[GRASS-SVN] r47922 - grass/trunk/lib/db/dbmi_client
svn_grass at osgeo.org
Sun Aug 28 15:08:15 EDT 2011
Author: mmetz
Date: 2011-08-28 12:08:15 -0700 (Sun, 28 Aug 2011)
New Revision: 47922
grass/trunk/lib/db/dbmi_client/delete_tab.c
db_delete_table(): remove code duplication with db_start_driver_open_database() and db_close_database_shutdown_driver()
Modified: grass/trunk/lib/db/dbmi_client/delete_tab.c
--- grass/trunk/lib/db/dbmi_client/delete_tab.c 2011-08-28 17:07:12 UTC (rev 47921)
+++ grass/trunk/lib/db/dbmi_client/delete_tab.c 2011-08-28 19:08:15 UTC (rev 47922)
@@ -29,31 +29,22 @@
int db_delete_table(const char *drvname, const char *dbname, const char *tblname)
dbDriver *driver;
- dbHandle handle;
dbString sql;
G_debug(3, "db_delete_table(): driver = %s, db = %s, table = %s\n",
drvname, dbname, tblname);
- db_init_handle(&handle);
- db_init_string(&sql);
/* Open driver and database */
- driver = db_start_driver(drvname);
+ driver = db_start_driver_open_database(drvname, dbname);
if (driver == NULL) {
- G_warning(_("Unable to open driver <%s>"), drvname);
+ G_warning(_("Unable open database <%s> by driver <%s>"), dbname,
+ drvname);
return DB_FAILED;
- db_set_handle(&handle, dbname, NULL);
- if (db_open_database(driver, &handle) != DB_OK) {
- G_warning(_("Unable to open database <%s> by driver <%s>"),
- dbname, drvname);
- db_shutdown_driver(driver);
- return DB_FAILED;
/* Delete table */
/* TODO test if the tables exist */
+ db_init_string(&sql);
db_set_string(&sql, "drop table ");
db_append_string(&sql, tblname);
G_debug(3, db_get_string(&sql));
@@ -61,13 +52,11 @@
if (db_execute_immediate(driver, &sql) != DB_OK) {
G_warning(_("Unable to drop table: '%s'"),
- db_close_database(driver);
+ db_close_database_shutdown_driver(driver);
return DB_FAILED;
return DB_OK;
