[GRASS-SVN] r49879 - grass/trunk/gui/wxpython/lmgr
    svn_grass at osgeo.org
    Fri Dec 23 05:50:43 EST 2011
Author: martinl
Date: 2011-12-23 02:50:43 -0800 (Fri, 23 Dec 2011)
New Revision: 49879
   grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI/LM: fix OnLocationWizard
	  (merge r49878 from devbr6)
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2011-12-23 10:47:21 UTC (rev 49878)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2011-12-23 10:50:43 UTC (rev 49879)
@@ -310,28 +310,32 @@
         """!Launch location wizard"""
         from location_wizard.wizard import LocationWizard
-        gisdbase = grass.gisenv()['GISDBASE']
         gWizard = LocationWizard(parent = self,
-                                 grassdatabase = gisdbase)
+                                 grassdatabase = grass.gisenv()['GISDBASE'])
+        location = gWizard.location
-        if gWizard.location !=  None:
+        if location !=  None:
             dlg = wx.MessageDialog(parent = self,
                                    message = _('Location <%s> created.\n\n'
                                                'Do you want to switch to the '
-                                               'new location?') % gWizard.location,
+                                               'new location?') % location,
                                    caption=_("Switch to new location?"),
                                    style = wx.YES_NO | wx.NO_DEFAULT |
                                    wx.ICON_QUESTION | wx.CENTRE)
             ret = dlg.ShowModal()
+            dlg.Destroy()
             if ret == wx.ID_YES:
-                RunCommand("g.gisenv",
-                           set = "LOCATION_NAME=%s" % gWizard.location)
-                           set = "MAPSET=PERMANENT")
-            dlg.Destroy()
+                if RunCommand('g.mapset', parent = self,
+                              location = location,
+                              mapset = 'PERMANENT') != 0:
+                    return
+                GMessage(parent = self,
+                         message = _("Current location is <%(loc)s>.\n"
+                                     "Current mapset is <%(mapset)s>.") % \
+                             { 'loc' : location, 'mapset' : 'PERMANENT' })
     def OnSettingsChanged(self, event):
         """!Here can be functions which have to be called after EVT_SETTINGS_CHANGED.
         Now only set copying of selected text to clipboard (in goutput).
