[GRASS-SVN] r49792 - grass-addons/grass6/raster/r.pi
svn_grass at osgeo.org
Sat Dec 17 09:33:18 EST 2011
Author: neteler
Date: 2011-12-17 06:33:18 -0800 (Sat, 17 Dec 2011)
New Revision: 49792
grass-addons/grass6/raster/r.pi/TODO.txt
crash + backtrace
Modified: grass-addons/grass6/raster/r.pi/TODO.txt
--- grass-addons/grass6/raster/r.pi/TODO.txt 2011-12-17 14:16:16 UTC (rev 49791)
+++ grass-addons/grass6/raster/r.pi/TODO.txt 2011-12-17 14:33:18 UTC (rev 49792)
@@ -51,13 +51,92 @@
gdb r.pi.nlm
r input=landclass96 keyval=5 output=test --o
-.... <crash>
bt full
This will generate a full backtrace if GRASS was compiled with "-g",
i.e. debugging. See
http://grass.osgeo.org/wiki/GRASS_Debugging#Using_GDB
+Got it, too:
+(gdb) r input=landclass96 keyval=5 output=test --o
+Starting program: /home/neteler/grass64/dist.x86_64-unknown-linux-gnu/bin/r.pi.nlm input=landclass96 keyval=5 output=test --o
+Program received signal SIGSEGV, Segmentation fault.
+0x0000000000401ac3 in CutValues (map=0x7ffff7fd8010, mapcover=0.49554953560371517, size=16641)
+ at func.c:128
+128 values[index]++;
+Missing debug package(s), you should install: glibc-debug-2.11.1-8.3mnb2.x86_64 zlib-debug-1.2.3-15mdv2010.1.x86_64
+(gdb) bt full
+#0 0x0000000000401ac3 in CutValues (map=0x7ffff7fd8010, mapcover=0.49554953560371517, size=16641)
+ at func.c:128
+ values = {0 <repeats 9999 times>}
+ min = 1000000
+ max = 1000000
+ span = 0
+ c = inf
+ pixels = 8246
+ i = 0
+ j = -11408
+ index = -2147483648
+ bottom = -11400
+ top = 32767
+ topdif = -134381552
+ bottomdif = 32767
+#1 0x00000000004030e3 in main (argc=5, argv=0x7fffffffd648) at main.c:256
+ oldname = 0x605320 "landclass96"
+ oldmapset = 0x608cf0 "PERMANENT"
+ newname = 0x608550 "test"
+ newmapset = 0x7ffff7bd9a60 "neteler"
+ in_fd = 7
+ out_fd = -153202504
+---Type <return> to continue, or q <return> to quit---
+ sx = 76
+ sy = 68
+ keyval = 5
+ nullval = 5658608
+ landcover = 0.49554953560371517
+ pixel_count = 2561
+ sharpness = 0.42363591465337014
+ rand_seed = 1324132228
+ title = 0x400c9c "__libc_start_main"
+ map_type = 0
+ buffer = 0x608d10
+ bigbuf = 0x7ffff7fd8010
+ i = 16641
+ j = 32768
+ row = 129
+ col = 129
+ cnt = 0
+ list = 0x0
+ result = 0x608a60
+ size = 129
+ n = 7
+ edge = 2.0788726070215255e-317
+ ch = {format = 2032, compressed = 1, rows = -134224200, rows3 = 32767, cols = -1402796274,
+ cols3 = 1357, depths = -134224768, proj = 32767, zone = -10880, ew_res = 0,
+ ew_res3 = 6.9533558072994372e-310, ns_res = 6.9533491653563855e-310,
+ ns_res3 = 6.9533491762080433e-310, tb_res = 6.9533490683959531e-310, north = 0,
+ south = 6.9533491653563855e-310, east = 4.9406564584124654e-324, west = 0,
+ top = 6.9531436082559572e-310, bottom = 6.9533491762080433e-310}
+ window = {format = -10960, compressed = 32767, rows = -153687424, rows3 = 32767, cols = 2,
+ cols3 = 0, depths = -136444124, proj = 32767, zone = -136445152,
+ ew_res = 6.9533491763230618e-310, ew_res3 = 6.9533558072919274e-310, ns_res = 0,
+ ns_res3 = 6.9533491762080433e-310, tb_res = 0, north = 6.9533491653563855e-310,
+ south = 6.9533491655911655e-310, east = 2.0738563585192993e-317,
+ west = 6.9533482148155844e-310, top = 2.0727634853106985e-317,
+ bottom = 2.1219957909652723e-314}
+ min = 1000000
+ max = -1000000
+ module = 0x7ffff7bd9f40
+ parm = {input = 0x7ffff7bd9ea0, output = 0x607f20, size = 0x7ffff7fc86e8, nullval = 0x6080c0,
+ keyval = 0x607ff0, landcover = 0x608190, sharpness = 0x608260, randseed = 0x608330,
+ title = 0x608400}
+ flag = {report = 0x7ffff7bd9e60}
HTML Descriptions TODO:
