[GRASS-SVN] r49714 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Tue Dec 13 08:48:02 EST 2011
Author: martinl
Date: 2011-12-13 05:48:02 -0800 (Tue, 13 Dec 2011)
New Revision: 49714
grass/trunk/scripts/g.extension/g.extension.py
g.extension: no need to fix manual pages, css file is already copied to addons
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2011-12-13 13:43:28 UTC (rev 49713)
+++ grass/trunk/scripts/g.extension/g.extension.py 2011-12-13 13:48:02 UTC (rev 49714)
@@ -298,30 +298,6 @@
else:
grass.message(_("Installation of <%s> successfully finished") % options['extension'])
- # manual page: fix href
- if os.getenv('GRASS_ADDON_PATH'):
- html_man = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'docs', 'html', options['extension'] + '.html')
- if os.path.exists(html_man):
- fd = open(html_man)
- html_str = '\n'.join(fd.readlines())
- fd.close()
- for rep in ('grassdocs.css', 'grass_logo.png'):
- patt = re.compile(rep, re.IGNORECASE)
- html_str = patt.sub(os.path.join(gisbase, 'docs', 'html', rep),
- html_str)
- patt = re.compile(r'(<a href=")(d|db|g|i|m|p|ps|r|r3|s|v|wxGUI)(\.)(.+)(.html">)', re.IGNORECASE)
- while True:
- m = patt.search(html_str)
- if not m:
- break
- html_str = patt.sub(m.group(1) + os.path.join(gisbase, 'docs', 'html',
- m.group(2) + m.group(3) + m.group(4)) + m.group(5),
- html_str, count = 1)
- fd = open(html_man, "w")
- fd.write(html_str)
- fd.close()
if not os.environ.has_key('GRASS_ADDON_PATH') or \
not os.environ['GRASS_ADDON_PATH']:
grass.warning(_('This add-on module will not function until you set the '
@@ -486,20 +462,17 @@
# check links in CSS
def check_style_files(fil):
- # check the links to grassdocs.css/grass_logo.png to a correct manual page of addons
- dist_file = os.path.join(os.getenv('GISBASE'), 'docs', 'html', fil)
+ dist_file = os.path.join(os.getenv('GISBASE'), 'docs', 'html', fil)
addons_file = os.path.join(options['prefix'], 'docs', 'html', fil)
- # check if file already exists in the grass addons docs html path
if os.path.isfile(addons_file):
return
- # otherwise copy the file from $GISBASE/docs/html, it doesn't use link
- # because os.symlink it work only in Linux
- else:
- try:
- shutil.copyfile(dist_file,addons_file)
- except OSError, e:
- grass.fatal(_("Unable to create '%s': %s") % (addons_file, e))
+ try:
+ shutil.copyfile(dist_file,addons_file)
+ except OSError, e:
+ grass.fatal(_("Unable to create '%s': %s") % (addons_file, e))
def create_dir(path):
if os.path.isdir(path):
return
