[GRASS-SVN] r47960 - grass/trunk/general/g.mapset
svn_grass at osgeo.org
Mon Aug 29 15:52:19 EDT 2011
Author: martinl
Date: 2011-08-29 12:52:19 -0700 (Mon, 29 Aug 2011)
New Revision: 47960
grass/trunk/general/g.mapset/main.c
g.mapset: add flag to print current mapset
Modified: grass/trunk/general/g.mapset/main.c
--- grass/trunk/general/g.mapset/main.c 2011-08-29 19:42:03 UTC (rev 47959)
+++ grass/trunk/general/g.mapset/main.c 2011-08-29 19:52:19 UTC (rev 47960)
@@ -9,7 +9,7 @@
* PURPOSE: Change current mapset, optionally adding it
* if the mapset does not exist.
- * COPYRIGHT: (C) 2004, 2010 by the GRASS Development Team
+ * COPYRIGHT: (C) 2004, 2010-2011 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -29,8 +29,12 @@
int ret;
struct GModule *module;
- struct Option *gisdbase_opt, *location_opt, *mapset_opt;
- struct Flag *f_add, *f_list;
+ struct {
+ struct Option *gisdbase, *location, *mapset;
+ } opt;
+ struct {
+ struct Flag *add, *list, *curr;
+ } flag;
const char *gisdbase_old, *location_old, *mapset_old;
const char *gisdbase_new, *location_new, *mapset_new;
const char *gis_lock;
@@ -44,74 +48,79 @@
module = G_define_module();
G_add_keyword(_("general"));
G_add_keyword(_("settings"));
- module->label = _("Changes current mapset.");
+ module->label = _("Changes/reports current mapset.");
module->description = _("Optionally create new mapset or list available mapsets in given location.");
- mapset_opt = G_define_option();
- mapset_opt->key = "mapset";
- mapset_opt->type = TYPE_STRING;
- mapset_opt->required = YES;
- mapset_opt->multiple = NO;
- mapset_opt->key_desc = "name";
- mapset_opt->description = _("Name of mapset where to switch");
- mapset_opt->guisection = _("Settings");
+ opt.mapset = G_define_standard_option(G_OPT_M_MAPSET);
+ opt.mapset->required = YES;
+ opt.mapset->description = _("Name of mapset where to switch");
+ opt.mapset->guisection = _("Settings");
- location_opt = G_define_option();
- location_opt->key = "location";
- location_opt->type = TYPE_STRING;
- location_opt->required = NO;
- location_opt->multiple = NO;
- location_opt->key_desc = "name";
- location_opt->description = _("Location name (not location path)");
- location_opt->guisection = _("Settings");
+ opt.location = G_define_option();
+ opt.location->key = "location";
+ opt.location->type = TYPE_STRING;
+ opt.location->required = NO;
+ opt.location->multiple = NO;
+ opt.location->key_desc = "name";
+ opt.location->description = _("Location name (not location path)");
+ opt.location->guisection = _("Settings");
- gisdbase_opt = G_define_option();
- gisdbase_opt->key = "gisdbase";
- gisdbase_opt->type = TYPE_STRING;
- gisdbase_opt->required = NO;
- gisdbase_opt->multiple = NO;
- gisdbase_opt->key_desc = "path";
- gisdbase_opt->label = _("GIS data directory");
- gisdbase_opt->description = _("Full path to the directory where the new location is");
- gisdbase_opt->guisection = _("Settings");
+ opt.gisdbase = G_define_option();
+ opt.gisdbase->key = "gisdbase";
+ opt.gisdbase->type = TYPE_STRING;
+ opt.gisdbase->required = NO;
+ opt.gisdbase->multiple = NO;
+ opt.gisdbase->key_desc = "path";
+ opt.gisdbase->label = _("GIS data directory");
+ opt.gisdbase->description = _("Full path to the directory where the new location is");
+ opt.gisdbase->guisection = _("Settings");
- f_add = G_define_flag();
- f_add->key = 'c';
- f_add->description = _("Create mapset if it doesn't exist");
- f_add->answer = FALSE;
- f_add->guisection = _("Create");
+ flag.add = G_define_flag();
+ flag.add->key = 'c';
+ flag.add->description = _("Create mapset if it doesn't exist");
+ flag.add->answer = FALSE;
+ flag.add->guisection = _("Create");
- f_list = G_define_flag();
- f_list->key = 'l';
- f_list->suppress_required = YES;
- f_list->description = _("List available mapsets");
- f_list->guisection = _("Print");
+ flag.list = G_define_flag();
+ flag.list->key = 'l';
+ flag.list->suppress_required = YES;
+ flag.list->description = _("List available mapsets and exit");
+ flag.list->guisection = _("Print");
+ flag.curr = G_define_flag();
+ flag.curr->key = 'p';
+ flag.curr->suppress_required = YES;
+ flag.curr->description = _("Print current mapset and exit");
+ flag.curr->guisection = _("Print");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (!mapset_opt->answer && !f_list->answer)
- G_fatal_error(_("Either mapset= or -l must be used"));
/* Store original values */
gisdbase_old = G__getenv("GISDBASE");
location_old = G__getenv("LOCATION_NAME");
mapset_old = G__getenv("MAPSET");
+ if (flag.curr->answer) {
+ fprintf(stdout, "%s\n", mapset_old);
+ exit(EXIT_SUCCESS);
G_asprintf(&mapset_old_path, "%s/%s/%s", gisdbase_old, location_old,
mapset_old);
/* New values */
- if (gisdbase_opt->answer)
- gisdbase_new = gisdbase_opt->answer;
+ if (opt.gisdbase->answer)
+ gisdbase_new = opt.gisdbase->answer;
else
gisdbase_new = gisdbase_old;
- if (location_opt->answer)
- location_new = location_opt->answer;
+ if (opt.location->answer)
+ location_new = opt.location->answer;
else
location_new = location_old;
- if (f_list->answer) {
+ if (flag.list->answer) {
char **ms;
int nmapsets;
@@ -130,7 +139,7 @@
exit(EXIT_SUCCESS);
- mapset_new = mapset_opt->answer;
+ mapset_new = opt.mapset->answer;
G_asprintf(&mapset_new_path, "%s/%s/%s", gisdbase_new, location_new,
mapset_new);
@@ -147,7 +156,7 @@
G_fatal_error(_("You don't have permission to use this mapset"));
break;
case -1:
- if (f_add->answer == TRUE) {
+ if (flag.add->answer == TRUE) {
G_debug(2, "Mapset %s doesn't exist, attempting to create it",
mapset_new);
G_make_mapset(gisdbase_new, location_new, mapset_new);
@@ -176,7 +185,8 @@
/* Warning: the value returned by system() is not that returned by exit() in executed program
* e.g. exit(1) -> 256 (multiplied by 256) */
if (ret != 0)
- G_fatal_error(_("%s is currently running GRASS in selected mapset or lock file cannot be checked"),
+ G_fatal_error(_("<%s> is currently running GRASS in selected mapset "
+ "or lock file cannot be checked"),
G_whoami());
/* Clean temporary directory */
@@ -195,7 +205,8 @@
G_free(mapset_old_path);
- G_important_message(_("Your shell continues to use the history for the old mapset"));
+ G_important_message(_("Your shell continues to use the history "
+ "for the old mapset"));
if ((shell = getenv("SHELL"))) {
if (strstr(shell, "bash")) {
@@ -210,7 +221,7 @@
- G_message(_("Your current mapset is <%s>"), mapset_new);
+ G_verbose_message(_("Your current mapset is <%s>"), mapset_new);
G_free(mapset_new_path);
