[GRASS-SVN] r47916 - grass/trunk/vector/v.select
svn_grass at osgeo.org
Sun Aug 28 04:49:57 EDT 2011
Author: martinl
Date: 2011-08-28 01:49:56 -0700 (Sun, 28 Aug 2011)
New Revision: 47916
grass/trunk/vector/v.select/main.c
v.select: fix segfault - List requires boxes
various minor changes
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c 2011-08-27 23:15:22 UTC (rev 47915)
+++ grass/trunk/vector/v.select/main.c 2011-08-28 08:49:56 UTC (rev 47916)
@@ -6,11 +6,11 @@
* Glynn Clements <glynn gclements.plus.com>, Markus Neteler <neteler itc.it>
* Martin Landa <landa.martin gmail.com> (GEOS support)
* PURPOSE:
- * COPYRIGHT: (C) 2003-2010 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2011 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
@@ -31,23 +31,19 @@
int aline, nalines, nskipped;
int ltype, itype[2], ifield[2];
int **cats, *ncats, nfields, *fields;
- char *pre[2];
struct GModule *module;
struct GParm parm;
struct GFlag flag;
struct Map_info In[2], Out;
struct field_info *IFi, *OFi;
struct line_pnts *APoints, *BPoints;
- struct line_cats *ACats, *BCats;
+ struct line_cats *ACats;
int *ALines; /* List of lines: 0 do not output, 1 - write to output */
struct ilist *BoundList, *LList;
struct boxlist *List, *TmpList;
G_gisinit(argv[0]);
- pre[0] = "a";
- pre[1] = "b";
module = G_define_module();
G_add_keyword(_("vector"));
G_add_keyword(_("spatial query"));
@@ -109,8 +105,7 @@
APoints = Vect_new_line_struct();
BPoints = Vect_new_line_struct();
ACats = Vect_new_cats_struct();
- BCats = Vect_new_cats_struct();
- List = Vect_new_boxlist(0);
+ List = Vect_new_boxlist(1);
TmpList = Vect_new_boxlist(1);
BoundList = Vect_new_list();
LList = Vect_new_list();
@@ -172,8 +167,6 @@
continue;
Vect_get_line_box(&(In[0]), aline, &abox);
- abox.T = PORT_DOUBLE_MAX;
- abox.B = -PORT_DOUBLE_MAX;
/* Check if this line overlaps any feature in B */
/* x Lines in B */
