[GRASS-SVN] r49598 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Wed Dec 7 04:27:46 EST 2011
Author: lucadelu
Date: 2011-12-07 01:27:46 -0800 (Wed, 07 Dec 2011)
New Revision: 49598
grass/branches/develbranch_6/locale/po/grasswxpy_it.po
italian translation
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_it.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_it.po 2011-12-07 09:26:57 UTC (rev 49597)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_it.po 2011-12-07 09:27:46 UTC (rev 49598)
@@ -9,13 +9,13 @@
"Project-Id-Version: grasswxpy_it\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2011-10-05 23:24+0200\n"
-"PO-Revision-Date: 2011-11-19 19:06+0100\n"
+"PO-Revision-Date: 2011-12-06 16:41+0100\n"
"Last-Translator: Luca Delucchi <lucadeluge at gmail.com>\n"
"Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
+"Language: it\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-"Language: it\n"
"Plural-Forms: nplurals=2; plural=(n != 1);\n"
"X-Generator: Lokalize 1.0\n"
@@ -824,11 +824,11 @@
#: ../gui/wxpython/icons/icon.py:383
msgid "Switch to fringe control page"
-msgstr ""
+msgstr "Si sposta alla pagina di controllo dei bordi"
#: ../gui/wxpython/icons/icon.py:384
msgid "Switch on/off fringes"
-msgstr ""
+msgstr "Attiva/disattiva bordi"
#: ../gui/wxpython/icons/icon.py:386
msgid "3D view mode tools"
@@ -1077,7 +1077,7 @@
#: ../gui/wxpython/scripts/vkrige.py:295
msgid "Variogram fitting"
-msgstr ""
+msgstr "Ottimizzazione del variogramma"
#: ../gui/wxpython/scripts/vkrige.py:305
msgid "Plot/refresh variogram"
@@ -1097,7 +1097,7 @@
#: ../gui/wxpython/scripts/vkrige.py:388
msgid "Auto-fit variogram"
-msgstr ""
+msgstr "Auto ottimizzazione del variogramma"
#: ../gui/wxpython/scripts/vkrige.py:412
msgid "Model: "
@@ -1162,7 +1162,7 @@
#: ../gui/wxpython/menustrings.py:16
msgid "Map display"
-msgstr ""
+msgstr "Visualizzatore delle mappe"
#: ../gui/wxpython/menustrings.py:17
msgid "Add raster"
@@ -1760,7 +1760,7 @@
#: ../gui/wxpython/menustrings.py:175
msgid "Performs transformation of 2D vector features to 3D."
-msgstr ""
+msgstr "Esegue trasformazione da vettoriali 2D a 3D"
#: ../gui/wxpython/menustrings.py:176
msgid "Sites to vector"
@@ -1813,11 +1813,11 @@
#: ../gui/wxpython/menustrings.py:190
msgid "Bearing/distance to coordinates"
-msgstr ""
+msgstr "Da orientamento/distanza a coordinate"
#: ../gui/wxpython/menustrings.py:191
msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
-msgstr ""
+msgstr "Un semplice strumento per convertire le misure su orientamento e distanza a coordinate e vice versa."
#: ../gui/wxpython/menustrings.py:193
msgid "Launch Cartographic Composer"
@@ -2012,7 +2012,7 @@
#: ../gui/wxpython/menustrings.py:243
msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
-msgstr ""
+msgstr "Strumento interattivo usato per disegnare e salvare elementi vettoriali su un monitor grafico usando un puntatore (mouse) e salvare ad una mappa raster."
#: ../gui/wxpython/menustrings.py:244
msgid "Compress/decompress"
@@ -2088,7 +2088,7 @@
#: ../gui/wxpython/menustrings.py:262 ../gui/wxpython/menustrings.py:544
msgid "Support file maintenance"
-msgstr ""
+msgstr "Gestione metadati"
#: ../gui/wxpython/menustrings.py:263
msgid "Allows creation and/or modification of raster map layer support files."
@@ -2280,7 +2280,7 @@
#: ../gui/wxpython/menustrings.py:309
msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
+msgstr "Crea un raster composto usando i valori conosciuti da una (o più) mappa(e) per riempire le aree di valori nulli in un'altra mappa."
#: ../gui/wxpython/menustrings.py:310
msgid "Statistical overlay"
@@ -2288,7 +2288,7 @@
#: ../gui/wxpython/menustrings.py:311
msgid "Calculates category or object oriented statistics."
-msgstr ""
+msgstr "Calcola statistiche sulle categorie o orientate agli oggetti"
#: ../gui/wxpython/menustrings.py:312
msgid "Solar radiance and shadows"
@@ -2308,7 +2308,7 @@
#: ../gui/wxpython/menustrings.py:316
msgid "Calculates cast shadow areas from sun position and elevation raster map."
-msgstr ""
+msgstr "Calcola aree ombreggiate dalle mappe della posizione del sole e dell'elevazione."
#: ../gui/wxpython/menustrings.py:317
msgid "Terrain analysis"
@@ -2328,7 +2328,7 @@
#: ../gui/wxpython/menustrings.py:321
msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
-msgstr ""
+msgstr "Crea un raster che mostra il costo totale per spostarsi da differenti località geografiche partendo da un raster contenente nelle celle il valore rappresentante il costo."
#: ../gui/wxpython/menustrings.py:322
msgid "Least cost route or flow"
@@ -2336,7 +2336,7 @@
#: ../gui/wxpython/menustrings.py:323
msgid "Traces a flow through an elevation model on a raster map."
-msgstr ""
+msgstr "Traccia un flusso attraverso un raster del modello dell'evazione."
#: ../gui/wxpython/menustrings.py:324
#: ../gui/wxpython/gui_modules/layertree.py:776
@@ -2413,7 +2413,7 @@
#: ../gui/wxpython/menustrings.py:342
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
+msgstr "Genera un raster con le aree contigue maggiorate di una cella."
#: ../gui/wxpython/menustrings.py:343
msgid "Thin"
@@ -2421,7 +2421,7 @@
#: ../gui/wxpython/menustrings.py:344
msgid "Thins non-zero cells that denote linear features in a raster map."
-msgstr ""
+msgstr "Riduce le celle diverse da zero che rappresentano elementi lineari in un raster."
#: ../gui/wxpython/menustrings.py:345
msgid "Hydrologic modeling"
@@ -2543,7 +2543,7 @@
#: ../gui/wxpython/menustrings.py:374
msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
-msgstr ""
+msgstr "Strumento interattivo per impostare il campione e la struttura dell'analisi che sarà usata da gli altri comandi r.le."
#: ../gui/wxpython/menustrings.py:375
msgid "Analyze landscape"
@@ -2551,19 +2551,19 @@
#: ../gui/wxpython/menustrings.py:376
msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
-msgstr ""
+msgstr "Contiene una serie di misure per attributi, diversità, tessitura, sovrapposizione, e bordi."
#: ../gui/wxpython/menustrings.py:377
msgid "Analyze patches"
-msgstr ""
+msgstr "Analizza particelle"
#: ../gui/wxpython/menustrings.py:378
msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
+msgstr "Calcolare attributi, dimensione della particella, dimensione interiore, forma, dimensione frattale e perimetro misurati per set di particelle in un territorio."
#: ../gui/wxpython/menustrings.py:380
msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
-msgstr ""
+msgstr "Visualizza il confine di ogni particella di r.le e mostra come il confine è tracciata, visualizza l'attributo, dimensione, perimentro e indici di forma per ogni particella e salva i dati in un output file."
#: ../gui/wxpython/menustrings.py:381
msgid "Landscape patch analysis"
@@ -2571,7 +2571,7 @@
#: ../gui/wxpython/menustrings.py:382
msgid "Set up sampling and analysis framework"
-msgstr ""
+msgstr "Imposta campioni e l'ambiente di analisi"
#: ../gui/wxpython/menustrings.py:383
msgid "Configuration editor for r.li.'index'"
@@ -2583,15 +2583,15 @@
#: ../gui/wxpython/menustrings.py:385
msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgstr "Calcola l'indice di densità dei bordi su un raster, usando un algoritmo che considera i 4 pixel più vicini"
#: ../gui/wxpython/menustrings.py:386
msgid "Contrast weighted edge density"
-msgstr ""
+msgstr "Indice di densità dei bordi pesato sull'area"
#: ../gui/wxpython/menustrings.py:387
msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr ""
+msgstr "Calcola l'indice di densità dei bordi pesato sull'area su un raster"
#: ../gui/wxpython/menustrings.py:388
msgid "Patch area mean"
@@ -2599,7 +2599,7 @@
#: ../gui/wxpython/menustrings.py:389
msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgstr "Calcola l'indice della dimensione media della tessera su un raster, usando un algoritmo che considera i 4 pixel più vicini"
#: ../gui/wxpython/menustrings.py:390
msgid "Patch area range"
@@ -2611,19 +2611,19 @@
#: ../gui/wxpython/menustrings.py:392
msgid "Patch area Std Dev"
-msgstr ""
+msgstr "Deviazione Standard dell'area della particella"
#: ../gui/wxpython/menustrings.py:393
msgid "Calculates standard deviation of patch area a raster map"
-msgstr ""
+msgstr "Calcola deviazione standard dell'area della particella su un raster"
#: ../gui/wxpython/menustrings.py:394
msgid "Patch area Coeff Var"
-msgstr ""
+msgstr "Coefficienze di variazione dell'area della particella"
#: ../gui/wxpython/menustrings.py:395
msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr ""
+msgstr "Calcola coefficiente di variazione dell'area della particella su un raster"
#: ../gui/wxpython/menustrings.py:396
msgid "Patch density"
@@ -2631,7 +2631,7 @@
#: ../gui/wxpython/menustrings.py:397
msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
+msgstr "Calcola indice di densità delle particelle su un raster, usando un algoritmo che considera i 4 pixel più vicini"
#: ../gui/wxpython/menustrings.py:398
msgid "Patch number"
@@ -2639,7 +2639,7 @@
#: ../gui/wxpython/menustrings.py:399
msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
+msgstr "Calcola l'indice del numero di particelle su un raster, usando un algoritmo che considera i 4 pixel più vicini"
#: ../gui/wxpython/menustrings.py:400
msgid "Dominance's diversity"
@@ -2683,7 +2683,7 @@
#: ../gui/wxpython/menustrings.py:411
msgid "Rate of spread"
-msgstr ""
+msgstr "Diffusione di fuoco"
#: ../gui/wxpython/menustrings.py:412
msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
@@ -2800,7 +2800,7 @@
#: ../gui/wxpython/menustrings.py:440
msgid "Gaussian kernel density surface"
-msgstr ""
+msgstr "Superficie "
#: ../gui/wxpython/menustrings.py:441
msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
@@ -2908,11 +2908,11 @@
#: ../gui/wxpython/menustrings.py:467
msgid "Ordinary or block kriging"
-msgstr ""
+msgstr "Kriging ordinario o a blocchi"
#: ../gui/wxpython/menustrings.py:468
msgid "Performs ordinary or block kriging."
-msgstr ""
+msgstr "Esegue kriging ordinario o a blocchi"
#: ../gui/wxpython/menustrings.py:469
msgid "Fill NULL cells"
@@ -3017,7 +3017,7 @@
#: ../gui/wxpython/menustrings.py:494
msgid "Sample transects (bearing/distance)"
-msgstr "Valori campione lungo i transetti (uss azimuth, distanza)"
+msgstr "Valori campione lungo i transetti (orientamento, distanza)"
#: ../gui/wxpython/menustrings.py:495
msgid "Outputs raster map layer values lying along user defined transect line(s)."
@@ -3633,7 +3633,7 @@
#: ../gui/wxpython/menustrings.py:653
msgid "Outputs basic information about a user-specified vector map."
-msgstr ""
+msgstr "Informazioni basilari sulla mappa specificata dall'utente."
#: ../gui/wxpython/menustrings.py:654
msgid "Classify attribute data"
@@ -3653,7 +3653,7 @@
#: ../gui/wxpython/menustrings.py:658
msgid "Upload or report topology"
-msgstr ""
+msgstr "Aggiorna o effettua un report della topologia"
#: ../gui/wxpython/menustrings.py:659
msgid "Populates database values from vector features."
@@ -3721,7 +3721,7 @@
#: ../gui/wxpython/menustrings.py:675
msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr ""
+msgstr "Mosaica 4 immagini ed estende la tabella dei colori; crea una mappa con suffisso *.mosaic"
#: ../gui/wxpython/menustrings.py:676
msgid "Manage image colors"
@@ -3753,7 +3753,7 @@
#: ../gui/wxpython/menustrings.py:684
msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
-msgstr ""
+msgstr "Rettifica un'immagine eseguendo una trasformazione sulle coordinate per ogni pixel dell'immagine basata sui punti di controllo."
#: ../gui/wxpython/menustrings.py:685
msgid "Ortho photo rectification (requires Xterm)"
@@ -3801,7 +3801,7 @@
#: ../gui/wxpython/menustrings.py:696
msgid "Interactive input for supervised classification (requires Xterm)"
-msgstr ""
+msgstr "Input interattivo per classificazione controllata (richiede Xterm)"
#: ../gui/wxpython/menustrings.py:697
msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
@@ -4859,7 +4859,7 @@
#: ../gui/wxpython/gui_modules/gpyshell.py:38
#, python-format
msgid "Type %s to add raster or vector to the layer tree."
-msgstr ""
+msgstr "Digita %s per aggiungere raster o vettoriali all'albero dei layer"
#: ../gui/wxpython/gui_modules/gpyshell.py:47
msgid "Delete all text from the shell"
@@ -5298,11 +5298,11 @@
#: ../gui/wxpython/gui_modules/gcpmanager.py:2404
msgid "Highlight highest RMS error only"
-msgstr ""
+msgstr "Evidenzia solo gli errori con scarto quadratico medio più elevato"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2410
msgid "Highlight RMS error > M + SD * factor:"
-msgstr ""
+msgstr "Evidenzia gli errori dello scarto quadratico medio > M + SD * fattore:"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2411
msgid ""
@@ -5310,6 +5310,9 @@
"mean + standard deviation * given factor. \n"
"Recommended values for this factor are between 1 and 2."
msgstr ""
+"Evidenzia punti di controllo sul terreno con un errore delli scarto quadratico medio maggiore di \n"
+"media + deviazione standard * fattore assegnato.\n"
+"Valori raccomandati per questo fattore sono compresi tra 1 e 2."
#: ../gui/wxpython/gui_modules/gcpmanager.py:2427
msgid "Symbol settings"
@@ -5328,7 +5331,7 @@
#: ../gui/wxpython/gui_modules/gcpmanager.py:2453
msgid "Color for high RMS error:"
-msgstr ""
+msgstr "Coloro per l'errore dello scarto quadratico medio errore:"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2470
msgid "Color for selected GCP:"
@@ -5380,13 +5383,15 @@
#: ../gui/wxpython/gui_modules/gcpmanager.py:2650
msgid "RMS threshold factor must be > 0"
-msgstr ""
+msgstr "La soglia del fattore dello scarto quadratico medio dev'essere > 0"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2653
msgid ""
"RMS threshold factor is < 1\n"
"Too many points might be highlighted"
msgstr ""
+"La soglia del fattore dello scarto quadratico è < 1\n"
+"Troppi punti potrebbero essere evidenziati"
#: ../gui/wxpython/gui_modules/gcpmanager.py:2772
#, python-format
@@ -5651,11 +5656,11 @@
#: ../gui/wxpython/gui_modules/mapdisp.py:1635
msgid "bearing"
-msgstr ""
+msgstr "orientamento"
msgid "deg"
-msgstr ""
+msgstr "gradi"
#: ../gui/wxpython/gui_modules/mapdisp.py:1771
msgid "Scale and North arrow"
@@ -5806,7 +5811,7 @@
#: ../gui/wxpython/gui_modules/ghelp.py:220
msgid "Menu tree (double-click to run command)"
-msgstr ""
+msgstr "Albero del meno (doppio click per eseguire il comando)"
#: ../gui/wxpython/gui_modules/ghelp.py:230
msgid "Run selected command"
@@ -6243,7 +6248,7 @@
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1903
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1924
msgid "custom"
-msgstr ""
+msgstr "personalizzato"
#: ../gui/wxpython/gui_modules/location_wizard.py:1709
#, python-format
@@ -6412,7 +6417,7 @@
#: ../gui/wxpython/gui_modules/vclean.py:37
msgid "set up vector cleaning tools"
-msgstr ""
+msgstr "imposta gli strumenti di pulizia vettoriale"
#: ../gui/wxpython/gui_modules/vclean.py:76
msgid "break lines/boundaries"
@@ -6424,19 +6429,19 @@
#: ../gui/wxpython/gui_modules/vclean.py:78
msgid "remove dangles"
-msgstr ""
+msgstr "rimuove sporgenze"
#: ../gui/wxpython/gui_modules/vclean.py:79
msgid "change boundary dangles to lines"
-msgstr ""
+msgstr "cambia sporgenze dei confini a linee"
#: ../gui/wxpython/gui_modules/vclean.py:80
msgid "remove bridges"
-msgstr ""
+msgstr "rimuove ponti"
#: ../gui/wxpython/gui_modules/vclean.py:81
msgid "change bridges to lines"
-msgstr ""
+msgstr "cambia ponti in linee"
#: ../gui/wxpython/gui_modules/vclean.py:82
msgid "snap lines/boundaries"
@@ -6464,16 +6469,16 @@
#: ../gui/wxpython/gui_modules/vclean.py:88
msgid "remove small angles at nodes"
-msgstr ""
+msgstr "rimuovo piccoli angoli ai nodi"
#: ../gui/wxpython/gui_modules/vclean.py:121
#: ../gui/wxpython/gui_modules/vclean.py:122
msgid "Set up vector cleaning tools"
-msgstr ""
+msgstr "Imposta gli strumenti di pulizia vettoriale"
#: ../gui/wxpython/gui_modules/vclean.py:124
msgid "Choose cleaning tools and set thresholds"
-msgstr ""
+msgstr "Scegli gli strumenti di pulizia e imposta le soglie"
#: ../gui/wxpython/gui_modules/vclean.py:128
msgid "Select input vector map:"
@@ -6521,37 +6526,37 @@
#: ../gui/wxpython/gui_modules/vclean.py:363
#, python-format
msgid "%s. cleaning tool removed, will be ignored"
-msgstr ""
+msgstr "%s. strumento di pulizia rimosso, sarà ignorato"
#: ../gui/wxpython/gui_modules/vclean.py:365
msgid "Please select a cleaning tool to remove"
-msgstr ""
+msgstr "Seleziona uno strumento di pulizia per rimuovere"
#: ../gui/wxpython/gui_modules/vclean.py:386
#, python-format
msgid "%s. cleaning tool moved up"
-msgstr ""
+msgstr "%s. strumento di pulizia spostato sopra"
#: ../gui/wxpython/gui_modules/vclean.py:388
msgid "1. cleaning tool can not be moved up "
-msgstr ""
+msgstr "1. strumento di pulizia non può essere mosso sopra"
#: ../gui/wxpython/gui_modules/vclean.py:390
msgid "Please select a cleaning tool to move up"
-msgstr ""
+msgstr "Seleziona uno strumento di pulizia da muovere sopra"
#: ../gui/wxpython/gui_modules/vclean.py:413
#, python-format
msgid "%s. cleaning tool moved down"
-msgstr ""
+msgstr "%s. strumento di pulizia da muovere sotto"
#: ../gui/wxpython/gui_modules/vclean.py:415
msgid "Last cleaning tool can not be moved down "
-msgstr ""
+msgstr "L'ultimo strumento di pulizia non può essere mosso sotto"
#: ../gui/wxpython/gui_modules/vclean.py:417
msgid "Please select a cleaning tool to move down"
-msgstr ""
+msgstr "Selezionare uno strumento di pulizia da muovere sotto"
#: ../gui/wxpython/gui_modules/vclean.py:428
#, python-format
@@ -6726,7 +6731,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:303
msgid "Fringe"
-msgstr ""
+msgstr "Bordo"
#: ../gui/wxpython/gui_modules/nviz_tools.py:343
msgid "Surface attributes"
@@ -6981,7 +6986,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:1271
msgid "Edges with fringe"
-msgstr ""
+msgstr "Vertici con bordo"
#: ../gui/wxpython/gui_modules/nviz_tools.py:1273
msgid "N && W"
@@ -7001,7 +7006,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:1296
msgid "Elevation of fringe from bottom:"
-msgstr ""
+msgstr "Altezza del bordo dalla base:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:2310
#: ../gui/wxpython/gui_modules/nviz_tools.py:2312
@@ -7634,7 +7639,7 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1378
#, python-format
msgid "%d lines selected for z bulk-labeling"
-msgstr ""
+msgstr "%d linee selezionate per etichettatura di massa"
#: ../gui/wxpython/gui_modules/vdigit.py:1381
msgid "Set value"
@@ -8180,18 +8185,24 @@
"Relation doesn't start with data item.\n"
"Unable to add relation."
msgstr ""
+"La relazione non incomincia con un dato.\n"
+"Impossibile aggiungere la relazione."
#: ../gui/wxpython/gui_modules/gmodeler.py:2690
msgid ""
"Relation doesn't point to GRASS command.\n"
msgstr ""
+"La relazione non punta ad un comando di GRASS.\n"
#: ../gui/wxpython/gui_modules/gmodeler.py:2703
msgid ""
"No relevant option found.\n"
msgstr ""
+"Nessuna rilevante opzione trovata.\n"
#: ../gui/wxpython/gui_modules/gmodeler.py:3237
msgid "Action"
@@ -8618,7 +8629,7 @@
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1836
msgid "Literal is not allowed!"
-msgstr ""
+msgstr "Testuale non è permesso!"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2431
@@ -8670,7 +8681,7 @@
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2080
msgid "fixed scale and map center"
-msgstr ""
+msgstr "Scala e centro della mappa fissi"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2088
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2256
@@ -8800,7 +8811,7 @@
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2700
msgid "The topmost vector map overlaps the others"
-msgstr ""
+msgstr "La mappa vettoriale più in alto nella lista delle mappe si sovrappone alle altre"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2702
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3998
@@ -8987,7 +8998,7 @@
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3507
msgid "Choose linecap:"
-msgstr ""
+msgstr "Scegli fine della linea:"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3532
msgid "Pattern"
@@ -9041,11 +9052,11 @@
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3889
msgid "discrete legend (categorical maps)"
-msgstr ""
+msgstr "Legenda discreta (mappe categoriali)"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3891
msgid "continuous color gradient legend (floating point map)"
-msgstr ""
+msgstr "Legenda con gradiente colori continui (mappe decimali)"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3902
msgid "Advanced legend settings"
@@ -9199,7 +9210,7 @@
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4911
msgid "Label every "
-msgstr ""
+msgstr "Aggiungi a tutto le etichette"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4912
msgid "segments"
@@ -11134,7 +11145,7 @@
#: ../gui/wxpython/gui_modules/preferences.py:1402
msgid "Map Display"
-msgstr ""
+msgstr "Visualizzatore di mappe"
#: ../gui/wxpython/gui_modules/preferences.py:1417
msgid "Default font for GRASS displays:"
@@ -12760,3 +12771,6 @@
#~ msgid "Abort the running command"
#~ msgstr "Stoppa l'esecuzione del comando"
+#~ msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+#~ msgstr "Partendo dal dato vettoriale dell'idrografia, trasforma in raster e ottiene la profondità per il DEM di output."
