[GRASS-SVN] r49715 - grass/branches/develbranch_6/gui/scripts
Tue Dec 13 08:52:25 EST 2011
Author: martinl
Date: 2011-12-13 05:52:25 -0800 (Tue, 13 Dec 2011)
New Revision: 49715
   grass/branches/develbranch_6/gui/scripts/g.extension.py
wxGUI/g.extension.py: sync with trunk
Modified: grass/branches/develbranch_6/gui/scripts/g.extension.py
--- grass/branches/develbranch_6/gui/scripts/g.extension.py	2011-12-13 13:48:02 UTC (rev 49714)
+++ grass/branches/develbranch_6/gui/scripts/g.extension.py	2011-12-13 13:52:25 UTC (rev 49715)
@@ -271,9 +271,9 @@
         fo.close()
     except HTTPError:
         grass.fatal(_("GRASS Addons <%s> not found") % options['extension'])
+    return 0
-    grass.message(_("Installation of <%s> successfully finished.") % options['extension'])
 # install extension
 def install_extension():
     gisbase = os.getenv('GISBASE')
@@ -284,10 +284,15 @@
         grass.warning(_("Extension <%s> already installed. Will be updated...") % options['extension'])
     if sys.platform == "win32":
-        install_extension_win()
+        ret = install_extension_win()
     else:
-        install_extension_other()
+        ret = install_extension_other()
+    if ret != 0:
+        grass.warning(_('Installation failed, sorry. Please check above error messages.'))
+    else:
+        grass.message(_("Installation of <%s> successfully finished") % options['extension'])
     # cleanup build cruft
     if not flags['s']:
         tidy_citizen()
@@ -296,30 +301,6 @@
             not os.environ['GRASS_ADDON_PATH']:
         grass.warning(_('This add-on module will not function until you set the '
                         'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
-    # manual page: fix href
-    if os.getenv('GRASS_ADDON_PATH'):
-        html_man = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'docs', 'html', 'description.html')
-        if os.path.exists(html_man):
-            fd = open(html_man)
-            html_str = '\n'.join(fd.readlines())
-            fd.close()
-            for rep in ('grassdocs.css', 'grass_logo.png'):
-                patt = re.compile(rep, re.IGNORECASE)
-                html_str = patt.sub(os.path.join(gisbase, 'docs', 'html', rep),
-                                    html_str)
-            patt = re.compile(r'(<a href=")(d|db|g|i|m|p|ps|r|r3|s|v|wxGUI)(\.)(.+)(.html">)', re.IGNORECASE)
-            while True:
-                m = patt.search(html_str)
-                if not m:
-                    break
-                html_str = patt.sub(m.group(1) + os.path.join(gisbase, 'docs', 'html',
-                                                              m.group(2) + m.group(3) + m.group(4)) + m.group(5),
-                                    html_str, count = 1)
-            fd = open(html_man, "w")
-            fd.write(html_str)
-            fd.close()
 # install extension on other plaforms
 def install_extension_other():
@@ -398,14 +379,9 @@
     grass.message(_("Installing <%s>...") % options['extension'])
-    ret = grass.call(installCmd,
-                     stdout = outdev)
-    if ret != 0:
-        grass.warning(_('Installation failed, sorry. Please check above error messages.'))
-    else:
+    return grass.call(installCmd,
+                      stdout = outdev)
 # remove dir if empty
 def remove_empty_dir(path):
     if os.path.exists(path) and not os.listdir(path):
@@ -524,20 +500,17 @@
 # check links in CSS
 def check_style_files(fil):
-    # check the links to grassdocs.css/grass_logo.png to a correct manual page of addons
-    dist_file = os.path.join(os.getenv('GISBASE'), 'docs', 'html', fil)
+    dist_file   = os.path.join(os.getenv('GISBASE'), 'docs', 'html', fil)
     addons_file = os.path.join(options['prefix'], 'docs', 'html', fil)
-    # check if file already exists in the grass addons docs html path
     if os.path.isfile(addons_file):
 	return
-    # otherwise copy the file from $GISBASE/docs/html, it doesn't use link
-    # because os.symlink it work only in Linux
-    else:
-	try:
-	    shutil.copyfile(dist_file,addons_file)
-	except OSError, e:
-	    grass.fatal(_("Unable to create '%s': %s") % (addons_file, e))
+    try:
+        shutil.copyfile(dist_file,addons_file)
+    except OSError, e:
+        grass.fatal(_("Unable to create '%s': %s") % (addons_file, e))
 def create_dir(path):
     if os.path.isdir(path):
         return
