[GRASS-SVN] r49677 - grass/branches/develbranch_6/gui/scripts
svn_grass at osgeo.org
Mon Dec 12 08:46:01 EST 2011
Author: martinl
Date: 2011-12-12 05:46:00 -0800 (Mon, 12 Dec 2011)
New Revision: 49677
grass/branches/develbranch_6/gui/scripts/g.extension.py
g.extension.py: be tidy citizen also on Windows
Modified: grass/branches/develbranch_6/gui/scripts/g.extension.py
--- grass/branches/develbranch_6/gui/scripts/g.extension.py 2011-12-12 12:35:27 UTC (rev 49676)
+++ grass/branches/develbranch_6/gui/scripts/g.extension.py 2011-12-12 13:46:00 UTC (rev 49677)
@@ -270,7 +270,9 @@
fo.close()
except HTTPError:
grass.fatal(_("GRASS Addons <%s> not found") % options['extension'])
+ grass.message(_("Installation of <%s> successfully finished.") % options['extension'])
# install extension
def install_extension():
gisbase = os.getenv('GISBASE')
@@ -279,12 +281,21 @@
if grass.find_program(options['extension'], ['--help']):
grass.warning(_("Extension <%s> already installed. Will be updated...") % options['extension'])
if sys.platform == "win32":
install_extension_win()
else:
install_extension_other()
+ # cleanup build cruft
+ if not flags['s']:
+ tidy_citizen()
+ if not os.environ.has_key('GRASS_ADDON_PATH') or \
+ not os.environ['GRASS_ADDON_PATH']:
+ grass.warning(_('This add-on module will not function until you set the '
+ 'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
# manual page: fix href
if os.getenv('GRASS_ADDON_PATH'):
html_man = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'docs', 'html', 'description.html')
@@ -309,39 +320,6 @@
fd.write(html_str)
fd.close()
- # symlink for binaries needed, see http://trac.osgeo.org/grass/changeset/49124
- src = None
- if sys.platform == 'win32':
- bin_ext = '.exe'
- sct_ext = '.bat'
- else:
- bin_ext = sct_ext = ''
- if os.path.exists(os.path.join(options['prefix'], 'bin',
- options['extension'] + bin_ext)):
- src = os.path.join(options['prefix'], 'bin', options['extension']) + bin_ext
- dst = os.path.join(options['prefix'], options['extension']) + bin_ext
- else:
- pdir = 'bin'
- else:
- pdir = 'scripts'
- if os.path.exists(os.path.join(options['prefix'], pdir,
- options['extension'] + sct_ext)):
- src = os.path.join(options['prefix'], pdir, options['extension']) + sct_ext
- dst = os.path.join(options['prefix'], options['extension']) + sct_ext
- if src and not os.path.exists(dst):
- shutil.copyfile(src, dst)
- else:
- os.symlink(src, dst)
- if not os.environ.has_key('GRASS_ADDON_PATH') or \
- not os.environ['GRASS_ADDON_PATH']:
- grass.warning(_('This add-on module will not function until you set the '
- 'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
# install extension on other plaforms
def install_extension_other():
@@ -427,45 +405,41 @@
else:
- # cleanup build cruft
- if not flags['s']:
- # move script/ and bin/ to main dir
- if os.path.exists(os.path.join(options['prefix'], 'bin', options['extension'])):
- shutil.move(os.path.join(options['prefix'], 'bin', options['extension']),
- os.path.join(options['prefix'], options['extension']))
+# remove dir if empty
+def remove_empty_dir(path):
+ if os.path.exists(path) and not os.listdir(path):
+ os.removedirs(path)
+# see http://lists.osgeo.org/pipermail/grass-dev/2011-December/056938.html
+def tidy_citizen():
+ if sys.platform == 'win32':
+ EXT_BIN = '.exe'
+ EXT_SCT = '.bat'
+ else:
+ EXT_BIN = EXT_SCT = ''
+ # move script/ and bin/ to main dir
+ if os.path.exists(os.path.join(options['prefix'], 'bin', options['extension']) + EXT_BIN):
+ shutil.move(os.path.join(options['prefix'], 'bin', options['extension']) + EXT_BIN,
+ os.path.join(options['prefix'], options['extension']) + EXT_BIN)
+ if os.path.exists(os.path.join(options['prefix'], 'bin', options['extension']) + EXT_SCT):
+ shutil.move(os.path.join(options['prefix'], 'bin', options['extension']) + EXT_SCT,
+ os.path.join(options['prefix'], options['extension']) + EXT_SCT)
+ else:
if os.path.exists(os.path.join(options['prefix'], 'scripts', options['extension'])):
shutil.move(os.path.join(options['prefix'], 'scripts', options['extension']),
+ # move man/ into docs/
+ if os.path.exists(os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')):
+ shutil.move(os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1'),
+ os.path.join(options['prefix'], 'docs', 'man', 'man1', options['extension'] + '.1'))
- # if empty, rmdir scripts/ and bin/
- if os.path.exists(os.path.join(options['prefix'], 'bin')):
- if os.listdir(os.path.join(options['prefix'], 'bin')) == []:
- os.removedirs(os.path.join(options['prefix'], 'bin'))
- if os.path.exists(os.path.join(options['prefix'], 'scripts')):
- if os.listdir(os.path.join(options['prefix'], 'scripts')) == []:
- os.removedirs(os.path.join(options['prefix'], 'scripts'))
- # move man/ into docs/
- if os.path.exists(os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')):
- shutil.move(os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1'),
- os.path.join(options['prefix'], 'docs', 'man', 'man1', options['extension'] + '.1'))
- # if empty, rmdir man/man1
- if os.path.exists(os.path.join(options['prefix'], 'man', 'man1')):
- if os.listdir(os.path.join(options['prefix'], 'man', 'man1')) == []:
- os.removedirs(os.path.join(options['prefix'], 'man', 'man1'))
- if os.path.exists(os.path.join(options['prefix'], 'man')):
- if os.listdir(os.path.join(options['prefix'], 'man')) == []:
- os.removedirs(os.path.join(options['prefix'], 'man'))
+ # if empty, rmdir bin, etc, man, scripts
+ for d in ('bin', 'etc', os.path.join('man', 'man1'), 'man', 'scripts'):
+ remove_empty_dir(os.path.join(options['prefix'], d))
# remove existing extension (reading XML file)
def remove_extension(force = False):
# try to download XML metadata file first
