[GRASS-SVN] r49567 - in grass/branches/develbranch_6:
gui/wxpython/gui_modules lib/python
svn_grass at osgeo.org
Tue Dec 6 12:22:42 EST 2011
Author: martinl
Date: 2011-12-06 09:22:42 -0800 (Tue, 06 Dec 2011)
New Revision: 49567
grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
grass/branches/develbranch_6/lib/python/core.py
grass/branches/develbranch_6/lib/python/task.py
attempt to fix #1496 - TODO: replace such ugly hacks with something more reasonable in the future
(merge r49565 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2011-12-06 17:14:43 UTC (rev 49566)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2011-12-06 17:22:42 UTC (rev 49567)
@@ -476,8 +476,15 @@
Debug.msg(1, "gcmd.CommandThread(): %s" % ' '.join(self.cmd))
self.startTime = time.time()
+ # TODO: replace ugly hack bellow
+ args = self.cmd
+ if sys.platform == 'win32' and os.path.splitext(self.cmd[0])[1] == '.py':
+ os.chdir(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'scripts'))
+ args = [sys.executable, self.cmd[0]] + self.cmd[1:]
try:
- self.module = Popen(self.cmd,
+ self.module = Popen(args,
stdin = subprocess.PIPE,
stdout = subprocess.PIPE,
stderr = subprocess.PIPE,
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py 2011-12-06 17:14:43 UTC (rev 49566)
+++ grass/branches/develbranch_6/lib/python/core.py 2011-12-06 17:22:42 UTC (rev 49567)
@@ -165,7 +165,10 @@
else:
options[opt] = val
args = make_command(prog, flags, overwrite, quiet, verbose, **options)
+ if sys.platform == 'win32' and os.path.splitext(prog)[1] == '.py':
+ args.insert(0, sys.executable)
global debug_level
if debug_level > 0:
sys.stderr.write("D1/%d: %s.start_command(): %s\n" % (debug_level, __name__, ' '.join(args)))
Modified: grass/branches/develbranch_6/lib/python/task.py
--- grass/branches/develbranch_6/lib/python/task.py 2011-12-06 17:14:43 UTC (rev 49566)
+++ grass/branches/develbranch_6/lib/python/task.py 2011-12-06 17:22:42 UTC (rev 49567)
@@ -431,8 +431,15 @@
@param cmd command (name of GRASS module)
try:
- cmdout, cmderr = Popen([cmd, '--interface-description'], stdout = PIPE,
- stderr = PIPE).communicate()
+ if sys.platform == 'win32' and os.path.splitext(cmd)[1] == '.py':
+ args = [sys.executable, cmd, '--interface-description']
+ else:
+ args = [cmd, '--interface-description']
+ cmdout, cmderr = Popen(args, stdout = PIPE,
+ stderr = PIPE).communicate()
except OSError, e:
raise ScriptError, _("Unable to fetch interface description for command '%(cmd)s'."
"\n\nDetails: %(det)s") % { 'cmd' : cmd, 'det' : e }
