[GRASS-SVN] r49811 - in grass/trunk/gui/wxpython: . gcp gui_core
lmgr mapdisp
svn_grass at osgeo.org
Sun Dec 18 12:44:12 EST 2011
Author: annakrat
Date: 2011-12-18 09:44:12 -0800 (Sun, 18 Dec 2011)
New Revision: 49811
grass/trunk/gui/wxpython/gcp/mapdisplay.py
grass/trunk/gui/wxpython/gui_core/mapdisp.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/wxpythonlib.dox
wxGUI: SingleMapFrame and DoubleMapFrame added (co-author V. Petras)
Modified: grass/trunk/gui/wxpython/gcp/mapdisplay.py
--- grass/trunk/gui/wxpython/gcp/mapdisplay.py 2011-12-18 17:18:02 UTC (rev 49810)
+++ grass/trunk/gui/wxpython/gcp/mapdisplay.py 2011-12-18 17:44:12 UTC (rev 49811)
@@ -29,7 +29,7 @@
from mapdisp.gprint import PrintOptions
from core.gcmd import GMessage
from gui_core.dialogs import GetImageHandlers, ImageSizeDialog
-from gui_core.mapdisp import MapFrameBase
+from gui_core.mapdisp import SingleMapFrame
from core.settings import UserSettings
from mapdisp.mapwindow import BufferedWindow
@@ -38,7 +38,7 @@
# for standalone app
cmdfilename = None
-class MapFrame(MapFrameBase):
+class MapFrame(SingleMapFrame):
"""!Main frame for map display window. Drawing takes place in
child double buffered drawing window.
@@ -58,7 +58,7 @@
@param kwargs wx.Frame attribures
- MapFrameBase.__init__(self, parent = parent, title = title, toolbars = toolbars,
+ SingleMapFrame.__init__(self, parent = parent, title = title,
Map = Map, auimgr = auimgr, name = name, **kwargs)
self._layerManager = lmgr # Layer Manager object
Modified: grass/trunk/gui/wxpython/gui_core/mapdisp.py
--- grass/trunk/gui/wxpython/gui_core/mapdisp.py 2011-12-18 17:18:02 UTC (rev 49810)
+++ grass/trunk/gui/wxpython/gui_core/mapdisp.py 2011-12-18 17:44:12 UTC (rev 49811)
@@ -5,6 +5,8 @@
Classes:
- mapdisp::MapFrameBase
+ - mapdisp::SingleMapFrame
+ - mapdisp::DoubleMapFrame
(C) 2009-2011 by the GRASS Development Team
@@ -13,11 +15,14 @@
@author Martin Landa <landa.martin gmail.com>
@author Michael Barton <michael.barton at asu.edu>
+ at author Vaclav Petras <wenzeslaus gmail.com>
+ at author Anna Kratochvilova <kratochanna gmail.com>
import os
import wx
+import wx.aui
from core import globalvar
from core.debug import Debug
@@ -27,24 +32,41 @@
class MapFrameBase(wx.Frame):
"""!Base class for map display window
- Derived class must use statusbarManager or override
- GetProperty, SetProperty and HasProperty methods.
+ Derived class must use (create and initialize) \c statusbarManager
+ or override
+ GetProperty(), SetProperty() and HasProperty() methods.
+ Several methods has to be overriden or
+ \c NotImplementedError("MethodName") will be raised.
If derived class enables and disables auto-rendering,
it should override IsAutoRendered method.
+ Derived class can has one or more map windows (and map renderes)
+ but implementation of MapFrameBase expects that one window and
+ one map will be current.
+ Current instances of map window and map renderer should be returned
+ by methods GetWindow() and GetMap() respectively.
+ AUI manager is stored in \c self._mgr.
def __init__(self, parent = None, id = wx.ID_ANY, title = None,
- style = wx.DEFAULT_FRAME_STYLE, toolbars = None,
- Map = None, auimgr = None, name = None, **kwargs):
+ style = wx.DEFAULT_FRAME_STYLE,
+ auimgr = None, name = None, **kwargs):
+ @warning Use \a auimgr parameter only if you know what you are doing.
+ @param parent gui parent
+ @param id wx id
+ @param title window title
+ @param style \c wx.Frame style
@param toolbars array of activated toolbars, e.g. ['map', 'digit']
- @param Map instance of render.Map
- @param auimgs AUI manager
+ @param auimgr AUI manager (if \c None, wx.aui.AuiManager is used)
@param name frame name
- @param kwargs wx.Frame attributes
+ @param kwargs arguments passed to \c wx.Frame
- self.Map = Map # instance of render.Map
self.parent = parent
wx.Frame.__init__(self, parent, id, title, style = style, name = name, **kwargs)
@@ -74,7 +96,10 @@
# Fancy gui
- self._mgr = wx.aui.AuiManager(self)
+ if auimgr == None:
+ self._mgr = wx.aui.AuiManager(self)
+ else:
+ self._mgr = auimgr
def _initMap(self, Map):
"""!Initialize map display, set dimensions and map region
@@ -159,7 +184,7 @@
@param map Map instance (if none self.Map is used)
if not map:
- map = self.Map
+ map = self.GetMap()
region = map.region
ppm = self.GetPPM()
@@ -187,17 +212,16 @@
return self.statusbarManager.GetProgressBar()
def GetMap(self):
- """!Returns current Map instance
- return self.Map
+ """!Returns current map (renderer) instance"""
+ raise NotImplementedError("GetMap")
def GetWindow(self):
- """!Get map window"""
- return self.MapWindow
+ """!Returns current map window"""
+ raise NotImplementedError("GetWindow")
def GetMapToolbar(self):
"""!Returns toolbar with zooming tools"""
- raise NotImplementedError()
+ raise NotImplementedError("GetMapToolbar")
def GetToolbar(self, name):
"""!Returns toolbar if exists else None.
@@ -234,7 +258,7 @@
toolbar.EnableLongHelp(enable)
def IsStandalone(self):
- """!Check if Map display is standalone"""
+ """!Check if map frame is standalone"""
raise NotImplementedError("IsStandalone")
def OnRender(self, event):
@@ -335,3 +359,228 @@
"""!Set display geometry to match default region settings
self.MapWindow.ZoomToDefault()
+class SingleMapFrame(MapFrameBase):
+ """! Frame with one map window.
+ It is base class for frames which needs only one map.
+ Derived class should have \c self.MapWindow or
+ it has to override GetWindow() methods.
+ @note To access maps use getters only
+ (when using class or when writing class itself).
+ def __init__(self, parent = None, id = wx.ID_ANY, title = None,
+ Map = None,
+ @param id wx id
+ @param Map instance of render.Map
+ @param name frame name
+ @param kwargs arguments passed to MapFrameBase
+ MapFrameBase.__init__(self, parent = parent, id = id, title = title,
+ style = style,
+ auimgr = auimgr, name = name, **kwargs)
+ self.Map = Map # instance of render.Map
+ # initialize region values
+ self._initMap(Map = self.Map)
+ def GetMap(self):
+ """!Returns map (renderer) instance"""
+ return self.Map
+ def GetWindow(self):
+ """!Returns map window"""
+ return self.MapWindow
+class DoubleMapFrame(MapFrameBase):
+ """! Frame with two map windows.
+ It is base class for frames which needs two maps.
+ There is no primary and secondary map. Both maps are equal.
+ However, one map is current.
+ It is expected that derived class will call _bindWindowsActivation()
+ when both map windows will be initialized.
+ Drived class should have method GetMapToolbar() returns toolbar
+ which has method SetActiveMap().
+ @todo Use it in GCP manager
+ (probably changes to both DoubleMapFrame and GCP MapFrame will be neccessary).
+ firstMap = None, secondMap = None,
+ \a firstMap is set as active (by assign it to \c self.Map).
+ Derived class should assging to \c self.MapWindow to make one
+ map window current by dafault.
+ @param id wx id
+ style = style,
+ self.firstMap = firstMap
+ self.secondMap = secondMap
+ self.Map = firstMap
+ self._initMap(Map = self.firstMap)
+ self._initMap(Map = self.secondMap)
+ def _bindWindowsActivation(self):
+ self.GetFirstWindow().Bind(wx.EVT_ENTER_WINDOW, self.ActivateFirstMap)
+ self.GetSecondWindow().Bind(wx.EVT_ENTER_WINDOW, self.ActivateSecondMap)
+ def GetFirstMap(self):
+ """!Returns first Map instance
+ return self.firstMap
+ def GetSecondMap(self):
+ """!Returns second Map instance
+ return self.secondMap
+ def GetFirstWindow(self):
+ """!Get first map window"""
+ return self.firstMapWindow
+ def GetSecondWindow(self):
+ """!Get second map window"""
+ return self.secondMapWindow
+ def GetMap(self):
+ @note Use this method to access current map renderer.
+ (It is not guarented that current map will be stored in
+ \c self.Map in future versions.)
+ return self.Map
+ @see GetMap()
+ def ActivateFirstMap(self, event = None):
+ """!Make first Map and MapWindow active"""
+ self.Map = self.firstMap
+ self.MapWindow = self.firstMapWindow
+ self.GetMapToolbar().SetActiveMap(0)
+ def ActivateSecondMap(self, event = None):
+ """!Make second Map and MapWindow active"""
+ self.Map = self.secondMap
+ self.MapWindow = self.secondMapWindow
+ self.GetMapToolbar().SetActiveMap(1)
+ def OnZoomIn(self, event):
+ """!Zoom in the map.
+ Set mouse cursor, zoombox attributes, and zoom direction
+ toolbar = self.GetMapToolbar()
+ self._switchTool(toolbar, event)
+ win = self.GetFirstWindow()
+ self._prepareZoom(mapWindow = win, zoomType = 1)
+ win = self.GetSecondWindow()
+ def OnZoomOut(self, event):
+ """!Zoom out the map.
+ self._prepareZoom(mapWindow = win, zoomType = -1)
+ def OnPan(self, event):
+ """!Panning, set mouse to drag
+ self._preparePan(mapWindow = win)
+ def OnPointer(self, event):
+ self.GetFirstWindow().mouse['use'] = 'pointer'
+ def OnRender(self, event):
+ """!Re-render map composition (each map layer)
+ self.Render(mapToRender = self.GetFirstWindow())
+ self.Render(mapToRender = self.GetSecondWindow())
+ def Render(self, mapToRender):
+ """!Re-render map composition"""
+ mapToRender.UpdateMap(render = True,
+ renderVector = mapToRender == self.GetFirstWindow())
+ # update statusbar
+ self.StatusbarUpdate()
+ def OnErase(self, event):
+ """!Erase the canvas
+ self.Erase(mapToErase = self.GetFirstWindow())
+ self.Erase(mapToErase = self.GetSecondWindow())
+ def Erase(self, mapToErase):
+ mapToErase.EraseMap()
+ def OnDraw(self, event):
+ """!Re-display current map composition
+ self.Draw(mapToDraw = self.GetFirstWindow())
+ self.Draw(mapToDraw = self.GetSecondWindow())
+ def Draw(self, mapToDraw):
+ mapToDraw.UpdateMap(render = False)
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2011-12-18 17:18:02 UTC (rev 49810)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2011-12-18 17:44:12 UTC (rev 49811)
@@ -65,6 +65,7 @@
from gui_core.forms import GUI
from gcp.manager import GCPWizard
from nviz.main import haveNviz
+from iclass.frame import IClassMapFrame
class GMFrame(wx.Frame):
"""!Layer Manager frame with notebook widget for controlling GRASS
@@ -1097,6 +1098,13 @@
self.goutput.RunCmd(['g.manual','-i'])
+ def OnIClass(self, event):
+ """!Start wxIClass tool"""
+ win = IClassMapFrame(parent = self)
+ win.CentreOnScreen()
+ win.Show()
def DispHistogram(self, event):
Init histogram display canvas and tools
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2011-12-18 17:18:02 UTC (rev 49810)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2011-12-18 17:44:12 UTC (rev 49811)
@@ -17,8 +17,8 @@
@author Jachym Cepicky
- at author Vaclav Petras <wenzeslaus gmail.com> (MapFrameBase)
- at author Anna Kratochvilova <kratochanna gmail.com> (MapFrameBase)
+ at author Vaclav Petras <wenzeslaus gmail.com> (SingleMapFrame)
+ at author Anna Kratochvilova <kratochanna gmail.com> (SingleMapFrame)
import os
@@ -44,7 +44,7 @@
from gui_core.dialogs import GetImageHandlers, ImageSizeDialog, DecorationDialog, TextLayerDialog
from modules.histogram import HistogramFrame
from wxplot.histogram import Histogram2Frame
@@ -57,7 +57,7 @@
haveCtypes = False
@@ -77,7 +77,7 @@
Modified: grass/trunk/gui/wxpython/wxpythonlib.dox
--- grass/trunk/gui/wxpython/wxpythonlib.dox 2011-12-18 17:18:02 UTC (rev 49810)
+++ grass/trunk/gui/wxpython/wxpythonlib.dox 2011-12-18 17:44:12 UTC (rev 49811)
@@ -142,6 +142,8 @@
- gselect::OgrTypeSelect
- gui_core::mapdisp
- gui_core::mapwindow
- mapwindow::MapWindow
- gui_core::menu
