'all':
if len(qa) != len(val):
@@ -309,18 +308,17 @@
# grass.message("mapc finalmap: %s" % finalmap)
grass.mapcalc(finalmap)
#grass.run_command('g.remove', quiet = True, rast=(valname, valname + '.2'))
grass.run_command('g.remove', quiet = True, rast=(valname + '.2'))
grass.run_command('g.mremove', flags="f", quiet = True,
rast = ("%s.*" % qaname))
- rast=(valname + '.3', valname + '.check'))
+ rast=(valname + '.3', valname))
- # TODO: restore region here
def single(options,remove,an,ow):
"""Convert the HDF file to TIF and import it
@@ -341,6 +339,14 @@
# import tif files
maps_import = import_tif(output,basedir,remove,ow)
if an:
+ grass.run_command('g.region', save = 'oldregion.%s' % str(os.getpid()))
+ try:
+ cod = os.path.split(pm.hdfname)[1].split('.')[0]
+ analyze(outname, an, cod, pm, ow)
+ except:
+ grass.run_command('g.region', region = 'oldregion.%s' % str(os.getpid()))
+ grass.run_command('g.remove',quiet = True,
+ region = 'oldregion.%s' % str(os.getpid()))
analyze(output, an, cod, pm, ow)
os.remove(confname)
@@ -378,12 +384,18 @@
execmodis = convertModis(hdf, confname, options['mrtpath'])
execmodis.run()
# remove hdf
- if remove:
+ if remove:
# import tif files
import_tif(outname, basedir, remove, ow)
if an:
- cod = os.path.split(pm.hdfname)[1].split('.')[0]
- analyze(outname, an, cod, pm, ow)
+ try:
+ except:
os.remove(hdf)
os.remove(hdf + '.xml')
# or move the hdf and hdf.xml to the dir where are the original files
@@ -391,8 +403,13 @@
# import tif files
import_tif(outname, basedir, remove, ow, targetdir)
if an:
+ try:
+ except:
+ grass.run_command('g.remove', region = 'oldregion.%s' % str(os.getpid()))
try:
shutil.move(hdf,targetdir)
shutil.move(hdf + '.xml',targetdir)
