[GRASS-SVN] r49812 - in grass/trunk: include/defs lib/vector/Vlib
lib/vector/diglib
svn_grass at osgeo.org
Sun Dec 18 14:01:00 EST 2011
Author: martinl
Date: 2011-12-18 11:00:59 -0800 (Sun, 18 Dec 2011)
New Revision: 49812
grass/trunk/include/defs/vector.h
grass/trunk/lib/vector/Vlib/write_nat.c
grass/trunk/lib/vector/Vlib/write_ogr.c
grass/trunk/lib/vector/diglib/plus_area.c
grass/trunk/lib/vector/diglib/plus_line.c
vlib: fix bug in dig_del_area() - update centroid topo
V2_delete_line protype change to use integer for 'line'
various minor fixes
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h 2011-12-18 17:44:12 UTC (rev 49811)
+++ grass/trunk/include/defs/vector.h 2011-12-18 19:00:59 UTC (rev 49812)
@@ -493,9 +493,9 @@
int V2_read_next_line_ogr(struct Map_info *, struct line_pnts *,
struct line_cats *);
int V1_delete_line_nat(struct Map_info *, off_t);
-int V2_delete_line_nat(struct Map_info *, off_t);
+int V2_delete_line_nat(struct Map_info *, int);
int V1_delete_line_ogr(struct Map_info *, off_t);
-int V2_delete_line_ogr(struct Map_info *, off_t);
+int V2_delete_line_ogr(struct Map_info *, int);
int V1_restore_line_nat(struct Map_info *, off_t);
int V2_restore_line_nat(struct Map_info *, int, off_t);
off_t V1_write_line_nat(struct Map_info *, int, const struct line_pnts *,
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c 2011-12-18 17:44:12 UTC (rev 49811)
+++ grass/trunk/lib/vector/Vlib/write_nat.c 2011-12-18 19:00:59 UTC (rev 49812)
@@ -654,7 +654,7 @@
\return 0 on success
\return -1 on error
-int V2_delete_line_nat(struct Map_info *Map, off_t line)
+int V2_delete_line_nat(struct Map_info *Map, int line)
int ret, i, side, type, first, next_line, area;
struct P_line *Line;
@@ -665,7 +665,7 @@
static struct line_cats *Cats = NULL;
static struct line_pnts *Points = NULL;
- G_debug(3, "V2_delete_line_nat(), line = %lu", (unsigned long) line);
+ G_debug(3, "V2_delete_line_nat(), line = %d", line);
type = first = n_adjacent = 0;
Line = NULL;
@@ -784,7 +784,10 @@
V2__delete_area_cats_from_cidx_nat(Map, topo->area);
Area = Map->plus.Area[topo->area];
- Area->centroid = 0;
+ if (Area)
+ Area->centroid = 0;
+ else
+ G_warning(_("Attempt to access dead area (%d)"), topo->area);
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c 2011-12-18 17:44:12 UTC (rev 49811)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c 2011-12-18 19:00:59 UTC (rev 49812)
@@ -36,7 +36,7 @@
const struct line_cats *cats)
int first, s, i;
- int type, area, side, new_area[2];
+ int type, area, side;
struct Plus_head *plus;
@@ -81,7 +81,6 @@
else
Vect_box_extend(&abox, &box);
- new_area[s] = area;
G_debug(4, "Vect_build_line_area(): -> area = %d", area);
@@ -265,7 +264,7 @@
if (ret != OGRERR_NONE)
return -1;
- G_debug(3, "V1_write_line_ogr(): -> offset = %d", offset);
+ G_debug(3, "V1_write_line_ogr(): -> offset = %lu", (unsigned long) offset);
return offset;
@@ -309,9 +308,9 @@
Vect_box_extend(&(plus->box), &box);
if (type == GV_BOUNDARY) {
- int ret, cline, lines[1];
+ int ret, cline;
long FID;
- double x, y, area_size;
+ double x, y;
struct bound_box box;
struct line_pnts *CPoints;
@@ -327,7 +326,7 @@
dig_line_box(CPoints, &box);
cline = dig_add_line(plus, GV_CENTROID,
CPoints, &box, FID);
- G_debug(4, "\tCentroid: x = %f, y = %f, cat = %d, line = %d",
+ G_debug(4, "\tCentroid: x = %f, y = %f, cat = %lu, line = %d",
x, y, FID, cline);
dig_cidx_add_cat(plus, 1, (int) FID,
cline, GV_CENTROID);
@@ -443,7 +442,7 @@
\return -1 on error
-int V2_delete_line_ogr(struct Map_info *Map, off_t line)
+int V2_delete_line_ogr(struct Map_info *Map, int line)
int ret, i, type, first;
@@ -451,7 +450,7 @@
- G_debug(3, "V2_delete_line_ogr(), line = %d", (int) line);
+ G_debug(3, "V2_delete_line_ogr(), line = %d", line);
type = first = 0;
Line = NULL;
Modified: grass/trunk/lib/vector/diglib/plus_area.c
--- grass/trunk/lib/vector/diglib/plus_area.c 2011-12-18 17:44:12 UTC (rev 49811)
+++ grass/trunk/lib/vector/diglib/plus_area.c 2011-12-18 19:00:59 UTC (rev 49812)
@@ -346,12 +346,12 @@
int i, line;
- /* int isle, area_out; */
struct P_area *Area;
struct P_isle *Isle;
- struct P_topo_b *topo;
+ struct P_topo_b *btopo;
+ struct P_topo_c *ctopo;
G_debug(3, "dig_del_area() area = %d", area);
Area = plus->Area[area];
@@ -367,16 +367,16 @@
for (i = 0; i < Area->n_lines; i++) {
line = Area->lines[i]; /* >0 = clockwise -> right, <0 = counterclockwise ->left */
Line = plus->Line[abs(line)];
- topo = (struct P_topo_b *)Line->topo;
+ btopo = (struct P_topo_b *)Line->topo;
if (plus->do_uplist)
dig_line_add_updated(plus, abs(line));
if (line > 0) {
G_debug(3, " Set line %d right side to 0", line);
- topo->right = 0;
+ btopo->right = 0;
else {
G_debug(3, " Set line %d left side to 0", line);
- topo->left = 0;
+ btopo->left = 0;
/* Find the isle this area is part of (used late below) */
@@ -401,8 +401,8 @@
line);
else {
- topo->left = 0;
+ ctopo = (struct P_topo_c *)Line->topo;
+ ctopo->area = 0;
dig_line_add_updated(plus, line);
Modified: grass/trunk/lib/vector/diglib/plus_line.c
--- grass/trunk/lib/vector/diglib/plus_line.c 2011-12-18 17:44:12 UTC (rev 49811)
+++ grass/trunk/lib/vector/diglib/plus_line.c 2011-12-18 19:00:59 UTC (rev 49812)
@@ -324,8 +324,11 @@
Line = plus->Line[line];
+ if (!Line) /* dead */
+ return -1;
if (Line->type != GV_BOUNDARY)
- return (-1);
+ return -1;
if (side == GV_LEFT) {
