[GRASS-SVN] r47959 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Aug 29 15:42:04 EDT 2011
Author: martinl
Date: 2011-08-29 12:42:03 -0700 (Mon, 29 Aug 2011)
New Revision: 47959
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py
wxGUI: only output name editable in gdialogs.ImportDialog
(merge r47957 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py 2011-08-29 19:39:27 UTC (rev 47958)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py 2011-08-29 19:42:03 UTC (rev 47959)
@@ -32,6 +32,7 @@
import os
import sys
import re
+from bisect import bisect
import wx
import wx.lib.filebrowsebutton as filebrowse
@@ -1381,9 +1382,9 @@
listmix.ListCtrlAutoWidthMixin.__init__(self)
listmix.TextEditMixin.__init__(self)
- self.InsertColumn(0, _('Layer'))
+ self.InsertColumn(0, _('Layer id'))
self.InsertColumn(1, _('Layer name'))
- self.InsertColumn(2, _('Name for GRASS map'))
+ self.InsertColumn(2, _('Name for GRASS map (editable)'))
self.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnPopupMenu) #wxMSW
self.Bind(wx.EVT_RIGHT_UP, self.OnPopupMenu) #wxGTK
@@ -1400,9 +1401,9 @@
self.SetStringItem(index, 1, "%s" % str(name))
self.SetStringItem(index, 2, "%s" % str(grassName))
# check by default
- self.CheckItem(index, True)
+ ### self.CheckItem(index, True)
- self.SetColumnWidth(col=0, width=wx.LIST_AUTOSIZE_USEHEADER)
+ self.SetColumnWidth(col = 0, width = wx.LIST_AUTOSIZE_USEHEADER)
def OnPopupMenu(self, event):
"""!Show popup menu"""
@@ -1448,6 +1449,26 @@
event.Skip()
+ def OnLeftDown(self, event):
+ """!Allow editing only output name
+ Code taken from TextEditMixin class.
+ x, y = event.GetPosition()
+ colLocs = [0]
+ loc = 0
+ for n in range(self.GetColumnCount()):
+ loc = loc + self.GetColumnWidth(n)
+ colLocs.append(loc)
+ col = bisect(colLocs, x + self.GetScrollPos(wx.HORIZONTAL)) - 1
+ if col == 2:
+ listmix.TextEditMixin.OnLeftDown(self, event)
+ else:
+ event.Skip()
def GetLayers(self):
"""!Get list of layers (layer name, output name)"""
data = []
