[GRASS-SVN] r47921 - grass/trunk/vector/v.select
    svn_grass at osgeo.org
    Sun Aug 28 13:07:12 EDT 2011
Author: martinl
Date: 2011-08-28 10:07:12 -0700 (Sun, 28 Aug 2011)
New Revision: 47921
   grass/trunk/vector/v.select/main.c
v.select: reuse IFi
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c	2011-08-28 16:11:34 UTC (rev 47920)
+++ grass/trunk/vector/v.select/main.c	2011-08-28 17:07:12 UTC (rev 47921)
@@ -420,13 +420,11 @@
     is_ogr = Vect_maptype(&Out) == GV_FORMAT_OGR_DIRECT;
     if (!flag.table->answer && is_ogr) {
 	/* Copy attributes for OGR output */
-	struct field_info *Fi;
-	Fi = Vect_get_field2(&(In[0]), parm.field[0]->answer);
-	if (!Fi)
+	if (!IFi)
 	    G_fatal_error(_("Database connection not defined for layer <%s>"),
-	Vect_map_add_dblink(&Out, Fi->number, Fi->name, Fi->table, Fi->key,
-			    Fi->database, Fi->driver);
+	Vect_map_add_dblink(&Out, IFi->number, IFi->name, IFi->table, IFi->key,
+			    IFi->database, IFi->driver);
     nfields = Vect_cidx_get_num_fields(&(In[0]));
