[GRASS-SVN] r47915 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Aug 27 19:15:22 EDT 2011
Author: cmbarton
Date: 2011-08-27 16:15:22 -0700 (Sat, 27 Aug 2011)
New Revision: 47915
grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
Backport fixes and enhancements to color rules dialog from trunk.
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2011-08-27 22:48:26 UTC (rev 47914)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py 2011-08-27 23:15:22 UTC (rev 47915)
@@ -60,19 +60,17 @@
self.attributeType = attributeType
self.properties = properties
self.parent = parent
+ self.panelWidth = panelWidth
- self.mainPanel = scrolled.ScrolledPanel(parent, id = wx.ID_ANY,
- size = (panelWidth, 300),
- style = wx.TAB_TRAVERSAL | wx.SUNKEN_BORDER)
- self.mainPanel.SetupScrolling(scroll_x = False)
self.mainSizer = wx.FlexGridSizer(cols = 3, vgap = 6, hgap = 4)
# put small border at the top of panel
for i in range(3):
self.mainSizer.Add(item = wx.Size(3, 3))
- self.mainPanel.SetSizer(self.mainSizer)
- self.mainPanel.SetAutoLayout(True)
+ self.mainPanel = scrolled.ScrolledPanel(parent, id = wx.ID_ANY,
+ size = (self.panelWidth, 300),
+ style = wx.TAB_TRAVERSAL | wx.SUNKEN_BORDER)
# (un)check all
self.checkAll = wx.CheckBox(parent, id = wx.ID_ANY, label = _("Check all"))
self.checkAll.SetValue(True)
@@ -87,12 +85,15 @@
self.btnAdd.Bind(wx.EVT_BUTTON, self.OnAddRules)
self.checkAll.Bind(wx.EVT_CHECKBOX, self.OnCheckAll)
self.clearAll.Bind(wx.EVT_BUTTON, self.OnClearAll)
+ self.mainPanel.SetSizer(self.mainSizer)
+ self.mainPanel.SetAutoLayout(True)
+ self.mainPanel.SetupScrolling()
def Clear(self):
"""!Clear and widgets and delete information"""
self.ruleslines.clear()
- self.mainPanel.DestroyChildren()
+ self.mainSizer.Clear(deleteWindows=True)
def OnCheckAll(self, event):
"""!(Un)check all rules"""
@@ -113,10 +114,9 @@
self.AddRules(nrules)
def AddRules(self, nrules, start = False):
- """!Add rules
+ """!Add rules
@param start set widgets (not append)"""
snum = len(self.ruleslines.keys())
if start:
snum = 0
@@ -157,7 +157,7 @@
if not start:
self.ruleslines[enable.GetId()] = { 'value' : '',
self.attributeType: init }
self.mainSizer.Add(item = enable, proportion = 0,
flag = wx.ALIGN_CENTER_VERTICAL)
self.mainSizer.Add(item = txt_ctrl, proportion = 0,
@@ -167,7 +167,6 @@
self.mainPanel.Layout()
def OnRuleEnable(self, event):
"""!Rule enabled/disabled"""
@@ -504,11 +503,7 @@
bodySizer.Add(item = self.rulesPanel.btnAdd, pos = (row, 1))
- return bodySizer
+ return bodySizer
def InitDisplay(self):
"""!Initialize preview display, set dimensions and region
@@ -528,8 +523,13 @@
@return True on success otherwise False
ret = self.CreateColorTable()
- if not self.colorTable:
- self.UseAttrColumn()
+ if not ret:
+ gcmd.GMessage(parent = self, message = _("No valid color rules given."))
+ if self.colorTable:
+ self.UseAttrColumn(False)
+ else:
+ self.UseAttrColumn(True)
if ret:
display = self.parent.GetLayerTree().GetMapDisplay()
if display and display.IsAutoRendered():
@@ -629,8 +629,8 @@
"""!Load current color table (using `r(v).colors.out`)
@param mapType map type (raster or vector)"""
self.rulesPanel.Clear()
if mapType == 'raster':
cmd = ['r.colors.out',
'read=True',
@@ -653,7 +653,7 @@
self.OnPreview()
return
- self.ReadColorTable(ctable = ctable)
+ self.ReadColorTable(ctable = ctable)
def CreateColorTable(self, tmp = False):
"""!Creates color table
@@ -677,7 +677,6 @@
rulestxt += rule['value'] + ' ' + rule['color'] + '\n'
if not rulestxt:
- gcmd.GMessage(parent = self, message = _("No color rules given."))
return False
gtemp = utils.GetTempfile()
@@ -1102,6 +1101,7 @@
def OnCheckColumn(self, event):
"""!Use color column instead of color table"""
if self.useColumn.GetValue():
self.properties['loadColumn'] = self.fromColumn.GetStringSelection()
self.properties['storeColumn'] = self.toColumn.GetStringSelection()
@@ -1119,9 +1119,7 @@
self.fromColumn.Enable(False)
self.toColumn.Enable(False)
self.colorTable = True
self.LoadTable()
def EnableVectorAttributes(self, enable):
"""!Enable/disable part of dialog connected with db"""
@@ -1154,9 +1152,10 @@
self.inmap = None
self.UpdateDialog()
def UpdateDialog(self):
"""!Update dialog after map selection"""
if not self.inmap:
self.DisableClearAll()
return
@@ -1188,7 +1187,6 @@
for prop in ('sourceColumn', 'loadColumn', 'storeColumn'):
self.properties[prop] = ''
self.EnableVectorAttributes(False)
else: # db connection exist
# initialize layer selection combobox
self.EnableVectorAttributes(True)
@@ -1207,10 +1205,11 @@
# initialize column selection comboboxes
self.OnLayerSelection(event = None)
if self.version7 and self.attributeType == 'color':
self.useColumn.SetValue(False)
self.OnCheckColumn(event = None)
self.LoadTable()
self.btnPreview.Enable(enable)
@@ -1529,27 +1528,29 @@
cmd = 'v.colors'
ColorTable.RunHelp(self, cmd = cmd)
- def UseAttrColumn(self, useAttrColumn = True):
- """!Use attribute column to render map"""
- # TODO switch back to table, not only selected map
- layer = self.parent.curr_page.maptree.layer_selected
- if layer and self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].GetName() == self.inmap:
-## cmd = self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].GetCmd()
-## if useAttrColumn:
-## cmd[1].update({'flags': 'a', })
- cmdlist = ['d.vect',
- '-a',
- 'map=%s' % self.inmap,
- 'type=point,line,boundary,area']
+ def UseAttrColumn(self, useAttrColumn):
+ """!Find layers and apply the changes in d.vect command"""
+ layers = self.parent.curr_page.maptree.FindItemByData(key = 'name', value = self.inmap)
+ if not layers:
+ return
+ for layer in layers:
+ if self.parent.curr_page.maptree.GetPyData(layer)[0]['type'] != 'vector':
+ continue
+ cmdlist = self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].GetCmd()
if self.attributeType == 'color':
- cmdlist.append('rgb_column=%s' % self.properties['storeColumn'])
+ if useAttrColumn:
+ cmdlist[1].update({'flags': 'a'})
+ cmdlist[1].update({'rgb_column': self.properties['storeColumn']})
+ else:
+ if 'flags' in cmdlist[1]:
+ cmdlist[1]['flags'] = cmdlist[1]['flags'].replace('a', '')
+ cmdlist[1].pop('rgb_column', None)
elif self.attributeType == 'size':
- cmdlist.append('size_column=%s' % self.properties['storeColumn'])
+ cmdlist[1].update({'size_column': self.properties['storeColumn']})
elif self.attributeType == 'width':
- cmdlist.append('width_column=%s' % self.properties['storeColumn'])
- self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer'].SetCmd(cmdlist)
+ cmdlist[1].update({'width_column' :self.properties['storeColumn']})
+ self.parent.curr_page.maptree.GetPyData(layer)[0]['cmd'] = cmdlist
"""!Create color rules (color table or color column)"""
@@ -1610,10 +1611,8 @@
for vector maps for thematic mapping in nviz"""
self.vectorType = vectorType
VectorColorTable.__init__(self, parent = parent, **kwargs)
- self.SetTitle(_("Thematic mapping for vector map in 3D view"))
+ self.SetTitle(_("Thematic mapping for vector map in 3D view"))
def _initLayer(self):
"""!Set initial layer when opening dialog"""
@@ -1629,7 +1628,7 @@
if not ret:
- gcmd.GMessage(parent = self, message = _("No rules given."))
data = self.parent.GetLayerData(nvizType = 'vector')
data['vector']['points']['thematic']['layer'] = int(self.properties['layer'])
@@ -1813,4 +1812,4 @@
def EraseMap(self):
"""!Erase preview"""
self.Draw(self.pdc, pdctype = 'clear')
\ No newline at end of file
