[GRASS-SVN] r49791 - grass-addons/grass6/raster/r.pi
svn_grass at osgeo.org
Sat Dec 17 09:16:16 EST 2011
Author: neteler
Date: 2011-12-17 06:16:16 -0800 (Sat, 17 Dec 2011)
New Revision: 49791
grass-addons/grass6/raster/r.pi/TODO.txt
debugging comment
Modified: grass-addons/grass6/raster/r.pi/TODO.txt
--- grass-addons/grass6/raster/r.pi/TODO.txt 2011-12-16 20:06:14 UTC (rev 49790)
+++ grass-addons/grass6/raster/r.pi/TODO.txt 2011-12-17 14:16:16 UTC (rev 49791)
@@ -46,64 +46,17 @@
gives:
*** buffer overflow detected ***: r.pi.nlm terminated
-======= Backtrace: =========
-/lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x37)[0x7f21b469f7f7]
-/lib/x86_64-linux-gnu/libc.so.6(+0xf7710)[0x7f21b469e710]
-r.pi.nlm(CutValues+0x76)[0x402286]
-r.pi.nlm(main+0x58e)[0x401aee]
-/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed)[0x7f21b45c830d]
-r.pi.nlm[0x401e15]
-======= Memory map: ========
-00400000-00404000 r-xp 00000000 08:01 659733 /usr/local/grass-6.4.2svn/bin/r.pi.nlm
-00603000-00604000 r--p 00003000 08:01 659733 /usr/local/grass-6.4.2svn/bin/r.pi.nlm
-00604000-00605000 rw-p 00004000 08:01 659733 /usr/local/grass-6.4.2svn/bin/r.pi.nlm
-02005000-02026000 rw-p 00000000 00:00 0 [heap]
-7f21b3d6c000-7f21b3d81000 r-xp 00000000 08:01 917027 /lib/x86_64-linux-gnu/libgcc_s.so.1
-7f21b3d81000-7f21b3f80000 ---p 00015000 08:01 917027 /lib/x86_64-linux-gnu/libgcc_s.so.1
-7f21b3f80000-7f21b3f81000 r--p 00014000 08:01 917027 /lib/x86_64-linux-gnu/libgcc_s.so.1
-7f21b3f81000-7f21b3f82000 rw-p 00015000 08:01 917027 /lib/x86_64-linux-gnu/libgcc_s.so.1
-7f21b3f82000-7f21b3f84000 r-xp 00000000 08:01 923260 /lib/x86_64-linux-gnu/libdl-2.13.so
-7f21b3f84000-7f21b4184000 ---p 00002000 08:01 923260 /lib/x86_64-linux-gnu/libdl-2.13.so
-7f21b4184000-7f21b4185000 r--p 00002000 08:01 923260 /lib/x86_64-linux-gnu/libdl-2.13.so
-7f21b4185000-7f21b4186000 rw-p 00003000 08:01 923260 /lib/x86_64-linux-gnu/libdl-2.13.so
-7f21b4186000-7f21b418e000 r-xp 00000000 08:01 1321532 /usr/local/grass-6.4.2svn/lib/libgrass_datetime.6.4.2svn.so
-7f21b418e000-7f21b438d000 ---p 00008000 08:01 1321532 /usr/local/grass-6.4.2svn/lib/libgrass_datetime.6.4.2svn.so
-7f21b438d000-7f21b438e000 r--p 00007000 08:01 1321532 /usr/local/grass-6.4.2svn/lib/libgrass_datetime.6.4.2svn.so
-7f21b438e000-7f21b438f000 rw-p 00008000 08:01 1321532 /usr/local/grass-6.4.2svn/lib/libgrass_datetime.6.4.2svn.so
-7f21b438f000-7f21b43a6000 r-xp 00000000 08:01 922555 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
-7f21b43a6000-7f21b45a5000 ---p 00017000 08:01 922555 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
-7f21b45a5000-7f21b45a6000 r--p 00016000 08:01 922555 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
-7f21b45a6000-7f21b45a7000 rw-p 00017000 08:01 922555 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
-7f21b45a7000-7f21b473c000 r-xp 00000000 08:01 923257 /lib/x86_64-linux-gnu/libc-2.13.so
-7f21b473c000-7f21b493b000 ---p 00195000 08:01 923257 /lib/x86_64-linux-gnu/libc-2.13.so
-7f21b493b000-7f21b493f000 r--p 00194000 08:01 923257 /lib/x86_64-linux-gnu/libc-2.13.so
-7f21b493f000-7f21b4940000 rw-p 00198000 08:01 923257 /lib/x86_64-linux-gnu/libc-2.13.so
-7f21b4940000-7f21b4946000 rw-p 00000000 00:00 0
-7f21b4946000-7f21b49c9000 r-xp 00000000 08:01 923277 /lib/x86_64-linux-gnu/libm-2.13.so
-7f21b49c9000-7f21b4bc8000 ---p 00083000 08:01 923277 /lib/x86_64-linux-gnu/libm-2.13.so
-7f21b4bc8000-7f21b4bc9000 r--p 00082000 08:01 923277 /lib/x86_64-linux-gnu/libm-2.13.so
-7f21b4bc9000-7f21b4bca000 rw-p 00083000 08:01 923277 /lib/x86_64-linux-gnu/libm-2.13.so
-7f21b4bca000-7f21b4bcc000 r-xp 00000000 08:01 1321711 /usr/local/grass-6.4.2svn/lib/libgrass_rpi.6.4.2svn.so
-7f21b4bcc000-7f21b4dcb000 ---p 00002000 08:01 1321711 /usr/local/grass-6.4.2svn/lib/libgrass_rpi.6.4.2svn.so
-7f21b4dcb000-7f21b4dcc000 r--p 00001000 08:01 1321711 /usr/local/grass-6.4.2svn/lib/libgrass_rpi.6.4.2svn.so
-7f21b4dcc000-7f21b4dcd000 rw-p 00002000 08:01 1321711 /usr/local/grass-6.4.2svn/lib/libgrass_rpi.6.4.2svn.so
-7f21b4dcd000-7f21b4e1f000 r-xp 00000000 08:01 1321614 /usr/local/grass-6.4.2svn/lib/libgrass_gis.6.4.2svn.so
-7f21b4e1f000-7f21b501f000 ---p 00052000 08:01 1321614 /usr/local/grass-6.4.2svn/lib/libgrass_gis.6.4.2svn.so
-7f21b501f000-7f21b5020000 r--p 00052000 08:01 1321614 /usr/local/grass-6.4.2svn/lib/libgrass_gis.6.4.2svn.so
-7f21b5020000-7f21b5022000 rw-p 00053000 08:01 1321614 /usr/local/grass-6.4.2svn/lib/libgrass_gis.6.4.2svn.so
-7f21b5022000-7f21b5023000 rw-p 00000000 00:00 0
-7f21b5023000-7f21b5044000 r-xp 00000000 08:01 923274 /lib/x86_64-linux-gnu/ld-2.13.so
-7f21b518c000-7f21b5213000 rw-p 00000000 00:00 0
-7f21b5241000-7f21b5243000 rw-p 00000000 00:00 0
-7f21b5243000-7f21b5244000 r--p 00020000 08:01 923274 /lib/x86_64-linux-gnu/ld-2.13.so
-7f21b5244000-7f21b5246000 rw-p 00021000 08:01 923274 /lib/x86_64-linux-gnu/ld-2.13.so
-7fff200ae000-7fff200cf000 rw-p 00000000 00:00 0 [stack]
-7fff201ff000-7fff20200000 r-xp 00000000 00:00 0 [vdso]
-ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
-Aborted
+--> Please rerun with gdb
+gdb r.pi.nlm
+r input=landclass96 keyval=5 output=test --o
+.... <crash>
+bt full
+This will generate a full backtrace if GRASS was compiled with "-g",
+i.e. debugging. See
+http://grass.osgeo.org/wiki/GRASS_Debugging#Using_GDB
HTML Descriptions TODO:
