[GRASS-SVN] r49566 -
grass/branches/develbranch_6/scripts/r.fillnulls
svn_grass at osgeo.org
Tue Dec 6 12:14:43 EST 2011
Author: martinl
Date: 2011-12-06 09:14:43 -0800 (Tue, 06 Dec 2011)
New Revision: 49566
grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls
r.fillnulls: cosmetics in module description
Modified: grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls
--- grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls 2011-12-06 17:06:43 UTC (rev 49565)
+++ grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls 2011-12-06 17:14:43 UTC (rev 49566)
@@ -20,21 +20,21 @@
#%Module
-#% description: Fills no-data areas in raster maps using v.surf.rst splines interpolation
+#% description: Fills no-data areas in raster maps using v.surf.rst splines interpolation.
#% keywords: raster, elevation, interpolation
#%End
#%option
#% key: input
#% gisprompt: old,cell,raster
#% type: string
-#% description: Raster map in which to fill nulls
+#% description: Name of input raster map in which to fill nulls
#% required : yes
#%end
#%option
#% key: output
#% gisprompt: new,cell,raster
#% type: string
-#% description: Output raster map with nulls filled by interpolation from surrounding values
+#% description: Name for output raster map with nulls filled by interpolation
#% required : yes
#%end
#%option
