[GRASS-SVN] r49678 - in grass/branches/releasebranch_6_4:
gui/scripts gui/wxpython/gui_modules lib/init lib/python
svn_grass at osgeo.org
Mon Dec 12 09:13:21 EST 2011
Author: martinl
Date: 2011-12-12 06:13:21 -0800 (Mon, 12 Dec 2011)
New Revision: 49678
grass/branches/releasebranch_6_4/gui/scripts/g.extension.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/ghelp.py
grass/branches/releasebranch_6_4/lib/init/init.bat
grass/branches/releasebranch_6_4/lib/python/core.py
grass/branches/releasebranch_6_4/lib/python/task.py
sync g.extension.py from devbr6 to enable installing extensions also on Windows
Modified: grass/branches/releasebranch_6_4/gui/scripts/g.extension.py
--- grass/branches/releasebranch_6_4/gui/scripts/g.extension.py 2011-12-12 13:46:00 UTC (rev 49677)
+++ grass/branches/releasebranch_6_4/gui/scripts/g.extension.py 2011-12-12 14:13:21 UTC (rev 49678)
@@ -28,7 +28,6 @@
#% type: string
#% key_desc: name
#% description: Name of extension to install/remove
-#% required: no
#%end
#%option
#% key: operation
@@ -61,8 +60,8 @@
#% guisection: Print
#%end
#%flag
-#% key: f
-#% description: List available modules in the GRASS Addons SVN repository including modules description
+#% key: c
+#% description: List available modules in the GRASS Addons SVN repository including module description
#%end
#%flag
@@ -82,24 +81,40 @@
#% key: i
#% description: Don't install new extension, just compile it
#%end
+#%flag
+#% key: f
+#% description: Force removal when uninstalling extension (operation=remove)
+#%end
import os
import sys
import re
import atexit
+import shutil
+import glob
+import zipfile
+import tempfile
+import shutil
-import urllib
+from urllib2 import urlopen, HTTPError
+try:
+ import xml.etree.ElementTree as etree
+except ImportError:
+ import elementtree.ElementTree as etree # Python <= 2.4
from grass.script import core as grass
# temp dir
remove_tmpdir = True
-def check():
+# check requirements
+def check_progs():
for prog in ('svn', 'make', 'gcc'):
if not grass.find_program(prog, ['--help']):
grass.fatal(_("'%s' required. Please install '%s' first.") % (prog, prog))
+# expand prefix to class name
def expand_module_class_name(c):
name = { 'd' : 'display',
'db' : 'database',
@@ -109,7 +124,7 @@
'ps' : 'postscript',
'p' : 'paint',
'r' : 'raster',
- 'r3' : 'raster3D',
+ 'r3' : 'raster3d',
's' : 'sites',
'v' : 'vector',
'gui' : 'gui/wxpython' }
@@ -119,27 +134,62 @@
return c
+# list modules (read XML file from grass.osgeo.org/addons)
def list_available_modules():
mlist = list()
+ # try to download XML metadata file first
+ url = "http://grass.osgeo.org/addons/grass%s.xml" % grass.version()['version'].split('.')[0]
+ try:
+ f = urlopen(url)
+ tree = etree.fromstring(f.read())
+ for mnode in tree.findall('task'):
+ name = mnode.get('name')
+ if flags['c'] or flags['g']:
+ desc = mnode.find('description').text
+ if not desc:
+ desc = ''
+ keyw = mnode.find('keywords').text
+ if not keyw:
+ keyw = ''
+ if flags['g']:
+ print 'name=' + name
+ print 'description=' + desc
+ print 'keywords=' + keyw
+ elif flags['c']:
+ print name + ' - ' + desc
+ else:
+ print name
+ except HTTPError:
+ return list_available_modules_svn()
+ return mlist
+# list modules (scan SVN repo)
+def list_available_modules_svn():
+ mlist = list()
grass.message(_('Fetching list of modules from GRASS-Addons SVN (be patient)...'))
pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
- i = 0
+ if flags['c']:
+ grass.warning(_("Flag 'c' ignored, metadata file not available"))
+ if flags['g']:
+ grass.warning(_("Flag 'g' ignored, metadata file not available"))
prefix = ['d', 'db', 'g', 'i', 'm', 'ps',
'p', 'r', 'r3', 's', 'v']
nprefix = len(prefix)
for d in prefix:
- if flags['g']:
- grass.percent(i, nprefix, 1)
- i += 1
modclass = expand_module_class_name(d)
grass.verbose(_("Checking for '%s' modules...") % modclass)
url = '%s/%s' % (options['svnurl'], modclass)
grass.debug("url = %s" % url, debug = 2)
- f = urllib.urlopen(url)
- if not f:
- grass.warning(_("Unable to fetch '%s'") % url)
+ try:
+ f = urlopen(url)
+ except HTTPError:
+ grass.debug(_("Unable to fetch '%s'") % url, debug = 1)
continue
for line in f.readlines():
@@ -149,16 +199,14 @@
continue
name = sline.group(2).rstrip('/')
if name.split('.', 1)[0] == d:
- print_module_desc(name, url)
+ print name
mlist.append(name)
mlist += list_wxgui_extensions()
- if flags['g']:
- grass.percent(1, 1, 1)
return mlist
+# list wxGUI extensions
def list_wxgui_extensions(print_module = True):
mlist = list()
grass.debug('Fetching list of wxGUI extensions from GRASS-Addons SVN (be patient)...')
@@ -167,7 +215,7 @@
url = '%s/%s' % (options['svnurl'], 'gui/wxpython')
+ f = urlopen(url)
if not f:
return
@@ -180,119 +228,101 @@
if name not in ('..', 'Makefile'):
if print_module:
+ print name
mlist.append(name)
return mlist
-def print_module_desc(name, url):
- if not flags['f'] and not flags['g']:
- print name
- return
- if flags['g']:
- print 'name=' + name
- # check main.c first
- desc = get_module_desc(url + '/' + name + '/' + name)
- if not desc:
- desc = get_module_desc(url + '/' + name + '/main.c', script = False)
- if not desc:
- if not flags['g']:
- print name + '-'
- return
- if flags['g']:
- print 'description=' + desc.get('description', '')
- print 'keywords=' + ','.join(desc.get('keywords', list()))
+def cleanup():
+ if remove_tmpdir:
+ grass.try_rmdir(tmpdir)
else:
- print name + ' - ' + desc.get('description', '')
-def get_module_desc(url, script = True):
- grass.debug('url=%s' % url)
- if script:
- ret = get_module_script(f)
- else:
- ret = get_module_main(f)
+ grass.message(_("Path to the source code:"))
+ sys.stderr.write('%s\n' % os.path.join(tmpdir, options['extension']))
+# install extension on MS Windows
+def install_extension_win():
+ ### TODO: do not use hardcoded url
+ version = grass.version()['version'].split('.')
+ url = "http://wingrass.fsv.cvut.cz/grass%s%s/addons/" % (version[0], version[1])
+ grass.message(_("Downloading precompiled GRASS Addons <%s>...") % options['extension'])
+ try:
+ f = urlopen(url + options['extension'] + '.zip')
- return ret
+ # create addons dir if not exists
+ if not os.path.exists(options['prefix']):
+ os.mkdir(options['prefix'])
+ # download data
+ fo = tempfile.TemporaryFile()
+ fo.write(f.read())
+ zfobj = zipfile.ZipFile(fo)
+ for name in zfobj.namelist():
+ if name.endswith('/'):
+ d = os.path.join(options['prefix'], name)
+ if not os.path.exists(d):
+ os.mkdir(d)
+ else:
+ outfile = open(os.path.join(options['prefix'], name), 'wb')
+ outfile.write(zfobj.read(name))
+ outfile.close()
+ fo.close()
+ except HTTPError:
+ grass.fatal(_("GRASS Addons <%s> not found") % options['extension'])
-def get_module_main(f):
- if not f:
- return dict()
- ret = { 'keyword' : list() }
- pattern = re.compile(r'(module.*->)(.+)(=)(.*)', re.IGNORECASE)
- keyword = re.compile(r'(G_add_keyword\()(.+)(\);)', re.IGNORECASE)
- key = ''
- value = ''
- for line in f.readlines():
- line = line.strip()
- find = pattern.search(line)
- if find:
- key = find.group(2).strip()
- line = find.group(4).strip()
- else:
- find = keyword.search(line)
- if find:
- ret['keyword'].append(find.group(2).replace('"', '').replace('_(', '').replace(')', ''))
- if key:
- value += line
- if line[-2:] == ');':
- value = value.replace('"', '').replace('_(', '').replace(');', '')
- if key == 'keywords':
- ret[key] = map(lambda x: x.strip(), value.split(','))
- else:
- ret[key] = value
- key = value = ''
- return ret
+ grass.message(_("Installation of <%s> successfully finished.") % options['extension'])
-def get_module_script(f):
- ret = dict()
- if not f:
- return ret
- begin = re.compile(r'#%.*module', re.IGNORECASE)
- end = re.compile(r'#%.*end', re.IGNORECASE)
- mline = None
- if not mline:
- mline = begin.search(line)
- if mline:
- if end.search(line):
- break
- try:
- key, value = line.split(':', 1)
- key = key.replace('#%', '').strip()
- value = value.strip()
- else:
- ret[key] = value
- except ValueError:
- pass
- return ret
-def cleanup():
- if remove_tmpdir:
- grass.try_rmdir(tmpdir)
- else:
- grass.info(_("Path to the source code: '%s'") % os.path.join(tmpdir, options['extension']))
def install_extension():
gisbase = os.getenv('GISBASE')
if not gisbase:
grass.fatal(_('$GISBASE not defined'))
if grass.find_program(options['extension'], ['--help']):
- grass.warning(_("Extension '%s' already installed. Will be updated...") % options['extension'])
+ grass.warning(_("Extension <%s> already installed. Will be updated...") % options['extension'])
+ if sys.platform == "win32":
+ install_extension_win()
+ else:
+ install_extension_other()
+ # cleanup build cruft
+ if not flags['s']:
+ tidy_citizen()
+ if not os.environ.has_key('GRASS_ADDON_PATH') or \
+ not os.environ['GRASS_ADDON_PATH']:
+ grass.warning(_('This add-on module will not function until you set the '
+ 'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
+ # manual page: fix href
+ if os.getenv('GRASS_ADDON_PATH'):
+ html_man = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'docs', 'html', 'description.html')
+ if os.path.exists(html_man):
+ fd = open(html_man)
+ html_str = '\n'.join(fd.readlines())
+ fd.close()
+ for rep in ('grassdocs.css', 'grass_logo.png'):
+ patt = re.compile(rep, re.IGNORECASE)
+ html_str = patt.sub(os.path.join(gisbase, 'docs', 'html', rep),
+ html_str)
+ patt = re.compile(r'(<a href=")(d|db|g|i|m|p|ps|r|r3|s|v|wxGUI)(\.)(.+)(.html">)', re.IGNORECASE)
+ while True:
+ m = patt.search(html_str)
+ if not m:
+ break
+ html_str = patt.sub(m.group(1) + os.path.join(gisbase, 'docs', 'html',
+ m.group(2) + m.group(3) + m.group(4)) + m.group(5),
+ html_str, count = 1)
+ fd = open(html_man, "w")
+ fd.write(html_str)
+ fd.close()
+# install extension on other plaforms
+def install_extension_other():
+ gisbase = os.getenv('GISBASE')
gui_list = list_wxgui_extensions(print_module = False)
if options['extension'] not in gui_list:
@@ -304,7 +334,7 @@
if not flags['s']:
grass.fatal(_("Installation of wxGUI extension requires -%s flag.") % 's')
- grass.message(_("Fetching '%s' from GRASS-Addons SVN (be patient)...") % options['extension'])
+ grass.message(_("Fetching <%s> from GRASS-Addons SVN (be patient)...") % options['extension'])
os.chdir(tmpdir)
if grass.verbosity() == 0:
@@ -314,7 +344,7 @@
if grass.call(['svn', 'checkout',
url], stdout = outdev) != 0:
- grass.fatal(_("GRASS Addons '%s' not found in repository") % options['extension'])
dirs = { 'bin' : os.path.join(tmpdir, options['extension'], 'bin'),
'docs' : os.path.join(tmpdir, options['extension'], 'docs'),
@@ -331,7 +361,7 @@
'HTMLDIR=%s' % dirs['html'],
'MANDIR=%s' % dirs['man1'],
'SCRIPTDIR=%s' % dirs['scripts'],
- 'ETC=%s' % dirs['etc']
+ 'ETC=%s' % os.path.join(dirs['etc'],options['extension'])
installCmd = ['make',
@@ -342,18 +372,16 @@
if flags['d']:
+ grass.message(_("To compile run:"))
sys.stderr.write(' '.join(makeCmd) + '\n')
+ grass.message(_("To install run:\n\n"))
sys.stderr.write(' '.join(installCmd) + '\n')
return
os.chdir(os.path.join(tmpdir, options['extension']))
- grass.message(_("Compiling '%s'...") % options['extension'])
+ grass.message(_("Compiling <%s>...") % options['extension'])
- for d in dirs.itervalues():
- if not os.path.exists(d):
- os.makedirs(d)
ret = grass.call(makeCmd,
stdout = outdev)
else:
@@ -363,11 +391,11 @@
if ret != 0:
grass.fatal(_('Compilation failed, sorry. Please check above error messages.'))
if flags['i'] or options['extension'] in gui_list:
return
- grass.message(_("Installing '%s'...") % options['extension'])
+ grass.message(_("Installing <%s>...") % options['extension'])
ret = grass.call(installCmd,
stdout = outdev)
@@ -375,30 +403,140 @@
if ret != 0:
grass.warning(_('Installation failed, sorry. Please check above error messages.'))
else:
- grass.message(_("Installation of '%s' successfully finished.") % options['extension'])
+# remove dir if empty
+def remove_empty_dir(path):
+ if os.path.exists(path) and not os.listdir(path):
+ os.removedirs(path)
- if not os.environ.has_key('GRASS_ADDON_PATH') or \
- not os.environ['GRASS_ADDON_PATH']:
- grass.warning(_('This add-on module will not function until you set the '
- 'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
+# see http://lists.osgeo.org/pipermail/grass-dev/2011-December/056938.html
+def tidy_citizen():
+ if sys.platform == 'win32':
+ EXT_BIN = '.exe'
+ EXT_SCT = '.bat'
+ else:
+ EXT_BIN = EXT_SCT = ''
+ # move script/ and bin/ to main dir
+ if os.path.exists(os.path.join(options['prefix'], 'bin', options['extension']) + EXT_BIN):
+ shutil.move(os.path.join(options['prefix'], 'bin', options['extension']) + EXT_BIN,
+ os.path.join(options['prefix'], options['extension']) + EXT_BIN)
+ if os.path.exists(os.path.join(options['prefix'], 'bin', options['extension']) + EXT_SCT):
+ shutil.move(os.path.join(options['prefix'], 'bin', options['extension']) + EXT_SCT,
+ os.path.join(options['prefix'], options['extension']) + EXT_SCT)
+ else:
+ if os.path.exists(os.path.join(options['prefix'], 'scripts', options['extension'])):
+ shutil.move(os.path.join(options['prefix'], 'scripts', options['extension']),
+ os.path.join(options['prefix'], options['extension']))
+ # move man/ into docs/
+ if os.path.exists(os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')):
+ shutil.move(os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1'),
+ os.path.join(options['prefix'], 'docs', 'man', 'man1', options['extension'] + '.1'))
+ # if empty, rmdir bin, etc, man, scripts
+ for d in ('bin', 'etc', os.path.join('man', 'man1'), 'man', 'scripts'):
+ remove_empty_dir(os.path.join(options['prefix'], d))
+# remove existing extension (reading XML file)
+def remove_extension(force = False):
+ name = options['extension']
+ if force:
+ grass.verbose(_("List of removed files:"))
+ else:
+ grass.info(_("Files to be removed (use flag 'f' to force removal):"))
+ try:
+ f = urlopen(url)
+ flist = []
+ for task in tree.findall('task'):
+ if name == task.get('name', default = '') and \
+ task.find('binary') is not None:
+ for f in task.find('binary').findall('file'):
+ fname = f.text
+ if fname:
+ fpath = fname.split('/')
+ if fpath[0] == 'bin':
+ fpath[-1] += '.exe'
+ if fpath[0] == 'scripts':
+ fpath[-1] += '.py'
+ flist.append(fpath)
+ if flist:
+ removed = False
+ err = list()
+ for f in flist:
+ fpath = os.path.join(options['prefix'], os.path.sep.join(f))
+ try:
+ if force:
+ grass.verbose(fpath)
+ os.remove(fpath)
+ removed = True
+ else:
+ print fpath
+ except OSError:
+ err.append((_("Unable to remove file '%s'") % fpath))
+ if force and not removed:
+ grass.fatal(_("Extension <%s> not found") % options['extension'])
+ if err:
+ for e in err:
+ grass.error(e)
+ else:
+ remove_extension_std(force)
+ except HTTPError:
-def remove_extension():
+ if force:
+ grass.message(_("Extension <%s> successfully uninstalled.") % options['extension'])
+ else:
+ grass.warning(_("Extension <%s> not removed. "
+ "Re-run '%s' with 'f' flag to force removal") % (options['extension'], 'g.extension'))
+# remove exising extension (using standard files layout)
+def remove_extension_std(force = False):
# is module available?
if not os.path.exists(os.path.join(options['prefix'], 'bin', options['extension'])):
- grass.fatal(_("Module '%s' not found") % options['extension'])
- for file in [os.path.join(options['prefix'], 'bin', options['extension']),
- os.path.join(options['prefix'], 'scripts', options['extension']),
- os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html')]:
- if os.path.isfile(file):
- os.remove(file)
- grass.message(_("'%s' successfully uninstalled.") % options['extension'])
+ for fpath in [os.path.join(options['prefix'], 'bin', options['extension']),
+ os.path.join(options['prefix'], 'scripts', options['extension']),
+ os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html'),
+ os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')]:
+ if os.path.isfile(fpath):
+ if force:
+ os.remove(fpath)
+ else:
+ print fpath
+# check links in CSS
+def check_style_files(fil):
+ # check the links to grassdocs.css/grass_logo.png to a correct manual page of addons
+ dist_file = os.path.join(os.getenv('GISBASE'), 'docs', 'html', fil)
+ addons_file = os.path.join(options['prefix'], 'docs', 'html', fil)
+ # check if file already exists in the grass addons docs html path
+ if os.path.isfile(addons_file):
+ return
+ # otherwise copy the file from $GISBASE/docs/html, it doesn't use link
+ # because os.symlink it work only in Linux
+ else:
+ try:
+ shutil.copyfile(dist_file,addons_file)
+ except OSError, e:
+ grass.fatal(_("Unable to create '%s': %s") % (addons_file, e))
def create_dir(path):
if os.path.isdir(path):
return
try:
os.makedirs(path)
except OSError, e:
@@ -409,15 +547,20 @@
def check_dirs():
create_dir(os.path.join(options['prefix'], 'bin'))
create_dir(os.path.join(options['prefix'], 'docs', 'html'))
+ check_style_files('grass_logo.png')
+ check_style_files('grassdocs.css')
+ # create_dir(os.path.join(options['prefix'], 'etc'))
+ create_dir(os.path.join(options['prefix'], 'docs', 'man', 'man1'))
create_dir(os.path.join(options['prefix'], 'man', 'man1'))
create_dir(os.path.join(options['prefix'], 'scripts'))
def main():
# check dependecies
- check()
+ if sys.platform != "win32":
+ check_progs()
# list available modules
- if flags['l'] or flags['f'] or flags['g']:
+ if flags['l'] or flags['c'] or flags['g']:
return 0
else:
@@ -442,9 +585,6 @@
grass.warning(_("GRASS_ADDON_PATH has more items, using first defined - '%s'") % path_list[0])
options['prefix'] = path_list[0]
- # check dirs
- check_dirs()
if flags['d']:
if options['operation'] != 'add':
grass.warning(_("Flag 'd' is relevant only to 'operation=add'. Ignoring this flag."))
@@ -453,9 +593,10 @@
remove_tmpdir = False
if options['operation'] == 'add':
+ check_dirs()
install_extension()
else: # remove
- remove_extension()
+ remove_extension(flags['f'])
return 0
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py 2011-12-12 13:46:00 UTC (rev 49677)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py 2011-12-12 14:13:21 UTC (rev 49678)
@@ -482,8 +482,15 @@
Debug.msg(1, "gcmd.CommandThread(): %s" % ' '.join(self.cmd))
self.startTime = time.time()
+ # TODO: replace ugly hack bellow
+ args = self.cmd
+ if sys.platform == 'win32' and os.path.splitext(self.cmd[0])[1] == '.py':
+ os.chdir(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'scripts'))
+ args = [sys.executable, self.cmd[0]] + self.cmd[1:]
try:
- self.module = Popen(self.cmd,
+ self.module = Popen(args,
stdin = subprocess.PIPE,
stdout = subprocess.PIPE,
stderr = subprocess.PIPE,
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/ghelp.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/ghelp.py 2011-12-12 13:46:00 UTC (rev 49677)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/ghelp.py 2011-12-12 14:13:21 UTC (rev 49678)
@@ -787,6 +787,7 @@
self.options = dict() # list of options
wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
@@ -798,17 +799,17 @@
self.repo = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
self.fullDesc = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
label = _("Fetch full info including description and keywords (takes time)"))
- self.fullDesc.SetValue(False)
+ self.fullDesc.SetValue(True)
self.search = SearchModuleWindow(parent = self.panel)
- self.search.SetSelection(2)
+ self.search.SetSelection(0)
self.tree = ExtensionTree(parent = self.panel, log = parent.GetLogWindow())
self.optionBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
label = " %s " % _("Options"))
- task = gtask.parse_interface('g.extension')
+ task = gtask.parse_interface('g.extension.py')
for f in task.get_options()['flags']:
name = f.get('name', '')
@@ -817,12 +818,12 @@
desc = f.get('description', '')
if not name and not desc:
continue
- if name in ('l', 'f', 'g', 'quiet', 'verbose'):
+ if name in ('l', 'c', 'g', 'quiet', 'verbose'):
continue
self.options[name] = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
label = desc)
self.repo.SetValue(task.get_param(value = 'svnurl').get('default',
- 'https://svn.osgeo.org/grass/grass-addons'))
+ 'http://svn.osgeo.org/grass/grass-addons'))
self.statusbar = self.CreateStatusBar(number = 1)
@@ -836,7 +837,7 @@
self.btnInstall.Enable(False)
self.btnCmd = wx.Button(parent = self.panel, id = wx.ID_ANY,
label = _("Command dialog"))
- self.btnCmd.SetToolTipString(_('Open %s dialog') % 'g.extension')
+ self.btnCmd.SetToolTipString(_('Open %s dialog') % 'g.extension.py')
self.btnClose.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
self.btnFetch.Bind(wx.EVT_BUTTON, self.OnFetch)
@@ -901,7 +902,7 @@
def _getCmd(self):
item = self.tree.GetSelected()
if not item or not item.IsOk():
- return ['g.extension']
+ return ['g.extension.py']
name = self.tree.GetItemText(item)
if not name:
@@ -912,8 +913,8 @@
if self.options[key].IsChecked():
flags.append('-%s' % key)
- return ['g.extension'] + flags + ['extension=' + name,
- 'svnurl=' + self.repo.GetValue().strip()]
+ return ['g.extension.py'] + flags + ['extension=' + name,
+ 'svnurl=' + self.repo.GetValue().strip()]
def OnUpdateStatusBar(self, event):
"""!Update statusbar text"""
@@ -954,10 +955,18 @@
def OnInstall(self, event):
"""!Install selected extension"""
log = self.parent.GetLogWindow()
- log.RunCmd(self._getCmd())
+ log.RunCmd(self._getCmd(), onDone = self.OnDone)
- ### self.OnCloseWindow(None)
+ def OnDone(self, cmd, returncode):
+ item = self.tree.GetSelected()
+ if not item or not item.IsOk() or \
+ returncode != 0 or \
+ not os.getenv('GRASS_ADDON_PATH'):
+ return
+ name = self.tree.GetItemText(item)
+ globalvar.grassCmd['all'].append(name)
def OnItemSelected(self, event):
"""!Item selected"""
item = event.GetItem()
@@ -999,7 +1008,7 @@
for prefix in ('display', 'database',
'general', 'imagery',
'misc', 'postscript', 'paint',
- 'raster', 'raster3D', 'sites', 'vector', 'wxGUI'):
+ 'raster', 'raster3D', 'sites', 'vector', 'wxGUI', 'other'):
self.AppendItem(parentId = self.root,
text = prefix)
self._loaded = False
@@ -1045,7 +1054,7 @@
flags = 'g'
else:
flags = 'l'
- ret = gcmd.RunCommand('g.extension.py', read = True,
+ ret = gcmd.RunCommand('g.extension.py', read = True, parent = self,
svnurl = url,
flags = flags, quiet = True)
if not ret:
@@ -1061,7 +1070,6 @@
except ValueError:
prefix = ''
name = value
if prefix not in mdict:
mdict[prefix] = dict()
mdict[prefix][name] = dict()
Modified: grass/branches/releasebranch_6_4/lib/init/init.bat
--- grass/branches/releasebranch_6_4/lib/init/init.bat 2011-12-12 13:46:00 UTC (rev 49677)
+++ grass/branches/releasebranch_6_4/lib/init/init.bat 2011-12-12 14:13:21 UTC (rev 49678)
@@ -25,8 +25,8 @@
set SAVEPATH=%PATH%
rem DON'T include scripts directory in PATH - .bat files in bin directory
rem are used to run scripts on Windows
-if "%GRASS_ADDON_PATH%"=="" set PATH=%WINGISBASE%\bin;%WINGISBASE%\lib;%APPDATA%\GRASS6\addons;%PATH%
-if not "%GRASS_ADDON_PATH%"=="" set PATH=%WINGISBASE%\bin;%WINGISBASE%\lib;%GRASS_ADDON_PATH%;%PATH%
+if "%GRASS_ADDON_PATH%"=="" set GRASS_ADDON_PATH=%APPDATA%\GRASS6\addons
+PATH=%WINGISBASE%\bin;%WINGISBASE%\lib;%GRASS_ADDON_PATH%;%PATH%
set GIS_LOCK=1
set GRASS_VERSION=GRASS_VERSION_NUMBER
Modified: grass/branches/releasebranch_6_4/lib/python/core.py
--- grass/branches/releasebranch_6_4/lib/python/core.py 2011-12-12 13:46:00 UTC (rev 49677)
+++ grass/branches/releasebranch_6_4/lib/python/core.py 2011-12-12 14:13:21 UTC (rev 49678)
@@ -165,7 +165,10 @@
else:
options[opt] = val
args = make_command(prog, flags, overwrite, quiet, verbose, **options)
+ if sys.platform == 'win32' and os.path.splitext(prog)[1] == '.py':
+ args.insert(0, sys.executable)
global debug_level
if debug_level > 0:
sys.stderr.write("D1/%d: %s.start_command(): %s\n" % (debug_level, __name__, ' '.join(args)))
Modified: grass/branches/releasebranch_6_4/lib/python/task.py
--- grass/branches/releasebranch_6_4/lib/python/task.py 2011-12-12 13:46:00 UTC (rev 49677)
+++ grass/branches/releasebranch_6_4/lib/python/task.py 2011-12-12 14:13:21 UTC (rev 49678)
@@ -427,8 +427,15 @@
@param cmd command (name of GRASS module)
try:
- cmdout, cmderr = Popen([cmd, '--interface-description'], stdout = PIPE,
- stderr = PIPE).communicate()
+ if sys.platform == 'win32' and os.path.splitext(cmd)[1] == '.py':
+ args = [sys.executable, cmd, '--interface-description']
+ else:
+ args = [cmd, '--interface-description']
+ cmdout, cmderr = Popen(args, stdout = PIPE,
+ stderr = PIPE).communicate()
except OSError, e:
raise ScriptError, _("Unable to fetch interface description for command '%(cmd)s'."
"\n\nDetails: %(det)s") % { 'cmd' : cmd, 'det' : e }
